Вопросы по интеграции OpenVPN в NDMS
Подскажите, пожалуйста, пытаюсь поднять VPN (от prostovpn), вот что пишет лог:
Это с UDP, с TCP всё окей но нужен именно UDP.
Apr 26 08:52:08
OpenVPN1
OpenVPN 2.4.6 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD]
Apr 26 08:52:08
OpenVPN1
library versions: OpenSSL 1.1.1d 10 Sep 2019, LZO 2.10
Apr 26 08:52:08
OpenVPN1
UDP link local: (not bound)
Apr 26 08:52:08
OpenVPN1
UDP link remote: [AF_INET6]2a00:d880:5:a29::2:1194
Apr 26 08:52:08
OpenVPN1
NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
Apr 26 08:52:08
OpenVPN1
write UDP: Network is unreachable (code=128)
Apr 26 08:52:08
OpenVPN1
Network unreachable, restarting
Apr 26 08:52:08
OpenVPN1
SIGTERM received, sending exit notification to peer
Apr 26 08:52:09
OpenVPN1
SIGTERM[soft,exit-with-notification] received, process exiting
Apr 26 08:52:09
ndm
Service: "OpenVPN1": unexpectedly stopped.
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:08
OpenVPN1
Apr 26 08:52:09
OpenVPN1
Apr 26 08:52:09
ndm
proto udp4
  • 3 weeks later...
А подскажите, пожалуйста, что с этим делать? По совету выше исправил на udp4, все прекрасно работало день, на следующий перестало - пишет на странице соединения No IP Address. Хотя в логе ничего критичного не вижу. Куда копать?
Spoiler
May 12 20:23:59
ndm
Core::Syslog: the system log has been cleared.
May 12 20:24:03
kernel
IPv6: ADDRCONF(NETDEV_UP): ovpn_br0: link is not ready
May 12 20:24:03
ndm
Network::Interface::Base: "OpenVPN0": interface is up.
May 12 20:24:03
ndm
May 12 20:24:06
OpenVPN0
May 12 20:24:06
OpenVPN0
May 12 20:24:06
OpenVPN0
UDPv4 link local: (not bound)
May 12 20:24:06
OpenVPN0
UDPv4 link remote: [AF_INET]185.14.28.10:1194
May 12 20:24:06
OpenVPN0
May 12 20:24:07
ndm
Core::ConfigurationSaver: configuration saved.
May 12 20:24:11
OpenVPN0
[nl6.pvpn.pw] Peer Connection Initiated with [AF_INET]185.14.28.10:1194
May 12 20:24:11
ndm
Network::Interface::OpenVpn: "OpenVPN0": connecting via PPPoE0 (PPPoE0).
May 12 20:24:11
ndm
Network::Interface::OpenVpn: "OpenVPN0": added host route to remote endpoint 185.14.28.10 via PPPoE0.
May 12 20:24:17
OpenVPN0
WARNING: INSECURE cipher with block size less than 128 bit (64 bit). This allows attacks like SWEET32. Mitigate by using a --cipher with a larger block size (e.g. AES-256-CBC).
May 12 20:24:17
OpenVPN0
May 12 20:24:17
OpenVPN0
WARNING: cipher with small block size in use, reducing reneg-bytes to 64MB to mitigate SWEET32 attacks.
May 12 20:24:17
OpenVPN0
TUN/TAP device tun0 opened
May 12 20:24:17
OpenVPN0
do_ifconfig, tt->did_ifconfig_ipv6_setup=1
May 12 20:24:17
kernel
IPv6: ADDRCONF(NETDEV_CHANGE): ovpn_br0: link becomes ready
May 12 20:24:17
ndm
Network::Interface::Ip: "OpenVPN0": IP address is 192.168.101.3/24.
May 12 20:24:17
OpenVPN0
IPv6 is not supported yet (ifconfig)
May 12 20:24:18
OpenVPN0
add_route_ipv6(2000::/3 -> 2002:b90e:1c0a:1::1 metric -1) dev tun0
May 12 20:24:18
OpenVPN0
IPv6 is not supported yet (add route)
May 12 20:24:18
OpenVPN0
add_route_ipv6(::/3 -> 2002:b90e:1c0a:1::1 metric -1) dev tun0
May 12 20:24:18
OpenVPN0
May 12 20:24:18
OpenVPN0
add_route_ipv6(2000::/4 -> 2002:b90e:1c0a:1::1 metric -1) dev tun0
May 12 20:24:18
OpenVPN0
May 12 20:24:18
OpenVPN0
add_route_ipv6(3000::/4 -> 2002:b90e:1c0a:1::1 metric -1) dev tun0
May 12 20:24:18
OpenVPN0
May 12 20:24:18
OpenVPN0
add_route_ipv6(fc00::/7 -> 2002:b90e:1c0a:1::1 metric -1) dev tun0
May 12 20:24:18
OpenVPN0
May 12 20:24:18
ndm
Network::Interface::OpenVpn: "OpenVPN0": adding nameserver 192.168.101.1.
