engelsit Posted June 17, 2020 Share Posted June 17, 2020 (edited) K Lite 3 Rev. B Будучи захваченными в Mesh, вызывают восклицательный знак ошибки в морде главной Viva KN-1910. Если крикнуть по этому знаку, появляется пустое белое окно. В логах самих ретрансляторов, вот такие ошибки постоянно повторяются: ndm Network::Interface::Base: "WifiMaster0/AccessPoint0": interface is down. Июн 17 04:11:47 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:11:47 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wifi". Июн 17 04:11:48 ndm Core::Syslog: last message repeated 3 times. Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wireless". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::AccessPoint". Июн 17 04:11:48 ndm Core::Syslog: last message repeated 4 times. Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wireless". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Base". Июн 17 04:11:48 ndm Network::Interface::Ethernet: "Bridge0": ACL type unchanged. Июн 17 04:11:48 ndm Network::Interface::Ethernet: "Bridge0": ACL cleared. Июн 17 04:11:48 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:11:48 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:11:48 ndm Network::Interface::Rtx::Iapp: Bridge0 key unchanged. Июн 17 04:11:48 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:11:48 ndm Network::Interface::Rtx::Iapp: unsupported interface: Bridge1. Июн 17 04:11:48 ndm Components::Manager: validity period set to 3600 seconds. Июн 17 04:11:48 ndhcpc Bridge0: received ACK for 192.168.113.4 from 192.168.113.111. Июн 17 04:11:48 ndm Peripheral::Manager: "WLAN/click" handler set. Июн 17 04:11:51 ndm Core::ConfigurationSaver: configuration saved. Июн 17 04:12:27 ndm Core::ConfigurationSaver: saving configuration... Июн 17 04:12:27 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wifi". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wifi". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wireless". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Base". Июн 17 04:12:27 ndm Network::Interface::Base: "WifiMaster0/AccessPoint0": renamed to "AccessPoint". Июн 17 04:12:27 ndm Network::Interface::Wifi: "WifiMaster0/AccessPoint0": WPA PSK set. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": wireless encryption enabled. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WPA algorithms disabled. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WPA2 algorithms enabled. Июн 17 04:12:27 ndm Network::Interface::Wireless: "WifiMaster0/AccessPoint0": SSID saved. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": SSID broadcasting enabled. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": RRM enabled. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": BTM enabled. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition MDID set to "7r". Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition OTD disabled. Июн 17 04:12:27 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition enabled. Июн 17 04:12:27 kernel br0: port 2(ra0) entered forwarding state Июн 17 04:12:27 kernel br0: port 2(ra0) entered forwarding state Июн 17 04:12:27 ndm Network::Interface::Base: "WifiMaster0/AccessPoint0": interface is up. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wifi". Июн 17 04:12:27 ndm Core::Syslog: last message repeated 3 times. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wireless". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::AccessPoint". Июн 17 04:12:27 ndm Core::Syslog: last message repeated 4 times. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wireless". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Base". Июн 17 04:12:27 ndm Network::Interface::Ethernet: "Bridge0": ACL type unchanged. Июн 17 04:12:27 ndm Network::Interface::Ethernet: "Bridge0": ACL cleared. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:12:27 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:27 ndm Network::Interface::Rtx::Iapp: Bridge0 key unchanged. Июн 17 04:12:27 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:27 ndm Network::Interface::Rtx::Iapp: unsupported interface: Bridge1. Июн 17 04:12:27 ndm Components::Manager: validity period set to 3600 seconds. Июн 17 04:12:27 ndhcpc Bridge0: received ACK for 192.168.113.4 from 192.168.113.111. Июн 17 04:12:27 ndm Peripheral::Manager: "WLAN/click" handler set. Июн 17 04:12:28 kernel br0: port 2(ra0) entered forwarding state Июн 17 04:12:30 ndm Core::ConfigurationSaver: configuration saved. Июн 17 04:12:30 ndm Core::ConfigurationSaver: saving configuration... Июн 17 04:12:30 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wifi". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wifi". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wireless". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Base". Июн 17 04:12:31 ndm Network::Interface::Base: "WifiMaster0/AccessPoint0": renamed to "AccessPoint". Июн 17 04:12:31 ndm Network::Interface::Wifi: "WifiMaster0/AccessPoint0": WPA PSK set. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": wireless encryption enabled. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WPA algorithms disabled. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WPA2 algorithms enabled. Июн 17 04:12:31 ndm Network::Interface::Wireless: "WifiMaster0/AccessPoint0": SSID saved. