LizerGun Posted October 4, 2021 Share Posted October 4, 2021 вобщем посмотрите что происходит подскажите кто знает можно сделать как решить? exec sh / # opkg install mariadb-client-extra mariadb-server-extra Installing mariadb-client-extra (10.4.18-1a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/mariadb-client-extra_10.4.18-1a_mipsel-3.4.ipk Installing mariadb-common (1.0-2) to root... Downloading http://bin.entware.net/mipselsf-k3.4/mariadb-common_1.0-2_mipsel-3.4.ipk Installing libatomic (8.4.0-11) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libatomic_8.4.0-11_mipsel-3.4.ipk Installing libncursesw (6.2-2a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libncursesw_6.2-2a_mipsel-3.4.ipk Installing libncurses (6.2-2a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libncurses_6.2-2a_mipsel-3.4.ipk Installing libedit (20210522-3.1-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libedit_20210522-3.1-1_mipsel-3.4.ipk Installing mariadb-client-base (10.4.18-1a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/mariadb-client-base_10.4.18-1a_mipsel-3.4.ipk Installing mariadb-client (10.4.18-1a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/mariadb-client_10.4.18-1a_mipsel-3.4.ipk Installing mariadb-server-extra (10.4.18-1a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/mariadb-server-extra_10.4.18-1a_mipsel-3.4.ipk Installing libaio (0.3.112-2) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libaio_0.3.112-2_mipsel-3.4.ipk Installing resolveip (2) to root... Downloading http://bin.entware.net/mipselsf-k3.4/resolveip_2_mipsel-3.4.ipk Installing mariadb-server-base (10.4.18-1a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/mariadb-server-base_10.4.18-1a_mipsel-3.4.ipk Installing mariadb-server (10.4.18-1a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/mariadb-server_10.4.18-1a_mipsel-3.4.ipk Configuring libatomic. Configuring mariadb-common. Configuring libncursesw. Configuring libncurses. Configuring libedit. Configuring mariadb-client-base. Configuring mariadb-client. Configuring resolveip. Configuring libaio. Configuring mariadb-server-base. Configuring mariadb-server. Configuring mariadb-server-extra. Configuring mariadb-client-extra. / # mysql_install_db Could not find plugin directory. Will continue with "/opt/lib/mariadb/plugin". WARNING: The host 'KN1010' could not be looked up with /opt/bin/resolveip. This probably means that your libc libraries are not 100 % compatible with this binary MariaDB version. The MariaDB daemon, mysqld, should work normally with the exception that host name resolving will not work. This means that you should use IP addresses instead of hostnames when specifying MariaDB privileges ! Installing MariaDB/MySQL system tables in '/opt/var/lib/mysql' ... 2021-10-04 10:15:51 0 [ERROR] mysqld: Can't lock aria control file '/opt/var/lib/mysql/aria_log_control' for exclusive use, error: 11. Wil l retry for 30 seconds 2021-10-04 10:16:22 0 [ERROR] mysqld: Got error 'Could not get an exclusive lock; file is probably in use by another process' when trying to use aria control file '/opt/var/lib/mysql/aria_log_control' 2021-10-04 10:16:22 0 [ERROR] Plugin 'Aria' init function returned error. 2021-10-04 10:16:22 0 [ERROR] Plugin 'Aria' registration as a STORAGE ENGINE failed. 2021-10-04 10:16:22 0 [Warning] InnoDB: Linux Native AIO interface is not supported on this platform. Please check your OS documentation a nd install appropriate binary of InnoDB. 2021-10-04 10:16:22 0 [Warning] InnoDB: Linux Native AIO disabled. 2021-10-04 10:16:22 0 [ERROR] InnoDB: mmap(134217728 bytes) failed; errno 12 2021-10-04 10:16:22 0 [ERROR] InnoDB: Cannot allocate memory for the buffer pool 2021-10-04 10:16:22 0 [ERROR] InnoDB: Database creation was aborted with error Generic error. You may need to delete the ibdata1 file befo re trying to start up again. double free or corruption (out) 211004 10:16:22 [ERROR] mysqld got signal 6 ; This could be because you hit a bug. It is also possible that this binary or one of the libraries it was linked against is corrupt, improperly built, or misconfigured. This error can also be caused by malfunctioning hardware. To report this bug, see https://mariadb.com/kb/en/reporting-bugs We will try our best to scrape up some info that will hopefully help diagnose the problem, but since we have already crashed, something is definitely wrong and this may fail. Server version: 10.4.18-MariaDB key_buffer_size=16777216 read_buffer_size=131072 max_used_connections=0 max_threads=153 thread_count=0 It is possible that mysqld could use up to key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 351739 K bytes of memory Hope that's ok; if not, decrease some variables in the equation. Thread pointer: 0x0 Attempting backtrace. You can use the following information to find out where mysqld died. If you see no messages after this, something went terribly wrong... stack_bottom = 0x0 thread_stack 0x30000 Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted October 4, 2021 Share Posted October 4, 2021 Нужен swap, Maria хочет 357 Мбайт ОЗУ, а столько нет. А еще лучше в конфиге уменьшить число тредов и размеры буферов. Quote Link to comment Share on other sites More sharing options...
LizerGun Posted October 4, 2021 Author Share Posted October 4, 2021 10 часов назад, Le ecureuil сказал: Нужен swap, Maria хочет 357 Мбайт ОЗУ, а столько нет. А еще лучше в конфиге уменьшить число тредов и размеры буферов. А не подскажешь какие точно параметры и в каком файле поменять надО? Quote Link to comment Share on other sites More sharing options...
LizerGun Posted October 15, 2021 Author Share Posted October 15, 2021 (edited) Все решил сам надо было ставить не из дебиана а из энтвари... и патом все ок и база создается и запускается.... ааа не эт я энтварю пеереустьановил и все встало нормально....... Edited October 15, 2021 by LizerGun Quote Link to comment Share on other sites More sharing options...