May 12 20:24:18
ndm
Dns::Manager: name server 192.168.101.1 added, domain (default).
May 12 20:24:18
ndm
Network::Interface::OpenVpn: "OpenVPN0": add route to nameserver 192.168.101.1 via 0.0.0.0 (OpenVPN0).
May 12 20:24:18
OpenVPN0
GID set to nobody
May 12 20:24:18
OpenVPN0
UID set to nobody
May 12 20:24:18
OpenVPN0
Initialization Sequence Completed
May 12 20:24:18
ndm
Http::Nginx: loaded SSL certificate for "61eefb62507a4b30d21eb455.keenetic.io".
May 12 20:24:18
ndm
Http::Nginx: loaded SSL certificate for "hench.keenetic.pro".
May 12 20:24:18
ndm
Core::Server: started Session /var/run/ndm.core.socket.
May 12 20:24:18
ndm
Core::Session: client disconnected.
May 12 20:24:19
ndm
Http::Manager: updated configuration.
May 12 20:24:19
ndm
May 12 20:24:19
ndm
May 12 20:24:21
ndhcpc
OpenVPN0: NDM DHCP client (version 3.2.37) started.
May 12 20:24:21
ndhcpc
OpenVPN0: created PID file "/var/run/ndhcpc-ovpn_br0.pid".
May 12 20:24:22
ndm
Network::Interface::Ip: "OpenVPN0": IP address cleared.
May 12 20:24:22
ndm
May 12 20:24:22
ndm
May 12 20:24:23
ndm
May 12 20:24:23
ndm
May 12 20:24:23
ndm
May 12 20:24:23
ndm
May 12 20:24:23
ndm
Edited by Алексей Воловиков
  • 1 month later...
Имеется Keenetic 4G, KeeneticOS: 3.4.6. Есть проблема с подключением к OpenVPN серверу.
Конфиг:
client
dev tun
proto udp
remote 192.168.0.1 1195
resolv-retry infinite
auth SHA1
cipher BF-CBC
comp-lzo
verb 5
<ca>
</ca>
<cert>
</cert>
<key>
</key>
Лог:
[I] Jun 22 16:06:34 OpenVPN1: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1542,tun-mtu 1500,proto UDPv4,comp-lzo,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
[I] Jun 22 16:06:34 OpenVPN1: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1542,tun-mtu 1500,proto UDPv4,comp-lzo,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
[I] Jun 22 16:06:34 OpenVPN1: Socket Buffers: R=[155648->155648] S=[155648->155648]
[I] Jun 22 16:06:34 OpenVPN1: UDP link local (bound): [AF_INET][undef]:1194
[I] Jun 22 16:06:34 OpenVPN1: UDP link remote: [AF_INET]192.168.0.1:1195
[I] Jun 22 16:06:34 OpenVPN1: NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
[I] Jun 22 16:06:34 OpenVPN1: TLS: Initial packet from [AF_INET]192.168.0.1:1195, sid=c399bbe9 6b9069d9
[E] Jun 22 16:06:35 OpenVPN1: OpenSSL: error:1425F102:lib(20):func(607):reason(258)
[E] Jun 22 16:06:35 OpenVPN1: TLS_ERROR: BIO read tls_read_plaintext error
[E] Jun 22 16:06:35 OpenVPN1: TLS Error: TLS object -> incoming plaintext read error
[E] Jun 22 16:06:35 OpenVPN1: TLS Error: TLS handshake failed
[I] Jun 22 16:06:35 OpenVPN1: TCP/UDP: Closing socket
[I] Jun 22 16:06:35 OpenVPN1: SIGTERM[soft,tls-error] received, process exiting
[E] Jun 22 16:06:35 ndm: Service: "OpenVPN1": unexpectedly stopped
Я так понимаю, проблема в том, что на сервере OpenVPN используется TLSv1, а на Keenetic openssl без поддержки TLSv1. Можно ли как-то включить поддержку TLSv1?
23 часа назад, maxvit сказал:
Конфиг:
client
dev tun
proto udp
auth SHA1
cipher BF-CBC
comp-lzo
verb 5
<ca>
</ca>
<cert>
</cert>
<key>
</key>
Лог:
Поддержка TLS 1.0 есть, равно как и 1.2. Нет только SSL3 и TLS1.1.
