Posts
131 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Downloads
Blogs
Events
Posts posted by OlegOs
Спасибо !
Обновился, также ругается при обновлении, но вроде всё работает !
~ # /opt/etc/init.d/S99hass stop
Checking hass... dead.
~ # opkg update
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/ha
~ # opkg upgrade
Upgrading python3-jose on root from 3.2.0-1 to 3.2.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-jose_3.2.0-2_mipsel-3.4.ipk
Upgrading python3-gtts on root from 2.2.1-1 to 2.2.2-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-gtts_2.2.2-1_mipsel-3.4.ipk
Removing obsolete file /opt/lib/python3.9/site-packages/gTTS-2.2.1-py3.9.egg-info/dependency_links.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/gTTS-2.2.1-py3.9.egg-info/PKG-INFO.
Removing obsolete file /opt/lib/python3.9/site-packages/gTTS-2.2.1-py3.9.egg-info/SOURCES.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/gTTS-2.2.1-py3.9.egg-info/requires.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/gTTS-2.2.1-py3.9.egg-info/entry_points.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/gTTS-2.2.1-py3.9.egg-info/top_level.txt.
Upgrading homeassistant on root from 2021.2.0-1 to 2021.2.2-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/homeassistant_2021.2.2-1_mipsel-3.4.ipk
Installing python3-awesomeversion (21.2.2-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-awesomeversion_21.2.2-1_mipsel-3.4.ipk
Removing obsolete file /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/entry_points.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/PKG-INFO.
Removing obsolete file /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/top_level.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/requires.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/not-zip-safe.
Removing obsolete file /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/dependency_links.txt.
Removing obsolete file /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/SOURCES.txt.
Upgrading python3-async-upnp-client on root from 0.14.14-1 to 0.14.14-2...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-async-upnp-client_0.14.14-2_mipsel-3.4.ipk
Configuring python3-jose.
Configuring python3-awesomeversion.
Configuring python3-gtts.
Configuring python3-async-upnp-client.
Configuring homeassistant.
Collected errors:
* remove_obsolesced_files: unlinking /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/entry_points.txt failed: No such file or directory.
* remove_obsolesced_files: unlinking /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/PKG-INFO failed: No such file or directory.
* remove_obsolesced_files: unlinking /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/top_level.txt failed: No such file or directory.
* remove_obsolesced_files: unlinking /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/requires.txt failed: No such file or directory.
* remove_obsolesced_files: unlinking /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/not-zip-safe failed: No such file or directory.
* remove_obsolesced_files: unlinking /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/dependency_links.txt failed: No such file or directory.
* remove_obsolesced_files: unlinking /opt/lib/python3.9/site-packages/homeassistant-2021.2.0-py3.9.egg-info/SOURCES.txt failed: No such file or directory.
* opkg_install_pkg: Failed to determine obsolete files from previously installed homeassistant
Спасибо !
Обновился, немного ругался при обновлении, но всё работает !
~ # opkg update
~ # opkg upgrade
Upgrading homeassistant on root from 2021.2.0-1 to 2021.2.1-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/homeassistant_2021.2.1-1_mipsel-3.4.ipk
Collected errors:
~ # /opt/etc/init.d/S99hass start
Starting hass... done.
Спасибо за новую версию !
Обновить тоже не удалось, поставил заново, с переустановкой Entware, настройки вернул, всё работает !
Спасибо !
Успешно обновил предыдущую версию, всё работает !
- 1
Спасибо !
4 часа назад, Sergey Neshin сказал:
Поставил, заработало, спасибо всем, кто поделился знаниями. Я в HA новичек. Не вижу вкладку supervisor, она же hass.io - это потому что это core инсталляция? Возможна ли тогда полная чтобы с аддонами?
Да, это только core. Полная, со своей ОС и с аддонами ставится на отдельное устройство или виртуалку и требует ресурсов побольше чем у кинетика.
Всё поставилось и настройки перенеслись !
Спасибо !
Что-то у меня опять не получается поставить интеграции ZHA и tuya на эту версию, даже на чистую (без восстановления настроек с предыдущей)
лог ha:
Скрытый текст2020-12-28 16:16:19 ERROR (MainThread) [homeassistant.components.updater] Error requesting Home Assistant update data: Cannot connect to host updater.home-assistant.io:443 ssl:default [Connection reset by peer]2020-12-28 16:21:03 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook bb8dc6c339956d9ab36b89934e05a1cd9b5fb5ca73e04a225e540fc236acf602 from 127.0.0.12020-12-28 16:29:55 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 03f42ad558e12d758c2bbf309c3a9de2fd5da68cae6e5d4a10aa41d208a71dfe from 127.0.0.12020-12-28 16:33:23 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package tuyaha==0.0.9: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(131, 'Connection reset by peer'))': /packages/b6/7d/dced85de25ee33ec958694e78a2af194f8ffa9293bb233068ca712fd119e/tuyaha-0.0.9-py3-none-any.whlWARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(131, 'Connection reset by peer'))': /packages/b6/7d/dced85de25ee33ec958694e78a2af194f8ffa9293bb233068ca712fd119e/tuyaha-0.0.9-py3-none-any.whlWARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(131, 'Connection reset by peer'))': /packages/b6/7d/dced85de25ee33ec958694e78a2af194f8ffa9293bb233068ca712fd119e/tuyaha-0.0.9-py3-none-any.whlWARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(131, 'Connection reset by peer'))': /packages/b6/7d/dced85de25ee33ec958694e78a2af194f8ffa9293bb233068ca712fd119e/tuyaha-0.0.9-py3-none-any.whlWARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(131, 'Connection reset by peer'))': /packages/b6/7d/dced85de25ee33ec958694e78a2af194f8ffa9293bb233068ca712fd119e/tuyaha-0.0.9-py3-none-any.whlERROR: Could not install packages due to an EnvironmentError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Max retries exceeded with url: /packages/b6/7d/dced85de25ee33ec958694e78a2af194f8ffa9293bb233068ca712fd119e/tuyaha-0.0.9-py3-none-any.whl (Caused by ProtocolError('Connection aborted.', ConnectionResetError(131, 'Connection reset by peer')))WARNING: You are using pip version 20.2.3; however, version 20.3.3 is available.You should consider upgrading via the '/opt/bin/python3 -m pip install --upgrade pip' command.2020-12-28 16:33:23 ERROR (MainThread) [aiohttp.server] Error handling requestTraceback (most recent call last):File "/opt/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_requestFile "/opt/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handleFile "/opt/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 118, in implFile "/opt/lib/python3.9/site-packages/homeassistant/components/http/request_context.py", line 18, in request_context_middlewareFile "/opt/lib/python3.9/site-packages/homeassistant/components/http/ban.py", line 72, in ban_middlewareFile "/opt/lib/python3.9/site-packages/homeassistant/components/http/auth.py", line 127, in auth_middlewareFile "/opt/lib/python3.9/site-packages/homeassistant/components/http/view.py", line 129, in handleFile "/opt/lib/python3.9/site-packages/homeassistant/components/config/config_entries.py", line 136, in postFile "/opt/lib/python3.9/site-packages/homeassistant/components/http/data_validator.py", line 60, in wrapperFile "/opt/lib/python3.9/site-packages/homeassistant/helpers/data_entry_flow.py", line 69, in postFile "/opt/lib/python3.9/site-packages/homeassistant/data_entry_flow.py", line 119, in async_initFile "/opt/lib/python3.9/site-packages/homeassistant/config_entries.py", line 532, in async_create_flowFile "/opt/lib/python3.9/site-packages/homeassistant/setup.py", line 343, in async_process_deps_reqsFile "/opt/lib/python3.9/site-packages/homeassistant/requirements.py", line 74, in async_get_integration_with_requirementsFile "/opt/lib/python3.9/site-packages/homeassistant/requirements.py", line 131, in async_process_requirementshomeassistant.requirements.RequirementsNotFound: Requirements for tuya not found: ['tuyaha==0.0.9']. -
Конечно, ждём !
