TheBB Posted August 13, 2021 Share Posted August 13, 2021 (edited) 12 часа назад, Meccep45 сказал: отправил. если не доверять людям, тогда и не узнаешь порядочных людей. Для проверки на свои менять, потому они без надобности... ))) ~ # diff -uraN msmtp/etc/php.ini /opt/etc/php.ini --- msmtp/etc/php.ini 2021-06-09 09:11:00.000000000 +0300 +++ /opt/etc/php.ini 2021-08-13 07:41:32.579970752 +0300 @@ -214,7 +214,8 @@ ;SMTP = localhost ;smtp_port = 25 ;sendmail_from = no-reply@xxx.yyy.zzz -sendmail_path = "/opt/sbin/sendmail -t" +;;sendmail_path = "/opt/sbin/sendmail -t" +sendmail_path = "/opt/bin/msmtp -t" ;mail.force_extra_parameters = ;mail.add_x_header = Off mail.log = "/opt/var/log/php8/php-mail.log" ~ # ~ # cat /opt/var/log/php8/php-mail.log [13-Aug-2021 07:46:44 Europe/Moscow] mail() on [/opt/share/www/ext-ui/msmtp.php:2]: To: receipient@domain.com -- Headers: -- Subject: A Subject Here Aug 13 07:46:52 host=smtp.gmail.com tls=on auth=on user=xxx@gmail.com from=root@xxx recipients=receipient@domain.com mailsize=173 smtpstatus=250 smtpmsg='250 2.0.0 OK 1628830012 v63sm612505pgv.59 - gsmtp' exitcode=EX_OK [13-Aug-2021 07:46:59 Europe/Moscow] mail() on [/opt/share/www/ext-ui/msmtp1.php:5]: To: receipient@yandex.ru -- Headers: -- Subject: my subject Aug 13 07:47:06 host=smtp.gmail.com tls=on auth=on user=xxx@gmail.com from=root@xxx recipients=receipient@yandex.ru mailsize=122 smtpstatus=250 smtpmsg='250 2.0.0 OK 1628830026 t19sm455174pfg.216 - gsmtp' exitcode=EX_OK ~ # Edited August 13, 2021 by TheBB Quote Link to comment Share on other sites More sharing options...
Meccep45 Posted August 13, 2021 Author Share Posted August 13, 2021 изменение sendmail_path = "/opt/sbin/sendmail -t" на sendmail_path = "/opt/bin/msmtp -t" не дали результат. всё также bool(false) Quote Link to comment Share on other sites More sharing options...
TheBB Posted August 13, 2021 Share Posted August 13, 2021 3 часа назад, Meccep45 сказал: всё также bool(false) локализовано ))) проблема тут passwordeval gpg --no-tty -q -d ~/.msmtp-password.gpg не может добраться и расшифровать ... [pid 20278] rt_sigaction(SIGQUIT, NULL, {sa_handler=SIG_IGN, sa_mask=[], sa_flags=0}, 16) = 0 [pid 20278] rt_sigaction(SIGTERM, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 16) = 0 [pid 20278] stat64("/sbin/gpg", 0x7ff48d78) = -1 ENOENT (No such file or directory) [pid 20278] stat64("/usr/sbin/gpg", 0x7ff48d78) = -1 ENOENT (No such file or directory) [pid 20278] stat64("/bin/gpg", 0x7ff48d78) = -1 ENOENT (No such file or directory) [pid 20278] stat64("/usr/bin/gpg", 0x7ff48d78) = -1 ENOENT (No such file or directory) [pid 20278] write(2, "/opt/bin/sh: ", 13) = 13 [pid 20278] write(2, "gpg: not found", 14) = 14 [pid 20278] write(2, "\n", 1) = 1 [pid 20278] exit_group(127) = ? [pid 20278] +++ exited with 127 +++ [pid 20277] <... read resumed>"", 4096) = 0 [pid 20277] --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=20278, si_uid=65534, si_status=127, si_utime=0, si_stime=0} --- [pid 20277] close(6) = 0 [pid 20277] waitpid(20278, [{WIFEXITED(s) && WEXITSTATUS(s) == 127}], 0) = 20278 [pid 20277] write(2, "msmtp: ", 7) = 7 [pid 20277] write(2, "cannot read output of 'gpg --qui"..., 94) = 94 [pid 20277] write(2, "\n", 1) = 1 [pid 20277] close(4) ... будем посмотреть дальше... Quote Link to comment Share on other sites More sharing options...
