al12s Posted August 30, 2021 Share Posted August 30, 2021 Решил на тестовом устройстве выполнить установку с 0... все по пунктам в итоге HASS не запускается вообще. Видимо какие-то обновления вышли, а HASS нет. Quote Link to comment Share on other sites More sharing options...
al12s Posted August 30, 2021 Share Posted August 30, 2021 (edited) echo "src/gz ha http://bin.entware.net/mipselsf-k3.4/test/HA" >> /opt/etc/opkg.conf opkg update opkg install gcc ldd make gawk sed patch diffutils coreutils-install libffi source /opt/bin/gcc_env.sh opkg install homeassistant ~ # /opt/etc/init.d/S99hass start Starting hass... done. ~ # /opt/etc/init.d/S99hass status Checking hass... dead. ~ # hass --debug -c /opt/var/lib/homeassistant Traceback (most recent call last): File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 568, in _build_master File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 886, in require File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 777, in resolve pkg_resources.ContextualVersionConflict: (requests 2.26.0 (/opt/lib/python3.9/site-packages), Requirement.parse('requests==2.25.1'), {'homeassistant'}) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/opt/bin/hass", line 33, in <module> sys.exit(load_entry_point('homeassistant==2021.8.6', 'console_scripts', 'hass')()) File "/opt/lib/python3.9/site-packages/homeassistant/__main__.py", line 280, in main File "/opt/lib/python3.9/site-packages/homeassistant/__main__.py", line 61, in get_arguments File "/opt/lib/python3.9/site-packages/homeassistant/config.py", line 18, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/auth/__init__.py", line 18, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/auth/mfa_modules/__init__.py", line 12, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/requirements.py", line 13, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/util/package.py", line 13, in <module> File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3243, in <module> File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3226, in _call_aside File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3255, in _initialize_master_working_set File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 570, in _build_master File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 583, in _build_from_requirements File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 772, in resolve pkg_resources.DistributionNotFound: The 'requests==2.25.1' distribution was not found and is required by homeassistant после pip install requests==2.25.1 выдает еще ошибки в версиях компонентов, устанавливал... ничего не выходит Edited August 30, 2021 by al12s Quote Link to comment Share on other sites More sharing options...
TheBB Posted August 30, 2021 Share Posted August 30, 2021 bump to 2021.8.8 1 Quote Link to comment Share on other sites More sharing options...
OlegOs Posted August 31, 2021 Share Posted August 31, 2021 TheBB, спасибо за обновление, обновился удачно, полёт нормальный ! 1 Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 6, 2021 Share Posted September 6, 2021 bump to 2021.9.3 Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 7, 2021 Share Posted September 7, 2021 bump to 2021.9.4 added homeassistant-cli ~ # ~ # hass-cli --version hass-cli, version 0.9.4 ~ # Скрытый текст ~ # ~ # hass-cli info BASE_URL LOCATION REQUIRES_API_PASSWORD VERSION http://ip.add.re.ss:8123 Home Assistant True 2021.9.4 ~ # ~ # hass-cli state list ENTITY DESCRIPTION STATE CHANGED person.tester tester unknown 2021-09-07T10:22:41.968862+00:00 sun.sun Sun above_horizon 2021-09-07T10:22:53.604363+00:00 zone.home Home Assistant zoning 2021-09-07T10:22:58.983330+00:00 binary_sensor.updater Updater off 2021-09-07T10:23:00.182321+00:00 weather.home_assistant Home Assistant cloudy 2021-09-07T10:23:11.473795+00:00 binary_sensor.keenetic_viva_kn_1910_online Keenetic Viva (KN-1910) Online on 2021-09-07T10:23:11.619045+00:00 device_tracker.keenetic_ultra_ii Keenetic Ultra II home 2021-09-07T10:23:12.152176+00:00 binary_sensor.keenetic_gateway_wan_status Keenetic Gateway wan status on 2021-09-07T10:23:15.127582+00:00 sensor.keenetic_gateway_b_received Keenetic Gateway B received 834071218 2021-09-07T10:42:16.287210+00:00 sensor.keenetic_gateway_b_sent