Олег Осипов Posted February 8 Share Posted February 8 TheBB, спасибо за обновление, всё работает! Quote Link to comment Share on other sites More sharing options...
skysilver Posted February 9 Share Posted February 9 (edited) Добрый день! При установки пакетов такая ошибка: ~ # npm install bufferutil > bufferutil@4.0.6 install /opt/root/node_modules/bufferutil > node-gyp-build sh: node-gyp-build: not found npm WARN root@1.0.0 No description npm WARN root@1.0.0 No repository field. npm ERR! code ELIFECYCLE npm ERR! syscall spawn npm ERR! file sh npm ERR! errno ENOENT npm ERR! bufferutil@4.0.6 install: `node-gyp-build` npm ERR! spawn ENOENT npm ERR! npm ERR! Failed at the bufferutil@4.0.6 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /opt/root/.npm/_logs/2022-02-09T12_28_54_702Z-debug.log Подскажите как исправить? Edited February 9 by skysilver Quote Link to comment Share on other sites More sharing options...
YuriV Posted February 9 Share Posted February 9 я устанавливал зависимости отсюда: Index of /mipselsf-k3.4/test/node-js/ (entware.net) opkg install http://bin.entware.net/mipselsf-k3.4/test/node-js/node-bufferutil_4.0.6-1_mipsel-3.4.ipk opkg install http://bin.entware.net/mipselsf-k3.4/test/node-js/node-utf-8-validate_5.0.8-1_mipsel-3.4.ipk opkg install http://bin.entware.net/mipselsf-k3.4/test/node-js/node-zigbee2mqtt_1.23.0-1_mipsel-3.4.ipk Quote Link to comment Share on other sites More sharing options...
skysilver Posted February 10 Share Posted February 10 21 час назад, YuriV сказал: я устанавливал зависимости отсюда: Index of /mipselsf-k3.4/test/node-js/ (entware.net) opkg install http://bin.entware.net/mipselsf-k3.4/test/node-js/node-bufferutil_4.0.6-1_mipsel-3.4.ipk opkg install http://bin.entware.net/mipselsf-k3.4/test/node-js/node-utf-8-validate_5.0.8-1_mipsel-3.4.ipk opkg install http://bin.entware.net/mipselsf-k3.4/test/node-js/node-zigbee2mqtt_1.23.0-1_mipsel-3.4.ipk YuriV спасибо Вам за подсказку. Установил, все работает! Quote Link to comment Share on other sites More sharing options...
SenatoR Posted March 4 Share Posted March 4 Добрые сутки всем! Поделитесь, пожалуйста, точными наименованиями стиков, которые гарантированно работают в Keenetic с точки зрения поддержки модулями ядра. Я дозрел до того, чтобы выкинуть хабы, хочу подкупить железо. Заранее спасибо! Quote Link to comment Share on other sites More sharing options...
skysilver Posted March 5 Share Posted March 5 Я пользуюсь стиком v4 на базе модуля Ebyte E72-2G4M20S1E (чип cc2652p). Страница проекта https://github.com/egony/cc2652p_E72-2G4M20S1E 1 Quote Link to comment Share on other sites More sharing options...
Олег Осипов Posted March 6 Share Posted March 6 (edited) Со стороны Кинетика работа со стиком осуществляется через компоненту: Переходники USB – Последовательный порт Поддерживаемые наборы микросхем: FTDI PL2303 CP2101/2102 CH340/341 Cypress M8 Следовательно будут работать любые стики, использующие перечисленные чипы на USB интерфейсе, Со стороны HA поддержка стиков в модулях ZHA или z2m в зависимости от того, что используете. С точки зрения работы с zigbee сетью, сейчас наиболее продвинутые стики на чипе сс2652. Сам использую Стик V4 СС2652р (модуль RF-star) Edited March 6 by Олег Осипов 1 Quote Link to comment Share on other sites More sharing options...
YuriV Posted March 7 Share Posted March 7 Я пользуюсь SONOFF Zigbee 3.0 USB Dongle Plus. Работает отлично, проблем не наблдаю. Покупал на aliexpress занедорого. 1 Quote Link to comment Share on other sites More sharing options...
SenatoR Posted March 8 Share Posted March 8 Всем большое спасибо за ответы! Попробую закупить железку! Quote Link to comment Share on other sites More sharing options...
Евгений Филимонов Posted March 19 Share Posted March 19 Обновите пожалуйста до 1.24. Quote Link to comment Share on other sites More sharing options...
