Добрый день. При использовании DDNS от dedyn.io не обновляется адрес. Видимо из-за того, что после неудачной попытки обновления нет повторных попыток (rescheduling?) после появления доступа. Если что-то изменить в настройках, и заново сохранить - первоначально работает нормально.
[I] Feb 9 20:39:12 ndm: Network::Interface::Base: "PPPoE0": interface is up.
[I] Feb 9 20:39:12 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "connecting" to "running".
[I] Feb 9 20:39:12 ndm: Network::Interface::Ip: "PPPoE0": interface "PPPoE0" is global, priority 33117.
[I] Feb 9 20:39:12 ndm: Network::Interface::Ip: "PPPoE0": adding default route via PPPoE0.
[W] Feb 9 20:39:12 ndm: Dns::InterfaceSpecific: name server 212.1.**.** is ignored.
[I] Feb 9 20:39:13 ndm: Network::Interface::Base: "PPPoE0": "ip" changed "ipv4" layer state "disabled" to "running".
[I] Feb 9 20:39:13 ndm: Network::Interface::Ip: "PPPoE0": IP address is **.**.**.**/32.
[E] Feb 9 20:39:13 ndm: Dns::Resolver: failed to resolve "update.dedyn.io": interrupted.
[I] Feb 9 20:39:13 ndm: Core::Schedule::Manager: raised action "stop" by "schedule0".
[I] Feb 9 20:39:13 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com".
[I] Feb 9 20:39:13 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com".
[I] Feb 9 20:39:13 ndm: Dns::Secure::DohConfigurator: "System": skip service "https://cloudflare-dns.com/dns-query", wait for bootstrap.
[I] Feb 9 20:39:13 ndm: Network::InterfaceFlusher: flushed IPv4 PPPoE0 conntrack and route cache.
[I] Feb 9 20:39:14 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Feb 9 20:39:14 ndm: Core::Session: client disconnected.
[I] Feb 9 20:39:14 ndm: Http::Manager: updated configuration.
[E] Feb 9 20:39:31 ndm: Dns::Resolver: failed to resolve "update.dedyn.io": timed out.
[E] Feb 9 20:39:31 ndm: Io::Http::Client: [196] failed to resolve "update.dedyn.io".
[W] Feb 9 20:39:31 ndm: DynDns::Profile: "_WEBADMIN": IPv4 update failure (network error).
[W] Feb 9 20:39:31 ndm: DynDns::Profile: "_WEBADMIN": IPv6 update disabled (disabled).
[E] Feb 9 20:39:31 ndm: DynDns::Profile: "_WEBADMIN": retry in 600000 ms.
[I] Feb 9 20:39:31 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com".
[I] Feb 9 20:39:31 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com".
[I] Feb 9 20:39:31 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap.
[I] Feb 9 20:39:41 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com".
[I] Feb 9 20:39:41 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com".
[I] Feb 9 20:39:41 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap.
[I] Feb 9 20:39:51 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com".
[I] Feb 9 20:39:51 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com".
[I] Feb 9 20:39:51 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap.
[I] Feb 9 20:39:53 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(24:0a:64:52:**:**) had associated.
[I] Feb 9 20:39:53 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(24:0a:64:52:**:**) set key done in WPA2/WPA2PSK.
[I] Feb 9 20:39:53 ndhcps: DHCPREQUEST received (STATE_INIT) for 192.168.1.44 from 24:0a:64:52:**:**.
[I] Feb 9 20:39:54 ndhcps: sending ACK of 192.168.1.44 to 24:0a:64:52:**:**.
[I] Feb 9 20:40:01 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com".
[I] Feb 9 20:40:01 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com".
[I] Feb 9 20:40:01 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap.
[I] Feb 9 20:40:11 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com".
[I] Feb 9 20:40:11 ndm: Dns::Manager: updating DNS-over-HTTPS servers addresses.
[I] Feb 9 20:40:11 ndm: Dns::Secure::DohConfigurator: "System": using "cloudflare-dns.com:443:104.16.248.249,104.16.249.249" as upstream.
[I] Feb 9 20:40:40 ndm: Network::InternetChecker: Internet access detected.
[I] Feb 9 20:40:58 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(24:0a:64:52:**:**) had disassociated by STA (reason: STA is leaving or has left BSS).
