moij258 Posted January 31 Posted January 31 Is possible to setup on KN-3610 (or KN-3611) on VDLS PTM connection simultaneously untagged VLAN and tagged VLAN with ID, 2 VLAN together. I need to replace ISP router what have this kind of complicated setup in ISP specific router. Where is possible to buy KN-3611 in Europe/EU? Quote
0 keen_parish27 Posted February 1 Posted February 1 Hi, It depends. Currently, it's not possible to have two different ISPs on the same port. If you need different services on different VLANs, refer to the attached screenshot for instructions. Quote
0 moij258 Posted February 1 Author Posted February 1 I have one ISP, but ISP have 2 VLAN-s on VDLS. 1. untagged (native) VALN, without ID for general internet connection. 2. VLAN with ID for IPTV. Is it possible to send them to different physical LAN ports? Quote
0 eralde Posted February 1 Posted February 1 15 hours ago, moij258 said: I have one ISP, but ISP have 2 VLAN-s on VDLS. 1. untagged (native) VALN, without ID for general internet connection. 2. VLAN with ID for IPTV. Is it possible to send them to different physical LAN ports? @moij258 if I understand you correctly, your goal is to configure something like this (in my example I configure the IPTV VLAN on the port #4): Spoiler Screen Recording 2026-02-02 at 04.27.29.mov Quote
0 moij258 Posted February 2 Author Posted February 2 (edited) This mean if VLAN ID is not defined router handles it as untagged (native) VALN? Other routers I have seen, did not expect empty VLAN ID at all or have some special check box for untagged (native) VLAN. Edited February 2 by moij258 Quote
0 eralde Posted February 2 Posted February 2 2 hours ago, moij258 said: This mean if VLAN ID is not defined router handles it as untagged (native) VALN? Other routers I have seen, did not expect empty VLAN ID at all or have some special check box for untagged (native) VLAN. Yes, this configuration (no VLAN for the Internet, only for IPTV) should work as you expect. I hope that helps 🙂 Quote
0 moij258 Posted February 2 Author Posted February 2 No, on my ISP both connections are VLAN connection: 1. is native untagged VLAN (special VLAN on an 802.1Q trunk link that carries traffic without VLAN tags), 2. is VLAN with specific ID number/tag. Is this configuration possible on KN-3610? Quote
0 eralde Posted February 2 Posted February 2 18 hours ago, moij258 said: No, on my ISP both connections are VLAN connection: 1. is native untagged VLAN (special VLAN on an 802.1Q trunk link that carries traffic without VLAN tags), 2. is VLAN with specific ID number/tag. Is this configuration possible on KN-3610? You can configure a configuration that you describe via the command line. It won't be possible to do it in the web UI. Spoiler telnet 192.168.1.1 Trying 192.168.1.1... Connected to 192.168.1.1. Escape character is '^]'. KeeneticOS version 5.00.C.4.0-1, copyright (c) 2010-2025 Keenetic Ltd. This software is a subject of Keenetic Ltd. end-user licence agreement. By using it you agree on terms and conditions hereof. For more information please check https://keenetic.com/legal WARNING: administrative password is not configured. (config)> in interface - network interface configuration (config)> interface Dsl0 Usage template: interface {name} Choose: Dsl0 Dsl0/Pvc0 (config)> interface Dsl0 Usage template: interface {name} Choose: Dsl0 Dsl0/Pvc0 (config)> interface Dsl0/Vlan0 Network::Interface::Repository: "Dsl0/Vlan0" interface created. (config-if)> ip address dhcp Dhcp::Client: Started DHCP client on Dsl0/Vlan0. (config-if)> ip global auto Network::Interface::L3Base: Global priority recalculated. (config-if)> up Network::Interface::Base: "Dsl0/Vlan0": interface is up. (config-if)> exit Core::Configurator: Done. (config)> interface Dsl0/Vlan123 Network::Interface::Repository: "Dsl0/Vlan123" interface created. (config-if)> ip address dhcp Dhcp::Client: Started DHCP client on Dsl0/Vlan123. (config-if)> ip global auto Network::Interface::L3Base: Global priority recalculated. (config-if)> up Network::Interface::Base: "Dsl0/Vlan0": interface is up. (config-if)> exit Core::Configurator: Done. (config)> sy system - maintenance functions (config)> system con configuration - manage system configuration (config)> system configuration save Core::System::StartupConfig: Saving (cli). The resulting configuration file (startup-config) will contain something like this: ... interface Dsl0 rename DSL ip dhcp client dns-routes ip name-servers ... up ! ... interface Dsl0/Vlan0 security-level public ip address dhcp ip dhcp client dns-routes ip global 306 up ! interface Dsl0/Vlan123 security-level public ip address dhcp ip dhcp client dns-routes ip global 153 up ! ... However, I don't have enough expertise to answer any following questions about the setup you want. I kindly suggest that you contact our technical support: https://support.keenetic.com/ Our support engineers will be able to answer your questions better than I am. Quote
0 moij258 Posted February 4 Author Posted February 4 I get conformation from support that simultaneous untagged (native) VALN without ID and VLAN with ID are possible on VDSL PTM IPoE connection. I also ordered KN-3610 and have soon possibility to check this in live. 1 Quote
0 moij258 Posted February 11 Author Posted February 11 (edited) Strange is that manual on web have no any information about untagged (native) VLAN, but it works when VLAN ID is left empty. Probably this "function" is good also to add to the manual. Edited February 11 by moij258 Quote
moij258
9 answers to this question
