Please consider adding a "Reboot" button next to the existing Edit and Remove buttons in the mesh device management interface. Currently, restarting a mesh node requires logging into each device separately, which is inefficient and time-consuming.
Suggested Placement:
[Update] [Edit] [Remove] [Reboot]
This addition would make it much easier to manage and restart mesh nodes directly from the controller interface.
ru.celebi
EditandRemovebuttons in the mesh device management interface. Currently, restarting a mesh node requires logging into each device separately, which is inefficient and time-consuming.Suggested Placement:
[Update] [Edit] [Remove] [Reboot]This addition would make it much easier to manage and restart mesh nodes directly from the controller interface.
Edited by ru.celebi2 answers to this question
