Бьюсь с подключением микрокомпьютера Orange PI Zero к Giga (KN-1010) EAEU (Service tag 210-829-077-051-737). Пробовал и с последней стабильной версией прошивки, и 4.1 Beta 3.
По спецификации у "Апельсинки" - Onboard WiFiXR819, IEEE 802.11 b/g/n. lshw выдаёт
"Апельсинка" раньше прекрасно работала с Keenetic Omni II, потом лежала без дела. Сейчас достал и безуспешно бодаюсь.
Список сетей видит:
nmcli d wifi list
IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY
kv405 (Guest) Infra 2 65 Mbit/s 100 ▂▄▆█ WPA2
kv405 2.4GHz Infra 2 65 Mbit/s 100 ▂▄▆█ WPA2
но при попытке соединиться выдаёт "Error: Connection activation failed: (7) Secrets were required, but not provided."
Jan 31 22:33:12 orangepizero NetworkManager[596]: <info> [1706729592.3548] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0142] keyfile: add connection /run/NetworkManager/system-connections/kv405 2.4GHz 12.nmconnection (423a545b-a8ce-4800-aee3-ab649b6e5d32,"kv405 2.4GHz 12")
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0255] device (wlan0): Activation: starting connection 'kv405 2.4GHz 12' (423a545b-a8ce-4800-aee3-ab649b6e5d32)
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0375] settings-connection[0x25868f8,423a545b-a8ce-4800-aee3-ab649b6e5d32]: write: successfully commited (keyfile: update /etc/NetworkManager/system-connections/kv405 2.4GHz 12.nmconnection (423a545b-a8ce-4800-aee3-ab649b6e5d32,"kv405 2.4GHz 12") and rename from "/run/NetworkManager/system-connections/kv405 2.4GHz 12.nmconnection")
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0383] audit: op="connection-add-activate" uuid="423a545b-a8ce-4800-aee3-ab649b6e5d32" name="kv405 2.4GHz 12" pid=2743 uid=0 result="success"
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0597] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0657] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0753] device (wlan0): state change: config -> need-auth (reason 'no-secrets', sys-iface-state: 'managed')
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.0915] device (wlan0): state change: need-auth -> config (reason 'none', sys-iface-state: 'managed')
Jan 31 22:34:24 orangepizero NetworkManager[596]: <info> [1706729664.2352] device (wlan0): new IWD device state is connecting
Jan 31 22:34:24 orangepizero kernel: wlan0: authenticate with 52:ff:20:50:59:fa
Jan 31 22:34:24 orangepizero kernel: wlan0: send auth to 52:ff:20:50:59:fa (try 1/3)
Jan 31 22:34:24 orangepizero kernel: wlan0: authenticated
Jan 31 22:34:24 orangepizero kernel: wlan0: associate with 52:ff:20:50:59:fa (try 1/3)
Jan 31 22:34:24 orangepizero kernel: wlan0: RX AssocResp from 52:ff:20:50:59:fa (capab=0x1011 status=0 aid=5)
Jan 31 22:34:24 orangepizero kernel: wlan0: associated
Jan 31 22:34:24 orangepizero kernel: wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 52:ff:20:50:59:fa
Jan 31 22:34:24 orangepizero kernel: xradio TXRX-WRN: received frame has no key status
Jan 31 22:34:24 orangepizero kernel: xradio TXRX-WRN: dropped received frame
Jan 31 22:34:29 orangepizero iwd[567]: 4-Way handshake failed for ifindex: 3, reason: 15
Jan 31 22:34:29 orangepizero kernel: wlan0: deauthenticating from 52:ff:20:50:59:fa by local choice (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
Jan 31 22:34:29 orangepizero kernel: xradio WSM-WRN: Issue unjoin command(TX).
Jan 31 22:34:29 orangepizero NetworkManager[596]: <error> [1706729669.2641] device (wlan0): Activation: (wifi) Network.Connect failed: GDBus.Error:net.connman.iwd.Failed: Operation failed
Jan 31 22:34:29 orangepizero NetworkManager[596]: <info> [1706729669.2751] device (wlan0): new IWD device state is disconnected
Jan 31 22:34:29 orangepizero NetworkManager[596]: <info> [1706729669.2775] device (wlan0): state change: config -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Jan 31 22:34:29 orangepizero NetworkManager[596]: <warn> [1706729669.2890] device (wlan0): Activation: failed for connection 'kv405 2.4GHz 12'
Jan 31 22:34:29 orangepizero NetworkManager[596]: <info> [1706729669.3236] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
В логе роутера:
Jan 31 22:52:56 ndhcps sending ACK of 192.168.100.60 to 8c:aa:b5:d6:91:79.
Jan 31 22:53:01 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) had associated (has FT caps).
Jan 31 22:53:01 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) RSN IE differs in key handshaking (msg 2 of 4-way).
Jan 31 22:53:04 ndm Core::Syslog: last message repeated 3 times.
Jan 31 22:53:04 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(8c:aa:b5:d6:91:79) had disassociated by STA (reason: due to inactivity).
Jan 31 22:53:05 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) RSN IE differs in key handshaking (msg 2 of 4-way).
Jan 31 22:53:06 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) had deauthenticated by STA (reason: PTK 4-way handshake timeout).
В процессе танцев с бубном пару раз удавалось подключиться, но только если создать новый сегмент (временную WiFi сеть), но систему не уловил.
Мощность урезал вплоть до 10%, включал-выключал опции, выключал 5 ггц совсем, оставлял только b режим - не помогает. Положил апельсинку рядом с роутером, не помогает тоже. По советам из интернета добавил в Network Manager опцию wifi.scan-rand-mac-address=no - не помогает.
Alexandre Bougakov
По спецификации у "Апельсинки" - Onboard WiFi XR819, IEEE 802.11 b/g/n. lshw выдаёт
description: Wireless interface physical id: 6 logical name: wlan0 serial: 12:42:e8:02:49:d9 capabilities: ethernet physical wireless configuration: broadcast=yes driver=xradio_wlan driverversion=5.4.45-sunxi firmware=N/A link=no multicast=yes wireless=IEEE 802.11
Список сетей видит:
nmcli d wifi list IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY kv405 (Guest) Infra 2 65 Mbit/s 100 ▂▄▆█ WPA2 kv405 2.4GHz Infra 2 65 Mbit/s 100 ▂▄▆█ WPA2
В логе роутера:
Jan 31 22:52:56 ndhcps sending ACK of 192.168.100.60 to 8c:aa:b5:d6:91:79. Jan 31 22:53:01 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) had associated (has FT caps). Jan 31 22:53:01 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) RSN IE differs in key handshaking (msg 2 of 4-way). Jan 31 22:53:04 ndm Core::Syslog: last message repeated 3 times. Jan 31 22:53:04 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(8c:aa:b5:d6:91:79) had disassociated by STA (reason: due to inactivity). Jan 31 22:53:05 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) RSN IE differs in key handshaking (msg 2 of 4-way). Jan 31 22:53:06 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(12:42:e8:02:49:d9) had deauthenticated by STA (reason: PTK 4-way handshake timeout).
self-test_KN-1010_stable_4.00.C.7.0-0_router_2024-01-31T23-00-16.976Z.txt
20 answers to this question
