Sendto Posted April 8, 2022 Share Posted April 8, 2022 Доброго дня! На двух практически одинаковых роутерах поднят WireGuard Client, на обоих периодически возникают ошибки по памяти, один справляется (подвисает и ребутит CdcEthernet), второй уходит в оффлайн, не поднимая CdcEthernet. 1 МодельKeenetic 4G III Сервисный код 709-547-979-073-XXX Версия ОС 2.16.D.12.0-5 2 МодельKeenetic 4G III Сервисный код 712-938-255-487-XXX Версия ОС 2.16.D.12.0-4 Ошибка: [I] Apr 8 20:49:12 ndhcpc: CdcEthernet1: recieved NAK. [W] Apr 8 20:49:12 ndm: Dhcp::Client: unable to configure interface "CdcEthernet1". [W] Apr 8 20:49:13 kernel: warn_alloc_failed: 5 callbacks suppressed [W] Apr 8 20:49:13 kernel: kworker/0:2: page allocation failure: order:9, mode:0x20 [W] Apr 8 20:49:13 kernel: Call Trace: [W] Apr 8 20:49:13 kernel: [<80283278>] dump_stack+0x8/0x34 [W] Apr 8 20:49:22 kernel: [<8006a8e0>] warn_alloc_failed+0xfc/0x138 [W] Apr 8 20:49:23 kernel: [<8006ce28>] __alloc_pages_nodemask+0x374/0x6f0 [W] Apr 8 20:49:23 kernel: [<80095d70>] cache_alloc_refill+0x30c/0x64c [W] Apr 8 20:49:23 kernel: [<800961b0>] __kmalloc+0x100/0x110 [W] Apr 8 20:49:23 kernel: [<80177318>] pskb_expand_head+0xc0/0x2dc [W] Apr 8 20:49:23 kernel: [<83184870>] wg_packet_queue_free+0x39c/0x52c [wireguard] [W] Apr 8 20:49:23 kernel: [<801a621c>] nf_iterate+0xf8/0x114 [W] Apr 8 20:49:23 kernel: [<801a62c8>] nf_hook_slow+0x90/0x1c8 [W] Apr 8 20:49:23 kernel: [<801d8c1c>] ip_finish_output+0x1cc/0x3c0 [W] Apr 8 20:49:23 kernel: [<8319bfe8>] udp_tunnel_xmit_skb+0x234/0x4c8 [wireguard] [W] Apr 8 20:49:23 kernel: [<83187874>] wg_packet_receive+0x768/0xd6c [wireguard] [W] Apr 8 20:49:23 kernel: [W] Apr 8 20:49:23 kernel: Mem-Info: [W] Apr 8 20:49:23 kernel: Normal per-cpu: [W] Apr 8 20:49:23 kernel: CPU 0: hi: 18, btch: 3 usd: 10 [W] Apr 8 20:49:23 kernel: active_anon:3051 inactive_anon:31 isolated_anon:0 [W] Apr 8 20:49:23 kernel: active_file:1195 inactive_file:3072 isolated_file:0 [W] Apr 8 20:49:23 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 [W] Apr 8 20:49:23 kernel: free:2156 slab_reclaimable:178 slab_unreclaimable:4129 [W] Apr 8 20:49:23 kernel: mapped:1390 shmem:55 pagetables:95 bounce:es in swap cache [W] Apr 8 20:49:23 kernel: Swap cache stats: add 0, delete 0, find 0/0 [W] Apr 8 20:49:23 kernel: Free swap = 0kB [W] Apr 8 20:49:23 kernel: Total swap = 0kB [W] Apr 8 20:49:23 kernel: SLAB: Unable to allocate memory on node 0 (gfp=0x20) [W] Apr 8 20:49:23 kernel: cache: size-262144, object size: 262144, order: 6 [W] Apr 8 20:49:23 kernel: node 0: slabs: 1/1, objs: 1/1, free: 0 [W] Apr 8 20:49:23 kernel: kworker/0:3: page allocation failure: order:6, mode:0x20 [W] Apr 8 20:49:23 kernel: Call Trace: [W] Apr 8 20:49:23 kernel: [<80283278>] dump_stack+0x8/0x34 [W] Apr 8 20:49:23 kernel: [<8006a8e0>] warn_alloc_failed+0xfc/0x138 [W] Apr 8 20:49:23 kernel: [<8006ce28>] __alloc_pages_nodemask+0x374/0x6f0 [W] Apr 8 20:49:23 kernel: [<80095d70>] cache_alloc_refill+0x30c/0x64c [W] Apr 8 20:49:23 kernel: [<800961b0>] __kmalloc+0x100/0x110 [W] Apr 8 20:49:23 kernel: [<80177318>] pskb_expand_head+0xc0/0x2dc [W] Apr 8 20:49:23 kernel: [<83184870>] wg_packet_queue_free+0x39c/0x52c [wireguard] [W] Apr 8 20:49:23 kernel: <...