  • 1
Падает PPPoe соединение
vrodetogo
 Share
Всем привет прошивка 3.6.10. роутер Giga (KN-1010), каждое утро в одно и тоже время рвется соединение, лог ниже, что может быть?
Jul 28 06:41:20 [ Info ] pppd[17163] > No response to 3 echo-requests
Jul 28 06:41:20 [ Info ] pppd[17163] > Serial link appears to be disconnected.
Jul 28 06:41:20 [ Info ] pppd[17163] > Connect time 687.0 minutes.
Jul 28 06:41:20 [ Info ] pppd[17163] > Sent 1019172918 bytes, received 3518965396 bytes.
Jul 28 06:41:20 [ Info ] ndm > Network::Interface::Ip: "PPPoE0": IP address cleared.
Jul 28 06:41:21 [ Info ] upnp > shutting down MiniUPnPd
Jul 28 06:41:21 [ Info ] ndm > Core::Session: client disconnected.
Jul 28 06:41:21 [ Info ] ndm > Http::Nginx: loaded SSL certificate for "59a5697e1c9485222954c388.keenetic.io".
Jul 28 06:41:21 [ Info ] ndm > Core::Server: started Session /var/run/ndm.core.socket.
Jul 28 06:41:21 [ Info ] ndm > Http::Manager: updated configuration.
Jul 28 06:41:25 [ Error ] ndnproxy > failed to connect to server [0] 95.128.243.2#53: network unreachable.
Jul 28 06:41:26 [ Info ] pppd[17163] > Connection terminated.
Jul 28 06:41:26 [ Error ] pppd[17163] > write: Bad file descriptor (9)
Jul 28 06:41:26 [ Info ] pppd[17163] > Sent PADT
Jul 28 06:41:26 [ Info ] pppd[17163] > Modem hangup
Jul 28 06:41:26 [ Info ] pppd[17163] > Exit.
Jul 28 06:41:26 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:41:26 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:41:28 [ Info ] pppd[24767] > Plugin rp-pppoe.so loaded.
Jul 28 06:41:28 [ Info ] pppd[24767] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:41:28 [ Info ] pppd[24767] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:41:29 [ Info ] pppd[24767] > Sent PADT
Jul 28 06:41:44 [ Warning ] pppd[24767] > Timeout waiting for PADO packets
Jul 28 06:41:44 [ Error ] pppd[24767] > Unable to complete PPPoE Discovery
Jul 28 06:41:44 [ Info ] pppd[24767] > Exit.
Jul 28 06:41:44 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:41:44 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:41:44 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 1.
Jul 28 06:41:46 [ Info ] pppd[24768] > Plugin rp-pppoe.so loaded.
Jul 28 06:41:46 [ Info ] pppd[24768] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:41:46 [ Info ] pppd[24768] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:41:46 [ Info ] pppd[24768] > Sent PADT
Jul 28 06:42:02 [ Warning ] pppd[24768] > Timeout waiting for PADO packets
Jul 28 06:42:02 [ Error ] pppd[24768] > Unable to complete PPPoE Discovery
Jul 28 06:42:02 [ Info ] pppd[24768] > Exit.
Jul 28 06:42:02 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:42:02 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:42:02 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 2.
Jul 28 06:42:04 [ Info ] pppd[24770] > Plugin rp-pppoe.so loaded.
Jul 28 06:42:04 [ Info ] pppd[24770] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:42:04 [ Info ] pppd[24770] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:42:05 [ Info ] pppd[24770] > Sent PADT
Jul 28 06:42:20 [ Warning ] pppd[24770] > Timeout waiting for PADO packets
Jul 28 06:42:20 [ Error ] pppd[24770] > Unable to complete PPPoE Discovery
Jul 28 06:42:20 [ Info ] pppd[24770] > Exit.
Jul 28 06:42:20 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:42:20 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:42:20 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 3.
Jul 28 06:42:22 [ Info ] pppd[24773] > Plugin rp-pppoe.so loaded.
Jul 28 06:42:22 [ Info ] pppd[24773] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:42:22 [ Info ] pppd[24773] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:42:22 [ Info ] pppd[24773] > Sent PADT
Jul 28 06:42:37 [ Warning ] pppd[24773] > Timeout waiting for PADO packets
Jul 28 06:42:38 [ Error ] pppd[24773] > Unable to complete PPPoE Discovery
Jul 28 06:42:38 [ Info ] pppd[24773] > Exit.
Jul 28 06:42:38 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:42:38 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:42:38 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 4.