Удалось обновить openssl и openvpn на сервере.
Проблема вопроизводится при указании в конфигурации сервера:
tls-version-max 1.0
  • 6 months later...
20 минут назад, SSTP сказал:
chacha20 использовать !
Оно с прошивки 3.3 доступно
Edited by r13
  • 6 months later...
Вопрос, надо ли делать “ip nat OpenVPNx”, для tap, если мне надо попасть внутрь сети подключённого клиента (на стороне клиента входящий трафик разрешён). Точнее, будет ли в принципе работать, тк в таблице маршрутизации tap не виден, тк сидит на Bridge0? При этом я тоже являюсь клиентом и в конфигурации сервера клиент-клиент разрешён.
Edited by Oleg Nekrylov
  • 2 months later...
16 часов назад, SSTP сказал:
почему опенвпн не подключается по порту 53 ??? и поддерживает ли openvpn клиент tls-crypt v2  ??? openvpn уже 2.5.3 есть ! а  кенетик 2.4.6 !
Давайте по шагам.
 - OpenVPN на 53 порту по идее не работает, это порт для DNS.
 - tls-crypt-v2 поддерживает.
 - в нашей версии 2.4.6 есть все патчи по CVE и принесена поддержка chapoly. Что еще вам не хватает в 2.4.6 из 2.5.3?
этот порт не работает только на кенетике на остальнов всем работает
Давайте по шагам.
это хорошо !
мне та хвотает просто вы почитайте что нового в последних версиях много чего ввели . и новое она и есть новое
tls-crypt-v2  работает только начиная с версии 2.5.0 и он не может работать на версии  2.4.х
может перепутали просто tls-crypt ??? На 2.4.x  работает tls-crypt и tls-auth
18 минут назад, Andy Moore сказал:
Хм, да, появилась такая тема.
А реально какие-то серверы ее требуют (покупные, а не самодельные)?
Я лично жду версии 2.6, чтобы сразу с dco все добавить. Если сейчас добавлять на месяца-полтора 2.5, а потом снова 2.6 - это лишняя работа. Прошу немного обождать.
  • Upvote 2
4 минуты назад, Le ecureuil сказал:
Есть и самодельные и покупные , есть те кто не стоит на месте
5 минут назад, Le ecureuil сказал:
не думаю что в ближайшие года 2 мы ее увидим
20 часов назад, SSTP сказал:
Потому что...
~ # lsof -P -i |grep ndnproxy
================================== Skiped ==================================
ndnproxy   1438   root    4u  IPv4     13102      0t0  UDP *:53
ndnproxy   1438   root    5u  IPv4     13103      0t0  UDP *:56298
ndnproxy   1438   root    6u  IPv6     13104      0t0  UDP *:53
ndnproxy   1438   root    8u  IPv4     13106      0t0  TCP *:53 (LISTEN)
ndnproxy   1438   root    9u  IPv6     13107      0t0  TCP *:53 (LISTEN)
Что вы будете делать с DNS proxy?  Свой DNS-сервер ставить?
54 минуты назад, Andy Moore сказал:
Тот, кто не стоит на месте может спокойно в opkg замутить что хочет (или в sdk).
Если массовой потребности нет, то пока я смысла вижу мало.
Мое дело предложить, как потребителю продукта , а решать уже вам, релиз 2.4.6 был в апреле 2018 если не ошибаюсь, а нынче грядет 2022
  • Upvote 2
5 часов назад, Le ecureuil сказал:
Полностью за такое решение!
Лучше бросьте ресурсы на действительно важную функцию - на ускорение OpenVPN (dco)
Думаю многие вам за это скажут спасибо и для кого-то это будет плюс для выбора кинетика для покупки, т.к. у остальных роутеров эта функция думаю появится намного позже, судя по скорости развития вами NDMS..
Я например жду ускорения OVPN с момента покупки Giga уже пару лет, т.к. сейчас скорость 100мбит канала утилизируется только на четверть.. а другие VPN утилизируют канал на 100% но по разным причинам не подходят.. например Wireguard работал-работал, а потом резко перестал и мне так и не удалось его больше заставить работать... пришлось вернуться на медленный но надежный OVPN
  • Y'r wrong 1
15 часов назад, Yury Zhidkov сказал:
Я уже пробовал dco в январе 2021, и на тот момент там было очень "сыро" + в ветке ovpn 2.x не было поддержки, я ее приделал сам, но все равно там далеко от того, что можно показать пользователям было. Сейчас уже стало вроде постабильнее, будем ждать и надеятся что в 2.6 таки допилят сами разработчики (а если нет, то я может и реанимирую код январский и доделаю).