Meccep45 Posted August 13, 2021 Author Share Posted August 13, 2021 1 час назад, TheBB сказал: локализовано ))) проблема тут попробовал дать пароль без шифрования. та же не удача. Quote Link to comment Share on other sites More sharing options...
TheBB Posted August 14, 2021 Share Posted August 14, 2021 15 часов назад, Meccep45 сказал: попробовал дать пароль без шифрования. та же не удача. Все логи отправки, что выше, были с паролем "открытым текстом" (для гугляпочты дополнительно сгенерен в настройках аккаунта, яндикс страдает той же фигнёй ))) ). ковыряния привели к Permission denied Скрытый текст ... [pid 23775] getuid() = 65534 [pid 23775] mlock(0x77dfa000, 32768) = 0 [pid 23775] geteuid() = 65534 [pid 23775] access("/opt/root/.gnupg/gpg.conf-2.2.23", R_OK) = -1 EACCES (Permission denied) [pid 23775] access("/opt/root/.gnupg/gpg.conf-2.2", R_OK) = -1 EACCES (Permission denied) [pid 23775] access("/opt/root/.gnupg/gpg.conf-2", R_OK) = -1 EACCES (Permission denied) [pid 23775] access("/opt/root/.gnupg/gpg.conf", R_OK) = -1 EACCES (Permission denied) [pid 23775] access("/opt/root/.gnupg/options", R_OK) = -1 EACCES (Permission denied) [pid 23775] stat64("/opt/root/.gnupg", {st_dev=makedev(0x8, 0x1), st_ino=1324634, st_mode=S_IFDIR|0700, st_nlink=5, st_uid=0, st_gid=0, st_blksize=4096, st_blocks=8, st_size=4096, st_atime=1628868670 /* 2021-08-13T18:31:10.723995861+0300 */, st_atime_nsec=723995861, st_mtime=1628930041 /* 2021-08-14T11:34:01.123989002+0300 */, st_mtime_nsec=123989002, st_ctime=1628930041 /* 2021-08-14T11:34:01.123989002+0300 */, st_ctime_nsec=123989002}) = 0 [pid 23775] stat64("/opt/root", {st_dev=makedev(0x8, 0x1), st_ino=1321921, st_mode=S_IFDIR|0755, st_nlink=16, st_uid=0, st_gid=0, st_blksize=4096, st_blocks=24, st_size=12288, st_atime=1625899748 /* 2021-07-10T09:49:08+0300 */, st_atime_nsec=0, st_mtime=1628889461 /* 2021-08-14T00:17:41.123993538+0300 */, st_mtime_nsec=123993538, st_ctime=1628889461 /* 2021-08-14T00:17:41.123993538+0300 */, st_ctime_nsec=123993538}) = 0 [pid 23775] getuid() = 65534 [pid 23775] write(2, "gpg: WARNING: unsafe ownership o"..., 59) = 59 [pid 23775] write(2, "'\n", 2) = 2 [pid 23775] openat(AT_FDCWD, "/opt/root/.gnupg/gpg.conf", O_RDONLY|O_LARGEFILE) = -1 EACCES (Permission denied) [pid 23775] access("/opt/root/.gnupg/random_seed", F_OK) = -1 EACCES (Permission denied) [pid 23775] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.gpg", O_RDONLY|O_LARGEFILE) = -1 EACCES (Permission denied) [pid 23775] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.kbx", O_RDONLY|O_LARGEFILE) = -1 EACCES (Permission denied) [pid 23775] access("/opt/root/.gnupg/pubring.kbx", F_OK) = -1 EACCES (Permission denied) [pid 23775] access("/opt/root/.gnupg", F_OK) = 0 [pid 23775] getpid() = 23775 [pid 23775] uname({sysname="Linux", nodename="Keenetic-6065", release="4.9-ndm-5", version="#2 SMP Thu Aug 12 16:12:48 MSK 2021", machine="mips", domainname="WORKGROUP"}) = 0 [pid 23775] getpid() = 23775 [pid 23775] openat(AT_FDCWD, "/opt/root/.gnupg/.