Jul 28 06:42:40 [ Info ] pppd[24774] > Plugin rp-pppoe.so loaded.
Jul 28 06:42:40 [ Info ] pppd[24774] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:42:40 [ Info ] pppd[24774] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:42:40 [ Info ] pppd[24774] > Sent PADT
Jul 28 06:42:55 [ Warning ] pppd[24774] > Timeout waiting for PADO packets
Jul 28 06:42:55 [ Error ] pppd[24774] > Unable to complete PPPoE Discovery
Jul 28 06:42:55 [ Info ] pppd[24774] > Exit.
Jul 28 06:42:55 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:42:55 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:42:55 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 5.
Jul 28 06:42:55 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": try to restart underlying link.
Jul 28 06:42:56 [ Info ] ndm > Network::Interface::Ethernet: "GigabitEthernet1": link down.
Jul 28 06:42:56 [ Info ] ndm > Network::Interface::Ppp: "PPPoE0": connection service standby.
Jul 28 06:42:56 [ Info ] ndhcpc > GigabitEthernet1: NDM DHCP client stopped (exit status 0).
Jul 28 06:42:57 [ Info ] ndm > Network::Interface::Ethernet: "GigabitEthernet1": link up (100FD/AN).
Jul 28 06:42:59 [ Info ] ndhcpc > GigabitEthernet1: NDM DHCP Client, v3.2.45.
Jul 28 06:42:59 [ Info ] ndhcpc > GigabitEthernet1: created PID file "/var/run/ndhcpc-eth3.pid".
Jul 28 06:42:59 [ Info ] pppd[24777] > Plugin rp-pppoe.so loaded.
Jul 28 06:42:59 [ Info ] pppd[24777] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:42:59 [ Info ] pppd[24777] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:42:59 [ Info ] pppd[24777] > Sent PADT
Jul 28 06:43:14 [ Warning ] pppd[24777] > Timeout waiting for PADO packets
Jul 28 06:43:14 [ Error ] pppd[24777] > Unable to complete PPPoE Discovery
Jul 28 06:43:14 [ Info ] pppd[24777] > Exit.
Jul 28 06:43:14 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:43:14 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:43:14 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 1.
Jul 28 06:43:16 [ Info ] pppd[24781] > Plugin rp-pppoe.so loaded.
Jul 28 06:43:16 [ Info ] pppd[24781] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:43:16 [ Info ] pppd[24781] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:43:16 [ Info ] pppd[24781] > Sent PADT
Jul 28 06:43:30 [ Warning ] pppd[24781] > Timeout waiting for PADO packets
Jul 28 06:43:30 [ Error ] pppd[24781] > Unable to complete PPPoE Discovery
Jul 28 06:43:30 [ Info ] pppd[24781] > Exit.
Jul 28 06:43:30 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:43:30 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:43:31 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 2.
Jul 28 06:43:33 [ Info ] pppd[24783] > Plugin rp-pppoe.so loaded.
Jul 28 06:43:33 [ Info ] pppd[24783] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:43:33 [ Info ] pppd[24783] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:43:33 [ Info ] pppd[24783] > Sent PADT
Jul 28 06:43:48 [ Warning ] pppd[24783] > Timeout waiting for PADO packets
Jul 28 06:43:48 [ Error ] pppd[24783] > Unable to complete PPPoE Discovery
Jul 28 06:43:48 [ Info ] pppd[24783] > Exit.
Jul 28 06:43:48 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:43:48 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:43:48 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 3.
Jul 28 06:43:50 [ Info ] pppd[24784] > Plugin rp-pppoe.so loaded.
Jul 28 06:43:50 [ Info ] pppd[24784] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:43:50 [ Info ] pppd[24784] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:43:50 [ Info ] pppd[24784] > Sent PADT
Jul 28 06:44:05 [ Warning ] pppd[24784] > Timeout waiting for PADO packets
Jul 28 06:44:05 [ Error ] pppd[24784] > Unable to complete PPPoE Discovery
Jul 28 06:44:05 [ Info ] pppd[24784] > Exit.
Jul 28 06:44:05 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:44:05 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:44:06 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 4.
Jul 28 06:44:08 [ Info ] pppd[24786] > Plugin rp-pppoe.so loaded.
Jul 28 06:44:08 [ Info ] pppd[24786] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:44:08 [ Info ] pppd[24786] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:44:08 [ Info ] pppd[24786] > Sent PADT
Jul 28 06:44:23 [ Warning ] pppd[24786] > Timeout waiting for PADO packets
Jul 28 06:44:23 [ Error ] pppd[24786] > Unable to complete PPPoE Discovery
Jul 28 06:44:23 [ Info ] pppd[24786] > Exit.
