  • 1
Wi-Fi System Error - Mws::Controller::Manager: the controller DPN document is not accepted.
Posted
I'm trying to connect KN-1111 as Extender to my KN-3811 using Wi-Fi System. KN-1111 shown in "Extenders available for adding to the Wi-Fi System" but on "Acquire" nothing happens.
Error from KN-3811 system log
I've tried to reset both devices, tried different os versions, reinstalled wifi system component,  tried both ethernet and wps connection methods. No success.
  • Thanks 2
7 answers to this question
  • 1
Posted
ok, lemme give a bit more context: I have two routers, one bought in Germany and another one is from the CIS. From the CIS one doesn't allow to build mesh anymore, so I switched EU one as the main router and the CIS one as a repeater; the setup now works.
P.S. The first setup worked on Feb 25 once I set it up, but after backup restore (yep, I did some shit and had to restore my routers), the mesh was not restored and had to be configured from scratch. The chatgpt says the DPD document and Mws::Controller::Manager are the components of Keenetic Cloud, so I may assume because of keenetic splitting into two companies (google netcraze), the old CIS-based devices now have issues.
Posted
Same problem!
Reset & downgrade firmware doesn’t help!
also, adding extender doesn't work through the netcraze app!
Posted (edited)
I found a solution. You need to connect to the main router via ssh and connect the candidate with the command: mws acquire <candidate MAC> eula-accept no-update
The MAC address you need to specify is the one that the candidate gives over the wire, and not the one on the device's sticker
Edited by Leg4te
Posted
do i need to connect via ssh as root ? bc with admin ((config)>) gives an error
(config)>  mws acquire 1a:7e:2c:f1:xx:xx
Command::Base error[7405602]: argument parse error.
Posted
If for some reason the MAC address does not work you also can use candidate's cid as the candidate identifier. Device's cid can be found in the show identification command output.
If you press Tab after entering mws acquire, there should be some autocomplete options available.
