Posted
Добрый день, при подключении внешнего HDD к роутеру не монтируется раздел для бэкапов TimeMachine (игнорируется неизвестная файловая система). На данный диск бэкапы писались на протяжении нескольких лет, последний на прошлой неделе (при подключении по USB к маку). Помогите пожалуйста разобраться в проблеме.
Keenetic Giga (KN-1010)
OS version: 2.15.C.3.0-2
Установлены модули:
* HFS+ filesystem
* File sharing (Apple File Protocol and Time Machine)
Разметка диска:
> diskutil list /dev/disk2
/dev/disk2 (external, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *500.1 GB   disk2
   1:                        EFI EFI                     209.7 MB   disk2s1
   2:                  Apple_HFS backup                  499.8 GB   disk2s2
Логи с роутера:
May 9 22:02:49 ndm
kernel: usb 2-1: new SuperSpeed USB device number 3 using xhci-hcd
May 9 22:02:49 ndm
kernel: usb 2-1: New USB device found, idVendor=0080, idProduct=a001
May 9 22:02:49 ndm
kernel: usb 2-1: Product: External USB 3.0
May 9 22:02:49 ndm
kernel: usb 2-1: Manufacturer: TOSHIBA
May 9 22:02:49 ndm
kernel: usb 2-1: SerialNumber: 201503310007F
May 9 22:02:49 ndm
kernel: scsi2 : usb-storage 2-1:1.0
May 9 22:02:53 ndm
kernel: scsi 2:0:0:0: Direct-Access TO Exter nal USB 3.0 0204 PQ: 0 ANSI: 6
May 9 22:02:53 ndm
kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
May 9 22:02:53 ndm
kernel: sd 2:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
May 9 22:02:53 ndm
kernel: sd 2:0:0:0: [sda] Write Protect is off
May 9 22:02:53 ndm
kernel: sd 2:0:0:0: [sda] Mode Sense: 47 00 00 08
May 9 22:02:53 ndm
kernel: sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 9 22:02:53 ndm
kernel: sda: sda1 sda2
May 9 22:02:53 ndm
kernel: sd 2:0:0:0: [sda] Attached SCSI disk
May 9 22:02:53 ndm
FileSystem::Ext: "/dev/sda" has an unknown partition type, ignored.
May 9 22:02:53 ndm
FileSystem::Ext: vfat "67E3-17ED:": filesystem initialized.
May 9 22:02:53 ndm
kernel: tfat: fail_safe is enabled
May 9 22:02:53 ndm
kernel: tfat: cluster_heap_lbo 0x317c00
May 9 22:02:53 ndm
kernel: tfat: 9 blkbits for normal inodes
May 9 22:02:53 ndm
kernel: tfat: fat start lbo 0x4000
May 9 22:02:53 ndm
kernel: tfat: 9 blkbits for main FAT32 inode
May 9 22:02:53 ndm
kernel: tfat: cluster size 512
May 9 22:02:53 ndm
kernel: tfat info: FAT32 volume name 'EFI', version 0.0.
May 9 22:02:53 ndm
FileSystem::Repository: "67E3-17ED:" registered.
May 9 22:02:53 ndm
FileSystem::Ext: "/dev/sda2" has an unknown partition type, ignored.
May 9 22:09:19 ndm
FileSystem::Repository: "67E3-17ED:" unmounted.
May 9 22:09:19 ndm
FileSystem::Repository: all USB storages in port 1 unmounted.
15 answers to this question
Posted
11 минуту назад, imanin сказал:
Установлены модули:
* HFS+ filesystem
Разметка диска:
Логи с роутера:
May 9 22:02:49 ndm
May 9 22:02:49 ndm
May 9 22:02:49 ndm
May 9 22:02:49 ndm
May 9 22:02:49 ndm
May 9 22:02:49 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:02:53 ndm
May 9 22:09:19 ndm
May 9 22:09:19 ndm
А какая на этом диске файловая система реально?
Posted
Этот раздел когда-нибудь монтировался в Keenetic?
Posted
Судя по diskutil Apple_HFS, и в целом когда диск впервые использовался для бэкапов macOS отформатировала его в Mac OS Extended (HFS+).
Нет, сегодня впервые подключил его к Keenetic, как раз чтобы попробовать TimeMachine по сети.
Posted
Может есть какая то разница для HFS и HFS+? И кинетик не пониает HFS+? Я не работал никогда с этими файловыми системами.
Posted (edited)
Разница есть, но насколько я знаю простая HFS уже давно не искользуется, и метка Apple_HFS свидетельствует именно о HFS+, она же называется Mac OS Extended.
https://en.wikipedia.org/wiki/HFS_Plus
 И к тому же, у Keenetic модуль называется именно HFS+ ¯\_(ツ)_/¯
Edited by imanin
Posted
5 минут назад, Илья Картавенко сказал:
Должен понимать:
Цитата
Posted (edited)
@imanin Компоненты все установлены?Первый пост не прочитал внимательно.
Edited by AndreBA
Posted
Вы имеете в виду вообще все или те которые у вас на скриншоте?)
Я в первом сообщении упомянул, что установлены:
* HFS+ filesystem
Но вот скрин вообще всех модулей для USB:
Posted
3 минуты назад, imanin сказал:
Я уже исправил свой пост:
10 минут назад, AndreBA сказал:
Posted
@imaninСейчас форматнул (правда флешку) в HFS+. Определилась и примонтировалась
Цитата
Может вашему роутеру раздел "EFI" не нравиться(так предположение).
Posted
1 минуту назад, AndreBA сказал:
Может быть. Но если я правильно понимаю, то механизм монтирывания разделов, как в линукс. А значит можно примонтирывать отдельные разделы.
Posted
2 минуты назад, Илья Картавенко сказал:
С разными разделами монтируется(пробовал). Просто в данном случае предположил(в EFI обычно загрузчик устанавливается).
Posted
3 minutes ago, Илья Картавенко said:
Так все, что нужно установленно. А сколько свободного места на разделе?
Свободно около 25GB
EFI монтируется, но это по сути загрузочный раздел. (Так macOS форматирует HDD под TimeMachine. Видимо для возможности восстановления системы во время загрузки) Судя по логам при монтировании проходится по всем разделам, но почему-то второй раздел, с HFS+ ему не нравится (FileSystem::Ext: "/dev/sda2" has an unknown partition type, ignored.)
Posted
Свободно около 25GB
А если раздел EFI и в правду убрать.