Keenetic Gateway B sent 3172951906 2021-09-07T10:42:16.288883+00:00 sensor.keenetic_gateway_packets_received Keenetic Gateway packets received 15193888 2021-09-07T10:42:16.290713+00:00 sensor.keenetic_gateway_packets_sent Keenetic Gateway packets sent 18617328 2021-09-07T10:42:16.292312+00:00 sensor.keenetic_gateway_kib_s_received Keenetic Gateway KiB/s received 1.1 2021-09-07T10:42:16.294344+00:00 sensor.keenetic_gateway_kib_s_sent Keenetic Gateway KiB/s sent 1.2 2021-09-07T10:42:16.296183+00:00 sensor.keenetic_gateway_packets_s_received Keenetic Gateway packets/s received 7.9 2021-09-07T10:42:16.297981+00:00 sensor.keenetic_gateway_packets_s_sent Keenetic Gateway packets/s sent 11.5 2021-09-07T10:42:16.299938+00:00 persistent_notification.config_entry_discovery New devices discovered notifying 2021-09-07T10:25:12.719496+00:00 ~ # ~ # hass-cli device list ID NAME MODEL MANUFACTURER AREA idididididididididididididididid Forecast Forecast Met.no idididididididididididididididid Keenetic Gateway Keenetic Gateway Keenetic Ltd. idididididididididididididididid Keenetic Viva (KN-1910) Viva (KN-1910) Keenetic Ltd. idididididididididididididididid Keenetic Ultra II None None ~ # Quote Link to comment Share on other sites More sharing options...
OlegOs Posted September 7, 2021 Share Posted September 7, 2021 TheBB, спасибо за обновление, обновился удачно, всё работает ! только hass-cli не находится Скрытый текст ~ # /opt/etc/init.d/S99hass start Starting hass... done. ~ # hass-cli --version -sh: hass-cli: not found ~ # hass-cli info -sh: hass-cli: not found ~ # hass-cli state list -sh: hass-cli: not found ~ # hass-cli device list -sh: hass-cli: not found ~ # Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 7, 2021 Share Posted September 7, 2021 ~ # opkg update Downloading http://bin.entware.net/mipselsf-k3.4/Packages.gz Updated list of available packages in /opt/var/opkg-lists/entware Downloading http://bin.entware.net/mipselsf-k3.4/keenetic/Packages.gz Updated list of available packages in /opt/var/opkg-lists/keendev Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/Packages.gz Updated list of available packages in /opt/var/opkg-lists/ha ~ # opkg info homeassistant-cli Package: homeassistant-cli Version: 0.9.4-1 Depends: libc, libssp, librt, libpthread, python3-aiohttp, python3-click-log, python3-click, python3-dateparser, python3-jinja2, python3-jsonpath-ng, python3-netdisco, python3-regex, python3-ruamel-yaml, python3-requests, python3-tabulate Status: unknown ok not-installed Section: utils Architecture: mipsel-3.4 Size: 53017 Filename: homeassistant-cli_0.9.4-1_mipsel-3.4.ipk Description: The Home Assistant Command-line interface (hass-cli) allows one to work with a local or a remote Home Assistant Core or Home Assistant (former Hass.io) instance directly from the command-line. ~ # opkg install homeassistant-cli Installing homeassistant-cli (0.9.4-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/homeassistant-cli_0.9.4-1_mipsel-3.4.ipk Installing python3-click-log (0.3.2-2) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-click-log_0.3.2-2_mipsel-3.4.ipk Installing python3-dateparser (1.0.0-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-dateparser_1.0.0-1_mipsel-3.4.ipk Installing python3-decorator (4.4.2-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-decorator_4.4.2-1_mipsel-3.4.ipk Installing python3-jsonpath-ng (1.5.2-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-jsonpath-ng_1.5.2-1_mipsel-3.4.ipk Installing python3-netdisco (2.9.0-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-netdisco_2.9.0-1_mipsel-3.4.ipk Installing python3-regex (2021.8.21-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/python3-regex_2021.8.21-1_mipsel-3.4.ipk Installing python3-tabulate (0.8.9-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-tabulate_0.8.9-1_mipsel-3.4.ipk Configuring python3-dateparser. Configuring python3-tabulate. Configuring python3-regex. Configuring python3-decorator. Configuring python3-click-log. Configuring python3-jsonpath-ng. Configuring python3-netdisco. Configuring homeassistant-cli. *** Please install homeassistant package manually *** ~ # hass-cli --version hass-cli, version 0.9.4 ~ # Quote Link to comment Share on other sites More sharing options...
