  • 1
Странное поведение ретранслятора при подключение к его LAN порту клиента на LAN
vasek00
Имеем 37B2 и схему
Keenetic(LAN)-----(LAN)KN3010(LAN)------ПК
Момент включения ПК
[I] Sep 22 12:42:51 mtkiappd: MediaTek IAPP daemon v2.0.5 started on br0.
[I] Sep 22 12:42:52 coalagent: version 0.4.32 starting.
В 12-46 ПК отключил и в 12-49 ПК включил, где 192...101 контроллер и он же DHCP для клиентов
Порт 2 LAN - ПК, порт 3 LAN к контроллеру. Ретранслятору назначен IP - 192....253
[I] Sep 22 12:42:53 ndm: Network::InternetChecker: Internet access detected.
[I] Sep 22 12:49:05 ndm: Network::Interface::Switch: "GigabitEthernet0/1": switch link down at port 2.
[I] Sep 22 12:49:05 kernel: br0: port 1(eth2.1) entered blocking state
[I] Sep 22 12:49:05 kernel: br0: port 1(eth2.1) entered listening state
[I] Sep 22 12:49:08 ndm: Network::Interface::Switch: "GigabitEthernet0/1": switch link up at port 2 (1000FD/AN).
[I] Sep 22 12:49:08 kernel: br0: port 1(eth2.1) entered blocking state
[I] Sep 22 12:49:08 kernel: br0: port 1(eth2.1) entered listening state
[W] Sep 22 12:49:11 ndm: Dhcp::Client: DHCP server is not responding.
[I] Sep 22 12:49:11 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.3/24.
[I] Sep 22 12:49:11 mtkiappd: stopped.
[I] Sep 22 12:49:11 kernel: br0: port 1(eth2.1) entered learning state
[I] Sep 22 12:49:11 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[I] Sep 22 12:49:12 ndm: Http::Nginx: loaded SSL certificate for "*****************813.keenetic.io".
[I] Sep 22 12:49:12 ndm: Http::Nginx: loaded SSL certificate for "sk*******8.keenetic.pro".
[I] Sep 22 12:49:12 ndm: Http::Nginx: loaded SSL certificate for MWS.
[I] Sep 22 12:49:12 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Sep 22 12:49:12 ndm: Core::Session: client disconnected.
[I] Sep 22 12:49:12 ndm: Http::Manager: updated configuration.
[W] Sep 22 12:49:13 ndm: Core::Server: client disconnected.
[I] Sep 22 12:49:13 mtkiappd: MediaTek IAPP daemon v2.0.5 started on br0.
[I] Sep 22 12:49:14 kernel: br0: port 1(eth2.1) entered forwarding state
[I] Sep 22 12:49:14 kernel: br0: topology change detected, sending tcn bpdu
[I] Sep 22 12:49:15 coalagent: version 0.4.32 starting.
[I] Sep 22 12:49:18 ndhcpc: Bridge0: received OFFER for 192.168.130.253 from 192.168.130.101.
[I] Sep 22 12:49:18 ndhcpc: Bridge0: received ACK for 192.168.130.253 from 192.168.130.101 lease 36600 sec.
[I] Sep 22 12:49:18 ndm: Dhcp::Client: configuring interface Home.
[I] Sep 22 12:49:18 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.130.253/24.
[I] Sep 22 12:49:18 ndm: Dhcp::Client: obtained IP address 192.168.130.253/24.
[I] Sep 22 12:49:18 ndm: Dhcp::Client: interface "Home" is global, priority 1.
[I] Sep 22 12:49:18 ndm: Dhcp::Client: adding a default route via 192.168.130.101.
[I] Sep 22 12:49:18 ndm: Dhcp::Client: adding name server 192.168.130.101.
[I] Sep 22 12:49:18 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Sep 22 12:49:18 mtkiappd: stopped.
[I] Sep 22 12:49:19 ndm: Http::Nginx: loaded SSL certificate for "*****************813.keenetic.io".
[I] Sep 22 12:49:19 ndm: Http::Nginx: loaded SSL certificate for "sk*******8.keenetic.pro".
[I] Sep 22 12:49:19 ndm: Network::Interface::Switch: "GigabitEthernet0/1": switch link down at port 2.
[I] Sep 22 12:49:19 ndm: Http::Nginx: loaded SSL certificate for MWS.
[I] Sep 22 12:49:19 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Sep 22 12:49:19 ndm: Core::Session: client disconnected.
[I] Sep 22 12:49:20 ndm: Http::Manager: updated configuration.
[I] Sep 22 12:49:20 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Sep 22 12:49:20 kernel: br0: port 1(eth2.1) entered blocking state
[I] Sep 22 12:49:20 kernel: br0: port 1(eth2.1) entered listening state
[I] Sep 22 12:49:20 ndm: Core::Session: client disconnected.
