Posted
Hi.
I create an OPVN client connection that works (green flag) but all connection go down after I set Policy Connections and Policy Bindings.
If I don't set them all traffic go out of tunnel openvpn.
I use Keenetic OS  4.2.6.2
How can I resolve this issue?
Thanks.
7 answers to this question
Posted
10 hours ago, fritz box said:
Hi.
Thanks.
Hello @fritz box
Please attach either a couple of screenshots of your browser with Policy Connections/Policy Bindings or a self-test file (you can download it from the Diagnostics page or the System Settings page.
Spoiler
If you decide to attach the self-test file, please toggle the "Hide" toggle when adding a new message to this thread, so only the moderators of the forum will see your message.
Posted
37 minutes ago, fritz box said:
Any news? I upload to you self-test file.
Thx.
Thank you for the self-test file! The configuration looks correct.
Can you try something? Will your devices have Internet access if you:
- disable multipath in that policy
- remove rate-limiting for the OpenVPN interface
Should look similar to this:
Posted
I tested...but NO connection.😵
Posted (edited)
Hello.
Issue is present in double tunnel vpn.
If I connect Titan router in cascading and VPN is operative on first router ---> on Titan (2°) new Tunnel not working.
But if I switch off VPN on 1 router ----> on Titan VPN tunnel works but very slowly speed (20 Mb Max with 1gb network).
So, anyone have same issue on vpn speed (openvpn)?
Thx.
Edited by fritz box
Posted
@fritz box, thank you for checking out the simplified policy configuration. After reading your last comment, I don't think I understand how your network is configured.
Can you draw a schematic of your network:
- how devices (Keenetic routers, computes, smartphones, ...) connected to each other (including connection policies on Keenetic routers)
- on which devices the OpenVPN is configured
And what problem are you trying to solve with a “double tunnel” VPN configuration?