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": SSID broadcasting enabled. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": RRM enabled. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": BTM enabled. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition MDID set to "7r". Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition OTD disabled. Июн 17 04:12:31 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition enabled. Июн 17 04:12:31 kernel br0: port 2(ra0) entered disabled state Июн 17 04:12:31 ndm Network::Interface::Base: "WifiMaster0/AccessPoint0": interface is down. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wifi". Июн 17 04:12:31 ndm Core::Syslog: last message repeated 3 times. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wireless". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::AccessPoint". Июн 17 04:12:31 ndm Core::Syslog: last message repeated 4 times. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wireless". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Base". Июн 17 04:12:31 ndm Network::Interface::Ethernet: "Bridge0": ACL type unchanged. Июн 17 04:12:31 ndm Network::Interface::Ethernet: "Bridge0": ACL cleared. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:12:31 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:31 ndm Network::Interface::Rtx::Iapp: Bridge0 key unchanged. Июн 17 04:12:31 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:31 ndm Network::Interface::Rtx::Iapp: unsupported interface: Bridge1. Июн 17 04:12:31 ndm Components::Manager: validity period set to 3600 seconds. Июн 17 04:12:31 ndhcpc Bridge0: received ACK for 192.168.113.4 from 192.168.113.111. Июн 17 04:12:31 ndm Peripheral::Manager: "WLAN/click" handler set. Июн 17 04:12:34 ndm Core::ConfigurationSaver: saving configuration... Июн 17 04:12:34 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:34 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wifi". Июн 17 04:12:34 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wifi". Июн 17 04:12:34 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Wireless". Июн 17 04:12:34 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint3 as "Network::Interface::Base". Июн 17 04:12:34 ndm Network::Interface::Base: "WifiMaster0/AccessPoint0": renamed to "AccessPoint". Июн 17 04:12:34 ndm Network::Interface::Wifi: "WifiMaster0/AccessPoint0": WPA PSK set. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": wireless encryption enabled. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WPA algorithms disabled. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WPA2 algorithms enabled. Июн 17 04:12:34 ndm Network::Interface::Wireless: "WifiMaster0/AccessPoint0": SSID saved. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": SSID broadcasting enabled. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": RRM enabled. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": BTM enabled. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition MDID set to "7r". Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition OTD disabled. Июн 17 04:12:34 ndm Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": fast transition enabled. Июн 17 04:12:35 kernel br0: port 2(ra0) entered forwarding state Июн 17 04:12:35 kernel br0: port 2(ra0) entered forwarding state Июн 17 04:12:35 ndm Network::Interface::Base: "WifiMaster0/AccessPoint0": interface is up. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wifi". Июн 17 04:12:35 ndm Core::Syslog: last message repeated 3 times. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Wireless". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::AccessPoint". Июн 17 04:12:35 ndm Core::Syslog: last message repeated 4 times. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint1 as "Network::Interface::Base". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wifi". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Wireless". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find WifiMaster0/AccessPoint2 as "Network::Interface::Base". Июн 17 04:12:35 ndm Network::Interface::Ethernet: "Bridge0": ACL type unchanged. Июн 17 04:12:35 ndm Network::Interface::Ethernet: "Bridge0": ACL cleared. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to find Bridge1 as "Network::Interface::Ethernet". Июн 17 04:12:35 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:35 ndm Network::Interface::Rtx::Iapp: Bridge0 key unchanged. Июн 17 04:12:35 ndm Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Июн 17 04:12:35 ndm Network::Interface::Rtx::Iapp: unsupported interface: Bridge1. Edited June 17, 2020 by engelsit 1 Quote Link to comment Share on other sites More sharing options...
Goblin Posted June 17, 2020 Share Posted June 17, 2020 а в спойлер эту простыню никак? [spoiler]картинка[/spoiler] [spoiler]текст[/spoiler] 1 Quote Link to comment Share on other sites More sharing options...
drugold Posted June 17, 2020 Share Posted June 17, 2020 ZK Lite3 Rev.B не поддерживается контроллером Wi-Fi. Необходим аппарат с прошивкой KeeneticOS v3.x. 2 Quote Link to comment Share on other sites More sharing options...
r13 Posted June 17, 2020 Share Posted June 17, 2020 Перевести в режим точки доступа и подключить по поводу, тогда прижевется. По wifi только в 3.х Quote Link to comment Share on other sites More sharing options...
