Максим Галамай Posted March 19, 2020 Share Posted March 19, 2020 Доброго времени суток, форумчане! Имею проблемы с подключением openvpn на роутере к Keenetic Giga к серверу OpenVpn, через нативный клиент всё подключается и работает. Конфиг: Hide contents client dev tap proto tcp remote x.x.x.x 443 nobind persist-key persist-tun cipher BF-CBC comp-lzo verb 5 mute 20 <tls-crypt> -----BEGIN OpenVPN Static key V1----- -----END OpenVPN Static key V1----- </tls-crypt> <ca> -----BEGIN CERTIFICATE----- -----END CERTIFICATE----- </ca> <cert> -----BEGIN CERTIFICATE----- -----END CERTIFICATE----- </cert> <key> -----BEGIN RSA PRIVATE KEY----- -----END RSA PRIVATE KEY----- </key> Регистрируемые в логе ошибки, дальше по кругу просто идёт одно и тоже: Hide contents Мар 18 21:30:27 ndm Core::Syslog: the system log has been cleared. Мар 18 21:30:50 ndm Network::Interface::Base: "OpenVPN0": interface is up. Мар 18 21:30:50 ndm Core::ConfigurationSaver: saving configuration... Мар 18 21:30:52 OpenVPN0 OpenVPN 2.4.6 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD] Мар 18 21:30:52 OpenVPN0 library versions: OpenSSL 1.1.1d 10 Sep 2019, LZO 2.10 Мар 18 21:30:52 OpenVPN0 Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key Мар 18 21:30:52 OpenVPN0 Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication Мар 18 21:30:52 OpenVPN0 Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key Мар 18 21:30:52 OpenVPN0 Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication Мар 18 21:30:52 OpenVPN0 LZO compression initializing Мар 18 21:30:52 OpenVPN0 Control Channel MTU parms [ L:1656 D:1154 EF:96 EB:0 ET:0 EL:3 ] Мар 18 21:30:52 OpenVPN0 Data Channel MTU parms [ L:1656 D:1450 EF:124 EB:412 ET:32 EL:3 ] Мар 18 21:30:52 OpenVPN0 Local Options String (VER=V4): 'V4,dev-type tap,link-mtu 1576,tun-mtu 1532,proto TCPv4_CLIENT,comp-lzo,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-client' Мар 18 21:30:52 OpenVPN0 Expected Remote Options String (VER=V4): 'V4,dev-type tap,link-mtu 1576,tun-mtu 1532,proto TCPv4_SERVER,comp-lzo,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-server' Мар 18 21:30:52 OpenVPN0 Socket Buffers: R=[87380->87380] S=[16384->16384] Мар 18 21:30:52 OpenVPN0 Attempting to establish TCP connection with [AF_INET]x.x.x.x:443 [nonblock] Мар 18 21:30:53 ndm Core::ConfigurationSaver: configuration saved. Мар 18 21:30:53 OpenVPN0 TCP connection established with [AF_INET]x.x.x.x:443 Мар 18 21:30:53 OpenVPN0 TCP_CLIENT link local: (not bound) Мар 18 21:30:53 OpenVPN0 TCP_CLIENT link remote: [AF_INET]x.x.x.x:443 Мар 18 21:30:53 OpenVPN0 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay Мар 18 21:30:54 OpenVPN0 Connection reset, restarting [0] Мар 18 21:30:54 OpenVPN0 TCP/UDP: Closing socket Мар 18 21:30:54 OpenVPN0 SIGTERM[soft,connection-reset] received, process exiting Мар 18 21:30:54 ndm Service: "OpenVPN0": unexpectedly stopped. Прошу помощи, товарищи! Quote Link to comment Share on other sites More sharing options...
techno Posted May 6, 2020 Share Posted May 6, 2020 Здравствуйте. Была такая же ерунда. Заменил <tls-crypt> на <tls-auth> и </tls-crypt> на </tls-auth>. После </tls-auth> добавил строку key-direction 1 И заработало. Наверное, надо изучать документацию. Но где взять время, если это не по специальности... Надеюсь поможет Quote Link to comment Share on other sites More sharing options...
Максим Галамай Posted May 7, 2020 Author Share Posted May 7, 2020 22 hours ago, techno said: Здравствуйте. Была такая же ерунда. Заменил <tls-crypt> на <tls-auth> и </tls-crypt> на </tls-auth>. После </tls-auth> добавил строку key-direction 1 И заработало. Наверное, надо изучать документацию. Но где взять время, если это не по специальности... Надеюсь поможет Доброго времени суток! Спасибо за ответ! Проблема уже решена. только деректива по ключу была добавлена вместо key-direction 1 tls-auth ta.key 0. Приведу пример конфига, может кому-то будет полезным: ------------------------------------------------------------------------------------- client dev tap proto tcp remote xxx.xxx.xxx.xxx 443 nobind persist-key persist-tun tls-auth ta.key 0 cipher BF-CBC comp-lzo verb 5 mute 20 <ca> -----BEGIN CERTIFICATE----- -----END CERTIFICATE----- </ca> <cert> -----BEGIN CERTIFICATE----- -----END CERTIFICATE----- </cert> <key> -----BEGIN RSA PRIVATE KEY----- -----END RSA PRIVATE KEY----- </key> <tls-auth> -----BEGIN OpenVPN Static key V1----- -----END OpenVPN Static key V1----- </tls-auth> ------------------------------------------------------------------------------------ 1 Quote Link to comment Share on other sites More sharing options...