Новая версия вышла, последняя в этом году !
Похоже теперь будут раз в месяц обновлять !
Обновиться не удалось, обновление прошло подозрительно быстро, после чего не запустился интерфейс.
Пришлось ставить заново с переустановкой Entware
Настройки вернул - подхватились.
Скрытый текст~ # /opt/etc/init.d/S99hass stop
Checking hass... alive.
Shutting down hass... done.~ # opkg update
Updated list of available packages in /opt/var/opkg-lists/ha~ # opkg list-upgradable
ldconfig - 2.27-10 - 2.27-11
libc - 2.27-10 - 2.27-11
opkg - 2020-05-07-f2166a89-1 - 2020-11-24-61b3c62d-1
libpthread - 2.27-10 - 2.27-11
zoneinfo-europe - 2020a-1 - 2020d-1
busybox - 1.31.1-4 - 1.31.1-6
python3-urllib - 3.8.5-2 - 3.9.0-2
python3-light - 3.8.5-2 - 3.9.0-2
glib2 - 2.65.2-1 - 2.66.1-1
python3-pydoc - 3.8.5-2 - 3.9.0-2
liblzma - 5.2.5-1 - 5.2.5-2
python3-email - 3.8.5-2 - 3.9.0-2
grep - 3.4-2 - 3.6-1
zoneinfo-asia - 2020a-1 - 2020d-1
python3-cgitb - 3.8.5-2 - 3.9.0-2
python3-decimal - 3.8.5-2 - 3.9.0-2
usbutils - 007-10 - 007-11
python3-xml - 3.8.5-2 - 3.9.0-2
python3-setuptools - 47.1.0-1 - 49.2.1-1
libxml2 - 2.9.10-1 - 2.9.10-2
python3-pkg-resources - 47.1.0-1 - 49.2.1-1
python3-aiohomekit - 0.2.54-1 - 0.2.57-1
homeassistant - 0.118.0-1 - 0.118.5-1
dropbear - 2020.80-2 - 2020.81-1
python3-pytz - 2020.1-1 - 2020.4-1
libstdcpp - 8.4.0-10 - 8.4.0-11
python3-ncurses - 3.8.5-2 - 3.9.0-2
python3-distutils - 3.8.5-2 - 3.9.0-2
python3-codecs - 3.8.5-2 - 3.9.0-2
libgcc - 8.4.0-10 - 8.4.0-11
python3-multiprocessing - 3.8.5-2 - 3.9.0-2
libuuid - 2.36-1 - 2.36-2
python3-cffi - 1.14.2-1 - 1.14.4-1
python3-hass-nabucasa - 0.37.2-1 - 0.38.0-1
python3-base - 3.8.5-2 - 3.9.0-2
python3 - 3.8.5-2 - 3.9.0-2
librt - 2.27-10 - 2.27-11
python3-home-assistant-frontend - 20201111.2-1 - 20201204.0-1
python3-sqlite3 - 3.8.5-2 - 3.9.0-2
python3-urllib3 - 1.25.11-1 - 1.26.2-1
python3-gdbm - 3.8.5-2 - 3.9.0-2
python3-pip - 20.1.1-1 - 20.2.3-1
python3-dbm - 3.8.5-2 - 3.9.0-2
libjpeg-turbo - 2.0.5-1 - 2.0.6-1
python3-yarl - 1.4.2-1 - 1.6.2-1
python3-openssl - 3.8.5-2 - 3.9.0-2
python3-asyncio - 3.8.5-2 - 3.9.0-2
libssp - 8.4.0-10 - 8.4.0-11
python3-cgi - 3.8.5-2 - 3.9.0-2
python3-logging - 3.8.5-2 - 3.9.0-2
libexpat - 2.2.9-2 - 2.2.10-1
python3-ctypes - 3.8.5-2 - 3.9.0-2
python3-pyopenssl - 19.1.0-2 - 20.0.0-1
python3-attrs - 20.1.0-1 - 20.3.0-1
python3-lzma - 3.8.5-2 - 3.9.0-2
python3-certifi - 2020.6.20-1 - 2020.11.8-1
libfreetype - 2.10.2-1 - 2.10.4-1
libopenssl - 1.1.1g-1 - 1.1.1h-1
python3-unittest - 3.8.5-2 - 3.9.0-2~ # time opkg upgrade
Upgrading ldconfig on root from 2.27-10 to 2.27-11...
Downloading http://bin.entware.net/mipselsf-k3.4/ldconfig_2.27-11_mipsel-3.4.ipk
Upgrading libc on root from 2.27-10 to 2.27-11...
Downloading http://bin.entware.net/mipselsf-k3.4/libc_2.27-11_mipsel-3.4.ipk
Upgrading opkg on root from 2020-05-07-f2166a89-1 to 2020-11-24-61b3c62d-1...
Downloading http://bin.entware.net/mipselsf-k3.4/opkg_2020-11-24-61b3c62d-1_mips el-3.4.ipk
Upgrading libpthread on root from 2.27-10 to 2.27-11...
Downloading http://bin.entware.net/mipselsf-k3.4/libpthread_2.27-11_mipsel-3.4.i pk
Upgrading zoneinfo-europe on root from 2020a-1 to 2020d-1...
Downloading http://bin.entware.net/mipselsf-k3.4/zoneinfo-europe_2020d-1_mipsel- 3.4.ipk
Upgrading busybox on root from 1.31.1-4 to 1.31.1-6...
Downloading http://bin.entware.net/mipselsf-k3.4/busybox_1.31.1-6_mipsel-3.4.ipk
Installing libubox (2020-08-06-9e52171d-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libubox_2020-08-06-9e52171d-1_m ipsel-3.4.ipk
Installing libjson-c (0.15-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libjson-c_0.15-1_mipsel-3.4.ipk
Installing jsonfilter (2018-02-04-c7e938d6-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/jsonfilter_2018-02-04-c7e938d6- 1_mipsel-3.4.ipk
Upgrading python3-urllib on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-urllib_3.9.0-2_mipsel-3 .4.ipk
Removing obsolete file /opt/lib/python3.8/urllib/request.pyc.
Removing obsolete file /opt/lib/python3.8/urllib/response.pyc.
Removing obsolete file /opt/lib/python3.8/urllib/robotparser.pyc.
Removing obsolete file /opt/lib/python3.8/urllib/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/urllib/error.pyc.
Removing obsolete file /opt/lib/python3.8/urllib/parse.pyc.
Upgrading python3-light on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-light_3.9.0-2_mipsel-3. 4.ipk
Removing obsolete file /opt/lib/python3.8/turtle.pyc.
Removing obsolete file /opt/lib/python3.8/ftplib.pyc.
Removing obsolete file /opt/lib/python3.8/random.pyc.
Removing obsolete file /opt/lib/python3.8/sndhdr.pyc.
Removing obsolete file /opt/lib/python3.8/socket.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_heapq.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/crypt.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/xxlimited.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/hmac.pyc.
