arachnanthe Posted February 24, 2025 Posted February 24, 2025 (edited) Can a panel be added to track which user visited which websites and when using the web history logging feature? In the Web History section, the default setting is "off." (1) When you enable the Web History feature, the web browsing history of all clients will be displayed on the page. (2) You can also select a specific client to review their web history. (3) You can either click directly on the "Next" button or enter the page number of the record you want to view and then click the "Next" button again. (4) The records are updated automatically. However, you can also manually update them by clicking the "Refresh" button. (5) If you need to clear the web history, click the "Clear" button. All saved data can be copied to a document program on the computer, such as Word or a Text Document. Edited February 24, 2025 by arachnanthe Quote
0 KYTECHNGAMING Posted February 28, 2025 Posted February 28, 2025 I'm not sure, but is there still this feature? I think it should be contrary to KVKK. Quote
0 arachnanthe Posted February 28, 2025 Author Posted February 28, 2025 This is important for monitoring my children at home. If an adult enters a foreign network, they know that they are being monitored by IT. Or how do I know if the person entering my network is malicious? My IP address will remain as a trace. Quote
0 MDP Posted March 2, 2025 Posted March 2, 2025 On 2/28/2025 at 7:56 AM, arachnanthe said: This is important for monitoring my children at home. If an adult enters a foreign network, they know that they are being monitored by IT. Or how do I know if the person entering my network is malicious? My IP address will remain as a trace. Also, you can use the netflow module. It will only be necessary to configure the upload where the information stream from the flow sensor will be uploaded. And set up a collector with an analysis program on a separate server. Quote
0 arachnanthe Posted March 2, 2025 Author Posted March 2, 2025 I don't have any technical knowledge on this subject. If development is not possible, I will consider changing the modem after a while. Quote
arachnanthe
Edited by arachnanthe5 answers to this question
