dexter Posted October 3, 2015 Share Posted October 3, 2015 Поставил минимальный набор из файла. Все отлично, подцепилось, зашел по SSH, сделал opkg update, затем opkg install mc. Оно начало ставиться, затем ssh клиент вылетел и больше подключиться не смог. Перезапустив роутер в журнале обнаружил следующее: Oct 02 21:40:03ndmkernel: tntfs info: NTFS volume name 'OPKGp', version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096). Oct 02 21:40:03ndmOpkg::Manager: /tmp/mnt/OPKG mounted to /tmp/mnt/OPKG. Oct 02 21:40:03ndmOpkg::Manager: /tmp/mnt/OPKG mounted to /opt/. Oct 02 21:40:03ndmOpkg::Manager: /tmp/mnt/OPKG initialized. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/rcS: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/rcS: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/rcS: /opt/bin/sh: can't load library 'libc.so.0'. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/rcS: exit code 16. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/S51dropbear: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/S51dropbear: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/S51dropbear: /opt/bin/sh: can't load library 'libc.so.0'. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/init.d/S51dropbear: exit code 16. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/010-homedir.sh: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/010-homedir.sh: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/010-homedir.sh: /opt/bin/sh: can't load library 'libc.so.0'. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/010-homedir.sh: exit code 16. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/011-tmpgroup.sh: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/011-tmpgroup.sh: /opt/bin/sh: '/opt/lib/libc.so.0' is not an ELF file. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/011-tmpgroup.sh: /opt/bin/sh: can't load library 'libc.so.0'. Oct 02 21:40:03ndmOpkg::Manager: /opt/etc/ndm/user.d/011-tmpgroup.sh: exit code 16. Oct 02 21:40:03ndmNetwork::Interface::Switch: switch link up at port 0 (Switch0). Готов всецело участвовать в проекте тестирования и отладки. Какие-то знания в линуксе имеются. Отлаживать могу на Giga 2 и если все пойдет нормально на Ultra. В последствии на Ultra 2. Link to comment Share on other sites More sharing options...
ndm Posted October 3, 2015 Share Posted October 3, 2015 После пересборки прошивок и SDK пакеты из opkg.keenopt.ru побились. Будем пересобирать в начале следующей недели, объявим об этом отдельно. Link to comment Share on other sites More sharing options...
McMCC Posted October 5, 2015 Share Posted October 5, 2015 После пересборки прошивок и SDK пакеты из opkg.keenopt.ru побились. Будем пересобирать в начале следующей недели, объявим об этом отдельно. Все уже пересобрано, пакеты рабочие, на GIGA II точно работают. Link to comment Share on other sites More sharing options...
dexter Posted October 5, 2015 Author Share Posted October 5, 2015 Проверил - работает, mc установился. Теперь вопросы и пожелания: - как прописать правила iptables? - не могли бы вы собрать пакеты для тестов: bind, isc-dhcp и какой-нибудь snmp-agent(ultra на V1 крашилась через какое-то время). Пока вроде все. Link to comment Share on other sites More sharing options...
ndm Posted October 5, 2015 Share Posted October 5, 2015 - как прописать правила iptables? Прописывается скриптом /opt/etc/ndm/netfilter.d/your_script.sh. Скрипт вызывается каждый раз, когда ndm перетирает таблицы netfilter, чтобы ваши правила не исчезали. В скрипте нужно проверять название таблицы "filter", "nat", "mangle". Пример здесь: https://github.com/ndmsystems/packages/ ... netfilterd Link to comment Share on other sites More sharing options...
artgur Posted October 15, 2015 Share Posted October 15, 2015 Один маленький вопрос, ибо по форуму не нашел. Можно ли удалить предустановленные компоненты? через cli пометил для удаления a дальше боюсь. Link to comment Share on other sites More sharing options...
ndm Posted October 16, 2015 Share Posted October 16, 2015 Сейчас, к сожалению, нельзя добавлять, удалять и обновлять ничего, т.к. в официальной раздаче opkg отсутствует. Link to comment Share on other sites More sharing options...
maxik Posted October 24, 2015 Share Posted October 24, 2015 Та же ситуация почти -- попробовал поставить busybox -- вылетел и больше не могу зайти по ssh. Перезагрузка не спасла. При этом интернет есть, телнетом заходит. Чуть позже попробую прошиться по новой. Link to comment Share on other sites More sharing options...
Александр Рыжов Posted October 24, 2015 Share Posted October 24, 2015 Та же ситуация почти -- попробовал поставить busybox -- вылетел и больше не могу зайти по ssh. В логе роутера есть сообщения о запуске OPKG и сопутствующих сервисах? Link to comment Share on other sites More sharing options...
maxik Posted October 27, 2015 Share Posted October 27, 2015 Та же ситуация почти -- попробовал поставить busybox -- вылетел и больше не могу зайти по ssh. В логе роутера есть сообщения о запуске OPKG и сопутствующих сервисах? Не посмотрел... Перепрошился -- вход восстановился. Настроил то, что мне надо (мне только dhcp надо было под pxe настроить), но ничего ставить не стал. И да, у меня giga 3 Link to comment Share on other sites More sharing options...