[I] Sep 22 12:49:20 mtkiappd: MediaTek IAPP daemon v2.0.5 started on br0.
[I] Sep 22 12:49:22 ndm: Network::Interface::Switch: "GigabitEthernet0/1": switch link up at port 2 (1000FD/AN).
[I] Sep 22 12:49:22 kernel: br0: port 1(eth2.1) entered blocking state
[I] Sep 22 12:49:22 kernel: br0: port 1(eth2.1) entered listening state
[I] Sep 22 12:49:22 coalagent: version 0.4.32 starting.
[W] Sep 22 12:49:25 ndm: Dhcp::Client: DHCP server is not responding.
[I] Sep 22 12:49:25 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.3/24.
[I] Sep 22 12:49:25 mtkiappd: stopped.
[I] Sep 22 12:49:25 kernel: br0: port 1(eth2.1) entered learning state
[I] Sep 22 12:49:26 ndm: Http::Nginx: loaded SSL certificate for "*****************813.keenetic.io".
[I] Sep 22 12:49:26 ndm: Http::Nginx: loaded SSL certificate for "sk*******8.keenetic.pro".
[I] Sep 22 12:49:26 ndm: Http::Nginx: loaded SSL certificate for MWS.
[I] Sep 22 12:49:26 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Sep 22 12:49:26 ndm: Core::Session: client disconnected.
[I] Sep 22 12:49:26 ndm: Http::Manager: updated configuration.
[I] Sep 22 12:49:27 mtkiappd: MediaTek IAPP daemon v2.0.5 started on br0.
[I] Sep 22 12:49:28 kernel: br0: port 1(eth2.1) entered forwarding state
[I] Sep 22 12:49:28 kernel: br0: topology change detected, sending tcn bpdu
[W] Sep 22 12:49:28 ndm: Process: "Coala Agent" has been killed.
[I] Sep 22 12:49:30 coalagent: version 0.4.32 starting.
[I] Sep 22 12:49:32 ndhcpc: Bridge0: received OFFER for 192.168.130.253 from 192.168.130.101.
[I] Sep 22 12:49:32 ndhcpc: Bridge0: received ACK for 192.168.130.253 from 192.168.130.101 lease 36600 sec.
[I] Sep 22 12:49:32 ndm: Dhcp::Client: configuring interface Home.
[I] Sep 22 12:49:32 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.130.253/24.
[I] Sep 22 12:49:32 ndm: Dhcp::Client: obtained IP address 192.168.130.253/24.
[I] Sep 22 12:49:32 ndm: Dhcp::Client: interface "Home" is global, priority 1.
[I] Sep 22 12:49:32 ndm: Dhcp::Client: adding a default route via 192.168.130.101.
[I] Sep 22 12:49:32 ndm: Dhcp::Client: adding name server 192.168.130.101.
[I] Sep 22 12:49:32 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Sep 22 12:49:32 mtkiappd: stopped.
[I] Sep 22 12:49:33 ndm: Network::InternetChecker: Internet access detected.
[I] Sep 22 12:49:33 ndm: Http::Nginx: loaded SSL certificate for "*****************813.keenetic.io".
[I] Sep 22 12:49:33 ndm: Http::Nginx: loaded SSL certificate for "sk*******8.keenetic.pro".
[I] Sep 22 12:49:33 ndm: Http::Nginx: loaded SSL certificate for MWS.
[I] Sep 22 12:49:33 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Sep 22 12:49:33 ndm: Core::Session: client disconnected.
[I] Sep 22 12:49:34 ndm: Http::Manager: updated configuration.
[I] Sep 22 12:49:34 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Sep 22 12:49:34 ndm: Core::Session: client disconnected.
[I] Sep 22 12:49:34 mtkiappd: MediaTek IAPP daemon v2.0.5 started on br0.
[I] Sep 22 12:49:36 coalagent: version 0.4.32 starting.
Вопрос в необходимости такой "перестройки/настройки" - в данном случае аж 4 раза которая вылилась в 30сек., возможно ли авто. определить порт контроллера, а на других портах ставить команду "iseq". Как видно сам ретранслятор так же передергивается - 192.168.1.3 и потом получил 192.168.130.253. Так же видно гашения индикатора Интернета после включения ПК и через некоторое время индикатор включается.
Edited by vasek00
  • Upvote 3
2 answers to this question
40 минут назад, vasek00 сказал:
Имеем 37B2 и схему
Момент включения ПК
  Скрыть содержимое
Я вручную на все интерфейсы прописал, кроме портов для связи контроллера и экстендера.
1 час назад, MDP сказал:
Тут вопрос в другом - всего 4 цикла по 6 сек. и так же на 22 сек якобы не было интернета,
Сами 4 цикла
1 раз
2 раз
3 раз
4 раз
Edited by vasek00