#lk0x006a1720.Keenetic-6065.23775", O_WRONLY|O_CREAT|O_EXCL|O_LARGEFILE, 0644) = -1 EACCES (Permission denied) [pid 23775] write(2, "gpg: failed to create temporary "..., 109) = 109 [pid 23775] write(2, "\n", 1) = 1 [pid 23775] write(2, "gpg: keyblock resource '/opt/roo"..., 72) = 72 [pid 23775] write(2, "\n", 1) = 1 [pid 23775] access("/opt/root/.gnupg/secring.gpg", F_OK) = -1 EACCES (Permission denied) [pid 23775] openat(AT_FDCWD, "/opt/etc/.mail.gpg", O_RDONLY|O_LARGEFILE) = -1 EACCES (Permission denied) [pid 23775] write(2, "gpg: can't open '/opt/etc/.mail."..., 55) = 55 [pid 23775] write(2, "\n", 1) = 1 [pid 23775] write(2, "gpg: decrypt_message failed: Per"..., 46) = 46 [pid 23775] write(2, "\n", 1) = 1 [pid 23775] munmap(0x77dfa000, 32768) = 0 [pid 23775] exit_group(2) = ? [pid 23775] +++ exited with 2 +++ [pid 23774] <... read resumed>"", 4096) = 0 [pid 23774] --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=23775, si_uid=65534, si_status=2, si_utime=2, si_stime=3} --- [pid 23774] close(6) = 0 [pid 23774] waitpid(23775, [{WIFEXITED(s) && WEXITSTATUS(s) == 2}], 0) = 23775 [pid 23774] write(2, "msmtp: ", 7) = 7 [pid 23774] write(2, "cannot read output of 'gpg --qui"..., 94) = 94 [pid 23774] write(2, "\n", 1) = 1 [pid 23774] close(4) = 0 [pid 23774] _llseek(0, -58, 0x7fcdd380, SEEK_CUR) = -1 ESPIPE (Illegal seek) [pid 23774] exit_group(78) = ? [pid 23774] +++ exited with 78 +++ <... waitpid resumed>[{WIFEXITED(s) && WEXITSTATUS(s) == 78}], 0) = 23774 --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=23774, si_uid=65534, si_status=78, si_utime=2, si_stime=3} --- chdir("/opt/root") = 0 times({tms_utime=1, tms_stime=5, tms_cutime=8, tms_cstime=15}) = 1727850946 setitimer(ITIMER_PROF, {it_interval={tv_sec=0, tv_usec=0}, it_value={tv_sec=0, tv_usec=0}}, NULL) = 0 write(3, "\1\6\0\1\0:\6\0Content-type: text/html;"..., 88) = 88 shutdown(3, SHUT_WR) = 0 recv(3, "\1\5\0\1\0\0\0\0", 8, 0) = 8 recv(3, "", 8, 0) = 0 close(3) = 0 write(2, "\0fscf\0", 6) = 6 accept(5, ^Cstrace: Process 23295 detached <detached ...> ~ # стало совсем не секурно ))) Скрытый текст ... [pid 28930] getuid() = 65534 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/gpg.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory) [pid 28930] access("/opt/root/.gnupg/random_seed", F_OK) = 0 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.gpg", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory) [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.kbx", O_RDONLY|O_LARGEFILE) = 6 [pid 28930] fstat64(6, {st_dev=makedev(0x8, 0x1), st_ino=1324647, st_mode=S_IFREG|0644, st_nlink=1, st_uid=65534, st_gid=0, st_blksize=4096, st_blocks=8, st_size=1458, st_atime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_atime_nsec=339995773, st_mtime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_mtime_nsec=339995773, st_ctime=1628934481 /* 2021-08-14T12:48:01.087988506+0300 */, st_ctime_nsec=87988506}) = 0 [pid 28930] read(6, "\0\0\0 \1\1\0\2KBXf\0\0\0\0a\26\220>a\26\220>\0\0\0\0\0\0\0\0"..., 4096) = 1458 [pid 28930] close(6) = 