40B1 контроль интерфейсов (в частности wireguard)
vasek00
Posted (edited)
1. есть "schedule schedule0" на 2.4 с 00-00 до 06-30 и на 5 schedule1 с 00-00 до 06-00
2. поднятые WG и профили для них, WG1/2/3 вообще отключены.
KN2710 на 4.0 Beta 1
[I] Jun  6 00:00:00 kernel: br0: port 3(ra0) entered disabled state
[I] Jun  6 00:00:00 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": "schedule" changed "conf" layer state "running" to "pending".
[I] Jun  6 00:00:00 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Jun  6 00:00:00 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Jun  6 00:00:00 kernel: wireguard: Wireguard0: peer "bmXOC....o=" (19) (162.159....) destroyed
[I] Jun  6 00:00:00 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Jun  6 00:00:00 kernel: wireguard: Wireguard1: peer "2Zxar....s=" (20) (92......) destroyed
[I] Jun  6 00:00:00 kernel: wireguard: Wireguard2: peer "dvgFt....M=" (21) (46.......) destroyed
[I] Jun  6 00:00:00 kernel: wireguard: Wireguard3: peer "Z8cLP....Y=" (22) (10.16....) destroyed
[I] Jun  6 00:00:00 kernel: wireguard: Wireguard3: peer "y09iO....A=" (23) (10.16....) destroyed
[I] Jun  6 00:00:00 ndm: Network::Interface::Ip: "Wireguard4": removing default route via Wireguard4.
[I] Jun  6 00:00:00 ndm: Network::Interface::Ip6: "Wireguard4": removing default route via Wireguard4.
[I] Jun  6 00:00:00 kernel: wireguard: Wireguard4: peer "BUp7V....0=" (24) (ххх.ххх.ххх.ххх:хххх) destroyed
[I] Jun  6 00:00:00 ndm: Network::Interface::Base: "Wireguard4": "wireguard" changed "link" layer state "running" to "pending".
... далее тишина про WG вообще
[I] Jun  6 06:00:00 kernel: IPv6: ADDRCONF(NETDEV_UP): rai0: link is not ready
[I] Jun  6 06:00:00 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): rai0: link becomes ready
[I] Jun  6 06:00:00 kernel: br0: port 4(rai0) entered blocking state
[I] Jun  6 06:00:00 ndm: Network::Interface::Base: "WifiMaster1/AccessPoint0": "schedule" changed "conf" layer state "pending" to "running".
[I] Jun  6 06:00:00 kernel: br0: port 4(rai0) entered forwarding state
[I] Jun  6 06:00:00 kernel: wireguard: Wireguard0: peer "bmXO.....o=" (25) created
[I] Jun  6 06:00:00 ndm: Wireguard::Interface: "Wireguard0": added a host route to peer "bmXO....o=" (162.159.....) via PPPoE0 (PPPoE0).
[I] Jun  6 06:00:00 kernel: wireguard: Wireguard1: peer "2Zxar......s=" (26) created
[I] Jun  6 06:00:00 ndm: Wireguard::Interface: "Wireguard1": added a host route to peer "2Zxa....s=" (92.........) via PPPoE0 (PPPoE0).
[I] Jun  6 06:00:00 kernel: wireguard: Wireguard2: peer "dvgFt......M=" (27) created
[I] Jun  6 06:00:00 ndm: Wireguard::Interface: "Wireguard2": added a host route to peer "dvgFt...M=" (46.........) via PPPoE0 (PPPoE0).
[I] Jun  6 06:00:00 kernel: wireguard: Wireguard3: peer "Z8cLP......Y=" (28) created
[I] Jun  6 06:00:00 ndm: Wireguard::Interface: "Wireguard3": added a host route to peer "Z8cLP...Y=" (10.16......) via PPPoE0 (PPPoE0).
[I] Jun  6 06:00:00 kernel: wireguard: Wireguard3: peer "y09iO......A=" (29) created
[I] Jun  6 06:00:00 ndm: Wireguard::Interface: "Wireguard3": added a host route to peer "y09iO....A=" (10.16.....) via PPPoE0 (PPPoE0).
[I] Jun  6 06:00:00 kernel: wireguard: Wireguard4: peer "BUp7V......0=" (30) created
[I] Jun  6 06:00:00 ndm: Wireguard::Interface: "Wireguard4": added a host route to peer "BUp7V....0=" (ххх.ххх.ххх.ххх) via PPPoE0 (PPPoE0).
[I] Jun  6 06:00:00 ndm: Network::Interface::Base: "WifiMaster1/AccessPoint0": "ethernet" changed "link" layer state "pending" to "running".
[I] Jun  6 06:00:03 ndm: Network::Interface::Base: "Wireguard4": "wireguard" changed "link" layer state "pending" to "running".
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip: "Wireguard4": interface "Wireguard4" is global, priority 1820.
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip: "Wireguard4": adding default route via Wireguard4.
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip6: "Wireguard4": interface "Wireguard4" is global, priority 1820.
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip6: "Wireguard4": adding default route via Wireguard4.
[I] Jun  6 06:00:03 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 43574.
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 43574.
[I] Jun  6 06:00:03 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Jun  6 06:30:00 kernel: IPv6: ADDRCONF(NETDEV_UP): ra0: link is not ready
[I] Jun  6 06:30:00 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): ra0: link becomes ready
[I] Jun  6 06:30:00 kernel: br0: port 3(ra0) entered blocking state
[I] Jun  6 06:30:00 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": "schedule" changed "conf" layer state "pending" to "running".
[I] Jun  6 06:30:00 kernel: br0: port 3(ra0) entered forwarding state
[I] Jun  6 06:30:00 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": "ethernet" changed "link" layer state "pending" to "running".
[I] Jun  6 06:30:55 ndm: Wireguard::Interface: "Wireguard1": peer "2Zxar.....s=" went offline, update configuration.
[I] Jun  6 06:34:01 ndm: Wireguard::Interface: "Wireguard1": peer "2Zxar.....s=" went offline, update configuration.
[I] Jun  6 06:37:06 ndm: Wireguard::Interface: "Wireguard1": peer "2Zxar...s=" went offline, update configuration.
... и т.д.
[I] Jun  7 00:00:00 kernel: br0: port 3(ra0) entered disabled state
[I] Jun  7 00:00:00 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": "schedule" changed "conf" layer state "running" to "pending".
[I] Jun  7 00:00:00 kernel: br0: port 4(rai0) entered disabled state
[I] Jun  7 00:00:00 ndm: Network::Interface::Base: "WifiMaster1/AccessPoint0": "schedule" changed "conf" layer state "running" to "pending".
[I] Jun  7 00:00:00 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Jun  7 00:00:00 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
... все повторяется
Edited by vasek00
0 answers to this question
