Привет! Есть Viva (KN-1910) и Ultra (KN-1810) на последних stable прошивках с обновлённым entware. Поставил man, но на любую команду с man получаю Segmentation fault. Я такой один, или проблема известная и есть решение? Спасибо!
~ # strace /opt/bin/man exec
execve("/opt/bin/man", ["/opt/bin/man", "exec"], 0x7ffe8374 /* 17 vars */) = 0
brk(NULL)                               = 0x587000
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x773d7000
access("/opt/etc/ld.so.preload", R_OK)  = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/opt/lib/tls/libmandb-2.10.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/opt/lib/tls", 0x7fd789e0)      = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/opt/lib/libmandb-2.10.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/opt/lib", {st_mode=S_IFDIR|0755, st_size=16384, ...}) = 0
openat(AT_FDCWD, "/opt/lib/man-db/tls/libmandb-2.10.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/opt/lib/man-db/tls", 0x7fd789e0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/opt/lib/man-db/libmandb-2.10.2.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\240\17\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=20708, ...}) = 0
mmap2(NULL, 83920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x77394000
mprotect(0x77399000, 61440, PROT_NONE)  = 0
mmap2(0x773a8000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x773a8000
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libman-2.10.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/opt/lib/man-db/libman-2.10.2.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\360a\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=265688, ...}) = 0
mmap2(NULL, 311024, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x77348000
mprotect(0x77383000, 65536, PROT_NONE)  = 0
mmap2(0x77393000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b000) = 0x77393000
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libgdbm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\260\33\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=63280, ...}) = 0
mmap2(NULL, 123968, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x77329000
mprotect(0x77338000, 61440, PROT_NONE)  = 0
mmap2(0x77347000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x77347000
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\260\27\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=89556, ...}) = 0
mmap2(NULL, 149488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x77304000
mprotect(0x77319000, 61440, PROT_NONE)  = 0
mmap2(0x77328000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x77328000
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libpipeline.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0000\30\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=55284, ...}) = 0
mmap2(NULL, 115632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x772e7000
mprotect(0x772f3000, 65536, PROT_NONE)  = 0
mmap2(0x77303000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x77303000
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libiconv.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\260\16\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=934324, ...}) = 0
mmap2(NULL, 989632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x771f5000
mprotect(0x772d6000, 65536, PROT_NONE)  = 0
mmap2(0x772e6000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe1000) = 0x772e6000
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\20(\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=94236, ...}) = 0
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x773d5000
mmap2(NULL, 152704, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x771cf000
mprotect(0x771e5000, 61440, PROT_NONE)  = 0
mmap2(0x771f4000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x771f4000
mprotect(0x7fd79000, 4096, PROT_READ|PROT_WRITE|PROT_EXEC|PROT_GROWSDOWN) = 0
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\240T\0\0004\0\0\0"..., 512) = 512
_llseek(3, 6340, [6340], SEEK_SET)      = 0
read(3, "\4\0\0\0\20\0\0\0\1\0\0\0GNU\0\0\0\0\0\3\0\0\0\2\0\0\0\0\0\0\0", 32) = 32
fstat64(3, {st_mode=S_IFREG|0755, st_size=123056, ...}) = 0
mmap2(NULL, 185392, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x771a1000
mprotect(0x771bc000, 61440, PROT_NONE)  = 0
mmap2(0x771cb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x771cb000
mmap2(0x771cd000, 5168, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x771cd000
close(3)                                = 0
openat(AT_FDCWD, "/opt/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0T\315\1\0004\0\0\0"..., 512) = 512
_llseek(3, 26116, [26116], SEEK_SET)    = 0
fstat64(3, {st_mode=S_IFREG|0755, st_size=1672960, ...}) = 0
mmap2(NULL, 1646736, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7700e000
mprotect(0x77188000, 61440, PROT_NONE)  = 0
mmap2(0x77197000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x179000) = 0x77197000
