Добавьте поддержку Huawei E5776.
Orbit
Keenetic II последний драфт
(config)> show interface UsbLte0
            index: 0
             type: UsbLte
      description:
   interface-name: UsbLte0
             link: down
        connected: no
            state: up
              mtu: 1500
         tx-queue: 1000
           global: yes
        defaultgw: no
         priority: 175
   security-level: public
              mac: 0c:5b:8f:27:9a:64
        auth-type: none
               fw:
             rssi:
             rsrp:
             cinr:
             rsrq:
             rscp:
             ecio:
     phone-number:
            txpow:
             freq:
            bssid:
      phy-cell-id:
             band:
              apn:
              lac:
              cqi:
           mobile:
             hspa:
        lte_state: Disconnected
             imsi:
             imei: 869647924644452
         operator:
     operator-raw:
             plmn:
max-dl-throughput:
max-ul-throughput:
cur-dl-throughput:
cur-ul-throughput:
         distance:
              sim:
              ati:
         manufacturer: Huawei
                model: E5776
             revision: 22.265.11.02.260
          plugged: yes
           vendor: 12d1
            model: 1506
     manufacturer: HUAWEI Technology
          product: HUAWEI Mobile
           serial:
(config)>
24 answers to this question
В 22.08.2018 в 00:15, Orbit сказал:
            index: 0
             type: UsbLte
      description:
             link: down
        connected: no
            state: up
              mtu: 1500
         tx-queue: 1000
           global: yes
        defaultgw: no
         priority: 175
        auth-type: none
               fw:
             rssi:
             rsrp:
             cinr:
             rsrq:
             rscp:
             ecio:
     phone-number:
            txpow:
             freq:
            bssid:
      phy-cell-id:
             band:
              apn:
              lac:
              cqi:
           mobile:
             hspa:
             imsi:
         operator:
     operator-raw:
             plmn:
max-dl-throughput:
max-ul-throughput:
cur-dl-throughput:
cur-ul-throughput:
         distance:
              sim:
              ati:
                model: E5776
          plugged: yes
           vendor: 12d1
            model: 1506
           serial:
(config)>
Расскажите точно и по шагам, где нам взять такой модем, и добавим.
две команды в cli решили вопрос
interface UsbLte0 usb wwan-force-connected
interface UsbLte0 ip address 192.168.79.11 255.255.255.0
Спасибо.
Авг 31 10:02:13 ndm
Network::Interface::UsbLte: "UsbLte0": connection initialized.
Авг 31 10:03:00 ndm
Network::Interface::UsbLte: "UsbLte0": connection timeout.
Авг 31 10:03:09 ndm
Авг 31 10:03:56 ndm
Авг 31 10:04:05 ndm
Авг 31 10:04:52 ndm
Единственное что осталось
Как убрать?
            index: 0
             type: UsbLte
      description: USB LTE
             link: up
        connected: yes
            state: up
              mtu: 1500
         tx-queue: 1000
          address: 192.168.79.100
             mask: 255.255.255.0
           uptime: 138
           global: yes
        defaultgw: yes
         priority: 49325
        auth-type: none
               fw:
             rssi:
             rsrp:
             cinr:
             rsrq:
             rscp:
             ecio:
     phone-number:
            txpow:
             freq:
            bssid:
      phy-cell-id:
             band:
              apn:
              lac:
              cqi:
           mobile:
             hspa:
             imsi:
         operator:
     operator-raw:
             plmn:
max-dl-throughput:
max-ul-throughput:
cur-dl-throughput:
cur-ul-throughput:
         distance:
              sim:
              ati:
                model: E5776
          plugged: yes
           vendor: 12d1
            model: 1506
           serial:
(config)>
Включите debug для интерфейса и пришлите лог. У нас добавлена модель E5786. Возможно аналогичный код инициализации сработает и для вашей модели. Где нам взять такой модем? Вы готовы предоставить ваш экземпляр?
Цитата
interface UsbLte0 debug
Увы предоставить не могу, но любые логи и тп без проблем. Сейчас интернет с этим модемом работает но в логе постоянные попытки соединения и иногда роутер произвольно перегружается. Лог ниже.
11 час назад, vst сказал:
это врядли, эти модели разделяет года 3. 5776 один из первых lte wifi роутеров продававшихся у наших операторов.
