Только вот вопрос на созданный (выделенный из LAN портов) WAN порт для второго провайдера GigabitEthernet0/Vlan9, не получилось добавить - ошибка, при выборе основного на PPPoE все ОК
(config)> interface Wireguard4 wireguard peer 5+Pf......8= connect via
Usage template:
connect [via {via}]
Choose:
via GigabitEthernet1
via ISP
via WifiMaster0/AccessPoint3
via WifiMaster0/AccessPoint1
via WifiMaster0/AccessPoint6
via WifiMaster0/AccessPoint0
via AccessPoint
via WifiMaster0/AccessPoint5
via WifiMaster0/AccessPoint4
via WifiMaster0/AccessPoint2
via WifiMaster0/WifiStation0
via WifiMaster1/AccessPoint5
via WifiMaster1/AccessPoint3
via WifiMaster1/AccessPoint1
via WifiMaster1/AccessPoint2
via WifiMaster1/AccessPoint0
via AccessPoint_5G
via WifiMaster1/AccessPoint6
via WifiMaster1/AccessPoint4
via WifiMaster1/WifiStation0
via GigabitEthernet0/Vlan1
via GigabitEthernet0/Vlan2
via GigabitEthernet0/Vlan3
via GigabitEthernet0/Vlan9 **************** второй провайдер
via AsixEthernet0
via Bridge0
via Home
via Bridge1
via HomeSmart
via PPPoE0
via OpenVPN0
via Wireguard0
via Wireguard1
via Wireguard2
via Wireguard3
via Wireguard4
via ZeroTier0
(config)> interface Wireguard4 wireguard peer 5+Pf.....D8= connect via GigabitEthernet0/Vlan9
Io::Netlink error[268239225]: system failed [0xcffd0179], got an error response: no such process.
(config)> interface Wireguard4 wireguard peer 5+Pf.....D8= connect via Inet-2
Command::Base error[7405602]: via: argument parse error.
(config)>
(config)>
(config)> interface Wireguard4 wireguard peer 5+Pf....D8= connect via PPPoE0
(config)> sys
system - maintenance functions
(config)> system
caption - set caption template
clock - change system clock settings
configuration - manage system configuration
country - set system country
Core::System::StartupConfig: Saving (cli).
(config)>
interface GigabitEthernet0/Vlan9
description Inet-2
security-level public
ip address dhcp
ip dhcp client hostname P-KN
ip dhcp client dns-routes
ip mtu 1500
ip global 65469
ip no name-servers
ipv6 no name-servers
up
interface GigabitEthernet0/3
rename 4
role inet for GigabitEthernet0/Vlan9
switchport mode access
switchport access vlan 9
up
interface PPPoE0
description RT
role inet
[I] Dec 9 11:59:08 ndm: Wireguard::Interface: "Wireguard4": set peer "5+Pfg.......D8=" connect via "GigabitEthernet0/Vlan9".
[I] Dec 9 11:59:08 kernel: wireguard: Wireguard4: peer "5+Pfg........DD8=" (9) (185.177.xxx.xxxx:5060) destroyed
[I] Dec 9 11:59:08 ndm: Network::Interface::Base: "Wireguard4": "wireguard" changed "link" layer state "running" to "pending".
[I] Dec 9 11:59:08 ndm: Network::Interface::Ip: "Wireguard4": removing default route via Wireguard4.
[I] Dec 9 11:59:08 ndm: Network::Interface::Ip6: "Wireguard4": removing default route via Wireguard4.
[I] Dec 9 11:59:08 ndm: Wireguard::Interface: "Wireguard4": "5+Pfg.......D8=": via interface is not ready, standby.
[I] Dec 9 11:59:31 kernel: wireguard: Wireguard0: retrying handshake with peer "bmXO.......fgyo=" (8) (162.159.xxx.xxx:xxxx) because we stopped hearing back after 15 seconds
[E] Dec 9 11:59:32 ndm: Command::Base: argument parse error.
[I] Dec 9 11:59:42 ndm: Network::Interface::L3Base: "Wireguard4": global priority unchanged.
[I] Dec 9 11:59:42 ndm: Wireguard::Interface: "Wireguard4": set peer "5+Pfg........DD8=" connect via "GigabitEthernet0/Vlan9".