TheBB Posted March 19 Author Share Posted March 19 9 часов назад, Евгений Филимонов сказал: Обновите... Для начала читаем, напр., тут (втыкание по ссылкам приветствуется). Проверять весь код из-за очередного долб гендерно-алтернативного (ш)кодера - нет ни желания, ни времени. Если готовы отправиться в "удивительный мир приключений", можно и собрать, но... испытывать на себе не буду. 3 Quote Link to comment Share on other sites More sharing options...
Алекс Стеблов Posted March 21 Share Posted March 21 (edited) Доброго времени суток. При установке z2m вылетает ошибка о несовместимости архитектуры. Как можно исправить ? Роутер keenetic-1011 Edited March 21 by Алекс Стеблов Quote Link to comment Share on other sites More sharing options...
Matus Posted June 9 Share Posted June 9 (edited) В 19.03.2022 в 19:28, TheBB сказал: Для начала читаем, напр., тут (втыкание по ссылкам приветствуется). Проверять весь код из-за очередного долб гендерно-алтернативного (ш)кодера - нет ни желания, ни времени. Если готовы отправиться в "удивительный мир приключений", можно и собрать, но... испытывать на себе не буду. Приветствую! Подскажите ,на kn-1011 GIGA возможна установка? или только на прошлые версии? з.ы я не про обновления, та же 1.23 версию вообще возможно установить или на кн-1011 не получится? Edited June 9 by Matus Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 10 Author Share Posted June 10 В 21.03.2022 в 09:25, Алекс Стеблов сказал: При установке z2m вылетает ошибка о несовместимости архитектуры. Как можно исправить ? Не архитектуры, а зависимостей "... cannot find dependency node-utf-8-validate..." см. https://forum.keenetic.com/topic/10684-zigbee2mqtt-z2m/?do=findComment&comment=141401 В 09.06.2022 в 11:27, Matus сказал: та же 1.23 версию вообще возможно установить или на кн-1011 не получится? то же самое, см. https://forum.keenetic.com/topic/10684-zigbee2mqtt-z2m/?do=findComment&comment=141401 Т.к. индекс пакетов отсутствует, помогаем "opkg install" руками... 1 Quote Link to comment Share on other sites More sharing options...
Matus Posted July 25 Share Posted July 25 Приветствую! Подскажите пожалуйста, кто как использует стики? К примеру SONOFF Zigbee 3.0 USB Dongle Plus, после установки z2m на kn-1011 всё равно требуется внешний сервер для управления этим всем? Или возможно, как то управлять по другому? На HA ставиться плагин с z2m и веб интерфейсом для управления, а на роутер зачем стик с z2m? Quote Link to comment Share on other sites More sharing options...
r13 Posted July 25 Share Posted July 25 (edited) 1 час назад, Matus сказал: Приветствую! Подскажите пожалуйста, кто как использует стики? К примеру SONOFF Zigbee 3.0 USB Dongle Plus, после установки z2m на kn-1011 всё равно требуется внешний сервер для управления этим всем? Или возможно, как то управлять по другому? На HA ставиться плагин с z2m и веб интерфейсом для управления, а на роутер зачем стик с z2m? Извращаться с установкой z2m на роутере имеет смысл если и управление(ha) там же Если же ha где то еще то к стику проще удаленно цепляться ЗФ А стики на роутере позволяют раскидать их по дому https://www.zigbee2mqtt.io/advanced/remote-adapter/connect_to_a_remote_adapter.html#_1-install-ser2net Edited July 25 by r13 Quote Link to comment Share on other sites More sharing options...
Matus Posted July 25 Share Posted July 25 55 минут назад, r13 сказал: Извращаться с установкой z2m на роутере имеет смысл если и управление(ha) там же Если же ha где то еще то к стику проще удаленно цепляться ЗФ А стики на роутере позволяют раскидать их по дому https://www.zigbee2mqtt.io/advanced/remote-adapter/connect_to_a_remote_adapter.html#_1-install-ser2net ha тоже не роутер ставят? или на внешний винт всмысле? Quote Link to comment Share on other sites More sharing options...
r13 Posted July 25 Share Posted July 25 1 час назад, Matus сказал: ha тоже не роутер ставят? или на внешний винт всмысле? На внешний винт подключенный к роутеру. Quote Link to comment Share on other sites More sharing options...
