веб мордочка еле прогружалась
Meccep45
сохранил лог и вот что там.
[E] Feb  6 14:34:58 ultra nginx_ssl: 2021/02/06 14:34:58 [error] 6955#0: *31084 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/dashboard"
[C] Feb  6 17:30:56 ndm: Core::Scgi::Auth: system failed [0xcffd0075], SCGI socket flush failed: connection reset by peer.
[E] Feb  6 17:41:54 ndm: Core::Scgi::Auth: authentication failed for user root.
[C] Feb  6 19:37:21 ndm: Core::Scgi::Auth: system failed [0xcffd0075], SCGI socket flush failed: connection reset by peer.
[C] Feb  7 00:31:28 ultra nginx_ssl: 2021/02/07 00:31:28 [crit] 6955#0: *35408 SSL_do_handshake() failed (SSL: error:141CF06C:lib(20):func(463):reason(108)) while SSL handshaking, client: 192.241.222.236, server: 0.0.0.0:443
[C] Feb  8 03:59:12 ultra nginx_ssl: 2021/02/08 03:59:12 [crit] 6955#0: *41948 SSL_do_handshake() failed (SSL: error:141CF06C:lib(20):func(463):reason(108)) while SSL handshaking, client: 184.105.247.254, server: 0.0.0.0:443
[E] Feb  8 05:29:05 ultra nginx_ssl: 2021/02/08 05:29:05 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:08 ultra nginx_ssl: 2021/02/08 05:29:08 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:11 ultra nginx_ssl: 2021/02/08 05:29:11 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:16 ultra nginx_ssl: 2021/02/08 05:29:16 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:19 ultra nginx_ssl: 2021/02/08 05:29:19 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "GET /rci/ls HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/ls", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:19 ultra nginx_ssl: 2021/02/08 05:29:19 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:23 ultra nginx_ssl: 2021/02/08 05:29:23 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:26 ultra nginx_ssl: 2021/02/08 05:29:26 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:29 ultra nginx: 2021/02/08 05:29:29 [error] 6957#0: *883564 upstream timed out (145: Unknown error) while reading response header from upstream, client: unix:, server: ultra.keenetic.io, request: "POST /rci/ HTTP/1.0", upstream: "scgi://unix:/var/run/ndm.scgi.socket", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:32 ultra nginx_ssl: 2021/02/08 05:29:32 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:36 ultra nginx_ssl: 2021/02/08 05:29:36 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:29:39 ultra nginx_ssl: 2021/02/08 05:29:39 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "POST /rci/ HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[C] Feb  8 05:30:40 ndm: Core::Scgi::Auth: system failed [0xcffd0075], SCGI socket flush failed: connection reset by peer.
[C] Feb  8 05:30:57 ndm: Core::Scgi::Auth: system failed [0xcffd0075], SCGI socket flush failed: connection reset by peer.
[E] Feb  8 05:31:08 ultra nginx: 2021/02/08 05:31:08 [error] 6957#0: *883577 upstream timed out (145: Unknown error) while reading response header from upstream, client: unix:, server: ultra.keenetic.io, request: "GET /rci/ls HTTP/1.0", upstream: "scgi://unix:/var/run/ndm.scgi.socket", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
[E] Feb  8 05:31:09 ultra nginx_ssl: 2021/02/08 05:31:09 [error] 6954#0: *42250 upstream timed out (145: Unknown error) while reading response header from upstream, client: 192.168.1.40, server: ultra.keenetic.pro, request: "GET /rci/ls HTTP/2.0", upstream: "http://unix:/var/run/ndm.https.socket/rci/ls", host: "ultra.keenetic.pro", referrer: "https://ultra.keenetic.pro/controlPanel/apps"
что за ошибки? после перезагрузки всё нормально стало.