Mamay Posted June 17, 2020 Share Posted June 17, 2020 2 часа назад, drugold сказал: ZK Lite3 Rev.B не поддерживается контроллером Wi-Fi. Необходим аппарат с прошивкой KeeneticOS v3.x. Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Как бы намекает, но видимо читать нету... Quote Link to comment Share on other sites More sharing options...
engelsit Posted June 17, 2020 Author Share Posted June 17, 2020 7 часов назад, Goblin сказал: а в спойлер эту простыню никак? [spoiler]картинка[/spoiler] [spoiler]текст[/spoiler] Не знал, что тут есть спойлер, приношу извинения. Кнопки нет, подумал, что и код отсутствует в форуме. Quote Link to comment Share on other sites More sharing options...
engelsit Posted June 17, 2020 Author Share Posted June 17, 2020 6 часов назад, drugold сказал: ZK Lite3 Rev.B не поддерживается контроллером Wi-Fi. Необходим аппарат с прошивкой KeeneticOS v3.x. В официальных статьях пишут, что поддерживается. Фактически, захватывается и работает. Но сыпет ошибками. Quote Link to comment Share on other sites More sharing options...
engelsit Posted June 17, 2020 Author Share Posted June 17, 2020 (edited) 3 часа назад, Mamay сказал: Network::Interface::Repository: unable to create new interfaces in "repeater" mode. Как бы намекает, но видимо читать нету... Прочитал: "Не могу создать интерфейс в режиме репитер". Ставил и режим B, C, D. Во всех одинаково: работает, но ругается. Edited June 17, 2020 by engelsit Quote Link to comment Share on other sites More sharing options...
drugold Posted June 17, 2020 Share Posted June 17, 2020 У вас на KN-1910 какая версия прошивки? Quote Link to comment Share on other sites More sharing options...
engelsit Posted June 19, 2020 Author Share Posted June 19, 2020 3.5 alfa9 В 17.06.2020 в 17:30, drugold сказал: У вас на KN-1910 какая версия прошивки? Quote Link to comment Share on other sites More sharing options...
engelsit Posted July 25, 2020 Author Share Posted July 25, 2020 В 17.06.2020 в 12:00, r13 сказал: По wifi только в 3.х Да нет, все нормально работает. Просто, ошибки сыпятся. Но работает. ) Quote Link to comment Share on other sites More sharing options...
Yurilla Posted September 13, 2021 Share Posted September 13, 2021 (edited) Та же проблема. Lite (KN-1310) захвачен в WIFI системой. unsupported interface: Bridge1.Режим "Точка доступа/Ретранслятор" (D) Edited September 13, 2021 by Yurilla Quote Link to comment Share on other sites More sharing options...
drugold Posted September 13, 2021 Share Posted September 13, 2021 IP-адрес 192.168.1.3 в режимах отличных от "Маршрутизатора", является служебным. После захвата ретранслятора WiFi-системой, ему должен присвоиться другой IP-адрес. Quote Link to comment Share on other sites More sharing options...
