  • 1
Пропадает доступ к Entware на внутренней памяти Nand
Serghey
При обновления роутера или его перезапуска, частенько пропадает доступ к Entware, установленной на внутренней памяти нанд микросхемы роутера. Скрин ниже.
Помогает две команды:
opkg no disk
opkg disk storage:/
Вопрос можно это как то автоматизировать?
10 answers to this question
5 минут назад, Le ecureuil сказал:
Как именно пропадает доступ?
Похоже проблема как и у других, какая-то не совместимость с  opkg dns-override.
Установлен Adguard Home у меня.
Edited by Serghey
(config)>
(config)> exec /opt/bin/sh
Process error[268241534]: system failed [0xcffd0a7e], "/opt/bin/sh" executable not found.
(config)>
(config)> exec /opt/bin/busybox sh
Process error[268241534]: system failed [0xcffd0a7e], "/opt/bin/busybox" executable not found.
(config)>
(config)> ls Sync_test:/bin/
Core::FileSystem::Native error[3867304]: failed to get file attributes.
(config)>
(config)> ls Sync_test:/usr/bin/
              rel: Sync_test:/usr/bin/
            entry, type = R:
            entry, type = R:
            entry, type = R:
            entry, type = R:
            entry, type = R:
            entry, type = R:
            entry, type = R:
(config)> exec /opt/usr/bin/sh
Process error[268241534]: system failed [0xcffd0a7e], "/opt/usr/bin/sh" executable not found.
(config)>
[I] Mar 26 08:49:16 ndnproxy: stopped.
[I] Mar 26 08:49:16 ndm: Dns::Manager: RPC-only mode enabled.
[E] Mar 26 08:49:16 ndm: Opkg::Manager: invalid initrc "/opt/etc/init.d/rc.unslung": no such file or directory, trying /opt/etc/init.d/.
[I] Mar 26 08:49:16 ndm: Storage::Manager: "Media0": enabled a disk spin down.
[I] Mar 26 08:49:16 ndm: Storage::Manager: created "Media0", port 1.
[C] Mar 26 09:07:11 ndm: Process: system failed [0xcffd0a7e], "/opt/bin/sh" executable not found.
[C] Mar 26 09:07:18 ndm: Process: system failed [0xcffd0a7e], "/opt/bin/busybox" executable not found.
[E] Mar 26 09:07:26 ndm: Core::FileSystem::Native: failed to get file attributes.
[C] Mar 26 09:07:46 ndm: Process: system failed [0xcffd0a7e], "/opt/usr/bin/sh" executable not found.
(config)> ls storage:/etc/
(config)> ls storage:/etc/init.d/
              rel: storage:/etc/init.d/
            entry, type = R:
            entry, type = R:
            entry, type = R:
(config)>
[E] Mar 26 09:21:40 ndm: Core::FileSystem::Native: failed to get file attributes.
Edited by TheBB
storage
Можно ещё поправить и данное сообщение и сделать выбор накопителя storage (в списке накопителей) в будущих обновлениях?
Edited by Serghey
В 26.03.2021 в 10:34, Le ecureuil сказал:
Другое дело. Посмотрю.
В 26.03.2021 в 10:17, TheBB сказал:
1. ставим систему
2. включаем opkg dns-override
3. сохраняем
4. перезагружаем устройство
5. пробуем зайти
Жаль что в новой Альфе 5 так же не работает ентваре после перезапуска роутера.
opkg no disk
opkg disk storage:/
Остается только ждать когда исправят.
В 28.04.2021 в 00:27, Le ecureuil сказал:
Будет поправлено в следующей сборке.
А в 2.16 не проявляется? Никто не проверял?
Огромное Спасибо в версия 3.7 Alpha 8 исправили.
PS Хотелось бы в следующих версиях сделать возможным проверку разделов жестких дисков NTFS/EXT4 на ошибки, нажатием кнопки в веб интерфейсе кинетика.
Edited by Serghey
