Роутер Keenetic Extra KN-1713. Периодически теряет соединение. Установлен Entware. Из пакетов только aria2 и ca-certificates. Прошивки как 3.9.4, так и 4.0 Alpha 12. Это всё таки провайдер чудит?
[I] Mar 8 16:43:42 ndm: Network::Interface::Switch: "FastEthernet0/0": switch link down at port 0.
[I] Mar 8 16:43:42 ndm: Network::Interface::Base: "FastEthernet0/0": "ethernet" changed "link" layer state "running" to "pending".
[I] Mar 8 16:43:42 ndm: Network::Interface::Base: "FastEthernet0/Vlan2": "ethernet" changed "link" layer state "running" to "pending".
[I] Mar 8 16:43:42 ndm: Dns::Manager: name server 1.1.1.1, domain (default) deleted.
[I] Mar 8 16:43:42 ndm: Dns::Manager: name server 8.8.8.8, domain (default) deleted.
[I] Mar 8 16:43:42 ndm: Dns::Manager: name server 77.88.8.8, domain (default) deleted.
[I] Mar 8 16:43:42 ndhcpc: FastEthernet0/Vlan2: sending RELEASE for 10.186.0.130 to 10.186.0.1.
[W] Mar 8 16:43:42 ndm: Dhcp::Client: DHCP server is not responding.
[I] Mar 8 16:43:42 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[I] Mar 8 16:43:42 ndm: Network::Interface::Ip: "FastEthernet0/Vlan2": IP address cleared.
[I] Mar 8 16:43:42 ndhcpc: FastEthernet0/Vlan2: NDM DHCP client stopped (exit status 0).
[I] Mar 8 16:43:42 nimproxy: NDM IGMP/Multicast proxy stopped (exit status: 0).
[I] Mar 8 16:43:42 ndm: Ip6::Dhcp::Client: "FastEthernet0/Vlan2": state "stopped".
[I] Mar 8 16:43:42 ndm: Ip6::Dhcp::Client: "FastEthernet0/Vlan2": state "unbound".
[I] Mar 8 16:43:43 ndm: Http::Nginx: loaded SSL certificate for "bd327c740ffaf5a73788c3e4.keenetic.io".
[I] Mar 8 16:43:43 ndm: Http::Nginx: loaded SSL certificate for "mauzervt.keenetic.name".
[I] Mar 8 16:43:44 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Mar 8 16:43:44 ndm: Core::Session: client disconnected.
[I] Mar 8 16:43:44 ndm: Http::Manager: updated configuration.
[I] Mar 8 16:43:44 nimproxy: NDM IGMP/Multicast Proxy, v0.0.36.
[E] Mar 8 16:43:47 coalagent: [SecLayer_OnSend] Coala_Send: Network unreachable.
[E] Mar 8 16:44:02 coalagent: Core::Syslog: last message repeated 4 times.
[I] Mar 8 16:45:00 ndm: Network::Interface::Switch: "FastEthernet0/0": switch link up at port 0 (100FD/AN).
[I] Mar 8 16:45:00 ndm: Network::Interface::Base: "FastEthernet0/0": "ethernet" changed "link" layer state "pending" to "running".
[I] Mar 8 16:45:00 ndm: Network::Interface::Base: "FastEthernet0/Vlan2": "ethernet" changed "link" layer state "pending" to "running".
[I] Mar 8 16:45:00 ndm: Dns::Manager: name server 1.1.1.1 added, domain (default).
[I] Mar 8 16:45:00 ndm: Dns::Manager: name server 8.8.8.8 added, domain (default).
[I] Mar 8 16:45:00 ndm: Dns::Manager: name server 77.88.8.8 added, domain (default).
[E] Mar 8 16:45:02 ndnproxy: failed to connect to server [0] 77.88.8.8#53: network unreachable.
[E] Mar 8 16:45:02 ndnproxy: Core::Syslog: last message repeated 3 times.
[I] Mar 8 16:45:02 ndhcpc: FastEthernet0/Vlan2: NDM DHCP Client, v3.2.51.
[I] Mar 8 16:45:02 ndhcpc: FastEthernet0/Vlan2: created PID file "/var/run/ndhcpc-eth2.2.pid".
[E] Mar 8 16:45:03 ndnproxy: failed to connect to server [0] 77.88.8.8#53: network unreachable.
[I] Mar 8 16:45:03 ndm: Ip6::Dhcp::Client: "FastEthernet0/Vlan2": state "started".
[I] Mar 8 16:45:03 ndhcpc: FastEthernet0/Vlan2: received OFFER for 10.186.0.130 from 10.186.0.1.
[I] Mar 8 16:45:03 ndhcpc: FastEthernet0/Vlan2: received ACK for 10.186.0.130 from 10.186.0.1 lease 3600 sec.
[I] Mar 8 16:45:03 ndm: Dhcp::Client: configuring interface ISP.
[I] Mar 8 16:45:03 ndm: Network::Interface::Ip: "FastEthernet0/Vlan2": IP address is 10.186.0.130/17.
[I] Mar 8 16:45:03 ndm: Dhcp::Client: obtained IP address 10.186.0.130/17.
[I] Mar 8 16:45:03 ndm: Dhcp::Client: interface "ISP" is global, priority 700.
[I] Mar 8 16:45:03 ndm: Dhcp::Client: adding a default route via 10.186.0.1.
[I] Mar 8 16:45:03 ndm: Dhcp::Client: adding a host route to name server 37.17.118.133.
[I] Mar 8 16:45:03 ndm: Dhcp::Client: adding name server 37.17.118.133.
[I] Mar 8 16:45:03 ndm: Dns::Manager: name server 37.17.118.133 added, domain (default).
[I] Mar 8 16:45:03 ndm: Dhcp::Client: adding a host route to name server 37.17.118.150.
[I] Mar 8 16:45:03 ndm: Dhcp::Client: adding name server 37.17.118.150.
[I] Mar 8 16:45:03 ndm: Dns::Manager: name server 37.17.118.150 added, domain (default).
[I] Mar 8 16:45:03 ndm: Network::Interface::Base: "FastEthernet0/Vlan2": "dhcp-client" changed "ipv4" layer state "pending" to "running".
[I] Mar 8 16:45:03 nimproxy: NDM IGMP/Multicast proxy stopped (exit status: 0).
[I] Mar 8 16:45:04 ndm: Dns::InterfaceSpecific: "FastEthernet0/Vlan2": adding a host route to name server 1.1.1.1 (via 10.186.0.1).
[I] Mar 8 16:45:04 ndm: Dns::InterfaceSpecific: "FastEthernet0/Vlan2": adding a host route to name server 8.8.8.8 (via 10.186.0.1).
[I] Mar 8 16:45:04 ndm: Dns::InterfaceSpecific: "FastEthernet0/Vlan2": adding a host route to name server 77.88.8.8 (via 10.186.0.1).
[I] Mar 8 16:45:04 ndm: Network::InternetChecker: Internet access detected.
Pavel Darey
log (1).txt
Edited by Pavel DareyСпрятал скриншот под спойлер.
2 answers to this question
