Posted
Имеется 2 компьютера с сетевыми картами 1000Мб.
Настройка сетевой карты компьютера 1:
 Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  1000baseT/Full
        Link partner advertised pause frame use: Symmetric
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        MDI-X: off
        Supports Wake-on: g
        Wake-on: g
        Current message level: 0x000000ff (255)
Настройка сетевой карты компьютера 2 приведена на рисунке 1.
Порты роутера настроены 1000Мб Full duplex, при этом скорость не превышает 54 Мб (рисунок 2).
6 answers to this question
Posted (edited)
Попробуйте выбрать на обоих ПК и Кинетике "Автосогласование".
Edited by drugold
Posted (edited)
(iperf3 -c .... -R -t 480)ПК(LAN)---(LAN)KN3010(LAN)---(LAN)KN1010(iperf3 -s)
или
(iperf3 -c .... -t 480)ПК(LAN)---(LAN)KN3010(LAN)---(LAN)KN1010(iperf3 -s)
В итоге
/ # iperf3 -s
Server listening on 5201
Accepted connection from 192.168.130.2, port 50375
[  5] local 192.168.130.100 port 5201 connected to 192.168.130.2 port 50376
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.02   sec  94.8 MBytes   778 Mbits/sec    0    406 KBytes
[  5]   1.02-2.02   sec  95.0 MBytes   801 Mbits/sec    0    406 KBytes
[  5]   2.02-3.02   sec  93.4 MBytes   780 Mbits/sec    0    568 KBytes
[  5]   3.02-4.03   sec  81.2 MBytes   679 Mbits/sec    0    650 KBytes
[  5]   4.03-5.04   sec  92.5 MBytes   768 Mbits/sec    0    696 KBytes
[  5]   5.04-6.02   sec  87.5 MBytes   749 Mbits/sec    0    696 KBytes
[  5]   6.02-7.01   sec  97.5 MBytes   819 Mbits/sec    0    749 KBytes
[  5]   7.01-8.02   sec  98.8 MBytes   821 Mbits/sec    0    749 KBytes
[  5]   8.02-9.02   sec  95.0 MBytes   799 Mbits/sec    0    749 KBytes
[  5]   9.02-10.02  sec  91.2 MBytes   765 Mbits/sec    0    749 KBytes
[  5]  10.02-11.02  sec  96.9 MBytes   817 Mbits/sec    0    817 KBytes
[  5]  11.02-12.01  sec  95.0 MBytes   798 Mbits/sec    0    817 KBytes
[  5]  12.01-13.02  sec  95.0 MBytes   790 Mbits/sec    0    817 KBytes
[  5]  13.02-14.02  sec  95.0 MBytes   799 Mbits/sec    0    817 KBytes
[  5]  14.02-15.02  sec  97.5 MBytes   815 Mbits/sec    0    817 KBytes
[  5]  15.02-16.02  sec  93.8 MBytes   790 Mbits/sec    0    817 KBytes
[  5]  16.02-17.02  sec  96.2 MBytes   804 Mbits/sec    0    817 KBytes
iperf3: error - unable to write to stream socket: Connection reset by peer
^Ciperf3: interrupt - the server has terminated
То же самое только передача
/ # iperf3 -s
Accepted connection from 192.168.130.2, port 50391
[  5] local 192.168.130.100 port 5201 connected to 192.168.130.2 port 50392
[  5]   0.00-1.00   sec  78.2 MBytes   655 Mbits/sec
[  5]   1.00-2.00   sec  87.3 MBytes   732 Mbits/sec
[  5]   2.00-3.00   sec  98.9 MBytes   831 Mbits/sec
[  5]   3.00-4.00   sec  96.8 MBytes   811 Mbits/sec
[  5]   4.00-5.00   sec  88.2 MBytes   740 Mbits/sec
[  5]   5.00-6.00   sec  96.8 MBytes   812 Mbits/sec
[  5]   6.00-7.00   sec  86.9 MBytes   729 Mbits/sec
[  5]   7.00-8.00   sec  91.9 MBytes   772 Mbits/sec
[  5]   8.00-9.00   sec  86.7 MBytes   727 Mbits/sec
[  5]   9.00-10.00  sec  86.7 MBytes   727 Mbits/sec
[  5]  10.00-11.00  sec  95.8 MBytes   804 Mbits/sec
[  5]  11.00-12.00  sec  96.6 MBytes   810 Mbits/sec
[  5]  12.00-13.00  sec  95.5 MBytes   800 Mbits/sec
[  5]  13.00-14.00  sec  94.6 MBytes   794 Mbits/sec
[  5]  14.00-15.00  sec  86.9 MBytes   729 Mbits/sec
[  5]  15.00-16.00  sec  99.2 MBytes   833 Mbits/sec
[  5]  16.00-17.00  sec  87.4 MBytes   733 Mbits/sec
[  5]  17.00-18.00  sec  99.1 MBytes   832 Mbits/sec
[  5]  18.00-19.00  sec  93.0 MBytes   780 Mbits/sec
[  5]  19.00-20.00  sec  87.8 MBytes   737 Mbits/sec
[  5]   0.00-20.00  sec  1.82 GBytes   783 Mbits/sec                  receiver
iperf3: the client has terminated
возможно драйвера на ПК
Edited by vasek00
Posted
Сделал порты 100МБ FullDuplex, скорость 11МБ. Драйвера на ПК обновил, автосогласование пробовал.
Posted
1 час назад, shik сказал:
Ну так и что вы хотите от 100? Не 10-11 мегабайт, а 80-100 мегабайт? Извините, но вам уже сказали - поставьте везде "авто". С Риалтеком и Кинетиками на гигабите проблем нет (не встречал :) ). Только если кабели/пачкорды у вас фуфел.
Posted
Я поставил 100МБ ради эксперимента, останется ли скорость такой же, как и на 1000МБ, вдруг проблема с автосогласованием на скорости 1000МБ. Попробую заменить патч-корды.