OlegOs Posted September 7, 2021 Share Posted September 7, 2021 hass-cli заработал, Интересно, кто-нибудь ставил HA+mqtt+zigbee2mqtt, вывезет ли keenetic по ресурсам? Сейчас всё настроено через ZHA, но не все параметры у zigbee девайсов доступны. Quote Link to comment Share on other sites More sharing options...
al12s Posted September 8, 2021 Share Posted September 8, 2021 (edited) TheBB, спасибо за обновление, После обновления в логах появилась ошибка на PyTurboJPEG==1.5.2 и очень долго загружался HA. После pip3 install PyTurboJPEG==1.5.2 ошибка в логах пропала и все заработало как надо. Edited September 8, 2021 by al12s 1 Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 8, 2021 Share Posted September 8, 2021 8 минут назад, al12s сказал: После обновления в логах появилась ошибка на PyTurboJPEG==1.5.2 и очень долго загружался HA. После pip3 install PyTurboJPEG==1.5.2 ошибка в логах пропала и все заработало как надо. ~ # ~ # opkg info python3-pyturbojpeg Package: python3-pyturbojpeg Version: 1.5.2-1 Depends: libc, libssp, librt, libpthread, python3-numpy, libjpeg-turbo Status: install user installed Section: lang Architecture: mipsel-3.4 Size: 9299 Filename: python3-pyturbojpeg_1.5.2-1_mipsel-3.4.ipk Description: A Python wrapper of libjpeg-turbo for decoding and encoding JPEG image. Installed-Time: 1630940114 ~ # Quote Link to comment Share on other sites More sharing options...
al12s Posted September 8, 2021 Share Posted September 8, 2021 (edited) при установке с "нуля" этот пакет не устанавливается. так же при установки с "нуля" после запуска в log ошибка Unable to install package python-miio==0.5.6, хотя установлен python-miio==0.5.8, с ним не работает? Edited September 8, 2021 by al12s Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 8, 2021 Share Posted September 8, 2021 Пакет "python-miio" не собирался, его нет. Надо смотреть откуда НА пытается вытянуть настройки, или с соседнего устройства (с установленным НА), или из облака... Quote Link to comment Share on other sites More sharing options...
al12s Posted September 9, 2021 Share Posted September 9, 2021 (edited) Подскажите пожалуйста, датчик перенес с одного Xiaomi gateway 3 на другой, физически на первом Xiaomi Gateway 3 его нет, но HA в списке устройство в ячейке интеграция выводить и на первой и второй интеграции. Как отвязать его в HA от первого Xiaomi Gateway 3? Edited September 9, 2021 by al12s Quote Link to comment Share on other sites More sharing options...
al12s Posted September 9, 2021 Share Posted September 9, 2021 Если зайти в сам датчик в настройки - зависимости, то у него стоит две интеграции, хотя физически от первого Xiaomi Gateway он отвязан, да забыл уточнить, датчик bluetooth. Quote Link to comment Share on other sites More sharing options...