Removing obsolete file /opt/lib/python3.8/code.pyc.
Removing obsolete file /opt/lib/python3.8/importlib/_bootstrap.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_random.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/importlib/_bootstrap_external.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/binascii.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/sre_constants.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_bz2.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_sha3.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/typing.pyc.
Removing obsolete file /opt/lib/python3.8/binhex.pyc.
Removing obsolete file /opt/lib/python3.8/tty.pyc.
Removing obsolete file /opt/lib/python3.8/webbrowser.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_csv.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_posixshmem.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/http/client.pyc.
Removing obsolete file /opt/lib/python3.8/zipimport.pyc.
Removing obsolete file /opt/lib/python3.8/reprlib.pyc.
Removing obsolete file /opt/lib/python3.8/ssl.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_pickle.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/tempfile.pyc.
Removing obsolete file /opt/lib/python3.8/_dummy_thread.pyc.
Removing obsolete file /opt/lib/python3.8/importlib/metadata.pyc.
Removing obsolete file /opt/lib/python3.8/statistics.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_sha512.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/cmd.pyc.
Removing obsolete file /opt/lib/python3.8/inspect.pyc.
Removing obsolete file /opt/lib/python3.8/mailcap.pyc.
Removing obsolete file /opt/lib/python3.8/asynchat.pyc.
Removing obsolete file /opt/lib/python3.8/configparser.pyc.
Removing obsolete file /opt/lib/python3.8/pathlib.pyc.
Removing obsolete file /opt/lib/python3.8/struct.pyc.
Removing obsolete file /opt/lib/python3.8/importlib/abc.pyc.
Removing obsolete file /opt/lib/python3.8/subprocess.pyc.
Removing obsolete file /opt/lib/python3.8/venv/scripts/posix/activate.csh.
Removing obsolete file /opt/lib/python3.8/mailbox.pyc.
Removing obsolete file /opt/lib/python3.8/operator.pyc.
Removing obsolete file /opt/lib/python3.8/pyclbr.pyc.
Removing obsolete file /opt/lib/python3.8/gzip.pyc.
Removing obsolete file /opt/lib/python3.8/netrc.pyc.
Removing obsolete file /opt/lib/python3.8/colorsys.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/select.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/socketserver.pyc.
Removing obsolete file /opt/lib/python3.8/shlex.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_sha1.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/re.pyc.
Removing obsolete file /opt/lib/python3.8/quopri.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/README.txt.
Removing obsolete file /opt/lib/python3.8/venv/scripts/common/Activate.ps1.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_json.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/smtplib.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/spwd.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/dummy_threading.pyc.
Removing obsolete file /opt/lib/python3.8/_bootlocale.pyc.
Removing obsolete file /opt/lib/python3.8/telnetlib.pyc.
Removing obsolete file /opt/lib/python3.8/asyncore.pyc.
Removing obsolete file /opt/lib/python3.8/html/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_sha256.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/pstats.pyc.
Removing obsolete file /opt/lib/python3.8/bdb.pyc.
Removing obsolete file /opt/lib/python3.8/_py_abc.pyc.
Removing obsolete file /opt/lib/python3.8/collections/abc.pyc.
Removing obsolete file /opt/lib/python3.8/types.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_xxtestfuzz.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/modulefinder.pyc.
Removing obsolete file /opt/lib/python3.8/textwrap.pyc.
Removing obsolete file /opt/lib/python3.8/filecmp.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/grp.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/_compat_pickle.pyc.
Removing obsolete file /opt/lib/python3.8/numbers.pyc.
Removing obsolete file /opt/lib/python3.8/pty.pyc.
Removing obsolete file /opt/lib/python3.8/imaplib.pyc.
Removing obsolete file /opt/lib/python3.8/signal.pyc.
Removing obsolete file /opt/lib/python3.8/ipaddress.pyc.
Removing obsolete file /opt/lib/python3.8/pkgutil.pyc.
Removing obsolete file /opt/lib/python3.8/traceback.pyc.
Removing obsolete file /opt/lib/python3.8/plistlib.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/ossaudiodev.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/queue.pyc.
Removing obsolete file /opt/lib/python3.8/_markupbase.pyc.
Removing obsolete file /opt/lib/python3.8/csv.pyc.
Removing obsolete file /opt/lib/python3.8/wsgiref/validate.pyc.
Removing obsolete file /opt/lib/python3.8/__phello__.foo.pyc.
Removing obsolete file /opt/lib/python3.8/getopt.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/array.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/weakref.pyc.
Removing obsolete file /opt/lib/python3.8/http/server.pyc.
Removing obsolete file /opt/lib/python3.8/warnings.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_datetime.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/locale.pyc.
Removing obsolete file /opt/lib/python3.8/antigravity.pyc.
Removing obsolete file /opt/lib/python3.8/zipfile.pyc.
Removing obsolete file /opt/lib/python3.8/__future__.pyc.
Removing obsolete file /opt/lib/python3.8/hashlib.pyc.
Removing obsolete file /opt/lib/python3.8/wsgiref/util.pyc.
Removing obsolete file /opt/lib/python3.8/gettext.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/parser.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/sunau.pyc.
Removing obsolete file /opt/lib/python3.8/fileinput.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/fcntl.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_struct.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/json/encoder.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_posixsubprocess.cpython-3 8.so.
Removing obsolete file /opt/lib/python3.8/copy.pyc.
Removing obsolete file /opt/lib/python3.8/contextvars.pyc.
Removing obsolete file /opt/lib/python3.8/json/tool.pyc.
Removing obsolete file /opt/lib/python3.8/pickletools.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/mmap.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/venv/__main__.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_crypt.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/json/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/concurrent/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/keyword.pyc.
Removing obsolete file /opt/lib/python3.8/timeit.pyc.
Removing obsolete file /opt/lib/python3.8/optparse.pyc.
Removing obsolete file /opt/lib/python3.8/token.pyc.
Removing obsolete file /opt/lib/python3.8/xdrlib.pyc.
Removing obsolete file /opt/lib/python3.8/heapq.pyc.
Removing obsolete file /opt/lib/python3.8/profile.pyc.
Removing obsolete file /opt/lib/python3.8/aifc.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_asyncio.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/venv/scripts/common/activate.
Removing obsolete file /opt/lib/python3.8/shutil.pyc.
Removing obsolete file /opt/lib/python3.8/linecache.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_md5.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_socket.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/venv/scripts/posix/activate.fish.
Removing obsolete file /opt/lib/python3.8/LICENSE.txt.
Removing obsolete file /opt/lib/python3.8/http/cookies.pyc.
Removing obsolete file /opt/lib/python3.8/json/decoder.pyc.
Removing obsolete file /opt/lib/python3.8/dis.pyc.
Removing obsolete file /opt/lib/python3.8/compileall.pyc.
Removing obsolete file /opt/lib/python3.8/sre_parse.pyc.
Removing obsolete file /opt/lib/python3.8/poplib.pyc.
Removing obsolete file /opt/lib/python3.8/symbol.pyc.
Removing obsolete file /opt/lib/python3.8/imghdr.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/syslog.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/symtable.pyc.
Removing obsolete file /opt/lib/python3.8/platform.pyc.
Removing obsolete file /opt/lib/python3.8/http/cookiejar.pyc.
Removing obsolete file /opt/lib/python3.8/concurrent/futures/thread.pyc.
Removing obsolete file /opt/lib/python3.8/sre_compile.pyc.