Jul 28 06:44:23 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:44:23 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:44:23 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 5.
Jul 28 06:44:23 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": try to restart underlying link.
Jul 28 06:44:24 [ Info ] ndm > Network::Interface::Ethernet: "GigabitEthernet1": link down.
Jul 28 06:44:24 [ Info ] ndm > Network::Interface::Ppp: "PPPoE0": connection service standby.
Jul 28 06:44:24 [ Info ] ndhcpc > GigabitEthernet1: NDM DHCP client stopped (exit status 0).
Jul 28 06:44:25 [ Info ] ndm > Network::Interface::Ethernet: "GigabitEthernet1": link up (100FD/AN).
Jul 28 06:44:27 [ Info ] ndhcpc > GigabitEthernet1: NDM DHCP Client, v3.2.45.
Jul 28 06:44:27 [ Info ] ndhcpc > GigabitEthernet1: created PID file "/var/run/ndhcpc-eth3.pid".
Jul 28 06:44:27 [ Info ] pppd[24789] > Plugin rp-pppoe.so loaded.
Jul 28 06:44:27 [ Info ] pppd[24789] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:44:27 [ Info ] pppd[24789] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
Jul 28 06:44:27 [ Info ] pppd[24789] > Sent PADT
Jul 28 06:44:42 [ Warning ] pppd[24789] > Timeout waiting for PADO packets
Jul 28 06:44:42 [ Error ] pppd[24789] > Unable to complete PPPoE Discovery
Jul 28 06:44:42 [ Info ] pppd[24789] > Exit.
Jul 28 06:44:42 [ Error ] ndm > Service: "PPPoE0": unexpectedly stopped.
Jul 28 06:44:42 [ Info ] ndm > Network::Interface::Base: "PPPoE0": interface is up.
Jul 28 06:44:43 [ Info ] ndm > Network::Interface::Pppoe: "PPPoE0": PADO timeouts: 1.
Jul 28 06:44:45 [ Info ] pppd[24791] > Plugin rp-pppoe.so loaded.
Jul 28 06:44:45 [ Info ] pppd[24791] > pppd 2.4.4-4 started by root, uid 0
Jul 28 06:44:45 [ Info ] pppd[24791] > Found unterminated session: 3139:1c:9c:8c:1f:d3:8c
9 answers to this question
18 минут назад, vrodetogo сказал:
  Скрыть содержимое
Только то что согласно конф данного сервиса
interface PPPoE0
    lcp echo 30 3
LCP echo interval или механизм Keep-Alive.
Цитата
Работает это таким образом: если от PPPoE-сервера нет никакой активности, то роутер начинает опрашивать сервер, отправив ему 3 пакетов PPP LCP Echo Request с интервалом в 30 секунд. Если за это время от сервера не придёт ответ (PPP LCP Echo Reply), то роутер считает сервер недоступным и завершает текущую PPPoE-сессию, после чего инициирует новую.
687 минут / 60 = 11,45 часа, т.е. старт данной сессии был 06-41 минус 11,45 часа где в районе 18часов плюс/минус.
Как то РТ баловался сменой IP через 12 часов или 24 часа. Но тут "No response to 3 echo-requests" нет ответов на Request. Выход разговаривать с провайдером по данному вопросу или увеличить интервал с 30 сек до 60 сек и при повторе опять же разговаривать с провайдером. Как увеличить интервал есть в описание команд CLI
Цитата
3.32.123 interface lcp echo
Описание Задать правила тестирования соединения PPP средствами LCP echo.
По умолчанию
interval равен 30, count равен 3.
Команда с префиксом
no отключает LCP echo.
Да
Да
Префикс no
Меняет настройки
Многократный ввод Нет
Тип интерфейса PPP
Синопсис
(config-if)> lcp echo interval› ‹count[adaptive]
30 минут назад, vasek00 сказал:
interface PPPoE0
    lcp echo 30 3
Спасибо огромное!
52 minutes ago, vrodetogo said:
Спасибо огромное!
Постоянно падает и включается. Переключение на ping не помогает.
Заигрывание с LCP тоже
Началось с 3.6.7 все. Откатился на основном роутере,о подключени. проблемы пропали,  с ДНС проблемы появились.