mmap2(0x7719e000, 8336, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7719e000
close(3)                                = 0
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x773d3000
set_thread_area(0x773da4a0)             = 0
mprotect(0x77197000, 16384, PROT_READ)  = 0
mprotect(0x771cb000, 4096, PROT_READ)   = 0
mprotect(0x773dc000, 4096, PROT_READ)   = 0
set_tid_address(0x773d3078)             = 13940
set_robust_list(0x773d3080, 12)         = 0
rt_sigaction(SIGRTMIN, {sa_handler=0x771a5e68, sa_mask=[], sa_flags=SA_SIGINFO}, NULL, 16) = 0
rt_sigaction(SIGRT_1, {sa_handler=0x771a5f6c, sa_mask=[], sa_flags=SA_RESTART|SA_SIGINFO}, NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 16) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=2147483647}) = 0
brk(0x5a8000)                           = 0x5a8000
umask(022)                              = 022
openat(AT_FDCWD, "/opt/usr/lib/locale/locale-archive", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=2931760, ...}) = 0
mmap2(NULL, 2097152, PROT_READ, MAP_PRIVATE, 3, 0) = 0x76e0e000
close(3)                                = 0
fcntl64(0, F_GETFD)                     = 0
fcntl64(1, F_GETFD)                     = 0
fcntl64(2, F_GETFD)                     = 0
rt_sigaction(SIGHUP, NULL, {sa_handler=SIG_DFL, sa_mask=[RT_73 RT_74 RT_79 RT_80 RT_87], sa_flags=0}, 16) = 0
rt_sigaction(SIGHUP, {sa_handler=0x7734e75c, sa_mask=[], sa_flags=0}, {sa_handler=SIG_DFL, sa_mask=[RT_73 RT_74 RT_79 RT_80 RT_87], sa_flags=0}, 16) = 0
rt_sigaction(SIGINT, NULL, {sa_handler=SIG_DFL, sa_mask=[RT_73 RT_74 RT_79 RT_80 RT_87], sa_flags=0}, 16) = 0
rt_sigaction(SIGINT, {sa_handler=0x7734e75c, sa_mask=[], sa_flags=0}, {sa_handler=SIG_DFL, sa_mask=[RT_73 RT_74 RT_79 RT_80 RT_87], sa_flags=0}, 16) = 0
rt_sigaction(SIGTERM, NULL, {sa_handler=SIG_DFL, sa_mask=[RT_73 RT_74 RT_79 RT_80 RT_87], sa_flags=0}, 16) = 0
rt_sigaction(SIGTERM, {sa_handler=0x7734e75c, sa_mask=[], sa_flags=0}, {sa_handler=SIG_DFL, sa_mask=[RT_73 RT_74 RT_79 RT_80 RT_87], sa_flags=0}, 16) = 0
openat(AT_FDCWD, "/opt/root/.manpath", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/opt/etc/man_db.conf", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0600, st_size=4349, ...}) = 0
read(3, "# \n#\n# This file is used by the "..., 4096) = 4096
read(3, " the terminal actually being use"..., 4096) = 253
read(3, "", 4096)                       = 0
close(3)                                = 0
ioctl(1, TCGETS, {B38400 opost isig icanon echo ...}) = 0
ioctl(0, TCGETS, {B38400 opost isig icanon echo ...}) = 0
getpid()                                = 13940
stat64("/opt/sbin/less", 0x7fd79360)    = -1 ENOENT (No such file or directory)
stat64("/opt/bin/less", {st_mode=S_IFREG|0755, st_size=190376, ...}) = 0
stat64("/opt/share/man", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat64("/opt/usr/man", 0x7fd792e8)      = -1 ENOENT (No such file or directory)
stat64("/opt/usr/sbin/man", 0x7fd792e8) = -1 ENOENT (No such file or directory)
stat64("/opt/usr/share/man", 0x7fd792e8) = -1 ENOENT (No such file or directory)
stat64("/opt/usr/sbin/share/man", 0x7fd792e8) = -1 ENOENT (No such file or directory)
stat64("/opt/usr/bin/man", 0x7fd792e8)  = -1 ENOENT (No such file or directory)
stat64("/opt/usr/bin/share/man", 0x7fd792e8) = -1 ENOENT (No such file or directory)
stat64("/usr/man", 0x7fd792e8)          = -1 ENOENT (No such file or directory)
stat64("/usr/sbin/man", 0x7fd792e8)     = -1 ENOENT (No such file or directory)
stat64("/usr/share/man", 0x7fd792e8)    = -1 ENOENT (No such file or directory)
stat64("/usr/sbin/share/man", 0x7fd792e8) = -1 ENOENT (No such file or directory)
stat64("/usr/bin/man", 0x7fd792e8)      = -1 ENOENT (No such file or directory)
stat64("/usr/bin/share/man", 0x7fd792e8) = -1 ENOENT (No such file or directory)
stat64("/man", 0x7fd792e8)              = -1 ENOENT (No such file or directory)
stat64("/sbin/man", 0x7fd792e8)         = -1 ENOENT (No such file or directory)
stat64("/share/man", 0x7fd792e8)        = -1 ENOENT (No such file or directory)
stat64("/sbin/share/man", 0x7fd792e8)   = -1 ENOENT (No such file or directory)
stat64("/bin/man", 0x7fd792e8)          = -1 ENOENT (No such file or directory)
stat64("/bin/share/man", 0x7fd792e8)    = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/opt/share/man", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_CLOEXEC|O_DIRECTORY) = 3
fstat64(3, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
getdents64(3, 0x589108 /* 10 entries */, 32768) = 240
getdents64(3, 0x589108 /* 0 entries */, 32768) = 0
close(3)                                = 0
lstat64("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/opt/share", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/opt/share/man", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=NULL} ---
+++ killed by SIGSEGV +++
Segmentation fault
Edited by PoliceMan