Removing obsolete file /opt/lib/python3.8/wave.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_lsprof.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/argparse.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_bisect.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/chunk.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_xxsubinterpreters.cpython -38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/termios.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/base64.pyc.
Removing obsolete file /opt/lib/python3.8/concurrent/futures/_base.pyc.
Removing obsolete file /opt/lib/python3.8/calendar.pyc.
Removing obsolete file /opt/lib/python3.8/codeop.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_multibytecodec.cpython-38 .so.
Removing obsolete file /opt/lib/python3.8/shelve.pyc.
Removing obsolete file /opt/lib/python3.8/html/entities.pyc.
Removing obsolete file /opt/lib/python3.8/uu.pyc.
Removing obsolete file /opt/lib/python3.8/bz2.pyc.
Removing obsolete file /opt/lib/python3.8/stringprep.pyc.
Removing obsolete file /opt/lib/python3.8/ntpath.pyc.
Removing obsolete file /opt/lib/python3.8/difflib.pyc.
Removing obsolete file /opt/lib/python3.8/importlib/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/zipapp.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_opcode.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/secrets.pyc.
Removing obsolete file /opt/lib/python3.8/contextlib.pyc.
Removing obsolete file /opt/lib/python3.8/_threading_local.pyc.
Removing obsolete file /opt/lib/python3.8/fnmatch.pyc.
Removing obsolete file /opt/lib/python3.8/wsgiref/headers.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_queue.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/glob.pyc.
Removing obsolete file /opt/lib/python3.8/ast.pyc.
Removing obsolete file /opt/lib/python3.8/_compression.pyc.
Removing obsolete file /opt/lib/python3.8/py_compile.pyc.
Removing obsolete file /opt/lib/python3.8/_pydecimal.pyc.
Removing obsolete file /opt/lib/python3.8/venv/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/tarfile.pyc.
Removing obsolete file /opt/lib/python3.8/fractions.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_blake2.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/pprint.pyc.
Removing obsolete file /opt/lib/python3.8/concurrent/futures/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/pipes.pyc.
Removing obsolete file /opt/lib/python3.8/imp.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/cmath.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/datetime.pyc.
Removing obsolete file /opt/lib/python3.8/nturl2path.pyc.
Removing obsolete file /opt/lib/python3.8/uuid.pyc.
Removing obsolete file /opt/lib/python3.8/wsgiref/handlers.pyc.
Removing obsolete file /opt/lib/python3.8/bisect.pyc.
Removing obsolete file /opt/lib/python3.8/importlib/resources.pyc.
Removing obsolete file /opt/lib/python3.8/sched.pyc.
Removing obsolete file /opt/lib/python3.8/dataclasses.pyc.
Removing obsolete file /opt/lib/python3.8/cProfile.pyc.
Removing obsolete file /opt/lib/python3.8/wsgiref/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/importlib/machinery.pyc.
Removing obsolete file /opt/lib/python3.8/trace.pyc.
Removing obsolete file /opt/lib/python3.8/getpass.pyc.
Removing obsolete file /opt/lib/python3.8/opcode.pyc.
Removing obsolete file /opt/lib/python3.8/functools.pyc.
Removing obsolete file /opt/lib/python3.8/collections/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/_pyio.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/math.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/rlcompleter.pyc.
Removing obsolete file /opt/lib/python3.8/tokenize.pyc.
Removing obsolete file /opt/lib/python3.8/json/scanner.pyc.
Removing obsolete file /opt/lib/python3.8/pickle.pyc.
Removing obsolete file /opt/lib/python3.8/copyreg.pyc.
Removing obsolete file /opt/lib/python3.8/mimetypes.pyc.
Removing obsolete file /opt/lib/python3.8/importlib/util.pyc.
Removing obsolete file /opt/lib/python3.8/tracemalloc.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_statistics.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/nis.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/formatter.pyc.
Removing obsolete file /opt/lib/python3.8/pdb.pyc.
Removing obsolete file /opt/lib/python3.8/tabnanny.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/resource.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/audioop.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/html/parser.pyc.
Removing obsolete file /opt/lib/python3.8/selectors.pyc.
Removing obsolete file /opt/lib/python3.8/threading.pyc.
Removing obsolete file /opt/lib/python3.8/nntplib.pyc.
Removing obsolete file /opt/lib/python3.8/http/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/wsgiref/simple_server.pyc.
Removing obsolete file /opt/lib/python3.8/enum.pyc.
Removing obsolete file /opt/lib/python3.8/string.pyc.
Removing obsolete file /opt/lib/python3.8/smtpd.pyc.
Removing obsolete file /opt/lib/python3.8/concurrent/futures/process.pyc.
Removing obsolete file /opt/lib/python3.8/_strptime.pyc.
Removing obsolete file /opt/lib/python3.8/this.pyc.
Removing obsolete file /opt/lib/python3.8/runpy.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_contextvars.cpython-38.so .
Upgrading glib2 on root from 2.65.2-1 to 2.66.1-1...
Downloading http://bin.entware.net/mipselsf-k3.4/glib2_2.66.1-1_mipsel-3.4.ipk
Removing obsolete file /opt/lib/libgobject-2.0.so.0.6502.0.
Removing obsolete file /opt/lib/libgio-2.0.so.0.6502.0.
Removing obsolete file /opt/lib/libglib-2.0.so.0.6502.0.
Removing obsolete file /opt/lib/libgmodule-2.0.so.0.6502.0.
Removing obsolete file /opt/lib/libgthread-2.0.so.0.6502.0.
Upgrading python3-pydoc on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-pydoc_3.9.0-2_mipsel-3. 4.ipk
Removing obsolete file /opt/lib/python3.8/doctest.pyc.
Removing obsolete file /opt/lib/python3.8/pydoc_data/topics.pyc.
Removing obsolete file /opt/lib/python3.8/pydoc_data/_pydoc.css.
Removing obsolete file /opt/lib/python3.8/pydoc.pyc.
Removing obsolete file /opt/lib/python3.8/pydoc_data/__init__.pyc.
Upgrading liblzma on root from 5.2.5-1 to 5.2.5-2...
Downloading http://bin.entware.net/mipselsf-k3.4/liblzma_5.2.5-2_mipsel-3.4.ipk
Upgrading python3-email on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-email_3.9.0-2_mipsel-3. 4.ipk
Removing obsolete file /opt/lib/python3.8/email/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/email/architecture.rst.
Removing obsolete file /opt/lib/python3.8/email/mime/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/image.pyc.
Removing obsolete file /opt/lib/python3.8/email/errors.pyc.
Removing obsolete file /opt/lib/python3.8/email/_policybase.pyc.
Removing obsolete file /opt/lib/python3.8/email/_parseaddr.pyc.
Removing obsolete file /opt/lib/python3.8/email/contentmanager.pyc.
Removing obsolete file /opt/lib/python3.8/email/policy.pyc.
Removing obsolete file /opt/lib/python3.8/email/generator.pyc.
Removing obsolete file /opt/lib/python3.8/email/charset.pyc.
Removing obsolete file /opt/lib/python3.8/email/_header_value_parser.pyc.
Removing obsolete file /opt/lib/python3.8/email/message.pyc.
Removing obsolete file /opt/lib/python3.8/email/parser.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/base.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/application.pyc.
Removing obsolete file /opt/lib/python3.8/email/header.pyc.
Removing obsolete file /opt/lib/python3.8/email/quoprimime.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/multipart.pyc.
