Потеря соединения в одно и то же время
Stan1s
Сообщения из журнала:
[I] Jan 13 00:11:52 pppd[2269]: LCP terminated by peer
[I] Jan 13 00:11:52 pppd[2269]: Connect time 1440.0 minutes.
[I] Jan 13 00:11:52 pppd[2269]: Sent 1052664922 bytes, received 4216753814 bytes.
[I] Jan 13 00:11:52 pppd[2269]: Modem hangup
[I] Jan 13 00:11:52 pppd[2269]: Connection terminated.
[I] Jan 13 00:11:52 pppd[2269]: Sent PADT
[I] Jan 13 00:11:52 ndm: Network::Interface::Base: "PPPoE0": "ip" changed "ipv4" layer state "running" to "disabled".
[I] Jan 13 00:11:52 ndm: Network::Interface::Ip: "PPPoE0": IP address cleared.
[I] Jan 13 00:11:52 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "running" to "connecting".
[I] Jan 13 00:11:52 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[E] Jan 13 00:11:52 coalagent: [SecLayer_OnSend] Coala_Send: Network unreachable.
[I] Jan 13 00:11:53 ndm: Http::Nginx: loaded SSL certificate for "f2a7376014a595b437d48794.keenetic.io".
[I] Jan 13 00:11:53 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Jan 13 00:11:53 ndm: Core::Session: client disconnected.
[I] Jan 13 00:11:53 pppd[2269]: Exit.
[E] Jan 13 00:11:53 ndm: Service: "PPPoE0": unexpectedly stopped.
[I] Jan 13 00:11:53 ndm: Network::Interface::Ip: "PPPoE0": removing default route via PPPoE0.
[I] Jan 13 00:11:53 ndm: Network::Interface::Base: "PPPoE0": interface is up.
[I] Jan 13 00:11:53 ndm: Http::Manager: updated configuration.
[I] Jan 13 00:11:55 pppd[12595]: Plugin rp-pppoe.so loaded.
[I] Jan 13 00:11:55 pppd[12595]: pppd 2.4.4-4 started by root, uid 0
[I] Jan 13 00:11:55 pppd[12595]: Found unterminated session: 507:1c:9c:8c:1f:d3:8c
[I] Jan 13 00:11:55 pppd[12595]: Sent PADT
[I] Jan 13 00:11:56 pppd[12595]: PPP session is 507
[I] Jan 13 00:11:56 pppd[12595]: Using interface ppp0
[I] Jan 13 00:11:56 pppd[12595]: Connect: ppp0 <--> eth3
[I] Jan 13 00:11:56 pppd[12595]: CHAP authentication succeeded
[I] Jan 13 00:11:56 pppd[12595]: peer from calling number 1C:9C:8C:1F:D3:8C authorized
[I] Jan 13 00:11:56 pppd[12595]: local  IP address 91.107.33.164
[I] Jan 13 00:11:56 pppd[12595]: remote IP address 95.128.240.0
[I] Jan 13 00:11:56 pppd[12595]: primary   DNS address 95.128.246.2
[I] Jan 13 00:11:56 pppd[12595]: secondary DNS address 95.128.243.2
[I] Jan 13 00:11:56 ndm: Network::Interface::Base: "PPPoE0": interface is up.
[I] Jan 13 00:11:56 ndm: Network::Interface::Ip: "PPPoE0": interface "PPPoE0" is global, priority 32767.
[I] Jan 13 00:11:56 ndm: Network::Interface::Ip: "PPPoE0": adding default route via PPPoE0.
[I] Jan 13 00:11:56 ndm: Dns::InterfaceSpecific: adding name server 95.128.246.2.
[I] Jan 13 00:11:56 ndm: Dns::InterfaceSpecific: "PPPoE0": name server 95.128.246.2 added, domain (default).
[I] Jan 13 00:11:56 ndm: Dns::InterfaceSpecific: adding name server 95.128.243.2.
[I] Jan 13 00:11:56 ndm: Dns::InterfaceSpecific: "PPPoE0": name server 95.128.243.2 added, domain (default).
[I] Jan 13 00:11:56 ndm: Network::Interface::Ip: "PPPoE0": IP address is 91.107.33.164/32.
[I] Jan 13 00:11:56 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "connecting" to "running".
[I] Jan 13 00:11:56 ndm: Dns::Manager: name server 95.128.246.2 added, domain (default).
[I] Jan 13 00:11:56 ndm: Dns::Manager: name server 95.128.243.2 added, domain (default).
[I] Jan 13 00:11:56 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 13 00:11:57 ndm: Http::Nginx: loaded SSL certificate for "f2a7376014a595b437d48794.keenetic.io".
[I] Jan 13 00:11:57 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Jan 13 00:11:57 ndm: Core::Session: client disconnected.
[I] Jan 13 00:11:57 ndm: Http::Manager: updated configuration.
С чем это связано и можно ли это исправить?
Edited by Stan1s
4 answers to this question
11 минуту назад, Stan1s сказал:
У вас тип соединения pppoe. В этом случае разрыв сессии в одно и то же время это нормально.
Соединение восстанавливается автоматически? Если да, то делать ничего не нужно.
2 минуты назад, Илья Картавенко сказал:
Да, восстанавливается, понял вас, спасибо
9 минут назад, Stan1s сказал:
Единственное, что вы можете сделать - перезагрузить роутер где-нибудь ночью, что бы процесс преподключения проходил незаметно для всех и ни кому не мешал
2 часа назад, Stan1s сказал:
1440 / 60 = 24 часа.
Понаблюдайте за логом, если такое каждые 24 то это "проделки" провайдере.