Добавлю. В данный момент с этими настройками инет есть. Как убрать ежеминутные попытки соединения?
interface UsbLte0
    description "USB LTE"
    usb device-id 12d1 1506
    security-level public
    ip address 192.168.79.100 255.255.255.0
    ip address dhcp
    ip dhcp client dns-routes
    ip dhcp client name-servers
    ip dhcp client displace Home
    ip dhcp client displace Guest
    ip global 49325
    up
@Orbit На неделе соберу вам тестовую прошивку с предполагаемым исправлением для алгоритма опроса состояния модема.
Пришлите селфтест, чтобы было ясно какое у вас устройство и какой набор компонентов.
отправил.
Пару часов полет нормальный. Селф-тест ниже.
И попутно почему ipsec сыпет?
03.09.2018 22:53:14	Kernel	Warning	ndm: kernel: EIP93: PE ring[14] error: AUTH_ERR
03.09.2018 22:53:14	Kernel	Warning	ndm: kernel: EIP93: PE ring[103] error: AUTH_ERR
03.09.2018 22:53:15	Kernel	Warning	ndm: kernel: EIP93: PE ring[59] error: AUTH_ERR
03.09.2018 22:53:16	Kernel	Warning	ndm: kernel: EIP93: PE ring[99] error: AUTH_ERR
03.09.2018 22:53:17	Kernel	Warning	ndm: kernel: EIP93: PE ring[38] error: AUTH_ERR
03.09.2018 22:53:18	Kernel	Warning	ndm: kernel: EIP93: PE ring[14] error: AUTH_ERR
03.09.2018 22:53:18	Kernel	Warning	ndm: kernel: EIP93: PE ring[104] error: AUTH_ERR
03.09.2018 22:53:19	Kernel	Warning	ndm: kernel: EIP93: PE ring[69] error: AUTH_ERR
03.09.2018 22:53:19	Kernel	Warning	ndm: kernel: EIP93: PE ring[29] error: AUTH_ERR
03.09.2018 22:53:20	Kernel	Warning	ndm: kernel: EIP93: PE ring[123] error: AUTH_ERR
03.09.2018 22:53:21	Kernel	Warning	ndm: kernel: EIP93: PE ring[95] error: AUTH_ERR
03.09.2018 22:53:22	Kernel	Warning	ndm: kernel: EIP93: PE ring[56] error: AUTH_ERR
03.09.2018 22:53:22	Kernel	Warning	ndm: kernel: EIP93: PE ring[25] error: AUTH_ERR
03.09.2018 22:53:23	Kernel	Warning	ndm: kernel: EIP93: PE ring[116] error: AUTH_ERR
03.09.2018 22:53:24	Kernel	Warning	ndm: kernel: EIP93: PE ring[91] error: AUTH_ERR
03.09.2018 22:53:25	Kernel	Warning	ndm: kernel: EIP93: PE ring[50] error: AUTH_ERR
03.09.2018 22:53:25	Kernel	Warning	ndm: kernel: EIP93: PE ring[14] error: AUTH_ERR
03.09.2018 22:53:26	Kernel	Warning	ndm: kernel: EIP93: PE ring[100] error: AUTH_ERR
03.09.2018 22:53:45	Kernel	Warning	ndm: kernel: EIP93: PE ring[25] error: AUTH_ERR
03.09.2018 22:53:46	Kernel	Warning	ndm: kernel: EIP93: PE ring[121] error: AUTH_ERR
03.09.2018 22:53:46	Kernel	Warning	ndm: kernel: EIP93: PE ring[50] error: AUTH_ERR
03.09.2018 22:53:46	Kernel	Warning	ndm: kernel: EIP93: PE ring[97] error: AUTH_ERR
03.09.2018 22:53:46	Kernel	Warning	ndm: kernel: EIP93: PE ring[19] error: AUTH_ERR
03.09.2018 22:53:46	Kernel	Warning	ndm: kernel: EIP93: PE ring[69] error: AUTH_ERR
03.09.2018 22:53:46	Kernel	Warning	ndm: kernel: EIP93: PE ring[127] error: AUTH_ERR
03.09.2018 22:53:46	Kernel	Warning	ndm: kernel: EIP93: PE ring[48] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[105] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[20] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[78] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[0] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[54] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[103] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[29] error: AUTH_ERR
03.09.2018 22:53:47	Kernel	Warning	ndm: kernel: EIP93: PE ring[75] error: AUTH_ERR
03.09.2018 23:00:02	Kernel	Warning	ndm: kernel: EIP93: PE ring[43] error: AUTH_ERR
03.09.2018 23:00:03	Kernel	Warning	ndm: kernel: EIP93: PE ring[15] error: AUTH_ERR
