Ahmed Ensar Posted May 16, 2020 Posted May 16, 2020 Google Translate: I cannot access the web interface from the local network after the 3.4.1 update. https://my.keenetic.net ---> the page never opens http://my.keenetic.net ---> I'm redirecting to domain page https://XXX.keenetic.pro https://192.168.1.1 ---> the page never opens http://192.168.1.1 --> the page opens but nothing happens when you press login https://XXX.keenetic.pro --> opening smoothly Quote
0 Le ecureuil Posted May 16, 2020 Posted May 16, 2020 You can't access my.keenetic.net via SSL by design, so that's OK. Plaintext request to my.keeentic.net redirects you to SSL-secured KeenDNS domain, that's OK. Try to use this scenario if possible. Direct SSL requests to IP is prohibited since 3.4 (because it is useless), that's OK also. Plaintext access to IP must work like before, seems like a bug. Try to flush your web-browser cache, and if nothing will change please file a bug report in the official help center. Quote
0 Ahmed Ensar Posted May 18, 2020 Author Posted May 18, 2020 192.168.1.1 ile session çerez vb. silerek girebildim. 👍 1 Quote
Ahmed Ensar
Google Translate:
2 answers to this question
