Keenetic Ultra ошибки ядра
Razoon
Всем доброго времени суток после установки ownCloud под этой инструкции в журнале начало выдавать примерно следующее
Jun 05 13:49:23ndmkernel: Kernel bug detected[#26]:
Jun 05 13:49:23ndmkernel: Cpu 0
Jun 05 13:49:23ndmkernel: $ 0 : 00000000 00000002 00000001 80000000
Jun 05 13:49:23ndmkernel: $ 4 : 811547c0 7f8e9fd4 81000000 00001fff
Jun 05 13:49:23ndmkernel: $ 8 : 7f8e9fd4 813a9000 00000011 fffffff8
Jun 05 13:49:23ndmkernel: $12 : 20302030 000000b6 00000000 004a0000
Jun 05 13:49:23ndmkernel: $16 : 0000000e 811547c0 813a9000 7f8e9fd4
Jun 05 13:49:23ndmkernel: $20 : 00000000 00000006 00000000 8509fe20
Jun 05 13:49:23ndmkernel: $24 : 00498278 2aaf7c70
Jun 05 13:49:23ndmkernel: $28 : 8509c000 8509fda8 8509fe24 80030a78
Jun 05 13:49:23ndmkernel: Hi : 000000ba
Jun 05 13:49:23ndmkernel: Lo : 0002e3d9
Jun 05 13:49:23ndmkernel: epc : 80031728 kmap_coherent+0x8/0xac Tainted: P
Jun 05 13:49:23ndmkernel: ra : 80030a78 __flush_anon_page+0x4c/0x84
Jun 05 13:49:23ndmkernel: Status: 11000303 KERNEL EXL IE
Jun 05 13:49:23ndmkernel: Cause : 50805834
Jun 05 13:49:23ndmkernel: PrId : 00019555
Jun 05 13:49:23ndmkernel: Modules linked in: hw_nat(P) igmpsn(P) rt539x_ap5(P) rt539x_ap2(P) ntc(P) ip6t_rt rndis_host nf_nat_rtsp dm9601 ip6table_raw ip6t_ipv6header cdc_ether nf_nat_sip ip6t_LOG ip6table_filter ip6t_ah asix ip6t_frag nf_nat_ftp ext3 ip6table_mangle nf_nat_pptp nf_nat_h323 nf_conntrack_pptp ip6t_hbh ip6t_mh resetnds(P) thfsplus tun nf_conntrack_ipv6 raeth ext2 crypto_hash nf_conntrack_h323 ip6_tables hw_cdc_net ip6t_owner pptp sierra pppol2tp usbnet tfat(P) jbd deflate nf_conntrack_proto_gre phr(P) nf_conntrack_rtsp nf_conntrack_ftp fastvpn tntfs(P) ip6t_eui64 nf_conntrack_sip powerstat ip6t_REJECT fastnat ip6_queue nf_nat_proto_gre xt_mac
Jun 05 13:49:23ndmkernel: Process pidof (pid: 16116, threadinfo=8509c000, task=8a247400)
Jun 05 13:49:23ndmkernel: Stack : 82a03d60 0000000e 0000000b 813a9000 7f8e9fd4 8007eec4 00000044 8509fec8
Jun 05 13:49:23ndmkernel: 80334210 80094df0 00000010 0000000e 00000000 0000000b 7f8e9fd4 8f4a8000
Jun 05 13:49:23ndmkernel: 8036e000 00000000 00001000 80000000 00000001 8007f048 81237400 8036e000
Jun 05 13:49:23ndmkernel: 80333f88 00000001 00000000 00000001 8509fe24 8509fe20 00000000 811547c0
Jun 05 13:49:23ndmkernel: 8036e034 00002001 00000000 8036e000 0000000b 00001000 8f4a8000 8509ff10
Jun 05 13:49:23ndmkernel: ...
Jun 05 13:49:23ndmkernel: Call Trace:
Jun 05 13:49:23ndmkernel: [<80031728>] kmap_coherent+0x8/0xac
Jun 05 13:49:23ndmkernel: [<80030a78>] __flush_anon_page+0x4c/0x84
Jun 05 13:49:23ndmkernel: [<8007eec4>] get_user_pages+0x274/0x2ec
Jun 05 13:49:23ndmkernel: [<8007f048>] access_process_vm+0x10c/0x200
Jun 05 13:49:23ndmkernel: [<800ce6e0>] proc_pid_cmdline+0x70/0x120
Jun 05 13:49:23ndmkernel: [<800cf8c4>] proc_info_read+0xd4/0x114
Jun 05 13:49:23ndmkernel: [<80094520>] vfs_read+0xc0/0x14c
Jun 05 13:49:23ndmkernel: [<800946d4>] sys_read+0x58/0xc0
Jun 05 13:49:23ndmkernel: [<8002f7a4>] stack_done+0x20/0x3c
Jun 05 13:49:23ndmkernel: Code: 00000000 8c820000 7c420240 <00028036> 8f820014 3c038038 7ca51300 24420001 af820014
а в ssh выглядит вот так (при запуске любого исполняемого скрипта)
/opt/share # /opt/etc/init.d/S70mysqld start
Starting mysqld... Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Железо keenetic ultra
Прошивка ndm v2.05 C4
Файл подкачки 500мб
После установки всей истории загрузка процессора подскочила до 100% и не спадает.
2 answers to this question
Зачем сюда. Есть же спец тема по тестированию прошивок.
Не должно userspace приложение приводить к ошибкам ядра.
Надеюсь у Вас стоит Entware-keenetic, а не Entware-ng!
Установка mysql сервера возможно не была тут описана
1. Установка
~ # opkg install mysql-server
Installing mysql-server (5.1.73-2) to root...
Downloading http://pkg.entware-keenetic.ru/binaries/keenle/mysql-server_5.1.73-2_keenle.ipk.
Installing libmysqlclient (5.1.73-2) to root...
Downloading http://pkg.entware-keenetic.ru/binaries/keenle/libmysqlclient_5.1.73-2_keenle.ipk.
Installing libreadline (6.3-1) to root...
Downloading http://pkg.entware-keenetic.ru/binaries/keenle/libreadline_6.3-1_keenle.ipk.
Configuring libmysqlclient.
Configuring libreadline.
Configuring mysql-server.
2. Редактируем
~ # mcedit /opt/etc/my.cnf
~ # cat /opt/etc/my.cnf
[client]
port            = 3306
socket          = /opt/var/run/mysqld.sock
[mysqld]
user            = root
port            = 3306
basedir         = /opt/
############ Don't put this on the NAND #############
# Figure out where you are going to put the databases
# And run mysql_install_db --force
datadir         = /opt/var/mysql/
См. строки basedir и datadir
3. Инициализируем
~ # mysql_install_db --datadir=/opt/var/mysql --basedir=/opt --force
Installing MySQL system tables...
OK
Filling help tables...
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
/opt/bin/mysqladmin -u root password 'new-password'
/opt/bin/mysqladmin -u root -h Extra password 'new-password'
4. Запускаем серевер и задаем пароль
~ # /opt/etc/init.d/S70mysqld start
Starting mysqld...              done.
~ # mysqladmin -u root password "secret"
5. Используем )))
[more]
1. Установка
2. Редактируем
[client]
port            = 3306
[mysqld]
user            = root
port            = 3306
basedir         = /opt/
3. Инициализируем
OK
OK
5. Используем )))
[/more]
Дык, в той теме она описана.
И если не в той ветке создал тему, то сори, перенесите пожалуйста в правильную ветку.