03.09.2018 23:00:03	Kernel	Warning	ndm: kernel: EIP93: PE ring[112] error: AUTH_ERR
03.09.2018 23:00:04	Kernel	Warning	ndm: kernel: EIP93: PE ring[69] error: AUTH_ERR
03.09.2018 23:00:05	Kernel	Warning	ndm: kernel: EIP93: PE ring[47] error: AUTH_ERR
03.09.2018 23:00:05	Kernel	Warning	ndm: kernel: EIP93: PE ring[7] error: AUTH_ERR
03.09.2018 23:00:06	Kernel	Warning	ndm: kernel: EIP93: PE ring[89] error: AUTH_ERR
03.09.2018 23:00:06	Kernel	Warning	ndm: kernel: EIP93: PE ring[52] error: AUTH_ERR
03.09.2018 23:00:07	Kernel	Warning	ndm: kernel: EIP93: PE ring[8] error: AUTH_ERR
03.09.2018 23:00:08	Kernel	Warning	ndm: kernel: EIP93: PE ring[120] error: AUTH_ERR
03.09.2018 23:00:08	Kernel	Warning	ndm: kernel: EIP93: PE ring[83] error: AUTH_ERR
03.09.2018 23:00:09	Kernel	Warning	ndm: kernel: EIP93: PE ring[13] error: AUTH_ERR
03.09.2018 23:02:31	Kernel	Warning	ndm: kernel: EIP93: PE ring[88] error: AUTH_ERR
03.09.2018 23:02:31	Kernel	Warning	ndm: kernel: EIP93: PE ring[49] error: AUTH_ERR
03.09.2018 23:02:31	Kernel	Warning	ndm: kernel: EIP93: PE ring[22] error: AUTH_ERR
03.09.2018 23:02:32	Kernel	Warning	ndm: kernel: EIP93: PE ring[120] error: AUTH_ERR
03.09.2018 23:02:32	Kernel	Warning	ndm: kernel: EIP93: PE ring[86] error: AUTH_ERR
9 часов назад, vst сказал:
@Orbit Если с модемом всё нормально, то исправление будет перенесено.
Проверьте настойки ipsec.
с модемом порядок.
ipsec между gigaIII и II. настройки идентичные. туннель работает. в логах gigaIII нет ничего подобного, только в логах II.
И ещё, нельзя ли добавить команду для принудительного включения режима только 4g, тк при установке через веб 4g режим включается, но в веб установках продолжает отображаться auto и через сутки включается 3g(хотя он слабее) и надо по новой заходить в веб чтоб включить 4g? Менял разные прошивки везде тоже самое, остановился на прошивке с telnet и adb но не могу найти соответствующие установки. Может кто знающий подскажет?
Edited by Orbit
День добрый.
При подключении кабелем (UsbLte0) раз в сутки Keenetic перегружается,
при подключении по Wireless ISP такого не наблюдается.
Есть селф-тест (30,2 МБ) при перезагрузке но ничего подозрительного в логе нет.
Edited by Orbit
  • Need more info 1
если в момент перезагрузки, то каким образом его снять? лог с включённым режимом отладки и с произвольным ребутом отправил.
Edited by Orbit
15 минут назад, Orbit сказал:
Никак. Просто пришлите селфтест.
К сожалению не помогает.
Ещё заметил что периодически в web вместо Версия ПО22.265.11.02.260 выскакивают разные данные типа Версия ПО^DSFLOWRPT:00013E5B,000087FD,0004DB44,000000008B518951,0000000587A1916B,00000000,00000000
Модем периодически шлёт "^DSFLOWRPT: какие-то цифры". Формат версий строго не определен, поэтому такие ответы невпопад могут восприниматься как версия прошивки.
Модифицировал опрос модема, исключил из него неподдерживаемые команды.
Понять причину перезагрузок пока не получилось. Так же непонятна роль модема как источника перезагрузок.
В 20.10.2018 в 23:46, Orbit сказал:
https://www.codeproject.com/Articles/120638/3G-Modem-Internet-Dialer
Цитата
^DSFLOWRPT: N1, N2, N3, N4, N5, N6, N7
        N1: Connection duration in seconds
        N2: measured upload speed
        N3: measured download speed
        N4: number of sent data
        N5: number of received data
        N6: connection, supported by the maximum upload speed
        N7: connection, supported by a maximum download speed
перевести из шестнадцатиричной системы в десятичную.