Removing obsolete file /opt/lib/python3.8/email/iterators.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/nonmultipart.pyc.
Removing obsolete file /opt/lib/python3.8/email/base64mime.pyc.
Removing obsolete file /opt/lib/python3.8/email/utils.pyc.
Removing obsolete file /opt/lib/python3.8/email/_encoded_words.pyc.
Removing obsolete file /opt/lib/python3.8/email/feedparser.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/message.pyc.
Removing obsolete file /opt/lib/python3.8/email/headerregistry.pyc.
Removing obsolete file /opt/lib/python3.8/email/encoders.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/text.pyc.
Removing obsolete file /opt/lib/python3.8/email/mime/audio.pyc.
Upgrading grep on root from 3.4-2 to 3.6-1...
Downloading http://bin.entware.net/mipselsf-k3.4/grep_3.6-1_mipsel-3.4.ipk
Upgrading zoneinfo-asia on root from 2020a-1 to 2020d-1...
Downloading http://bin.entware.net/mipselsf-k3.4/zoneinfo-asia_2020d-1_mipsel-3. 4.ipk
Upgrading python3-cgitb on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-cgitb_3.9.0-2_mipsel-3. 4.ipk
Removing obsolete file /opt/lib/python3.8/cgitb.pyc.
Upgrading python3-decimal on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-decimal_3.9.0-2_mipsel- 3.4.ipk
Removing obsolete file /opt/lib/python3.8/decimal.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_decimal.cpython-38.so.
Upgrading usbutils on root from 007-10 to 007-11...
Downloading http://bin.entware.net/mipselsf-k3.4/usbutils_007-11_mipsel-3.4.ipk
Upgrading python3-xml on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-xml_3.9.0-2_mipsel-3.4. ipk
Removing obsolete file /opt/lib/python3.8/xml/dom/pulldom.pyc.
Removing obsolete file /opt/lib/python3.8/xml/sax/saxutils.pyc.
Removing obsolete file /opt/lib/python3.8/xml/sax/expatreader.pyc.
Removing obsolete file /opt/lib/python3.8/xml/sax/handler.pyc.
Removing obsolete file /opt/lib/python3.8/xml/etree/ElementInclude.pyc.
Removing obsolete file /opt/lib/python3.8/xml/dom/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/xml/dom/expatbuilder.pyc.
Removing obsolete file /opt/lib/python3.8/xml/sax/_exceptions.pyc.
Removing obsolete file /opt/lib/python3.8/xml/dom/minicompat.pyc.
Removing obsolete file /opt/lib/python3.8/xml/etree/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/xml/dom/minidom.pyc.
Removing obsolete file /opt/lib/python3.8/xml/dom/NodeFilter.pyc.
Removing obsolete file /opt/lib/python3.8/xml/sax/xmlreader.pyc.
Removing obsolete file /opt/lib/python3.8/xml/etree/ElementPath.pyc.
Removing obsolete file /opt/lib/python3.8/xml/sax/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/xmlrpc/client.pyc.
Removing obsolete file /opt/lib/python3.8/xml/dom/domreg.pyc.
Removing obsolete file /opt/lib/python3.8/xml/etree/cElementTree.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_elementtree.cpython-38.so .
Removing obsolete file /opt/lib/python3.8/xml/parsers/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/xml/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/pyexpat.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/xml/parsers/expat.pyc.
Removing obsolete file /opt/lib/python3.8/xml/etree/ElementTree.pyc.
Removing obsolete file /opt/lib/python3.8/xmlrpc/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/xml/dom/xmlbuilder.pyc.
Removing obsolete file /opt/lib/python3.8/xmlrpc/server.pyc.
Upgrading python3-setuptools on root from 47.1.0-1 to 49.2.1-1...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-setuptools_49.2.1-1_mip sel-3.4.ipk
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/version.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/dep_util.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/build _clib.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/uploa d.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/script (dev). tmpl.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/requirements.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/sdist .pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/RECORD.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/extension.pyc .
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/WHEEL.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/zip-safe.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/rotat e.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/insta ll_egg_info.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/launch.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/launc her manifest.xml.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/insta ll.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/order ed_set.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/ssl_support.p yc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/bdist _egg.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/unicode_utils .pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/package_index .pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/markers.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/test. pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/dist.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/wheel.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/__ini t__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/bdist _wininst.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/alias .pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/py36c ompat.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/monkey.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/INSTALLER.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/pypar sing.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_deprecation_ warning.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/build _ext.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/regis ter.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/py27compat.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/tags.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/script.tmpl.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/__about__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/insta ll_scripts.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/METADATA.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/msvc.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/egg_i nfo.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/sandbox.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/entry_points.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/py33compat.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/easy_ install.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/namespaces.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/LICENSE.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/depends.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/dist_ info.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/build_meta.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/devel op.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/saveo pts.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/glob.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/build _py.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/windows_suppo rt.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/extern/__init __.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/version.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/__ini t__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/_compat.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/_structures.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_imp.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/direct_url.json.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/site-patch.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/lib2to3_ex.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/errors.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/archive_util. pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/installer.pyc .
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/insta ll_lib.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/setop t.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/utils.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/dependency_links.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/bdist _rpm.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/py34compat.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/command/uploa d_docs.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/packa ging/specifiers.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/site-patch.py .txt.
Removing obsolete file /opt/bin/easy_install-3.8.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/_vendor/six.p yc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/py31compat.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/easy_install.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools-47.1.0.dist-i nfo/top_level.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/setuptools/config.pyc.
Upgrading libxml2 on root from 2.9.10-1 to 2.9.10-2...
Downloading http://bin.entware.net/mipselsf-k3.4/libxml2_2.9.10-2_mipsel-3.4.ipk
Upgrading python3-pkg-resources on root from 47.1.0-1 to 49.2.1-1...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-pkg-resources_49.2.1-1_ mipsel-3.4.ipk
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/__about__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/requirements.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/ap pdirs.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/utils.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/markers.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/specifiers.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/__ init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/__init__.p yc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/si x.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/extern/__i nit__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/py2_warn.p yc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/version.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/_compat.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/py31compat .pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/py parsing.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pkg_resources/_vendor/pa ckaging/_structures.pyc.
Upgrading python3-aiohomekit on root from 0.2.54-1 to 0.2.57-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-aiohomekit_0.2. 57-1_mipsel-3.4.ipk
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/data.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/service s/data.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/protocol/stat uscodes.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/protocol/tlv. pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/feature _flags.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/characteristic_formats.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/units.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit-0.2.54-py3.8. egg-info/PKG-INFO.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/service s/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/ip /connection.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/structs.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/service s/service_types.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/ip /discovery.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/types.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/__ init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/const.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/characteristic_types.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit-0.2.54-py3.8. egg-info/dependency_links.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/crypto/__init __.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/__main__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/mixin.p yc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit-0.2.54-py3.8. egg-info/entry_points.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/crypto/hkdf.p yc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/protocol/__in it__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/co ntroller.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/exceptions.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/pa iring.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/http/response .pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/service s/types.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/crypto/srp.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/tlv8.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/permissions.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/service s/service.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/http/__init__ .pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/status_ flags.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/utils.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/ip /zeroconf.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/const.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/charact eristics/characteristic.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit-0.2.54-py3.8. egg-info/requires.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/zeroconf/__in it__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/ip /__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/controller/ip /pairing.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/crypto/chacha 20poly1305.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit-0.2.54-py3.8. egg-info/top_level.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/testing.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit-0.2.54-py3.8. egg-info/SOURCES.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/categor ies.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/aiohomekit/model/__init_ _.pyc.