dancom Posted September 13, 2021 Share Posted September 13, 2021 В 08.09.2021 в 14:53, al12s сказал: при установке с "нуля" этот пакет не устанавливается. так же при установки с "нуля" после запуска в log ошибка Unable to install package python-miio==0.5.6, хотя установлен python-miio==0.5.8, с ним не работает? надо ставить сначала gcc. В районе 3-й -4-й страницы я уже спотыкался на эти грабли. Посмотри по моим постам. В 09.09.2021 в 10:11, al12s сказал: Если зайти в сам датчик в настройки - зависимости, то у него стоит две интеграции, хотя физически от первого Xiaomi Gateway он отвязан, да забыл уточнить, датчик bluetooth. у меня НА с большой задержкой иногда отвязывает/цепляет устройства. Попробуй в МиНоме вручную отвяжи его, если еще не сделал. Интеграция стоит XiaomiGateway3 от AlexITT Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 14, 2021 Share Posted September 14, 2021 bump to 2021.9.6 Quote Link to comment Share on other sites More sharing options...
umc Posted September 14, 2021 Share Posted September 14, 2021 Подскажите как установить HASS Configurator ? Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 15, 2021 Share Posted September 15, 2021 8 часов назад, umc сказал: Подскажите как установить HASS Configurator ? https://github.com/danielperna84/hass-configurator/wiki/Installation 1 Quote Link to comment Share on other sites More sharing options...
OlegOs Posted September 15, 2021 Share Posted September 15, 2021 TheBB, спасибо за обновление, всё работает ! 1 Quote Link to comment Share on other sites More sharing options...
Dmitriy Sovin Posted September 20, 2021 Share Posted September 20, 2021 Здравствуйте! Подскажите пожалуйста, как решить проблему. HA поднят на Keenetic VIVA (KN-1910) на данный момент версия HA 2021.8.8 Интеграции: Tuya (9 устройств), Xiaomi Gateway 3 (13 устройств), Yandex Smart Home. К сожалению происходит зависание HA раз в 3-4 дня, помогает только полная перезагрузка Keenetic. На данный момент установка чистая, я не производил update, upgrade, так как при регулярном обновление зависание происходило ежедневно. Я понимаю что у моей модели мало оперативной памяти, но и зависание не происходит сразу, т.е. такое ощущение что происходит какое то переполнение. Можете ли подсказать вероятную причину и решение? Спасибо! Quote Link to comment Share on other sites More sharing options...
OlegOs Posted September 20, 2021 Share Posted September 20, 2021 9 часов назад, Dmitriy Sovin сказал: Я понимаю что у моей модели мало оперативной памяти Оперативки да, мало, а виртуальная подкачка памяти настроена? Quote Link to comment Share on other sites More sharing options...
Dmitriy Sovin Posted September 20, 2021 Share Posted September 20, 2021 47 минут назад, Олег Осипов сказал: Оперативки да, мало, а виртуальная подкачка памяти настроена? Да, Linux Swap 512 мб имеется! Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 21, 2021 Share Posted September 21, 2021 bump to 2021.9.7 Quote Link to comment Share on other sites More sharing options...
alex1 Posted September 22, 2021 Share Posted September 22, 2021 (edited) добрый день, проблема с обновлением Xiaomi Gateway 3 с версии 1.4.0 на новее. После обновления вылетает ошибка. На версии 1.4.0 все работает прекрасно. На версии новее в логах вылетает ошибка: при этом zigbee устройства не активные. Logger: custom_components.xiaomi_gateway3.core.gateway3 Source: custom_components/xiaomi_gateway3/core/unqlite.py:113 Integration: Xiaomi Gateway 3 (documentation, issues) First occurred: 14:18:51 (1 occurrences) Last logged: 14:18:51 Can't read mesh devices Traceback (most recent call last): File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/gateway3.py", line 741, in _get_devices db = SQLite(raw) File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 87, in __init__ self.read_db_header() File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 113, in read_db_header assert self.read(16) == b'SQLite format 3\0', "Wrong file signature" AssertionError: Wrong file signature Edited September 22, 2021 by alex1 Quote Link to comment Share on other sites More sharing options...
