Posted
Hello, recently i bought keenetic hero dsl and using it in router mode with my fttb fiber internet. I also have my operators IPTV called Turkcell TV+ , there are some people that can use it without any issues but unfortunately i cant. My main issue is when STB is in standby mode i guess it looses VLAN ID 103 connection and it says check network connection and doesnt reconnects automaticly so i have to unplug and replug the STB's power to reboot it.
Second issue is channel transition speed. Normally if i use it with isp's router i can switch channels in less than half of second but with keenetic it takes 4.5 seconds to change a channel.
I saw some people which uses some openwrt router and uses that iptv box without any issue and also they shared an tutorial to setup it in openwrt but i cant setup in that way with keenetic os. I tried step 4 with igmpproxy installed from opkg but seems like doesnt work and also tried 5.
Im sharing that tutorial below, maybe you guys know how to adapt in keenetic os
Here is tutorial
Turkcell TV+ Routed mode with OpenWRT
1) NETWORK - INTERFACES
Devices - br-lan - Configure - Advanced - Enable IGMP snooping: SELECTED (Save&Apply)
Devices - Add device config - type:vlan802.1q, base device: wan, vlanid:103, enable ip6:OFF, MAC: wan interfaces mac adress but 1 more in base 16. (Save&Apply)
Example: if wan mac is xx:xx:xx:xx:xx:09 then use  xx:xx:xx:xx:xx:0A for iptv
Interfaces - Add new interface
Name:iptv, dhcp-client, device: (software vlan) wan.103 - Create interface
Advanced: Use default gateway: OFF, Use DNS servers advertised by peer: OFF
Firewall settings: Create/assign - custom:iptv
(Save&Apply)
2) NETWORK - FIREWALL - General
Zone:lan EDIT - Allow forward to destination zones: SELECT wan+iptv (Save&Apply)
Zone:iptv EDIT - input:accept, output:accept, forward:reject, Masquerading:SELECTED, MSS clamping:SELECTED (Save&Apply)
3) STATUS - ROUTING - In IPv4 Neighbours Table copy Interface (iptv.103) Router ip adress.
NETWORK - ROUTING - Add:
interface:iptv, target: 172.31.128.0/19, gateway:ROUTERIP
interface:iptv, target: 176.43.0.0/24, gateway:ROUTERIP
interface:iptv, target: 176.235.0.0/20, gateway:ROUTERIP
interface:iptv, target: 10.31.0.0/16, gateway:ROUTERIP
(Save&Apply)
4) System - Software - Update Lists
Install igmpproxy
vi /etc/config/igmpproxy
config igmpproxy
option quickleave 1
config phyint
option network iptv
option zone iptv
option direction upstream
list altnet 0.0.0.0/0
config phyint
option network lan
option zone lan
option direction downstream
5) SYSTEM - Time Sync - NTP server candidates remove all time servers and add this:
cpentp.superonline.net
1 answer to this question
Posted (edited)
Also normally on ISP's ZTE router connections looks like this
Pppoe is normal internet and dhcp is iptv
Edited by techgenius