Upgrading homeassistant on root from 0.118.0-1 to 0.118.5-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/homeassistant_0.118.5-1 _mipsel-3.4.ipk
Installing python3-click (7.1.2-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-click_7.1.2-1_m ipsel-3.4.ipk
Installing python3-gtts (2.2.1-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-gtts_2.2.1-1_mi psel-3.4.ipk
python3-gtts-token was autoinstalled and is now orphaned, removing.
Removing package python3-gtts-token from root...
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /cloudflare/translations/zh-Hant.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /control4/manifest.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /moon/translations/sensor.ko.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /sensor/translations/hy.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /simplisafe/config_flow.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /sleepiq/const.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /ue_smart_radio/media_player.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /vacuum/reproduce_state.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /vesync/translations/es-419.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /websocket_api/sensor.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /wemo/translations/es-419.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /aqualogic/manifest.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /bond/strings.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /device_tracker/translations/ro.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /doorbird/translations/ru.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /geo_json_events/geo_location.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /ipp/translations/en.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /tank_utility/sensor.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /tplink/common.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /traccar/translations/pl.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /binary_sensor/translations/sl.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /coolmaster/translations/pt.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /dsmr/translations/ru.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /forked_daapd/translations/de.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /hassio/addon_panel.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /heos/config_flow.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /input_text/translations/bg.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /islamic_prayer_times/const.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /media_player/translations/hi.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /openuv/translations/uk.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /persistent_notification/manifest.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /rest/binary_sensor.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /ripple/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /tesla/translations/pt.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /tradfri/base_class.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /braviatv/translations/sl.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /geofency/config_flow.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /geofency/translations/lb.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /google_maps/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /griddy/sensor.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /melcloud/translations/de.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /meteo_france/translations/cs.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /mqtt/light/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /nissan_leaf/sensor.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /smtp/notify.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /wiffi/translations/sv.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /brother/translations/sv.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /decora/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /gogogate2/cover.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /microsoft_face_identify/image_processing.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /myq/const.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /plex/manifest.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /rpi_power/const.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /smarty/binary_sensor.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /synology_dsm/translations/fr.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /tradfri/switch.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /vizio/config_flow.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /adguard/const.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /alarm_control_panel/translations/pt.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /aquostv/media_player.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /aurora/translations/cs.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /avri/config_flow.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /config/core.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /cover/translations/hy.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /dialogflow/translations/fr.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /emulated_roku/translations/fi.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /glances/translations/es-419.json.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /input_select/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/homeassistant/components /ps4/translations/bg.json.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_internal/req/constr uctors.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_internal/network/do wnload.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/pep517/__ini t__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/chardet/cli/ chardetect.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/cachecontrol /caches/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_internal/resolution /base.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/requests/__v ersion__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/chardet/mbcs sm.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/urllib3/pack ages/backports/makefile.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_internal/utils/file system.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/idna/core.py c.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/html5lib/_tr ie/py.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pip/_vendor/pkg_resource s/__init__.pyc.
Upgrading python3-dbm on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-dbm_3.9.0-2_mipsel-3.4. ipk
Removing obsolete file /opt/lib/python3.8/dbm/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/dbm/ndbm.pyc.
Removing obsolete file /opt/lib/python3.8/dbm/gnu.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_dbm.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/dbm/dumb.pyc.
Upgrading libjpeg-turbo on root from 2.0.5-1 to 2.0.6-1...
Downloading http://bin.entware.net/mipselsf-k3.4/libjpeg-turbo_2.0.6-1_mipsel-3. 4.ipk
Upgrading python3-yarl on root from 1.4.2-1 to 1.6.2-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-yarl_1.6.2-1_mi psel-3.4.ipk
Removing obsolete file /opt/lib/python3.8/site-packages/yarl-1.4.2-py3.8.egg-inf o/PKG-INFO.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl-1.4.2-py3.8.egg-inf o/SOURCES.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl/quoting.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl/_quoting.cpython-38 .so.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl/py.typed.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl-1.4.2-py3.8.egg-inf o/top_level.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl/_quoting.c.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl/__init__.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl/_quoting.pyx.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl-1.4.2-py3.8.egg-inf o/requires.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/yarl-1.4.2-py3.8.egg-inf o/dependency_links.txt.
Upgrading python3-openssl on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-openssl_3.9.0-2_mipsel- 3.4.ipk
Removing obsolete file /opt/lib/python3.8/lib-dynload/_hashlib.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_ssl.cpython-38.so.
Upgrading python3-asyncio on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-asyncio_3.9.0-2_mipsel- 3.4.ipk
Removing obsolete file /opt/lib/python3.8/asyncio/format_helpers.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/locks.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/sslproto.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/unix_events.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/proactor_events.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/base_tasks.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/runners.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/constants.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/windows_events.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/selector_events.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/subprocess.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/transports.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/trsock.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/staggered.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/log.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/base_subprocess.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/events.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/base_events.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/coroutines.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/streams.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/base_futures.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/queues.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/exceptions.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/protocols.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/futures.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/windows_utils.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/__main__.pyc.
Removing obsolete file /opt/lib/python3.8/asyncio/tasks.pyc.
Upgrading libssp on root from 8.4.0-10 to 8.4.0-11...
Downloading http://bin.entware.net/mipselsf-k3.4/libssp_8.4.0-11_mipsel-3.4.ipk
Upgrading python3-cgi on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-cgi_3.9.0-2_mipsel-3.4. ipk
Removing obsolete file /opt/lib/python3.8/cgi.pyc.
Upgrading python3-logging on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-logging_3.9.0-2_mipsel- 3.4.ipk
Removing obsolete file /opt/lib/python3.8/logging/handlers.pyc.
Removing obsolete file /opt/lib/python3.8/logging/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/logging/config.pyc.
Upgrading libexpat on root from 2.2.9-2 to 2.2.10-1...
Downloading http://bin.entware.net/mipselsf-k3.4/libexpat_2.2.10-1_mipsel-3.4.ip k
Removing obsolete file /opt/lib/libexpat.so.1.6.11.
Upgrading python3-ctypes on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-ctypes_3.9.0-2_mipsel-3 .4.ipk
Removing obsolete file /opt/lib/python3.8/ctypes/macholib/README.ctypes.
Removing obsolete file /opt/lib/python3.8/ctypes/macholib/fetch_macholib.bat.
Removing obsolete file /opt/lib/python3.8/ctypes/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/ctypes/macholib/dyld.pyc.
Removing obsolete file /opt/lib/python3.8/ctypes/macholib/dylib.pyc.
Removing obsolete file /opt/lib/python3.8/ctypes/util.pyc.
Removing obsolete file /opt/lib/python3.8/lib-dynload/_ctypes_test.cpython-38.so .
Removing obsolete file /opt/lib/python3.8/lib-dynload/_ctypes.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/ctypes/macholib/framework.pyc.
Removing obsolete file /opt/lib/python3.8/ctypes/_aix.pyc.
Removing obsolete file /opt/lib/python3.8/ctypes/wintypes.pyc.
Removing obsolete file /opt/lib/python3.8/ctypes/macholib/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/ctypes/_endian.pyc.