0 [pid 28930] access("/opt/root/.gnupg/pubring.kbx", F_OK) = 0 [pid 28930] access("/opt/root/.gnupg/pubring.kbx", R_OK) = 0 [pid 28930] access("/opt/root/.gnupg/pubring.kbx", W_OK) = 0 [pid 28930] getpid() = 28930 [pid 28930] uname({sysname="Linux", nodename="Keenetic-6065", release="4.9-ndm-5", version="#2 SMP Thu Aug 12 16:12:48 MSK 2021", machine="mips", domainname="WORKGROUP"}) = 0 [pid 28930] getpid() = 28930 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930", O_WRONLY|O_CREAT|O_EXCL|O_LARGEFILE, 0644) = 6 [pid 28930] write(6, " 28930\n", 11) = 11 [pid 28930] write(6, "Keenetic-6065", 13) = 13 [pid 28930] write(6, "\n", 1) = 1 [pid 28930] close(6) = 0 [pid 28930] stat64("/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930", {st_dev=makedev(0x8, 0x1), st_ino=1324662, st_mode=S_IFREG|0644, st_nlink=1, st_uid=65534, st_gid=65534, st_blksize=4096, st_blocks=8, st_size=25, st_atime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_atime_nsec=607988480, st_mtime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_mtime_nsec=607988480, st_ctime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_ctime_nsec=607988480}) = 0 [pid 28930] link("/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930", "/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930x") = 0 [pid 28930] stat64("/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930", {st_dev=makedev(0x8, 0x1), st_ino=1324662, st_mode=S_IFREG|0644, st_nlink=2, st_uid=65534, st_gid=65534, st_blksize=4096, st_blocks=8, st_size=25, st_atime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_atime_nsec=607988480, st_mtime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_mtime_nsec=607988480, st_ctime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_ctime_nsec=607988480}) = 0 [pid 28930] unlink("/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930x") = 0 [pid 28930] link("/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930", "/opt/root/.gnupg/pubring.kbx.lock") = 0 [pid 28930] stat64("/opt/root/.gnupg/.#lk0x0094e720.Keenetic-6065.28930", {st_dev=makedev(0x8, 0x1), st_ino=1324662, st_mode=S_IFREG|0644, st_nlink=2, st_uid=65534, st_gid=65534, st_blksize=4096, st_blocks=8, st_size=25, st_atime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_atime_nsec=607988480, st_mtime=1628934717 /* 2021-08-14T12:51:57.607988480+0300 */, st_mtime_nsec=607988480, st_ctime=1628934717 /* 2021-08-14T12:51:57.611988480+0300 */, st_ctime_nsec=611988480}) = 0 [pid 28930] access("/opt/root/.gnupg/pubring.kbx", W_OK) = 0 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.kbx", O_RDONLY|O_LARGEFILE) = 6 [pid 28930] _llseek(6, 0, [0], SEEK_CUR) = 0 [pid 28930] fstat64(6, {st_dev=makedev(0x8, 0x1), st_ino=1324647, st_mode=S_IFREG|0644, st_nlink=1, st_uid=65534, st_gid=0, st_blksize=4096, st_blocks=8, st_size=1458, st_atime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_atime_nsec=339995773, st_mtime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_mtime_nsec=339995773, st_ctime=1628934481 /* 