vasek00 Posted September 13, 2021 Share Posted September 13, 2021 59 минут назад, Yurilla сказал: Та же проблема. Lite (KN-1310) захвачен в WIFI системой. unsupported interface: Bridge1.Режим "Точка доступа/Ретранслятор" (D) Согласно настроек по умолчанию например 192.168.1.1 это сам роутер (или он же например Контроллер) далее есть пул адресов DHCP сервера для домашней сети. ТочкаДоступа/Ретранслятор после старта interface Bridge0 ip address 192.168.1.3 255.255.255.0 ip address dhcp До момента старта DHCP клиента на "ТочкаДоступа/Ретранслятор" будет данный IP [I] Aug 14 20:27:40 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.3/24. [I] Aug 14 20:27:40 ndm: Dhcp::Client: started DHCP client on Bridge0. [I] Aug 14 20:27:40 ndm: Dhcp::Client: a DHCP address fallback is static. [I] Aug 14 20:27:40 ndm: Dhcp::Client: Bridge0 DHCP client DNS host routes are enabled. [I] Aug 14 20:27:40 ndm: Dhcp::Client: Bridge0 DHCP name servers are enabled. После запуска сервиса DHCP клиента на "ТочкаДоступа/Ретранслятор" произойдет смена IP адреса на тот который в пуле адресов сервера DHCP или он же Контроллер [I] Aug 14 20:27:50 ndhcpc: Bridge0: received OFFER for 192.168.1.254 from 192.168.1.1 [I] Aug 14 20:27:51 ndhcpc: Bridge0: received ACK for 192.168.1.254 from 192.168.1.1 lease 36600 sec. [I] Aug 14 20:27:51 ndm: Dhcp::Client: configuring interface Home. [I] Aug 14 20:27:51 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.254/24. [I] Aug 14 20:27:51 ndm: Dhcp::Client: obtained IP address 192.168.1.254/24. [I] Aug 14 20:27:51 ndm: Dhcp::Client: interface "Home" is global, priority 1. [I] Aug 14 20:27:51 ndm: Dhcp::Client: adding a default route via 192.168.1.1. [I] Aug 14 20:27:51 ndm: Dhcp::Client: adding name server 192.168.1.1. [I] Aug 14 20:27:51 ndm: Dns::Manager: name server 192.168.1.1 added, domain (default). Далее есть возможность закрепить за данной "ТочкаДоступа/Ретранслятор" стат IP адрес, но уже не из пула DHCP но IP из сегмента дом.сети. Quote Link to comment Share on other sites More sharing options...
insider Posted September 13, 2021 Share Posted September 13, 2021 2 часа назад, Yurilla сказал: Та же проблема. Lite (KN-1310) захвачен в WIFI системой. unsupported interface: Bridge1.Режим "Точка доступа/Ретранслятор" (D) когда ретранслятор цепляете в сеть, ему присваивается адрес и по нему можно в веб зайти и все настроить Quote Link to comment Share on other sites More sharing options...
insider Posted September 13, 2021 Share Posted September 13, 2021 1 час назад, vasek00 сказал: Согласно настроек по умолчанию например 192.168.1.1 это сам роутер (или он же например Контроллер) далее есть пул адресов DHCP сервера для домашней сети. ТочкаДоступа/Ретранслятор после старта interface Bridge0 ip address 192.168.1.3 255.255.255.0 ip address dhcp До момента старта DHCP клиента на "ТочкаДоступа/Ретранслятор" будет данный IP [I] Aug 14 20:27:40 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.3/24. [I] Aug 14 20:27:40 ndm: Dhcp::Client: started DHCP client on Bridge0. [I] Aug 14 20:27:40 ndm: Dhcp::Client: a DHCP address fallback is static. [I] Aug 14 20:27:40 ndm: Dhcp::Client: Bridge0 DHCP client DNS host routes are enabled. [I] Aug 14 20:27:40 ndm: Dhcp::Client: Bridge0 DHCP name servers are enabled. После запуска сервиса DHCP клиента на "ТочкаДоступа/Ретранслятор" произойдет смена IP адреса на тот который в пуле адресов сервера DHCP или он же Контроллер [I] Aug 14 20:27:50 ndhcpc: Bridge0: received OFFER for 192.168.1.254 from 192.168.1.1 [I] Aug 14 20:27:51 ndhcpc: Bridge0: received ACK for 192.168.1.254 from 192.168.1.1 lease 36600 sec. [I] Aug 14 20:27:51 ndm: Dhcp::Client: configuring interface Home. [I] Aug 14 20:27:51 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.254/24. [I] Aug 14 20:27:51 ndm: Dhcp::Client: obtained IP address 192.168.1.254/24. [I] Aug 14 20:27:51 ndm: Dhcp::Client: interface "Home" is global, priority 1. [I] Aug 14 20:27:51 ndm: Dhcp::Client: adding a default route via 192.168.1.1. [I] Aug 14 20:27:51 ndm: Dhcp::Client: adding name server 192.168.1.1. [I] Aug 14 20:27:51 ndm: Dns::Manager: name server 192.168.1.1 added, domain (default). Далее есть возможность закрепить за данной "ТочкаДоступа/Ретранслятор" стат IP адрес, но уже не из пула DHCP но IP из сегмента дом.сети. закрепить или изменить тоже можно? Quote Link to comment Share on other sites More sharing options...
vasek00 Posted September 13, 2021 Share Posted September 13, 2021 3 часа назад, insider сказал: закрепить или изменить тоже можно? ДА, прям в Web на контроллере. 1 Quote Link to comment Share on other sites More sharing options...