OlegOs Posted September 22, 2021 Share Posted September 22, 2021 TheBB, спасибо, обновился удачно ! Quote Link to comment Share on other sites More sharing options...
al12s Posted September 24, 2021 Share Posted September 24, 2021 (edited) В 22.09.2021 в 14:19, alex1 сказал: добрый день, проблема с обновлением Xiaomi Gateway 3 с версии 1.4.0 на новее. После обновления вылетает ошибка. На версии 1.4.0 все работает прекрасно. На версии новее в логах вылетает ошибка: при этом zigbee устройства не активные. Logger: custom_components.xiaomi_gateway3.core.gateway3 Source: custom_components/xiaomi_gateway3/core/unqlite.py:113 Integration: Xiaomi Gateway 3 (documentation, issues) First occurred: 14:18:51 (1 occurrences) Last logged: 14:18:51 Can't read mesh devices Traceback (most recent call last): File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/gateway3.py", line 741, in _get_devices db = SQLite(raw) File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 87, in __init__ self.read_db_header() File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 113, in read_db_header assert self.read(16) == b'SQLite format 3\0', "Wrong file signature" AssertionError: Wrong file signature Эту проблему решил, версия самого девайса Xiaomi Gateway 3 была 1.4.6_0012 — рекомендована AlexxIT, и в этом крылась проблема, обновил до 1.5.0_0102 — рекомендована AlexxIT и все прекрасно завелось. Edited September 24, 2021 by al12s Quote Link to comment Share on other sites More sharing options...
al12s Posted September 24, 2021 Share Posted September 24, 2021 В 08.09.2021 в 13:50, TheBB сказал: ~ # ~ # opkg info python3-pyturbojpeg Package: python3-pyturbojpeg Version: 1.5.2-1 Depends: libc, libssp, librt, libpthread, python3-numpy, libjpeg-turbo Status: install user installed Section: lang Architecture: mipsel-3.4 Size: 9299 Filename: python3-pyturbojpeg_1.5.2-1_mipsel-3.4.ipk Description: A Python wrapper of libjpeg-turbo for decoding and encoding JPEG image. Installed-Time: 1630940114 ~ # Удалил PyTurboJPEG==1.5.2, установил python3-pyturbojpeg ошибки пропали, HA заработал стабильно, но теперь в логах появились ошибки Logger: homeassistant.components.camera.img_util Source: deps/lib/python3.9/site-packages/turbojpeg.py:492 Integration: Камера (documentation, issues) First occurred: 12:41:01 (1 occurrences) Last logged: 12:41:01 Error loading libturbojpeg; Cameras may impact HomeKit performance Traceback (most recent call last): File "/opt/lib/python3.9/site-packages/homeassistant/components/camera/img_util.py", line 96, in __init__ File "/opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/turbojpeg.py", line 148, in __init__ self.__find_turbojpeg() if lib_path is None else lib_path) File "/opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/turbojpeg.py", line 492, in __find_turbojpeg raise RuntimeError( RuntimeError: Unable to locate turbojpeg library automatically. You may specify the turbojpeg library path manually. e.g. jpeg = TurboJPEG(lib_path) Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 25, 2021 Share Posted September 25, 2021 В 24.09.2021 в 14:14, al12s сказал: Удалил PyTurboJPEG==1.5.2, установил python3-pyturbojpeg ошибки пропали, HA заработал стабильно, но теперь в логах появились ошибки зачистить "хвосты" - /opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/turbojpeg.py /opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/PyTurboJPEG-* 1 Quote Link to comment Share on other sites More sharing options...
umc Posted September 27, 2021 Share Posted September 27, 2021 В 15.09.2021 в 09:55, TheBB сказал: https://github.com/danielperna84/hass-configurator/wiki/Installation по данной ссылке установил hass-configurator таким способом pip install hass-configurator .... как теперь сделать чтоб он запускался автоматически после включения роутера? Quote Link to comment Share on other sites More sharing options...
