Posts
131 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Downloads
Blogs
Events
Posts posted by OlegOs
У кого-нибудь работает заявленный в новой версии Icon Picker https://www.home-assistant.io/blog/2021/11/03/release-202111/#the-icon-picker ?
У меня на кинетике в core - нет, а на виртуалке в полной версии - работает.
После того как сделал opkg upgrade, всё завелось. Думал что хватит remove и install. Спасибо !
И еще по вот что:
Скрытый текст~ # hass
Traceback (most recent call last):
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 568, in _build_master
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 886, in require
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 777, in resolve
pkg_resources.ContextualVersionConflict: (PyYAML 5.4.1 (/opt/lib/python3.9/site-packages), Requirement.parse('pyyaml==6.0'), {'homeassistant'})During handling of the above exception, another exception occurred:
File "/opt/bin/hass", line 33, in <module>
sys.exit(load_entry_point('homeassistant==2021.11.3', 'console_scripts', 'hass')())
File "/opt/lib/python3.9/site-packages/homeassistant/__main__.py", line 281, in main
File "/opt/lib/python3.9/site-packages/homeassistant/__main__.py", line 64, in get_arguments
File "/opt/lib/python3.9/site-packages/homeassistant/config.py", line 19, in <module>
File "/opt/lib/python3.9/site-packages/homeassistant/auth/__init__.py", line 18, in <module>
File "/opt/lib/python3.9/site-packages/homeassistant/auth/mfa_modules/__init__.py", line 12, in <module>
File "/opt/lib/python3.9/site-packages/homeassistant/requirements.py", line 14, in <module>
File "/opt/lib/python3.9/site-packages/homeassistant/util/package.py", line 13, in <module>
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3243, in <module>
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3226, in _call_aside
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3255, in _initialize_master_working_set
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 570, in _build_master
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 583, in _build_from_requirements
File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 772, in resolve
pkg_resources.DistributionNotFound: The 'pyyaml==6.0' distribution was not found and is required by homeassistant
TheBB, спасибо за обновление !
Но почему-то после remove и install, hass стартует и сразу вываливается смотрю командой top
Скрытый текст~ # opkg remove homeassistant
Removing package homeassistant from root...
~ # opkg install homeassistant
Installing homeassistant (2021.11.3-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/homeassistant_2021.11.3-1_mipsel-3.4.ipk
Configuring homeassistant.*** Prepare your device to use the Home Assistant ***
Please read the wiki:
https://github.com/Entware/Entware/wiki/Self-installation-of-python-modules~ # /opt/etc/init.d/S99hass start
Starting hass... done.
~ # top
Mem: 235308K used, 19316K free, 432K shrd, 18764K buff, 69424K cached
CPU: 25.5% usr 8.5% sys 0.0% nic 65.9% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 0.94 0.57 0.30 4/254 3721
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
3713 1 root R 36840 14.3 0 24.0 {hass} /opt/bin/python3 /opt/bin/hass -c /opt/var/lib/homeassistant
2987 2 root SW 0 0.0 3 4.0 [kworker/3:1]
257 1 root S 39708 15.5 1 2.0 ndm
3721 3471 root R 3880 1.5 2 2.0 top
Ошибок при обновлении не было, в логах ha тоже ничего нет, похоже до них не доходит,
сделал remove и install прошлой версии, проблема осталась, стартует и вываливается
И ещё заметил что install происходит подозрительно быстро, раньше дольше ставилось
TheBB, спасибо, всё работает !
TheBB, спасибо, всё обновилось и работает !
- 1
TheBB, спасибо за обновление,
обновился удачно, вроде всё работает !
Если не сложно обновите пожалуйста z2m до 1.21.2 - https://github.com/Koenkk/zigbee2mqtt/releases/tag/1.21.2
- 1
В 07.09.2021 в 21:56, Олег Осипов сказал:
hass-cli заработал,
Интересно, кто-нибудь ставил HA+mqtt+zigbee2mqtt, вывезет ли keenetic по ресурсам?
Сейчас всё настроено через ZHA, но не все параметры у zigbee девайсов доступны.
Отвечу сам себе, настроил я всю эту связку HA+mosquitto+zigbee2mqtt на своём Keenetic
Всё работает ! В отличии от ZHA , намного больше поддерживаемых устройств и настроек !
TheBB, спасибо, разобрался !
Напрямую с дебагом начинает запускаться, не запускается со скрипта S99hass start вручную, с перезагрузкой роутера стартует нормально
Скрытый текст~ # ~ # /opt/etc/init.d/S99hass start
-sh: /opt/root: Permission denied
~ # hass -c /opt/var/lib/homeassistant --debug
2021-10-03 16:10:07 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration gismeteo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-03 16:10:07 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-03 16:10:07 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration yandex_smart_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-03 16:10:07 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
После одного из последних обновлений ha перестал стартовать командой:
-sh: /opt/root: Permission deniedстартует только с перезагрузкой роутера.
всё работает под root
В чём может быть проблема ?
TheBB, спасибо, обновился удачно !
9 часов назад, Dmitriy Sovin сказал:
Я понимаю что у моей модели мало оперативной памяти
Оперативки да, мало, а виртуальная подкачка памяти настроена?
TheBB, спасибо за обновление, всё работает !
- 1
hass-cli заработал,
обновился удачно, всё работает !
только hass-cli не находится
Скрытый текст~ # /opt/etc/init.d/S99hass start
~ # hass-cli --version
-sh: hass-cli: not found
~ # hass-cli info
~ # hass-cli state list
~ # hass-cli device list
обновился удачно, полёт нормальный !
- 1
В 22.08.2021 в 23:40, Leader Leader сказал:
Внезапно. После очередного спонтанного ребута (похоже, все-таки, не вытягивает роутер всякие Adguard-ы и прочие HA - иконка стала оранжевой. Интергация заработала!
У меня стабильно работает, правда есть раздел подкачки и всё на ssd установлено. Без подкачки тоже плохо было, озу маленькое у роутера.
Ссылки на www так пишете?
elements:
- type: image
entity: light.kitchen_lustra
state_image:
'on': /local/Plan/kitchen_lamp.png
'off': /local/Plan/transparent.png -
15 часов назад, Leader Leader сказал:
Нужен каталог www
Создаю его, но HA его не видит и ругается.
Что-то вырезано?
Каталог www у меня нормально работает, может с правами доступа чего не так?
TheBB, спасибо за оперативность, обновился удачно !
- 1
TheBB, спасибо за обновление, обновился удачно !
- 1
53 минуты назад, neomatic сказал:
И снова здравствуйте.
Не могу разобраться как подключить HA к яндексу
https://github.com/dmitry-k/yandex_smart_home
Предлагается установить в HA репозиторий сообщества (HACS) и уже из него загружать Yandex_Smart_Home
кто нибудь может подсказать куда рыть?
Home Assistant
in Вопросы по сборке и настройке Opkg
Posted
В этом смысле бОльшую точность даёт определение коннекта с роутером со стороны смартфона - sensor.wifi_bssid из интеграции мобильное приложение, на основе которого можно сделать device_tracker и прицепить его на персону.
