Posted
Release 4.3.5 (preview):
  • DynDNS: fixed "IPv6 update disabled" issue while IPv6 address is present (reported by @ru.celebi) [NDM-3927]
  • HTTP: fixed "ban remote host 127.0.0.1" error when using the mobile application [NDM-3926]
  • IPsec: fixed binding IKEv2 policy to a home network segment (reported by @Denis P) [NDM-3925]
  • IPsec: fixed rekey issue when initiating IKEv2 connection [NDM-3922]
  • OpenConnect: fixed usage of authgroup with anyconnect protocol [NDM-3918]
  • Web: improved function blocking during fail-safe operation [NWI-4252]
  • Wireguard: fixed "system failed [0xcffd009e]" error when loading settings with rearranged [Peer] and [Interface] blocks (reported by @Sergeykk) [NDM-3930]
  • 3 weeks later...
Posted
Release 4.3.6 (preview → stable):
  • IPv6: fixed MAP-T bypass of UDP packets with zero checksum [SYS-1404]
  • Proxy: fixed "socks5 client read auth" error [NDM-3942]
  • SNMP: added wireless broadband connection metrics [NDM-3934]:
    • RSSI OID: .1.3.6.1.4.1.9.9.661.1.3.4.1.1.1.7006
    • RSRP OID: .1.3.6.1.4.1.9.9.817.1.1.1.1.1.1.7006
    • RSRQ OID: .1.3.6.1.4.1.9.9.817.1.1.1.1.1.2.7006
    • SNR OID: .1.3.6.1.4.1.9.9.817.1.1.1.1.1.3.7006
  • USB: implemented support for Signalinks M806B D525C modems [NDM-3933]
  • Web: added cable testing display on Diagnostics page (reported by @dimon27254) [NWI-4029]
  • Web: changed auto-update status on Extender (reported by @iggo) [NWI-4205]
  • Web: fixed translation issues (reported by @dimon27254) [NWI-4281]
  • Wireguard: enabled peer "keepalive" interval set to 15 by default (reported by @FLK) [NDM-3948]
  • Wireguard: fixed various configuration import issues [NDM-3943]
  • 1 month later...
  • 2 weeks later...
Posted
Release 4.3.6.2:
  • HTTP: fixed display of custom logo in the "Information for the Wi-Fi network" pop-up (reported by @dimon27254) [NDM-3969]
  • USB: added support for Fibocom FM101-GL modem [NDM-3970]
  • USB: added support for Olax F90 modem [NDM-3983]
  • 3 weeks later...
Posted
Release 4.3.6.3:
  • CIFS: fixed copying files using named streams (reported by @dimon27254) [SYS-1450]
  • HTTP: disabled public access to the device with a weak administrator password [NDM-4097]
  • LTE: improved FM350gl-16 modem compatibility with Yota [NDM-3997]
  • 3 weeks later...
Posted
Release 4.3.6.4 (Attention: for KN-1812 only):
  • Wi-Fi: fixed KN-1812 bootloop when radio is disabled by WLAN button [SYS-1481]
  • 3 months later...
Posted
Release 4.3.7 LTS* (preview):
  • CIFS: fixed compatibility with macOS TimeMachine® [NDM-4112]
  • Core: restricted access to sensitive data for users with 'readonly' privileges [NDM-4169]
  • DNS: fixed possible system restart triggered by 'DNS FQDN event sink' threads [NDM-4162]
  • HTTP: eliminated CVE-2026-1642 security vulnerability in the HTTP proxy service [NDM-4267]
  • IP: fixed operation of static routes added after the default route [NDM-4209]
  • IPsec: fixed convey of IKEv1/IPsec VPN and IKEv2/IPsec VPN servers custom routes to clients (reported by @lexm434) [NDM-3954]
  • IPv6: fixed the IPv4 default route setup for DS-Lite over PPPoE connections [NDM-4109]
  • Monitor: changed the packet dump file extension from .pcapng to .pcap [NDM-4091]
  • MWS: fixed the wireless 2.4 GHz backhaul operation for MT7603 and MT7628-based devices [SYS-1513]
  • SSDP: fixed possible system restart under certain conditions [NDM-4224]
  • Web: fixed the mobile connection settings save after changing the TTL value [NWI-4322]
  • Web: fixed the display of the drop-down list on the Internet Safety page (reported by @kroleg) [NWI-4306]
  • Web: removed the option to delete main home network segment (reported by @dimon27254) [NWI-4340]
  • Web: restored the 'lte-firmware' file missing in the list of system files under certain conditions [NWI-4367]
  • Wi-Fi: fixed the ACL filtering for Wi-Fi 7 clients with MLO enabled [SYS-1507]
  • Wi-Fi: fixed the iPhone® 17 connection issues with Wi-Fi 7 MLO and Fast Transition enabled [SYS-1497]
  • Wi-Fi: eliminated security vulnerabilities [SYS-1542]
  • Wi-Fi: fixed the KN-1812 enter continuous restart after adding a local network while the radio is turned off via hardware [SYS-1481]
  • Wi-Fi: fixed the MWS zoning for Wi-Fi 7 clients that use MLO [SYS-1505]
  • Wi-Fi: fixed possible system crash when using OWE authentication [SYS-1461]
  • ZeroTier: fixed the system restart when using the fail-safe mode [NDM-4187]
* publication scope: KN-1111, KN-1211, KN-1212, KN-1311, KN-1511, KN-1611, KN-1711, KN-2210, KN-3010
