Chervonenko_CA Posted January 29, 2019 Share Posted January 29, 2019 Пользовался Transmission и радовался. И вот: после перерыва пару недель поднял клиента, зарядил magnet. И - ничего. Журнал забит руганью: Jan 29 13:05:10transmissiond Transmission 2.84 (14307) started Jan 29 13:05:10transmissiond RPC Server Adding address to whitelist: *.*.*.* Jan 29 13:05:10transmissiond RPC Server Serving RPC and Web requests on port 127.0.0.1:8090/transmission/ Jan 29 13:05:10transmissiond RPC Server Whitelist enabled Jan 29 13:05:10transmissiond RPC Server Password required Jan 29 13:05:10transmissiond Port Forwarding Stopped Jan 29 13:05:10transmissiond DHT Reusing old id Jan 29 13:05:10transmissiond DHT Bootstrapping from 82 IPv4 nodes Jan 29 13:05:10transmissiond Using settings from "/tmp/mnt/My Book/Transmission" Jan 29 13:05:10transmissiond transmissiond requiring authentication Jan 29 13:05:10transmissiond Watching "/tmp/mnt/My Book/Transmission/watch" for new .torrent files Jan 29 13:05:10transmissiond Using inotify to watch directory "/tmp/mnt/My Book/Transmission/watch" Jan 29 13:05:10transmissiond Loaded 4 torrents Jan 29 13:05:10transmissiond Planes, Trains & Automobiles.1987.HDRip.dexter_lex.avi Could not connect to tracker Jan 29 13:05:10transmissiond Planes, Trains & Automobiles.1987.HDRip.dexter_lex.avi Retrying announce in 20 seconds. Jan 29 13:05:10transmissiond Planes, Trains & Automobiles.1987.HDRip.dexter_lex.avi Could not connect to tracker Jan 29 13:05:10transmissiond Planes, Trains & Automobiles.1987.HDRip.dexter_lex.avi Retrying announce in 20 seconds. ... Поднимаю uTorrent на компе, задаю экв.настройки сети (порт, протоколы) - качает! Что-бы это значило? Quote Link to comment Share on other sites More sharing options...
2 zyxmon Posted February 9, 2019 Share Posted February 9, 2019 2 часа назад, Алексей Аксенов сказал: Transmission начинает сканировать все 50 Гб, на что уходит примерно 1 час и только после этого начинается загрузка. Transmission, если ему правильно сказали, что делать, скачивает тот же объем, что и uTorrent. Разница лишь в том, что utorrent прячет файлы, куски которых он скачал (общие с нужным), а transmission это не умеет. На форуме transmission это обсуждалось 100 миллионов раз. Чтобы не было пересканирования - удалите торрент с данными, перед тем, как качать новую серию. Если нужно переместите предыдущие серии в свою медиатеку в отдельной папке. PS Файлы в технологии torrent хранятся не по-файлово, а чанками (chunks). PPS Моно поискать, как избежать пересканирование при обновлении. Но, если это возможно, нужно будет ставит transmission из Entware и управлять им через консоль. Quote Link to comment Share on other sites More sharing options...
0 Алексей Аксенов Posted February 9, 2019 Share Posted February 9, 2019 Здравствуйте. Есть торрент на 50 Гб, нужно скачать из него 1 файл 1Гб(новая серия сериала), с остальных файлов галочки сняты. Transmission начинает сканировать все 50 Гб, на что уходит примерно 1 час и только после этого начинается загрузка. Можно подкорректировать этот алгоритм, а то приходится качать на компе через uTorrent и скидывать на диск подключенный к Keenetic II чтоб посмотреть через DLNA. Прошивка 2.14C.0.0-4 Quote Link to comment Share on other sites More sharing options...
0 ankar84 Posted February 9, 2019 Share Posted February 9, 2019 В 29.01.2019 в 17:16, Chervonenko_CA сказал: Could not connect to tracker Думаю, что проблема в этом. Возможно на компьютере используются какие-то средства обхода блокировок, которых нет на роутере. Или у uTorrent есть какая-то технология поиска пиров, которой нет у Transmission. Quote Link to comment Share on other sites More sharing options...
0 Александр Рыжов Posted February 9, 2019 Share Posted February 9, 2019 3 часа назад, ankar84 сказал: Думаю, что проблема в этом. Возможно на компьютере используются какие-то средства обхода блокировок, которых нет на роутере. Вы издалека видите список трекеров?:) В трекерах могут быть перечислены до кучи ipv6-адреса, публичные нерабочие сервисы или retracker.local. Скачиванию это никак не мешает. Quote Link to comment Share on other sites More sharing options...
0 ankar84 Posted February 9, 2019 Share Posted February 9, 2019 1 час назад, Александр Рыжов сказал: Вы издалека видите список трекеров?:) В трекерах могут быть перечислены до кучи ipv6-адреса, публичные нерабочие сервисы или retracker.local. Скачиванию это никак не мешает. Нет. Из предложенного куска лога только эта строка показывает лично мне определённую проблему. Исходя из этого и попытался сделать вывод о причинах описанной ситуации. На истинность не претендую, просто догадка. Quote Link to comment Share on other sites More sharing options...
Chervonenko_CA
5 answers to this question
