I know SFP-Gigabit combo port. But SFP id is GigabitEthernet1/0. Since I don't have a router with an sfp port at the moment, I couldn't test it and be sure.
So, can the SFP port connect to the mesh in AP mode? No need to even enter this command, right? As a result, in AP mode, all ports turn into Lan ports.
Can I include it in the mesh with fiber or ethernet cable with my sfp module?
I wrote this topic because I am very curious about the answer.
KYTECHNGAMING
As an article this command make wan to lan in router mode. Is SFP port inclueded? https://help.keenetic.com/hc/en-us/articles/115005486085-Setting-up-the-WAN-port-as-a-LAN-port-in-KN-2610-KN-1810-KN-1010-KN-1910-and-KN-3010
Does gigabit ethernet cover all? All for ISP
For example;
"ISP": { "id": "GigabitEthernet1", "index": 1, "type": "GigabitEthernet", "description": "Broadband connection", "interface-name": "ISP","port": { "id": "GigabitEthernet1/0", "index": 0, "interface-name": "0", "type": "Port", "link": "up", "auto-negotiation": "on", "speed": "100", "duplex": "full", "flow-control": "off", "transceiver": "internal", "sfp-combo": true"ISP-Vlan": { "id": "GigabitEthernet1/Vlan107", "index": 107, "type": "Vlan", "description": "Metronet TTNET", "interface-name": "ISP-Vlan",An another article said yes it is. https://help.keenetic.com/hc/en-us/articles/360000893880-Internet-connection-via-an-optical-fiber-link-SFP-module-
thanks.
Edited by yerebakan1 answer to this question
