Выборочный роутинг с помощью ipset
Всем доброго дня. Пытаюсь сделать выборочный роутинг по инструкции https://keenetic-gi.ga/2018/01/16/selective-routing.html , но почему-то соединение просто висит. Не уверен что это поможет, но вот tcpdump с попыткой открыть https://linkedin.com
Spoiler
~ # tcpdump -i ovpn_br0 -vv
tcpdump: listening on ovpn_br0, link-type EN10MB (Ethernet), capture size 262144 bytes
08:48:57.536119 IP (tos 0x0, ttl 127, id 12958, offset 0, flags [DF], proto TCP (6), length 52)
    192.168.255.6.52157 > 13.107.42.14.https: Flags [S], cksum 0xdfa7 (correct), seq 925931686, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
08:48:57.691822 IP (tos 0x0, ttl 116, id 44032, offset 0, flags [DF], proto TCP (6), length 52)
    13.107.42.14.https > 192.168.255.6.52157: Flags [S.], cksum 0x362e (correct), seq 3198608920, ack 925931687, win 65535, options [mss 1358,nop,wscale 8,nop,nop,sackOK], length 0
08:48:57.695452 IP (tos 0x0, ttl 127, id 12959, offset 0, flags [DF], proto TCP (6), length 40)
    192.168.255.6.52157 > 13.107.42.14.https: Flags [.], cksum 0x7499 (correct), seq 1, ack 1, win 514, length 0
08:48:57.698313 IP (tos 0x0, ttl 127, id 12960, offset 0, flags [DF], proto TCP (6), length 432)
    192.168.255.6.52157 > 13.107.42.14.https: Flags [P.], cksum 0xace8 (correct), seq 1:393, ack 1, win 514, length 392
08:48:57.853623 IP (tos 0x0, ttl 117, id 44033, offset 0, flags [DF], proto TCP (6), length 40)
    13.107.42.14.https > 192.168.255.6.52157: Flags [.], cksum 0x6d10 (correct), seq 1, ack 393, win 2051, length 0
08:48:57.854726 IP (tos 0x0, ttl 117, id 44034, offset 0, flags [DF], proto TCP (6), length 1398)
    13.107.42.14.https > 192.168.255.6.52157: Flags [.], cksum 0xcfcc (correct), seq 1:1359, ack 393, win 2051, length 1358
08:48:57.855144 IP (tos 0x0, ttl 117, id 44035, offset 0, flags [DF], proto TCP (6), length 1398)
    13.107.42.14.https > 192.168.255.6.52157: Flags [.], cksum 0xe2c1 (correct), seq 1359:2717, ack 393, win 2051, length 1358
08:48:57.855485 IP (tos 0x0, ttl 117, id 44036, offset 0, flags [DF], proto TCP (6), length 1038)
    13.107.42.14.https > 192.168.255.6.52157: Flags [P.], cksum 0xcdf8 (correct), seq 2717:3715, ack 393, win 2051, length 998
08:48:57.858017 IP (tos 0x0, ttl 127, id 12961, offset 0, flags [DF], proto TCP (6), length 40)
    192.168.255.6.52157 > 13.107.42.14.https: Flags [.], cksum 0x6880 (correct), seq 393, ack 2717, win 503, length 0
08:48:57.858097 IP (tos 0x0, ttl 127, id 12962, offset 0, flags [DF], proto TCP (6), length 40)
    192.168.255.6.52157 > 13.107.42.14.https: Flags [.], cksum 0x6875 (correct), seq 393, ack 2717, win 514, length 0
08:48:57.875542 IP (tos 0x0, ttl 127, id 12963, offset 0, flags [DF], proto TCP (6), length 198)
    192.168.255.6.52157 > 13.107.42.14.https: Flags [P.], cksum 0xc2c3 (correct), seq 393:551, ack 3715, win 510, length 158
08:48:58.030963 IP (tos 0x0, ttl 117, id 44037, offset 0, flags [DF], proto TCP (6), length 40)
    13.107.42.14.https > 192.168.255.6.52157: Flags [.], cksum 0x5df1 (correct), seq 3715, ack 551, win 2050, length 0
08:48:58.032235 IP (tos 0x0, ttl 117, id 44038, offset 0, flags [DF], proto TCP (6), length 91)
    13.107.42.14.https > 192.168.255.6.52157: Flags [P.], cksum 0xa6bc (correct), seq 3715:3766, ack 551, win 2050, length 51
08:48:58.380668 IP (tos 0x0, ttl 116, id 44039, offset 0, flags [DF], proto TCP (6), length 91)
08:48:58.740483 IP (tos 0x0, ttl 117, id 44040, offset 0, flags [DF], proto TCP (6), length 91)
08:48:59.439163 IP (tos 0x0, ttl 117, id 44041, offset 0, flags [DF], proto TCP (6), length 91)
08:49:00.835664 IP (tos 0x0, ttl 117, id 44042, offset 0, flags [DF], proto TCP (6), length 91)
08:49:02.765293 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 13.107.42.14 tell 192.168.255.6, length 28
08:49:02.765332 ARP, Ethernet (len 6), IPv4 (len 4), Reply 13.107.42.14 is-at de:72:0d:a2:a8:0e (oui Unknown), length 28
08:49:03.628367 IP (tos 0x0, ttl 117, id 44043, offset 0, flags [DF], proto TCP (6), length 91)
08:49:09.212746 IP (tos 0x0, ttl 117, id 44044, offset 0, flags [DF], proto TCP (6), length 91)
Если задать прямой маршрут ip route add 13.107.42.14 dev ovpn_br0, то всё работает, но через ipset ни в какую не хочет. Подскажите, куда можно подсмотреть чтобы понять в чём проблема?
 Share
