Mihail_Boyanskiy Posted January 20, 2021 Share Posted January 20, 2021 Приветствую. Кто может, соберите пожалуйста stun-server и stun-client для entware. Quote Link to comment Share on other sites More sharing options...
TheBB Posted January 21, 2021 Share Posted January 21, 2021 coturn libevent2-extra_2.1.11-2_mipsel-3.4.ipk libsocket_2.5.0-1_mipsel-3.4.ipk coturn_4.5.2-1_mipsel-3.4.ipk Скрытый текст ~ # /opt/etc/init.d/S99turnserver start Starting turnserver... done. ~ # ~ # /opt/etc/init.d/S99turnserver check Checking turnserver... alive. ~ # ~ # cat /opt/var/log/turn_2021-01-21.log 0: : log file opened: /opt/var/log/turn_2021-01-21.log 0: : Listener address to use: 127.0.0.1 0: : Aux server: 127.0.0.1 0: : Relay address to use: 127.0.0.1 0: : RFC 3489/5389/5766/5780/6062/6156 STUN/TURN Server Version Coturn-4.5.2 'dan Eider' 0: : Max number of open files/sockets allowed for this process: 4096 0: : Due to the open files/sockets limitation, max supported number of TURN Sessions possible is: 1000 (approximately) 0: : ==== Show him the instruments, Practical Frost: ==== 0: : TLS supported 0: : DTLS supported 0: : DTLS 1.2 supported 0: : TURN/STUN ALPN supported 0: : Third-party authorization (oAuth) is not supported 0: : OpenSSL compile-time version: OpenSSL 1.1.1h 22 Sep 2020 (0x1010108f) 0: : 0: : SQLite supported, default database location is /opt/var/lib/turn/turndb 0: : Redis is not supported 0: : PostgreSQL is not supported 0: : MySQL is not supported 0: : MongoDB is not supported 0: : 0: : Default Net Engine version: 2 (UDP thread per network endpoint) ===================================================== 0: : Domain name: WORKGROUP 0: : Default realm: WORKGROUP 0: : SSL23: Certificate file found: /opt/etc/turnserver/turn_server_cert.pem 0: : SSL23: Private key file found: /opt/etc/turnserver/turn_server_pkey.pem 0: : TLS1.0: Certificate file found: /opt/etc/turnserver/turn_server_cert.pem 0: : TLS1.0: Private key file found: /opt/etc/turnserver/turn_server_pkey.pem 0: : TLS1.1: Certificate file found: /opt/etc/turnserver/turn_server_cert.pem 0: : TLS1.1: Private key file found: /opt/etc/turnserver/turn_server_pkey.pem 0: : TLS1.2: Certificate file found: /opt/etc/turnserver/turn_server_cert.pem 0: : TLS1.2: Private key file found: /opt/etc/turnserver/turn_server_pkey.pem 0: : TLS cipher suite: DEFAULT 0: : DTLS: Certificate file found: /opt/etc/turnserver/turn_server_cert.pem 0: : DTLS: Private key file found: /opt/etc/turnserver/turn_server_pkey.pem 0: : DTLS1.2: Certificate file found: /opt/etc/turnserver/turn_server_cert.pem 0: : DTLS1.2: Private key file found: /opt/etc/turnserver/turn_server_pkey.pem 0: : DTLS cipher suite: DEFAULT 0: : log file opened: /opt/var/log/turn_2021-01-21.log 0: : pid file created: /opt/var/run/turnserver.pid 0: : IO method (main listener thread): epoll (with changelist) 0: : WARNING: I cannot support STUN CHANGE_REQUEST functionality because only one IP address is provided 0: : Wait for relay ports initialization... 0: : relay 127.0.0.1 initialization... 0: : relay 127.0.0.1 initialization done 0: : Relay ports initialization done 0: : IO method (general relay thread): epoll (with changelist) 0: : IO method (general relay thread): epoll (with changelist) 0: : IO method (udp listener/relay thread): epoll (with changelist) 0: : turn server id=0 created 0: : IO method (general relay thread): epoll (with changelist) 0: : turn server id=1 created 0: : IO method (general relay thread): epoll (with changelist) 0: : turn server id=128 created 0: : turn server id=2 created 0: : turn server id=3 created 0: : IO method (udp listener/relay thread): epoll (with changelist) 0: : turn server id=129 created 0: : IO method (udp listener/relay thread): epoll (with changelist) 0: : turn server id=130 created 0: : Total UDP servers: 3 0: : Total General servers: 4 0: : IO method (auth thread): epoll (with changelist) 0: : IO method (auth thread): epoll (with changelist) 0: : IO method (admin thread): epoll (with changelist) 0: : SQLite DB connection success: /opt/var/lib/turn/turndb 0: : Keep GID: root(0) 0: : Keep UID: root(0) ~ # 1 Quote Link to comment Share on other sites More sharing options...