  • Upvote 5
  • 1 month later...
  • 2 weeks later...
Добрый день. Надеюсь - не ошибся тредом и прошу извинить, если информация избыточна.
Имеется центральный офис, в котором в локальной сети на сервере VmWare развернут Open VPN сервер на FreeBSD (используется pfSense 2.4.4). С этим сервером успешно работают филиалы, в качестве клиентов - Mikrotik, FreeBSD(pfSense) и т.д, Keenetic в этой сети пока не было.
Исользуется конфигурация Open VPN site-to-site, филиалы видят сеть офиса за Open VPN, офис видит сети клиентов.
Планируя очередной филиал, решил выбрать Keenetic Viva KN-1910 для подключения к Интернет, развертывания mesh и поднятия на нем Open VPN клиента.
Столкнулся с тем, что сеть за этим клиентом не видит сеть офиса за Open VPN сервером, а сеть офиса - сеть за клиентом. Туннель поднимается, но из сети клиента доступен только LAN IP сервера VPN 192.168.7.65. Маршруты в сеть за сервером клиент Keenetic получает.
Keenetic Viva KN-1910 (3.6.12)
Сеть за сервером 192.168.0.0/21
Сеть туннеля 10.20.20.0/24
Сеть за клиентом, на котором тестировался Keenetic 10.10.5.0/24
Конфиг сервера:
Spoiler
dev ovpns1
verb 1
dev-type tun
dev-node /dev/tun1
writepid /var/run/openvpn_server1.pid
#user nobody
#group nobody
script-security 3
daemon
keepalive 10 60
ping-timer-rem
persist-tun
persist-key
proto tcp4-server
cipher none
auth SHA1
up /usr/local/sbin/ovpn-linkup
down /usr/local/sbin/ovpn-linkdown
local 192.168.7.65
engine cryptodev
tls-server
server 10.20.20.0 255.255.255.0
client-config-dir /var/etc/openvpn-csc/server1
ifconfig 10.20.20.1 10.20.20.2
tls-verify "/usr/local/sbin/ovpn_auth_verify tls '......' 1"
lport 31194
management /var/etc/openvpn/server1.sock unix
push "route 192.168.0.0 255.255.248.0"
route 192.168.110.0 255.255.255.0
route 192.168.82.0 255.255.255.0
#еще много route
route 10.10.5.0 255.255.255.0 #тестируемый клиент Keenetic
ca /var/etc/openvpn/server1.ca
cert /var/etc/openvpn/server1.cert
key /var/etc/openvpn/server1.key
dh /etc/dh-parameters.1024
crl-verify /var/etc/openvpn/server1.crl-verify
ncp-ciphers AES-128-GCM
persist-remote-ip
float
topology subnet
sndbuf 524288
rcvbuf 524288
push "sndbuf 393216"
push "rcvbuf 393216"
iroute для всех сетей филиалов на сервере в /ccd указаны
Конфиг клиента Keenetic:
Spoiler
dev tun
persist-tun
persist-key
cipher none
auth SHA1
tls-client
client
remote-cert-tls server
remote aa.aa.cc.dd 31194 tcp4
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
Клиент с данным конфигом успешно проверен на Mikrotik,Padavan
Пингуя хост удаленной сети делал захват пакетов.
Пообщался с поддержкой.  Ответили так:
Я могу предположить, что сервер ожидает в качестве источника ip не адрес в OVPN туннеле клиента, а непосредственно адрес хоста клиента в сети 10.10.5.0/24
При конфигурации site-to-site вполне естественно, что сервер ожидает адрес хоста клиента в сети 10.10.5.0/24. Однако в туннель  IP хостов не уходят. NAT?
Поддержка:
Проверить это можно отключив NAT
no ip nat Home
ip static Home ISP
Естественно, при отключенном NAT все работает. Но тогда, что естественно, с ПК за Кинетик теряется доступ в интернет.
Решаема ли эта проблема?
Если вопрос только в NAT, то отлючаете его совсем для домашней сети:
> no ip nat Home
и включаете только между теми интерфейсами, где он нужен:
> ip static Home ISP
в таком случае у вас из Home в ISP NAT будет, а в OpenVPN - нет.
5 minutes ago, Le ecureuil said:
Поддержка, кстати, все правильно сказала.
Поддержка на то и поддержка. 😃
Home и Home ISP - это универсальные наименования интерфейсов?
Да, вероятно нужно отключть NAT только для OpenVPN, оставив доступ с LAN\Wi-Fi и в туннель и в интернет.
Приведенные вами и поддержкой команды, как писал выше, делают интернет недоступным