2021-08-14T12:48:01.087988506+0300 */, st_ctime_nsec=87988506}) = 0 [pid 28930] read(6, "\0\0\0 \1\1\0\2KBXf\0\0\0\0a\26\220>a\26\220>\0\0\0\0\0\0\0\0"..., 4096) = 1458 [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] _llseek(6, 0, [0], SEEK_SET) = 0 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.kbx.tmp", O_WRONLY|O_CREAT|O_TRUNC|O_LARGEFILE, 0666) = 7 [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] read(6, "\0\0\0 \1\1\0\2KBXf\0\0\0\0a\26\220>a\26\220>\0\0\0\0\0\0\0\0"..., 4096) = 1458 [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] fstat64(7, {st_dev=makedev(0x8, 0x1), st_ino=1324663, st_mode=S_IFREG|0644, st_nlink=1, st_uid=65534, st_gid=65534, st_blksize=4096, st_blocks=0, st_size=0, st_atime=1628934717 /* 2021-08-14T12:51:57.615988480+0300 */, st_atime_nsec=615988480, st_mtime=1628934717 /* 2021-08-14T12:51:57.615988480+0300 */, st_mtime_nsec=615988480, st_ctime=1628934717 /* 2021-08-14T12:51:57.615988480+0300 */, st_ctime_nsec=615988480}) = 0 [pid 28930] read(6, "", 4096) = 0 [pid 28930] close(6) = 0 [pid 28930] write(7, "\0\0\0 \1\1\0\2KBXf\0\0\0\0a\26\220>a\27\222=\0\0\0\0\0\0\0\0"..., 1458) = 1458 [pid 28930] close(7) = 0 [pid 28930] unlink("/opt/root/.gnupg/pubring.kbx.tmp") = 0 [pid 28930] access("/opt/root/.gnupg/pubring.kbx", W_OK) = 0 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.kbx.lock", O_RDONLY|O_LARGEFILE) = 6 [pid 28930] read(6, " 28930\nKeenetic-6065\n", 25) = 25 [pid 28930] close(6) = 0 [pid 28930] getpid() = 28930 [pid 28930] unlink("/opt/root/.gnupg/pubring.kbx.lock") = 0 [pid 28930] access("/opt/root/.gnupg/secring.gpg", F_OK) = -1 ENOENT (No such file or directory) [pid 28930] openat(AT_FDCWD, "/opt/etc/.mail.gpg", O_RDONLY|O_LARGEFILE) = 6 [pid 28930] read(6, "\205\1\f\3D3 ^&\206{\31\1\10\0\250\345>I\32)H\277vA\256z\343\230\350*+"..., 8192) = 339 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.kbx", O_RDONLY|O_LARGEFILE) = 7 [pid 28930] _llseek(7, 0, [0], SEEK_CUR) = 0 [pid 28930] fstat64(7, {st_dev=makedev(0x8, 0x1), st_ino=1324647, st_mode=S_IFREG|0644, st_nlink=1, st_uid=65534, st_gid=0, st_blksize=4096, st_blocks=8, st_size=1458, st_atime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_atime_nsec=339995773, st_mtime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_mtime_nsec=339995773, st_ctime=1628934481 /* 2021-08-14T12:48:01.087988506+0300 */, st_ctime_nsec=87988506}) = 0 [pid 28930] read(7, "\0\0\0 \1\1\0\2KBXf\0\0\0\0a\26\220>a\26\220>\0\0\0\0\0\0\0\0"..., 4096) = 1458 [pid 28930] _llseek(7, 0, [1458], SEEK_CUR) = 0 [pid 28930] getuid() = 65534 [pid 28930] stat64("/opt/var/run/user/65534", 0x7fd17b40) = -1 ENOENT (No such file or directory) [pid 28930] getuid() = 65534 [pid 28930] stat64("/opt/var/run/user/65534", 0x7fd17b40) = -1 ENOENT (No such file or directory) [pid 28930] stat("/opt/root/.gnupg/S.gpg-agent", {st_dev=makedev(0x8, 0x1), st_ino=1324642, st_mode=S_IFSOCK|0700, st_nlink=1, st_uid=65534, st_gid=0, st_blksize=4096, st_blocks=0, st_size=0, st_atime=1628933124 /* 2021-08-14T12:25:24.835988658+0300 */, st_atime_nsec=835988658, st_mtime=1628933124 /* 2021-08-14T12:25:24.835988658+0300 */, st_mtime_nsec=835988658, st_ctime=1628934481 /* 2021-08-14T12:48:01.083988506+0300 */, st_ctime_nsec=83988506}) = 0 [pid 28930] socket(AF_UNIX, SOCK_STREAM, 0) = 8 [pid 28930] stat("/opt/root/.gnupg/S.gpg-agent", {st_dev=makedev(0x8, 0x1), st_ino=1324642, st_mode=S_IFSOCK|0700, st_nlink=1, st_uid=65534, st_gid=0, st_blksize=4096, st_blocks=0, st_size=0, st_atime=1628933124 /* 2021-08-14T12:25:24.835988658+0300 */, st_atime_nsec=835988658, st_mtime=1628933124 /* 2021-08-14T12:25:24.835988658+0300 */, st_mtime_nsec=835988658, st_ctime=1628934481 /* 2021-08-14T12:48:01.083988506+0300 */, st_ctime_nsec=83988506}) = 0 [pid 28930] connect(8, {sa_family=AF_UNIX, sun_path="/opt/root/.gnupg/S.gpg-agent"}, 30) = 0 [pid 28930] read(8, "OK Pleased to meet you, process "..., 1002) = 38 [pid 28930] write(8, "RESET", 5) = 5 [pid 28930] write(8, "\n", 1) = 1 [pid 28930] read(8, "OK\n", 1002) = 3 [pid 28930] ioctl(0, TCGETS, 0x7fd179e8) = -1 ENOTTY (Inappropriate ioctl for device) [pid 28930] ioctl(0, TCGETS, 0x7fd179e8) = -1 ENOTTY (Inappropriate ioctl for device) [pid 28930] write(8, "GETINFO version", 15) = 15 [pid 28930] write(8, "\n", 1) = 1 [pid 28930] read(8, "D 2.2.23\nOK\n", 1002) = 12 [pid 28930] write(8, "OPTION allow-pinentry-notify", 28) = 28 [pid 28930] write(8, "\n", 1) = 1 [pid 28930] read(8, "OK\n", 1002) = 3 [pid 28930] write(8, "OPTION agent-awareness=2.1.0", 28) = 28 [pid 28930] write(8, "\n", 1) = 1 [pid 28930] read(8, "OK\n", 1002) = 3 [pid 28930] write(8, "HAVEKEY 103B54970B29926CE0C3D6CE"..., 48) = 48 [pid 28930] write(8, "\n", 1) = 1 [pid 28930] read(8, "OK\n", 1002) = 3 [pid 28930] close(7) = 0 [pid 28930] openat(AT_FDCWD, "/opt/root/.gnupg/pubring.kbx", O_RDONLY|O_LARGEFILE) = 7 [pid 28930] _llseek(7, 0, [0], SEEK_CUR) = 0 [pid 28930] fstat64(7, {st_dev=makedev(0x8, 0x1), st_ino=1324647, st_mode=S_IFREG|0644, st_nlink=1, st_uid=65534, st_gid=0, st_blksize=4096, st_blocks=8, st_size=1458, st_atime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_atime_nsec=339995773, st_mtime=1628869457 /* 2021-08-13T18:44:17.339995773+0300 */, st_mtime_nsec=339995773, st_ctime=1628934481 /* 2021-08-14T12:48:01.087988506+0300 */, st_ctime_nsec=87988506}) = 0 [pid 28930] read(7, "\0\0\0 \1\1\0\2KBXf\0\0\0\0a\26\220>a\26\220>\0\0\0\0\0\0\0\0"..., 4096) = 1458 [pid 28930] _llseek(7, 0, [1458], SEEK_CUR) = 0 [pid 28930] write(8, "HAVEKEY DC7B773FB778B1FAF9BA1365"..., 89) = 89 [pid 28930] write(8, "\n", 1) = 1 [pid 28930] read(8, "OK\n", 1002) = 3 [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] time(NULL) = 1628934717 (2021-08-14T12:51:57+0300) [pid 28930] write(8, "HAVEKEY 103B54970B29926CE0C3D6CE"..., 48) = 48 [pid 28930] write(8, "\n", 1) = 1 [pid 28930] read(8, "OK\n", 1002) = 3 ... [14-Aug-2021 12:49:13 Europe/Moscow] mail() on [/opt/share/nginx/html/msmtp.php:2]: To: receipient@domain.com -- Headers: -- Subject: A Subject Here Aug 14 12:49:28 host=smtp.gmail.com tls=on auth=on user=xxx@gmail.com