Upgrading python3-pyopenssl on root from 19.1.0-2 to 20.0.0-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-pyopenssl_20.0. 0-1_mipsel-3.4.ipk
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/tsafe.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pyOpenSSL-19.1.0-py3.8.e gg-info/SOURCES.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/pyOpenSSL-19.1.0-py3.8.e gg-info/requires.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/_util.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pyOpenSSL-19.1.0-py3.8.e gg-info/PKG-INFO.
Removing obsolete file /opt/lib/python3.8/site-packages/pyOpenSSL-19.1.0-py3.8.e gg-info/top_level.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/SSL.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/crypto.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/pyOpenSSL-19.1.0-py3.8.e gg-info/dependency_links.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/rand.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/version.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/OpenSSL/debug.pyc.
Upgrading python3-attrs on root from 20.1.0-1 to 20.3.0-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-attrs_20.3.0-1_ mipsel-3.4.ipk
Removing obsolete file /opt/lib/python3.8/site-packages/attr/exceptions.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/attrs-20.1.0-py3.8.egg-i nfo/dependency_links.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/setters.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/setters.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/__init__.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/_make.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/filters.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/filters.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/_version_info.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/_version_info.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/py.typed.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/_funcs.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attrs-20.1.0-py3.8.egg-i nfo/PKG-INFO.
Removing obsolete file /opt/lib/python3.8/site-packages/attrs-20.1.0-py3.8.egg-i nfo/top_level.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/converters.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attrs-20.1.0-py3.8.egg-i nfo/requires.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/converters.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/validators.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/validators.pyi.
Removing obsolete file /opt/lib/python3.8/site-packages/attrs-20.1.0-py3.8.egg-i nfo/SOURCES.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/attrs-20.1.0-py3.8.egg-i nfo/not-zip-safe.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/_next_gen.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/_config.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/_compat.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/attr/exceptions.pyc.
Upgrading python3-lzma on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-lzma_3.9.0-2_mipsel-3.4 .ipk
Removing obsolete file /opt/lib/python3.8/lib-dynload/_lzma.cpython-38.so.
Removing obsolete file /opt/lib/python3.8/lzma.pyc.
Upgrading python3-certifi on root from 2020.6.20-1 to 2020.11.8-1...
Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-certifi_2020.11 .8-1_mipsel-3.4.ipk
Removing obsolete file /opt/lib/python3.8/site-packages/certifi/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi-2020.6.20-py3.8. egg-info/not-zip-safe.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi/core.pyc.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi-2020.6.20-py3.8. egg-info/top_level.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi-2020.6.20-py3.8. egg-info/SOURCES.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi/cacert.pem.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi-2020.6.20-py3.8. egg-info/PKG-INFO.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi-2020.6.20-py3.8. egg-info/dependency_links.txt.
Removing obsolete file /opt/lib/python3.8/site-packages/certifi/__main__.pyc.
Upgrading libfreetype on root from 2.10.2-1 to 2.10.4-1...
Downloading http://bin.entware.net/mipselsf-k3.4/libfreetype_2.10.4-1_mipsel-3.4 .ipk
Removing obsolete file /opt/lib/libfreetype.so.6.17.2.
Upgrading libopenssl on root from 1.1.1g-1 to 1.1.1h-1...
Downloading http://bin.entware.net/mipselsf-k3.4/libopenssl_1.1.1h-1_mipsel-3.4. ipk
Upgrading python3-unittest on root from 3.8.5-2 to 3.9.0-2...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-unittest_3.9.0-2_mipsel -3.4.ipk
Removing obsolete file /opt/lib/python3.8/unittest/case.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/mock.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/__main__.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/suite.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/runner.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/loader.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/__init__.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/signals.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/async_case.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/main.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/util.pyc.
Removing obsolete file /opt/lib/python3.8/unittest/result.pyc.
Configuring libgcc.
Configuring libc.
Configuring libssp.
Configuring libpthread.
Configuring librt.
Configuring python3-base.
Configuring libuuid.
Configuring python3-light.
Configuring python3-unittest.
Configuring python3-ncurses.
Configuring python3-ctypes.
Configuring python3-pydoc.
Configuring python3-logging.
Configuring python3-multiprocessing.
Configuring python3-codecs.
Configuring python3-gdbm.
Configuring python3-sqlite3.
Configuring python3-email.
Configuring python3-urllib.
Configuring libexpat.
Configuring python3-xml.
Configuring python3-distutils.
Configuring libopenssl.
Configuring python3-openssl.
Configuring python3-cgi.
Configuring python3-cgitb.
Configuring libxml2.
Configuring python3-dbm.
Configuring python3-asyncio.
Configuring liblzma.
Configuring python3-lzma.
Configuring python3-decimal.
Configuring python3.
Configuring ldconfig.
Configuring glib2.
Configuring grep.
Configuring opkg.
Configuring python3-urllib3.
Configuring python3-certifi.
Configuring zoneinfo-europe.
Configuring libubox.
Configuring libjson-c.
Configuring jsonfilter.
Configuring busybox.
Warning: '/opt/bin/xargs' is already exists, skipping.
Warning: '/opt/bin/egrep' is already exists, skipping.
Warning: '/opt/bin/fgrep' is already exists, skipping.
Warning: '/opt/bin/grep' is already exists, skipping.
Warning: '/opt/bin/find' is already exists, skipping.
Warning: '/opt/bin/lsusb' is already exists, skipping.
Configuring python3-pkg-resources.
Configuring python3-setuptools.
Configuring python3-click.
Configuring zoneinfo-asia.
Configuring usbutils.
Configuring python3-gtts.
Configuring libjpeg-turbo.
Configuring libfreetype.
Configuring python3-aiohomekit.
Configuring python3-cffi.
Configuring python3-pyopenssl.
Configuring python3-pytz.
Configuring python3-attrs.
Configuring python3-yarl.
Configuring python3-hass-nabucasa.
Configuring python3-home-assistant-frontend.
Configuring python3-pip.
Configuring homeassistant.
Configuring dropbear.
Configuring libstdcpp.
Collected errors:
* resolve_conffiles: Existing conffile /opt/etc/config/dropbear.conf is differe nt from the conffile in the new package. The new conffile will be placed at /opt /etc/config/dropbear.conf-opkg.
real 2m 18.09s
user 1m 57.15s
sys 0m 47.02s
~ # /opt/etc/init.d/S99hass start
Starting hass... done.
~ # /opt/etc/init.d/S99hass stop
Checking hass... dead. -
С поддержкой USB-Bluetooth что-нибудь изменилось?
На Кинетике крутится Home Assistant, чтобы пробросить в него датчики и устройства нужны интерфейсы. Zigbee свисток завёлся, а Bluetooth не хочет, я так понимаю нужна поддержка в ядре?
- 1
- 1
А как грамотно скопировать настройки, снести всё без сноса Entware, установить заново и вернуть настройки?
