vasek00 Posted December 6, 2019 Share Posted December 6, 2019 Столкнулся с такой ошибкой данной програмки / # opkg install iotop Installing iotop (0.6-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/iotop_0.6-1_mipsel-3.4.ipk Configuring iotop. / # iotop -obPat Could not run iotop as some of the requirements are not met: - Linux >= 2.6.20 with - I/O accounting support (CONFIG_TASKSTATS, CONFIG_TASK_DELAY_ACCT, CONFIG_TASK_IO_ACCOUNTING) - VM event counters (CONFIG_VM_EVENT_COUNTERS) / # 2 Quote Link to comment Share on other sites More sharing options...
vasek00 Posted December 6, 2019 Author Share Posted December 6, 2019 так же / # opkg install fatrace Installing fatrace (0.13-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/fatrace_0.13-1_mipsel-3.4.ipk Configuring fatrace. / # fatrace -h Usage: fatrace [options...] Options: -c, --current-mount Only record events on partition/mount of current directory. -o FILE, --output=FILE Write events to a file instead of standard output. -s SECONDS, --seconds=SECONDS Stop after the given number of seconds. -t, --timestamp Add timestamp to events. Give twice for seconds since the epoch. -p PID, --ignore-pid PID Ignore events for this process ID. Can be specified multiple times. -f TYPES, --filter=TYPES Show only the given event types; choose from C, R, O, or W, e. g. --filter=OC. -C COMM, --command=COMM Show only events for this command. -h, --help Show help. / # fatrace Cannot initialize fanotify: Function not implemented / # fatrace -t -s 30 Cannot initialize fanotify: Function not implemented 1 Quote Link to comment Share on other sites More sharing options...
Александр Рыжов Posted December 6, 2019 Share Posted December 6, 2019 На системе назначения не реализованы нужные sycall'ы, увы. Quote Link to comment Share on other sites More sharing options...
vasek00 Posted December 6, 2019 Author Share Posted December 6, 2019 Понял Quote Link to comment Share on other sites More sharing options...
TheBB Posted December 6, 2019 Share Posted December 6, 2019 Первый отвалился ещё во времена 2.07. Собственно, вопрос надо адресовать "ядерщикам"* на предмет включения, если такое возможно. --- * разработчикам прошивки Quote Link to comment Share on other sites More sharing options...