[I] Dec 9 11:59:42 kernel: wireguard: Wireguard4: peer "5+Pfgs2q2......DD8=" (10) created
[I] Dec 9 11:59:42 kernel: wireguard: Wireguard4: peer "5+Pfgs2q.......D8=" (10) (185.177.xxx.xxx:5060) destroyed
[I] Dec 9 11:59:42 ndm: Wireguard::Interface: "Wireguard4": "5+Pfgs2q......D8=": via interface is not ready, standby.
[I] Dec 9 11:59:42 kernel: wireguard: Wireguard4: invalid handshake response from 185.177.xxx.xxx:5060
[I] Dec 9 12:00:00 kernel: wireguard: Wireguard4: peer "5+Pfgs2q2......D8=" (11) created
[I] Dec 9 12:00:00 ndm: Network::Interface::L3Base: "Wireguard4": global priority unchanged.
[I] Dec 9 12:00:00 ndm: Wireguard::Interface: "Wireguard4": set peer "5+Pfgs.....D8=" connect via "PPPoE0".
[I] Dec 9 12:00:00 ndm: Network::Interface::EndpointTracker: "Wireguard4": "5+Pfgs......DD8=": remote endpoint is "185.177.xxx.xxx".
[I] Dec 9 12:00:00 ndm: Network::Interface::EndpointTracker: "Wireguard4": "5+Pfgs......D8=": connecting via "PPPoE0" (PPPoE0).
[I] Dec 9 12:00:00 ndm: Network::Interface::EndpointTracker: "Wireguard4": "5+Pfgs......D8=": local endpoint is "1xx.xx.xxx.200".
[I] Dec 9 12:00:05 ndm: Network::Interface::Base: "Wireguard4": "wireguard" changed "link" layer state "pending" to "running".
[I] Dec 9 12:00:05 ndm: Network::Interface::Ip: "Wireguard4": interface "Wireguard4" is global, priority 65293.
[I] Dec 9 12:00:05 ndm: Network::Interface::Ip: "Wireguard4": adding default route via Wireguard4.
[I] Dec 9 12:00:05 ndm: Network::Interface::Ip6: "Wireguard4": interface "Wireguard4" is global, priority 65293.
[I] Dec 9 12:00:05 ndm: Network::Interface::Ip6: "Wireguard4": adding default route via Wireguard4.
OpenVPN все ОК
interface OpenVPN0
description Anti
role misc
ip mtu 1500
ip tcp adjust-mss pmtu
ip no name-servers
openvpn accept-routes
openvpn connect via GigabitEthernet0/Vlan9
down
vasek00
Спасибо за реализацию, проверка на Peak
(config)> interface Wireguard4 wireguard peer 5+Pf......8= connect via Usage template: connect [via {via}] Choose: via GigabitEthernet1 via ISP via WifiMaster0/AccessPoint3 via WifiMaster0/AccessPoint1 via WifiMaster0/AccessPoint6 via WifiMaster0/AccessPoint0 via AccessPoint via WifiMaster0/AccessPoint5 via WifiMaster0/AccessPoint4 via WifiMaster0/AccessPoint2 via WifiMaster0/WifiStation0 via WifiMaster1/AccessPoint5 via WifiMaster1/AccessPoint3 via WifiMaster1/AccessPoint1 via WifiMaster1/AccessPoint2 via WifiMaster1/AccessPoint0 via AccessPoint_5G via WifiMaster1/AccessPoint6 via WifiMaster1/AccessPoint4 via WifiMaster1/WifiStation0 via GigabitEthernet0/Vlan1 via GigabitEthernet0/Vlan2 via GigabitEthernet0/Vlan3 via GigabitEthernet0/Vlan9 **************** второй провайдер via AsixEthernet0 via Bridge0 via Home via Bridge1 via HomeSmart via PPPoE0 via OpenVPN0 via Wireguard0 via Wireguard1 via Wireguard2 via Wireguard3 via Wireguard4 via ZeroTier0 (config)> interface Wireguard4 wireguard peer 5+Pf.....D8= connect via GigabitEthernet0/Vlan9 Io::Netlink error[268239225]: system failed [0xcffd0179], got an error response: no such process. (config)> interface Wireguard4 wireguard peer 5+Pf.....D8= connect via Inet-2 Command::Base error[7405602]: via: argument parse error. (config)> (config)> (config)> interface Wireguard4 wireguard peer 5+Pf....D8= connect via PPPoE0 (config)> sys system - maintenance functions (config)> system caption - set caption template clock - change system clock settings configuration - manage system configuration country - set system country (config)> system configuration save