Nick N. Posted June 8, 2022 Posted June 8, 2022 Hi Viva (KN-1910), 2TB extrenal USB drive NTFS, 3.7.4 I have acronis backup file, 350Gb. I trying: 1. Copy to router with external HDD - very SLOW, after 150GB writing speed down to 1-2 MB/s 2. Open TIB file from router with external HDD in Acronis Tru Image not working 3. Copy to PC with external HDD is ok, writing speed is stable, 30-40 MB/s 4. Open TIB file from PC with external HDD via network in Acronis Tru Image working fine Small size files (less then 150GB) is working fine. Check please All test maked from Notebook, external HDD was connected to Keenetic Viva or PC. Viva did not working stable with large files Quote
0 Nick N. Posted June 9, 2022 Author Posted June 9, 2022 (edited) (delete) Edited June 9, 2022 by Nick N. Quote
0 Nick N. Posted June 9, 2022 Author Posted June 9, 2022 Find in log: tntfs error (device sda1, pid 30929): ntfs_write_end(): Write failed (orig copied 2664, len 4096, actual copied 0). Quote
0 Nick N. Posted June 12, 2022 Author Posted June 12, 2022 Big files not copied via SMB to any hdd. I testes another HDD on 500GB and exFat 1 Quote
0 bora ozver Posted July 12, 2022 Posted July 12, 2022 can you resolve your issue with using exFat? 1 Quote
0 Nick N. Posted July 13, 2022 Author Posted July 13, 2022 No. ExFat working as NTFS Tested on two HDDs, 500GB and 2TB Quote
0 Alem Posted July 25, 2022 Posted July 25, 2022 (edited) I have KN2510 Router/modem.Seagate Backup Plus 3.5" 6TB USB 3.0 device working very well Edited August 1, 2022 by Alem Quote
0 PasKy Posted July 26, 2022 Posted July 26, 2022 generally formatting the disks in NTFS does not allow you to write files larger than 4 Gb, format the disk connected to the modem / router and make it GPT, you will see that all limits will disappear, as well as errors. It is recommended to use GPT formatted disks for capacities over 2 Tb, otherwise use Linux ext4 formatting. (for everyone) Quote
0 PasKy Posted July 26, 2022 Posted July 26, 2022 P.S. The disk over 2 Tb GPT is mandatory, otherwise NTFS will not show you beyond 2 Tb if you do not make it GPT, but it also works great on 1 Tb disks. (Less than 1 Really makes little sense but if you don't want to use Linux ext4 that's fine anyway!) Quote
0 Nick N. Posted August 1, 2022 Author Posted August 1, 2022 (edited) В 27.07.2022 в 02:27, PasKy сказал: P.S. The disk over 2 Tb GPT is mandatory, otherwise NTFS will not show you beyond 2 Tb if you do not make it GPT, but it also works great on 1 Tb disks. (Less than 1 Really makes little sense but if you don't want to use Linux ext4 that's fine anyway!) I have GPT disk and NTFS partition. From PC all working fine, from router working fine for files less then 100GB Edited August 1, 2022 by Nick N. Quote
0 bora ozver Posted August 1, 2022 Posted August 1, 2022 On 7/27/2022 at 1:55 AM, PasKy said: generally formatting the disks in NTFS does not allow you to write files larger than 4 Gb, format the disk connected to the modem / router and make it GPT, you will see that all limits will disappear, as well as errors. It is recommended to use GPT formatted disks for capacities over 2 Tb, otherwise use Linux ext4 formatting. (for everyone) FAT32 does not allow you to write files larger than 4 Gb, it's not NTFS Quote
0 PasKy Posted August 1, 2022 Posted August 1, 2022 1 hour ago, bora ozver said: FAT32 does not allow you to write files larger than 4 Gb, it's not NTFS 100Gb? I hope you are not using Windows 32, otherwise it is not explained, because these are the specifications of NTFS on Windows 64. Quote
0 PasKy Posted August 1, 2022 Posted August 1, 2022 (edited) 1 hour ago, bora ozver said: FAT32 does not allow you to write files larger than 4 Gb, it's not NTFS https://www.seagate.com/support/kb/how-to-format-your-hard-drive-220151en/ https://community.wd.com/c/wd-forum-italiano/15 Edited August 1, 2022 by PasKy Quote
Nick N.
Hi
12 answers to this question