TheBB Posted January 21, 2021 Share Posted January 21, 2021 прикручена одна база - sqlite3 (mysql, postgresql, redis, mongodb - идут тёмным лесом, широким полем), конфиг править под свои нужды (приведённый - для теста на работу), серты - генерить... в общем - читать доки. Quote Link to comment Share on other sites More sharing options...
Mihail_Boyanskiy Posted January 24, 2021 Author Share Posted January 24, 2021 (edited) Спасибо конечно, но меня интересовали не turn-server, а скорее Stun и по большей части client. для обмена информацией с другими stun (не turn) серверами. Исходники можно глянуть тут: https://freefr.dl.sourceforge.net/project/stun/stun/0.97/stund-0.97.tgz Edited January 24, 2021 by Mihail_Boyanskiy Quote Link to comment Share on other sites More sharing options...
Mihail_Boyanskiy Posted January 24, 2021 Author Share Posted January 24, 2021 Или вот: https://github.com/jselbie/stunserver Но это я не собирал, а вот первое установлено и хорошо работает на Ubuntu. Quote Link to comment Share on other sites More sharing options...
TheBB Posted January 24, 2021 Share Posted January 24, 2021 8 часов назад, Mihail_Boyanskiy сказал: а скорее Stun по умолчанию работают оба-два stun+turn, остальное зависит от желания пользователя: или stun, или turn 8 часов назад, Mihail_Boyanskiy сказал: по большей части client угу, напр., туть (из вики прожекта) 8 часов назад, Mihail_Boyanskiy сказал: Исходники можно глянуть тут... хорошечно, раз отговаривать "архиологов" смысла неть, то: stund_0.97-1_mipsel-3.4.ipk stun-client_0.97-1_mipsel-3.4.ipk 8 часов назад, Mihail_Boyanskiy сказал: Но это я не собирал а я собрал ))) stunclient_1.2.16-1_mipsel-3.4.ipk stunserver_1.2.16-1_mipsel-3.4.ipk stuntestcode_1.2.16-1_mipsel-3.4.ipk 1 1 Quote Link to comment Share on other sites More sharing options...
Mihail_Boyanskiy Posted January 25, 2021 Author Share Posted January 25, 2021 (edited) Ого! Спасибо огромное. Чтоб добру не пропадать, в идеале можно выложить в репозиторий Entware, но это уже вам видней. Спасибо ещё раз. Edited January 25, 2021 by Mihail_Boyanskiy Quote Link to comment Share on other sites More sharing options...
Sano Posted November 29, 2021 Share Posted November 29, 2021 В 24.01.2021 в 18:28, TheBB сказал: а я собрал ))) Спасибо Вам за труды. А подскажите начинающему, как этот .ipk установить на роутер? Entware поставил. Как пакет установить? Quote Link to comment Share on other sites More sharing options...
TheBB Posted November 30, 2021 Share Posted November 30, 2021 11 час назад, Sano сказал: Как пакет установить? Загружаете на устройство, набираете "opkg install /path/to/pkg" , где /path/to/pkg - путь к нужному пакету, напр., `opkg install stuntestcode_1.2.16-1_mipsel-3.4.ipk` Quote Link to comment Share on other sites More sharing options...
Sano Posted November 30, 2021 Share Posted November 30, 2021 (edited) 2 часа назад, TheBB сказал: Загружаете на устройство, набираете "opkg install /path/to/pkg" , где /path/to/pkg - путь к нужному пакету, напр., `opkg install stuntestcode_1.2.16-1_mipsel-3.4.ipk` Спасибо большое еще раз Edited November 30, 2021 by Sano Quote Link to comment Share on other sites More sharing options...