В 01.12.2020 в 18:19, Олег Осипов сказал:
Поставил пакеты, вроде нормально встали, но при запуске ошибки, кто может переведите
~ # opkg install bluez-daemon
Installing bluez-daemon (5.54-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/bluez-daemon_5.54-1_mipsel-3.4.ipk
Installing bluez-libs (5.54-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/bluez-libs_5.54-1_mipsel-3.4.ipk
Installing bluez-utils (5.54-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/bluez-utils_5.54-1_mipsel-3.4.ipk
Installing libiconv-full (1.11.1-4) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libiconv-full_1.11.1-4_mipsel-3.4.ipk
Installing libintl-full (0.19.8.1-2) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libintl-full_0.19.8.1-2_mipsel-3.4.ipk
Installing libattr (2.4.48-2) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libattr_2.4.48-2_mipsel-3.4.ipk
Installing glib2 (2.65.2-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/glib2_2.65.2-1_mipsel-3.4.ipk
Installing libreadline (8.0-1a) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libreadline_8.0-1a_mipsel-3.4.ipk
Installing libdbus (1.13.12-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libdbus_1.13.12-1_mipsel-3.4.ipk
Installing dbus (1.13.12-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/dbus_1.13.12-1_mipsel-3.4.ipk
Installing bluez-utils-extra (5.54-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/bluez-utils-extra_5.54-1_mipsel-3.4.ipk
Installing libical (3.0.6-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/libical_3.0.6-1_mipsel-3.4.ipk
Configuring libical.
Configuring bluez-libs.
Configuring libiconv-full.
Configuring libintl-full.
Configuring libattr.
Configuring glib2.
Configuring libreadline.
Configuring libdbus.
Configuring dbus.
Configuring bluez-utils-extra.
Configuring bluez-utils.
Configuring bluez-daemon.
~ # bluetoothctl
Waiting to connect to bluetoothd...dbus[22717]: arguments to dbus_connection_get_object_path_data() were incorrect, assertion "connection != NULL" failed in file dbus-connection.c line 5921.
This is normally a bug in some application using the D-Bus library.D-Bus not built with -rdynamic so unable to print a backtrace
Aborted~ # bluetoothd start
D-Bus setup failed: Failed to connect to socket /opt/var/run/dbus/system_bus_socket: No such file or directory
Segmentation fault
~ # btmon
Bluetooth monitor ver 5.54
Failed to open channel: Address family not supported by protocol~ # btmgmt
Unable to open mgmt_socket~ # btattach
No controller attached~ # bluemoon
Bluemoon configuration utility ver 5.54
Failed to open HCI user channel
~ # lsusb
Bus 002 Device 004: ID 1058:0832 Western Digital Technologies, Inc.
Bus 001 Device 009: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter
Bus 001 Device 013: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 002 Device 003: ID 4971:8017 SimpleTech
Bus 001 Device 014: ID 1310:0001 Roper Class 1 Bluetooth Dongle
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 05e3:0612 Genesys Logic, Inc. Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hubЯ так понял не работает потому что поддержку BT надо в ядре делать?
Разработчики, это можно сделать?
Тема неоднократно поднималась но заглохла:
Скрытый текст~ # opkg install bluez-daemon
Configuring glib2.
Configuring dbus.
~ # bluetoothctl
Segmentation fault
~ # btmon
~ # lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub -
Господа, большое спасибо за поддержку !
Дверной датчик Xiaomi через ZHA тоже в HA успешно прокинулся !
Zigbee Stick - V4 (дизайн ZigStar от mercenaruss) на основе чипа TI CC2652P со встроенным усилителем на +19.5dbm. Стик на модуле от RF-STAR повторяет оригинальный лаунчпад от TI.
Покупал здесь - https://t.me/zigberu у Frianik
Этот новый стик хотя и имеет на борту чип с поддержкой и Bluetooth тоже, но прошивка BT пока не поддерживает.
Поэтому, пока попробую подключить отдельный стик Bluetooth и прокинуть BT устройства
Как уже писал выше нужна поддержка BT на кинетике, я так понял пакеты в Entware есть и их нужно просто поставить?
bluez-daemon_5.54-1_mipsel-3.4.ipk bluez-libs_5.54-1_mipsel-3.4.ipk bluez-utils-extra_5.54-1_mipsel-3.4.ipk bluez-utils_5.54-1_mipsel-3.4.ipk
Это они ?
Что можете сказать по этому поводу?
Всё, что нашел по теме https://hejdom.pl/blog/22-home-assistant/301-home-assistant-bluetooth-usb-do-terminali.html - с гугл переводчиком понятно.
Просто добавил в Кинетике компоненту Usb-Serial и ZHA сам нашел и подключил стик !
Согласно статье https://sprut.ai/client/article/2495
на RPi можно просмотреть usb устройства командой
ls /dev/serial/by-id/usb-*
Как в кинетике это же сделать?
В 20.11.2020 в 00:19, TheBB сказал:
поставьте пакет `opkg install python3-cryptodome`
т.к. устройств нет, имеем:
~ # ls -1 /opt/var/lib/homeassistant/deps/lib/python3.8/site-packages/ aiosqlite aiosqlite-0.16.0.dist-info attr attrs-20.3.0.dist-info bellows bellows-0.20.3.dist-info certifi certifi-2020.11.8.dist-info click click-7.1.2.dist-info click_log click_log-0.2.0.dist-info coloredlogs coloredlogs-14.0.dist-info coloredlogs.pth crccheck crccheck-1.0.dist-info gTTS_token-1.1.4-py3.8.egg-info gtts_token humanfriendly humanfriendly-8.2.dist-info pure_pcapy pure_pcapy3-1.0.1-py3.8.egg-info pyserial-3.4.dist-info pyserial_asyncio-0.4.dist-info pyusb-1.1.0.dist-info serial serial_asyncio tests urllib3 urllib3-1.26.2.dist-info usb zha_quirks-0.0.46.dist-info zhaquirks zigpy zigpy-0.27.0.dist-info zigpy_cc zigpy_cc-0.5.2.dist-info zigpy_deconz zigpy_deconz-0.11.0.dist-info zigpy_xbee zigpy_xbee-0.13.0.dist-info zigpy_zigate zigpy_zigate-0.7.2-py3.8.egg-info zigpy_znp zigpy_znp-0.2.2.dist-info ~ #
с ожидаемым результатом )))
Подключил zigbee stick,
в логе появилось:
Ноя 30 14:45:35 kernelusb 1-2: new full-speed USB device number 8 using xhci-mtkНоя 30 14:45:35 kernelusb 1-2: New USB device found, idVendor=1a86, idProduct=7523Ноя 30 14:45:35 kernelusb 1-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0Ноя 30 14:45:35 kernelusb 1-2: Product: USB SerialВ ZHA такое же окно с запросом порта тоже появляетсяВопрос - что писать в поле - путь к устройству? -
13 минуты назад, Семён Карелин сказал:
Не знаю ваших задач для bluetoth но для многих подходит разворачивание BLE на esp32, esphome
Отдельное устройство - шлюз с BLE на esp32 для проброса ВТ устройств в НА через WiFi - это один из вариантов. Хотелось бы обойтись без шлюза, только используя стик прямо на кинетике с установленным HA
Пытаюсь подцепить в HA bluetooth стик.
По аналогии со статьёй - https://hejdom.pl/blog/22-home-assistant/301-home-assistant-bluetooth-usb-do-terminali.html,
по идее нужно установить пакеты для поддержки BT
в Entware есть что-то подобное:
Кто может прояснить ситуацию?
Что поставить чтобы можно было использовать bluetooth стик ?
1 час назад, BDV сказал:
Олег, у меня HACS встал без проблем. Он как бы и не должен появиться в списке интеграций, он добавляется в боковое меню главного экрана.
Благодарю за подсказку, тоже поставил через конфиг. Просто на hassos он у меня без редактирования конфига ставился и в интеграциях виден !
А ZHA у Вас ставится? Доходит до запроса порта?
Home Assistant
in Вопросы по сборке и настройке Opkg
Posted
То же самое, поставил HTTP и в межсетевом экране оставил снаружи только 443 порт, остальные прикрыл.