Опять на новой, теперь 3.6.10 переключается между PPPoE и второй линией резервной каждую минуту
18 минут назад, Melzy сказал:
О каком заигрывание идет речь.
Для начало лог и только после оценки лога можно что-то сказать.
Столкнулся с похожей проблемой. Доступ в интернет был интервалами. Помогло сбросить на заводские (пока что помогло...)
Грешил на провайдера. Они пришли и проверили всю линию целиком от коробки до роутера и пк. И после часа экспериментов, было выявлено что роутер живет своей жизнью. Перед сбросом на дефол  сохранил логи и селф тест. (скину скрыто следующим сообщением)
21 минуту назад, Si_Siska сказал:
Не видя реальности по логу выскажу свое мнение а свой сервер провайдера к которому вы подключаетесь для PPPoE у них тоже в порядке не дурит ?
Если нужна помощь от формунчан то нужно от чего отталкиваться, если от разработчиков то selftest обязателен.
7 минут назад, vasek00 сказал:
Пока все в порядке. Все стабильно грузит, по вайвай доступ в инет есть. (ранее телефон вообще не имел выхода в инет, а комп пробивался интервалами)
25 минут назад, vasek00 сказал:
Проблемы ранее не наблюдалось, но на какой версии прошивки я был до, не помню. но помню точно обновился и началась проблемы. Грешил на провайдера, так как совпало с изменением скорости для абонентов в +.
Всем привет! Сидел на Ultra (KN-1810) ver. 3.6.3 до сегодняшнего дня, PPPoE работало (только 3-4 раза в год происходили проблемы с сервером на стороне провайдера), с утра у провайдера была авария, за это время успел подключить нового провайдера (под резервную линию), отдал ему Port 1 (итого 2 WAN и 3 LAN), а после восстановления первого провайдера его интернет отработал 2-3 минуты и пропал. Оказалось, физически линк на месте, как и локальные настройки по DHCP, а вот PPPoE клиент кинетика держит режим Connecting... Приходили спецы, заменили входящий кабель, без толку... Переключил второго провайдера на основной режим, а первого под резервный, начал думать :) Обновил прошивку роутера до 3.6.10 никаких улучшений. Достал Mikrotik hAP ac2 (ROS ver.7.1rc3) настроил под первого провайдера и всё работает отлично, PPPoE не обрывается. Грешу теперь именно на новую настройку с резервным провайдером, но пока попробовать вернуть настройки как было не могу...
Прикладываю лог, отключил второго провайдера (теперь основной), MTU на линке 1500, на PPPoE MTU 1412 (был 1492, на всякий случай уменьшил), коннект происходит, интернет есть, затем пропадает с 22:50:30 (свой ip скрыл за XXX)
Sep 20 22:50:01
ndm
Network::Interface::Base: "GigabitEthernet1": interface is up.
Sep 20 22:50:01
ndm
Sep 20 22:50:01
ndm
Sep 20 22:50:01
ndm
Sep 20 22:50:01
ndm
Sep 20 22:50:01
ndm
Sep 20 22:50:03
ndhcpc
Sep 20 22:50:03
ndhcpc
Sep 20 22:50:04
ndm
Core::ConfigurationSaver: configuration saved.
Sep 20 22:50:10
ndhcpc
GigabitEthernet1: received OFFER for 10.105.15.151 from 172.20.0.3.
Sep 20 22:50:19
ndm
PingCheck::Profile: "_WEBADMIN_GigabitEthernet1": restore connected state.
Sep 20 22:50:19
ndm
PingCheck::Profile: interface ISP connection recovered.
Sep 20 22:50:21
pppd[5124]
Sep 20 22:50:21
pppd[5124]
Sep 20 22:50:21
pppd[5124]
Found unterminated session: 42447:cc:bb:fe:5e:c2:81
Sep 20 22:50:21
pppd[5124]
Sent PADT
Sep 20 22:50:22
pppd[5124]
PPP session is 24778
Sep 20 22:50:22
pppd[5124]
Using interface ppp1
Sep 20 22:50:22
pppd[5124]
Connect: ppp1 <--> eth3
Sep 20 22:50:25
pppd[5124]
Remote message: Authentication success,Welcome!