> [W] Apr 8 20:50:50 kernel: Mem-Info: [W] Apr 8 20:50:50 kernel: Normal per-cpu: [W] Apr 8 20:50:50 kernel: CPU 0: hi: 18, btch: 3 usd: 0 [W] Apr 8 20:50:50 kernel: active_anon:3003 inactive_anon:29 isolated_anon:0 [W] Apr 8 20:50:50 kernel: active_file:1120 inactive_file:2182 isolated_file:22 [W] Apr 8 20:50:50 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 [W] Apr 8 20:50:50 kernel: free:1101 slab_reclaimable:169 slab_unreclaimable:6174 [W] Apr 8 20:50:50 kernel: mapped:530 shmem:54 pagetables:91 bounce:0 [W] Apr 8 20:50:50 kernel: Normal free:4404kB min:4096kB low:5120kB high:6144kB active_anon:12012kB inactive_anon:116kB active_file:4480kB inactive_file:8728kB unevictable:0kB isolated(anon):0kB isolated(file):88kB present:65024kB mlocked:0kB dirty:0kB writeback:0kB mapped:2120kB shmem:216kB slab_reclaimable:676kB slab_unreclaimable:24696kB kernel_stack:648kB pagetables:364kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no [W] Apr 8 20:50:50 kernel: lowmem_reserve[]: 0 0 [W] Apr 8 20:50:50 kernel: Normal: 265*4kB 358*8kB 18*16kB 0*32kB 1*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 4404kB [W] Apr 8 20:50:50 kernel: 3385 total pagecache pages [W] Apr 8 20:50:50 kernel: 0 pages in swap cache [W] Apr 8 20:50:50 kernel: Swap cache stats: add 0, delete 0, find 0/0 [W] Apr 8 20:50:50 kernel: Free swap = 0kB [W] Apr 8 20:50:50 kernel: Total swap = 0kB [W] Apr 8 20:50:50 kernel: SLAB: Unable to allocate memory on node 0 (gfp=0x20) [W] Apr 8 20:50:50 kernel: cache: size-32768, object size: 32768, order: 3 [W] Apr 8 20:50:50 kernel: node 0: slabs: 51/51, objs: 51/51, free: 0 [I] Apr 8 20:51:15 ndm: Network::NeighbourListener: retrying to enable wilddumping mode. [I] Apr 8 20:51:27 ndm: Network::Interface::WebCaller::Zte: "CdcEthernet1": connection established. Большая просьба, если это возможно, исправить данную ошибку, очевидно, что это некорректная работа с памятью, возможно переполнение. И ещё просьба, портировать в прошивку ОС 2.16 команду ping-check restart , чтоб хотя бы работал ребут при потере связи. На данный момент в этой прошивке ситуация такая: (config)> interface Wireguard0 ping-check restart CdcEthernet1Command::Base error[7405600]: no such command: restart. Заранее благодарю! Quote Link to comment Share on other sites More sharing options...
mesb Posted April 9, 2022 Share Posted April 9, 2022 А вы где для 4ж 3 взяли прошивку 2.16.D.12.0-5? Ато один из наших только 2.16.D.12.0-4 видит. По теме да, что такое есть с ваергвардом, ловлю на первой ультра при разрыве связи основного канала например тоже. Ну и тема пониже тоже про это похоже. Quote Link to comment Share on other sites More sharing options...
Sendto Posted April 10, 2022 Author Share Posted April 10, 2022 17 часов назад, mesb сказал: А вы где для 4ж 3 взяли прошивку 2.16.D.12.0-5? Ато один из наших только 2.16.D.12.0-4 видит. У них разные ревизии по железу, а и б вроде. Тот, что с 5 портами - у него 2.16.D.12.0-4, а у которого 2 порта - 2.16.D.12.0-5. Сама накатилась 17 часов назад, mesb сказал: По теме да, что такое есть с ваергвардом, ловлю на первой ультра при разрыве связи основного канала например тоже. Ну и тема пониже тоже про это похоже. Хорошо, что я не один такой ) Больше шансов, что исправят )) Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted April 16, 2022 Share Posted April 16, 2022 Проверяйте на 2.16.D.12.0-6. Quote Link to comment Share on other sites More sharing options...
