Илья Ганжин Posted May 24 Share Posted May 24 Добрый вечер, помогите пожалуйста перенести диск с Entware на новый роутер KN-1811. После выбора накопителя в лог сыпятся ошибки: Скрытый текст [I] May 24 22:35:15 ndm: Core::Syslog: the system log has been cleared. [I] May 24 22:35:20 ndm: Opkg::Manager: disk is set to: 727c2672-6d6f-40e1-9ea7-7b40e482b877:/. [I] May 24 22:35:20 ndm: Opkg::Manager: init script reset to default: /opt/etc/initrc. [I] May 24 22:35:20 ndm: Core::System::StartupConfig: saving (http/rci). [I] May 24 22:35:20 kernel: EXT4-fs (sda1): re-mounted. Opts: (null) [I] May 24 22:35:20 ndm: Opkg::Manager: /tmp/mnt/727c2672-6d6f-40e1-9ea7-7b40e482b877 mounted to /tmp/mnt/727c2672-6d6f-40e1-9ea7-7b40e482b877. [I] May 24 22:35:20 ndm: Opkg::Manager: /tmp/mnt/727c2672-6d6f-40e1-9ea7-7b40e482b877 mounted to /opt/. [I] May 24 22:35:20 ndm: Opkg::Manager: /tmp/mnt/727c2672-6d6f-40e1-9ea7-7b40e482b877 initialized. [E] May 24 22:35:20 ndm: Opkg::Manager: invalid initrc "/opt/etc/initrc": no such file or directory, trying /opt/etc/init.d/. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S10cron: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S20dbus: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S51dropbear: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S60netdata: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S79fcgi: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S79php7-fastcgi: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S80mosquitto: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S80nginx: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/S99hass: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/rc.func: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/init.d/rc.unslung: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/ndm/usb.d/S100cryfs: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [E] May 24 22:35:20 ndm: Opkg::Manager: process /opt/etc/ndm/neighbour.d/010-neighbour.sh: failed to start. [C] May 24 22:35:20 ndm: Process: "Opkg shell": unable to start (unable to execute a process: exec format error). [E] May 24 22:35:20 ndm: Process: failed to start "Opkg shell". [I] May 24 22:35:21 ndm: Core::System::StartupConfig: configuration saved. Хотелось бы оживить и перенести существующий Entware во внутреннюю память, если это возможно. Quote Link to comment Share on other sites More sharing options...
zyxmon Posted May 24 Share Posted May 24 Старый роутер наверняка с архитектурой mips*, а новый aarch64. Ставьте все заново. Настройки старые подойдут. Quote Link to comment Share on other sites More sharing options...
MDP Posted May 24 Share Posted May 24 2 минуты назад, zyxmon сказал: Старый роутер наверняка с архитектурой mips*, а новый aarch64. Ставьте все заново. Настройки старые подойдут. А докер есть интересно в ентваре? Для мощных устройств думаю пора докер из коробки придумать? Quote Link to comment Share on other sites More sharing options...
zyxmon Posted May 24 Share Posted May 24 6 минут назад, MDP сказал: А докер есть интересно в ентваре? Offtopic 100%! Наличие докера зависит от кое чего другого..... Quote Link to comment Share on other sites More sharing options...
MDP Posted May 24 Share Posted May 24 8 минут назад, zyxmon сказал: Offtopic 100%! Наличие докера зависит от кое чего другого..... ... просто спросил)))) ...ну нет так нет. Так автор поста просто на мысль подтолкнул. Офтопик 100%... извиняюсь. Quote Link to comment Share on other sites More sharing options...
Илья Ганжин Posted May 25 Author Share Posted May 25 11 час назад, zyxmon сказал: Старый роутер наверняка с архитектурой mips*, а новый aarch64. Ставьте все заново. Настройки старые подойдут. Подскажите пожалуйста как можно перенести все установленные пакеты и их настройки? Quote Link to comment Share on other sites More sharing options...
zyxmon Posted May 25 Share Posted May 25 список установленных пакетов - `opkg list-installed`. Настройки, которые Вы редактировали, в файлах, в '/opt/etc/....' - вспоминайте, какие меняли руками сами. 1 Quote Link to comment Share on other sites More sharing options...
