Keenetic Giga 1010. После обновления прошивки 4.0 с beta 1 на beta 2 перестал соединяться pptp vpn. Т.к. 4.0b1 не сохранил, пришлось откатиться на стабильную 3.9.8
В журнале следующее:
[I] Jun 13 08:43:21 pptp[18175]: Plugin pptp.so loaded.
[I] Jun 13 08:43:21 pptp[18175]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jun 13 08:43:21 pptp[18175]: pppd 2.4.4-4 started by root, uid 0
[I] Jun 13 08:43:22 ndm: Network::Interface::EndpointTracker: "PPTP0": added a host route to xxx.xxx.xxx.xxx via UsbLte0 (UsbLte0).
[I] Jun 13 08:43:22 pppd_PPTP0: IP: xxx.xxx.xxx.xxx
[I] Jun 13 08:43:22 pppd_PPTP0: local bind: 100.98.56.32
[I] Jun 13 08:43:22 pppd_PPTP0: control connection
[I] Jun 13 08:43:22 pppd_PPTP0: unix_sock
[I] Jun 13 08:43:22 pppd_PPTP0: enable echo requests (30:3)
[I] Jun 13 08:43:22 pppd_PPTP0: Sent control packet type is 1 'Start-Control-Connection-Request'
[I] Jun 13 08:43:22 pppd_PPTP0: Received Start Control Connection Reply
[I] Jun 13 08:43:22 pppd_PPTP0: Client connection established.
[I] Jun 13 08:43:23 pppd_PPTP0: Sent control packet type is 7 'Outgoing-Call-Request'
[I] Jun 13 08:43:23 pppd_PPTP0: Received Outgoing Call Reply.
[I] Jun 13 08:43:23 pppd_PPTP0: Outgoing call established (call ID 638, peer's call ID 435).
[I] Jun 13 08:43:23 pppd_PPTP0: Using interface ppp1
[I] Jun 13 08:43:23 pppd_PPTP0: Connect: ppp1 <--> pptp (xxx.xxx.xxx.xxx)
[I] Jun 13 08:43:47 pppd_PPTP0: Received Stop Control Connection Request.
[I] Jun 13 08:43:47 pppd_PPTP0: Sent control packet type is 4 'Stop-Control-Connection-Reply'
[I] Jun 13 08:43:47 pppd_PPTP0: Closing connection (shutdown)
[I] Jun 13 08:43:47 pppd_PPTP0: Sent control packet type is 12 'Call-Clear-Request'
[I] Jun 13 08:43:47 pppd_PPTP0: Closing connection (call state)
[I] Jun 13 08:43:47 pppd_PPTP0: Modem hangup
[I] Jun 13 08:43:47 pppd_PPTP0: Connection terminated.
[I] Jun 13 08:43:47 pppd_PPTP0: Exit.
[E] Jun 13 08:43:47 ndm: Service: "PPTP0": unexpectedly stopped.
Со стороны сервера вижу только следующее:
[I] Jun 13 08:43:15 ppp-pptp: pptp: new connection from xxx.xxx.xxx.xxx
[I] Jun 13 08:43:16 ppp-pptp: ppp7:: connect: ppp7 <--> pptp(xxx.xxx.xxx.xxx)
[I] Jun 13 08:43:40 ppp-pptp: ppp7:: pptp: disconnected
Eugene A
Edited by Eugene A[I] Jun 13 08:43:16 ppp-pptp: ppp7:: connect: ppp7 <--> pptp(xxx.xxx.xxx.xxx)
0 answers to this question