from=root@xxx recipients=receipient@domain.com errormsg='cannot locate host smtp.gmail.com: Temporary failure in name resolution' exitcode=EX_NOHOST [14-Aug-2021 12:49:31 Europe/Moscow] mail() on [/opt/share/nginx/html/msmtp.php:2]: To: receipient@domain.com -- Headers: -- Subject: A Subject Here Aug 14 12:49:39 host=smtp.gmail.com tls=on auth=on user=xxx@gmail.com from=root@xxx recipients=receipient@domain.com mailsize=173 smtpstatus=250 smtpmsg='250 2.0.0 OK 1628934579 b20sm4744690pfl.9 - gsmtp' exitcode=EX_OK [14-Aug-2021 12:51:43 Europe/Moscow] mail() on [/opt/share/nginx/html/msmtp.php:2]: To: receipient@domain.com -- Headers: -- Subject: A Subject Here Aug 14 12:51:50 host=smtp.gmail.com tls=on auth=on user=xxx@gmail.com from=nobody@xxx recipients=receipient@domain.com mailsize=175 smtpstatus=250 smtpmsg='250 2.0.0 OK 1628934710 r10sm4993668pff.7 - gsmtp' exitcode=EX_OK [14-Aug-2021 12:51:57 Europe/Moscow] mail() on [/opt/share/nginx/html/msmtp1.php:5]: To: receipient@yandex.ru -- Headers: -- Subject: my subject Aug 14 12:52:04 host=smtp.gmail.com tls=on auth=on user=xxx@gmail.com from=nobody@xxx recipients=receipient@yandex.ru mailsize=124 smtpstatus=250 smtpmsg='250 2.0.0 OK 1628934724 125sm5255156pfy.17 - gsmtp' exitcode=EX_OK Aug 14 12:52:37 host=smtp.gmail.com tls=on auth=on user=xxx@gmail.com from=root@xxx recipients=username@domain.com mailsize=87 smtpstatus=250 smtpmsg='250 2.0.0 OK 1628934756 f1sm5229922pfk.115 - gsmtp' exitcode=EX_OK Aug 14 12:52:54 host=smtp.gmail.com tls=on auth=on user=xxxo@gmail.com from=root@xxx recipients=username@domain.com mailsize=87 smtpstatus=250 smtpmsg='250 2.0.0 OK 1628934774 r16sm4273396pje.10 - gsmtp' exitcode=EX_OK ~ # убил систему... ))) ___ по "паролю" оно работает, по "крипте" надо или настраивать многопользовательскую систему (и не факт, что взлетит), или установить debian (надо проверять). Quote Link to comment Share on other sites More sharing options...
Meccep45 Posted August 14, 2021 Author Share Posted August 14, 2021 1 час назад, TheBB сказал: Все логи отправки, что выше, были с паролем "открытым текстом" я делал пароли для приложений в google. а у вас версия msmtp c ssl или nossl? Quote Link to comment Share on other sites More sharing options...
TheBB Posted August 14, 2021 Share Posted August 14, 2021 Пробовал обе-две, сейчас с ssl, работало везде. Quote Link to comment Share on other sites More sharing options...
Meccep45 Posted August 25, 2021 Author Share Posted August 25, 2021 так и не смог запустить из браузера отправку теста. Quote Link to comment Share on other sites More sharing options...
Meccep45 Posted October 10, 2021 Author Share Posted October 10, 2021 мне бы поглядеть рабочие конфиги. два месяца бьюсь с этим чёрным ящиком, хоть бы ругнулось ошибкой какой. Quote Link to comment Share on other sites More sharing options...
Meccep45 Posted April 10, 2022 Author Share Posted April 10, 2022 помучился, но так она и не взлетела. поставил XMail. Quote Link to comment Share on other sites More sharing options...