AnteC
[I] Feb 9 20:39:12 ndm: Network::Interface::Base: "PPPoE0": interface is up. [I] Feb 9 20:39:12 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "connecting" to "running". [I] Feb 9 20:39:12 ndm: Network::Interface::Base: "PPPoE0": interface is up. [I] Feb 9 20:39:12 ndm: Network::Interface::Ip: "PPPoE0": interface "PPPoE0" is global, priority 33117. [I] Feb 9 20:39:12 ndm: Network::Interface::Ip: "PPPoE0": adding default route via PPPoE0. [W] Feb 9 20:39:12 ndm: Dns::InterfaceSpecific: name server 212.1.**.** is ignored. [W] Feb 9 20:39:12 ndm: Dns::InterfaceSpecific: name server 212.1.**.** is ignored. [I] Feb 9 20:39:13 ndm: Network::Interface::Base: "PPPoE0": "ip" changed "ipv4" layer state "disabled" to "running". [I] Feb 9 20:39:13 ndm: Network::Interface::Ip: "PPPoE0": IP address is **.**.**.**/32. [E] Feb 9 20:39:13 ndm: Dns::Resolver: failed to resolve "update.dedyn.io": interrupted. [I] Feb 9 20:39:13 ndm: Core::Schedule::Manager: raised action "stop" by "schedule0". [I] Feb 9 20:39:13 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:39:13 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com". [I] Feb 9 20:39:13 ndm: Dns::Secure::DohConfigurator: "System": skip service "https://cloudflare-dns.com/dns-query", wait for bootstrap. [I] Feb 9 20:39:13 ndm: Network::InterfaceFlusher: flushed IPv4 PPPoE0 conntrack and route cache. [I] Feb 9 20:39:13 ndm: Core::Schedule::Manager: raised action "stop" by "schedule0". [I] Feb 9 20:39:13 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:39:13 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com". [I] Feb 9 20:39:13 ndm: Dns::Secure::DohConfigurator: "System": skip service "https://cloudflare-dns.com/dns-query", wait for bootstrap. [I] Feb 9 20:39:14 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Feb 9 20:39:14 ndm: Core::Session: client disconnected. [I] Feb 9 20:39:14 ndm: Http::Manager: updated configuration. [I] Feb 9 20:39:14 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Feb 9 20:39:14 ndm: Core::Session: client disconnected. [E] Feb 9 20:39:31 ndm: Dns::Resolver: failed to resolve "update.dedyn.io": timed out. [E] Feb 9 20:39:31 ndm: Io::Http::Client: [196] failed to resolve "update.dedyn.io". [W] Feb 9 20:39:31 ndm: DynDns::Profile: "_WEBADMIN": IPv4 update failure (network error). [W] Feb 9 20:39:31 ndm: DynDns::Profile: "_WEBADMIN": IPv6 update disabled (disabled). [E] Feb 9 20:39:31 ndm: DynDns::Profile: "_WEBADMIN": retry in 600000 ms. [I] Feb 9 20:39:31 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:39:31 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com". [I] Feb 9 20:39:31 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap. [I] Feb 9 20:39:41 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:39:41 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com". [I] Feb 9 20:39:41 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap. [I] Feb 9 20:39:51 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:39:51 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com". [I] Feb 9 20:39:51 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap. [I] Feb 9 20:39:53 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(24:0a:64:52:**:**) had associated. [I] Feb 9 20:39:53 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(24:0a:64:52:**:**) set key done in WPA2/WPA2PSK. [I] Feb 9 20:39:53 ndhcps: DHCPREQUEST received (STATE_INIT) for 192.168.1.44 from 24:0a:64:52:**:**. [I] Feb 9 20:39:54 ndhcps: sending ACK of 192.168.1.44 to 24:0a:64:52:**:**. [I] Feb 9 20:40:01 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:40:01 ndm: Dns::Secure::Tools: unable to obtain addresses for "cloudflare-dns.com". [I] Feb 9 20:40:01 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap. [I] Feb 9 20:40:11 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:40:11 ndm: Dns::Manager: updating DNS-over-HTTPS servers addresses. [I] Feb 9 20:40:11 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "cloudflare-dns.com". [I] Feb 9 20:40:11 ndm: Dns::Secure::DohConfigurator: "System": using "cloudflare-dns.com:443:104.16.248.249,104.16.249.249" as upstream. [I] Feb 9 20:40:40 ndm: Network::InternetChecker: Internet access detected. [I] Feb 9 20:40:58 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(24:0a:64:52:**:**) had disassociated by STA (reason: STA is leaving or has left BSS).
0 answers to this question