Core::System::StartupConfig: Saving (cli). (config)> interface GigabitEthernet0/Vlan9 description Inet-2 security-level public ip address dhcp ip dhcp client hostname P-KN ip dhcp client dns-routes ip mtu 1500 ip global 65469 ip no name-servers ipv6 no name-servers up ! interface GigabitEthernet0/3 rename 4 role inet for GigabitEthernet0/Vlan9 switchport mode access switchport access vlan 9 up ! ! interface PPPoE0 description RT role inet ... [I] Dec 9 11:59:08 ndm: Wireguard::Interface: "Wireguard4": set peer "5+Pfg.......D8=" connect via "GigabitEthernet0/Vlan9". [I] Dec 9 11:59:08 kernel: wireguard: Wireguard4: peer "5+Pfg........DD8=" (9) (185.177.xxx.xxxx:5060) destroyed [I] Dec 9 11:59:08 ndm: Network::Interface::Base: "Wireguard4": "wireguard" changed "link" layer state "running" to "pending". [I] Dec 9 11:59:08 ndm: Network::Interface::Ip: "Wireguard4": removing default route via Wireguard4. [I] Dec 9 11:59:08 ndm: Network::Interface::Ip6: "Wireguard4": removing default route via Wireguard4. [I] Dec 9 11:59:08 ndm: Wireguard::Interface: "Wireguard4": "5+Pfg.......D8=": via interface is not ready, standby. [I] Dec 9 11:59:31 kernel: wireguard: Wireguard0: retrying handshake with peer "bmXO.......fgyo=" (8) (162.159.xxx.xxx:xxxx) because we stopped hearing back after 15 seconds [E] Dec 9 11:59:32 ndm: Command::Base: argument parse error. [I] Dec 9 11:59:42 ndm: Network::Interface::L3Base: "Wireguard4": global priority unchanged. [I] Dec 9 11:59:42 ndm: Wireguard::Interface: "Wireguard4": set peer "5+Pfg........DD8=" connect via "GigabitEthernet0/Vlan9". [I] Dec 9 11:59:42 kernel: wireguard: Wireguard4: peer "5+Pfgs2q2......DD8=" (10) created [I] Dec 9 11:59:42 kernel: wireguard: Wireguard4: peer "5+Pfgs2q.......D8=" (10) (185.177.xxx.xxx:5060) destroyed [I] Dec 9 11:59:42 ndm: Wireguard::Interface: "Wireguard4": "5+Pfgs2q......D8=": via interface is not ready, standby. [I] Dec 9 11:59:42 kernel: wireguard: Wireguard4: invalid handshake response from 185.177.xxx.xxx:5060 [I] Dec 9 12:00:00 kernel: wireguard: Wireguard4: peer "5+Pfgs2q2......D8=" (11) created [I] Dec 9 12:00:00 ndm: Network::Interface::L3Base: "Wireguard4": global priority unchanged. [I] Dec 9 12:00:00 ndm: Wireguard::Interface: "Wireguard4": set peer "5+Pfgs.....D8=" connect via "PPPoE0". [I] Dec 9 12:00:00 ndm: Network::Interface::EndpointTracker: "Wireguard4": "5+Pfgs......DD8=": remote endpoint is "185.177.xxx.xxx". [I] Dec 9 12:00:00 ndm: Network::Interface::EndpointTracker: "Wireguard4": "5+Pfgs......D8=": connecting via "PPPoE0" (PPPoE0). [I] Dec 9 12:00:00 ndm: Network::Interface::EndpointTracker: "Wireguard4": "5+Pfgs......D8=": local endpoint is "1xx.xx.xxx.200". [I] Dec 9 12:00:05 ndm: Network::Interface::Base: "Wireguard4": "wireguard" changed "link" layer state "pending" to "running". [I] Dec 9 12:00:05 ndm: Network::Interface::Ip: "Wireguard4": interface "Wireguard4" is global, priority 65293. [I] Dec 9 12:00:05 ndm: Network::Interface::Ip: "Wireguard4": adding default route via Wireguard4. [I] Dec 9 12:00:05 ndm: Network::Interface::Ip6: "Wireguard4": interface "Wireguard4" is global, priority 65293. [I] Dec 9 12:00:05 ndm: Network::Interface::Ip6: "Wireguard4": adding default route via Wireguard4.
OpenVPN все ОК
interface OpenVPN0 description Anti role misc security-level public ip dhcp client dns-routes ip mtu 1500 ip tcp adjust-mss pmtu ip no name-servers ipv6 no name-servers openvpn accept-routes openvpn connect via GigabitEthernet0/Vlan9 down
14 answers to this question