Sep 20 22:50:25
pppd[5124]
PAP authentication succeeded
Sep 20 22:50:25
pppd[5124]
peer from calling number CC:BB:FE:5E:C4:71 authorized
Sep 20 22:50:25
pppd[5124]
local IP address 85.234.1X.XXX
Sep 20 22:50:25
pppd[5124]
remote IP address 85.234.2.XXX
Sep 20 22:50:25
pppd[5124]
primary DNS address 89.151.190.213
Sep 20 22:50:25
pppd[5124]
secondary DNS address 89.151.191.2
Sep 20 22:50:25
ndm
Sep 20 22:50:25
ndm
Sep 20 22:50:25
ndm
Network::Interface::Ppp: "PPPoE0": interface "PPPoE0" is global, priority 64267.
Sep 20 22:50:25
ndm
Network::Interface::Ppp: "PPPoE0": adding default route via PPPoE0.
Sep 20 22:50:25
ndm
Network::Interface::Ppp: "PPPoE0": adding nameserver 89.151.190.213.
Sep 20 22:50:25
ndm
Dns::Manager: name server 89.151.190.213 added, domain (default).
Sep 20 22:50:25
ndm
Network::Interface::Ppp: "PPPoE0": adding nameserver 89.151.191.2.
Sep 20 22:50:25
ndm
Dns::Manager: name server 89.151.191.2 added, domain (default).
Sep 20 22:50:25
ndm
Network::Interface::Ip: "PPPoE0": IP address is 85.234.1X.XXX/32.
Sep 20 22:50:25
ndm
Dns::Manager: name server 77.88.8.8 added, domain (default).
Sep 20 22:50:25
ndm
Dns::Manager: name server 77.88.8.1 added, domain (default).
Sep 20 22:50:26
ndm
Http::Nginx: loaded SSL certificate for "3f7d8776fbc9ac2f0f62eXXX.keenetic.io".
Sep 20 22:50:26
ndm
Sep 20 22:50:26
ndm
Sep 20 22:50:26
ndm
Sep 20 22:50:26
ndm
Sep 20 22:50:26
ndm
Sep 20 22:50:27
ndm
Sep 20 22:50:27
upnp
HTTP listening on port 52257
Sep 20 22:50:27
upnp
Listening for NAT-PMP/PCP traffic on port 5351
Sep 20 22:50:30
ndm
Network::InternetChecker: Internet access detected.
Sep 20 22:50:39
ndm
PingCheck::Profile: "_WEBADMIN_PPPoE0": restore connected state.
Sep 20 22:50:39
ndhcpc
GigabitEthernet1: received ACK for 10.105.15.151 from 172.20.0.3 lease 3600 sec.
Sep 20 22:50:39
ndm
Dhcp::Client: configuring interface ISP.
Sep 20 22:50:39
ndm
Network::Interface::Ip: "GigabitEthernet1": IP address is 10.105.15.151/24.
Sep 20 22:50:39
ndm
Dhcp::Client: obtained IP address 10.105.15.151/24.
Sep 20 22:50:39
ndm
Dhcp::Client: interface "ISP" is not global.
Sep 20 22:50:39
ndm
Dhcp::Client: name server 85.234.0.20 is ignored.
Sep 20 22:50:39
ndm
Dhcp::Client: name server 85.234.0.38 is ignored.
Sep 20 22:50:39
ndm
Dhcp::Client: adding route 172.20.0.0/255.255.254.0/10.105.15.254.
Sep 20 22:50:39
ndm
Dhcp::Client: adding route 85.234.0.0/255.255.255.192/10.105.15.254.
Sep 20 22:50:39
ndm
Dhcp::Client: adding route 85.234.2.52/255.255.255.252/10.105.15.254.
Sep 20 22:50:39
ndm
Dhcp::Client: adding route 172.21.0.0/255.255.0.0/10.105.15.254.
Sep 20 22:50:39
ndm
Dhcp::Client: adding route 10.0.0.0/255.0.0.0/10.105.15.254.
Sep 20 22:50:39
ndm
Sep 20 22:50:39
ndm
Sep 20 22:50:39
ndm
Sep 20 22:50:39
ndm
Sep 20 22:50:39
ndm
Sep 20 22:50:39
nimproxy
NDM IGMP/Multicast proxy stopped (exit status: 0).
Sep 20 22:50:40
ndm
Http::Nginx: loaded SSL certificate for "3f7d8776fbc9ac2f0f62ee14.keenetic.io".
Sep 20 22:50:40
ndm
Sep 20 22:50:40
ndm
Sep 20 22:50:40
ndm
Sep 20 22:50:40
ndm
Sep 20 22:50:41
ndm
Sep 20 22:50:41
nimproxy
NDM IGMP/Multicast Proxy, v0.0.35.
Sep 20 22:50:59
ndm
Edited by Ринат Сабиров
 Share
