AlexanderG3 Posted August 26, 2021 Share Posted August 26, 2021 Добрый день. Регулярно раз в шесть часов падает L2TP/IPSec, в логах видно: [I] Aug 24 23:04:33 ipsec: 05[IKE] received NAT-T (RFC 3947) vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received draft-ietf-ipsec-nat-t-ike-00 vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received Cisco Unity vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] received DPD vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] W1.X1.Y1.Z1 is initiating a Main Mode IKE_SA [I] Aug 24 23:04:33 ipsec: 05[CFG] received proposals: IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024 [I] Aug 24 23:04:33 ipsec: 05[CFG] configured proposals: IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/ECP_384, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/ECP_256, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:AES_CBC=256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1024, IKE:AES_CBC=128/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1024, IKE:3DES_CBC/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1024 [I] Aug 24 23:04:33 ipsec: 05[CFG] selected proposal: IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024 [I] Aug 24 23:04:33 ipsec: 05[IKE] sending XAuth vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] sending DPD vendor ID [I] Aug 24 23:04:33 ipsec: 05[IKE] sending NAT-T (RFC 3947) vendor ID [I] Aug 24 23:04:33 ipsec: 10[IKE] linked key for crypto map '(unnamed)' is not found, still searching [I] Aug 24 23:04:33 ipsec: 11[CFG] looking for pre-shared key peer configs matching W2.X2.Y2.Z2...W1.X1.Y1.Z1[W1.X1.Y1.Z1] [I] Aug 24 23:04:33 ipsec: 11[CFG] selected peer config "L2TP0" [I] Aug 24 23:04:33 ipsec: 11[IKE] detected reauth of existing IKE_SA, adopting 1 children and 0 virtual IPs [I] Aug 24 23:04:33 ipsec: 11[IKE] schedule delete of duplicate IKE_SA for peer 'W1.X1.Y1.Z1' due to uniqueness policy and suspected reauthentication [I] Aug 24 23:04:33 ipsec: 11[IKE] IKE_SA L2TP0[106] established between W2.X2.Y2.Z2[W2.X2.Y2.Z2]...W1.X1.Y1.Z1[W1.X1.Y1.Z1] [I] Aug 24 23:04:33 ipsec: 11[IKE] scheduling reauthentication in 28767s [I] Aug 24 23:04:33 ipsec: 11[IKE] maximum IKE_SA lifetime 28787s [I] Aug 24 23:04:34 ndm: IpSec::CryptoMapInfo: "L2TP0": crypto map active IKE SA: 2, active CHILD SA: 1. [I] Aug 24 23:04:43 ipsec: 08[IKE] deleting IKE_SA L2TP0[105] between W2.X2.Y2.Z2[W2.X2.Y2.Z2]...W1.X1.Y1.Z1[W1.X1.Y1.Z1] [I] Aug 24 23:04:43 ipsec: 08[IKE] sending DELETE for IKE_SA L2TP0[105] [I] Aug 24 23:04:44 ndm: IpSec::CryptoMapInfo: "L2TP0": crypto map active IKE SA: 1, active CHILD SA: 1. [I] Aug 24 23:06:35 pppd_L2TP0: No response to 3 echo-requests [I] Aug 24 23:06:35 pppd_L2TP0: Serial link appears to be disconnected. [I] Aug 24 23:06:35 pppd_L2TP0: Connect time 386.1 minutes. [I] Aug 24 23:06:35 pppd_L2TP0: Sent 505126 bytes, received 1072468 bytes. [I] Aug 24 23:06:35 ndm: Network::Interface::Ip: "L2TP0": IP address cleared. Пожалуйста помогите решить проблему. Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 26, 2021 Share Posted August 26, 2021 Уменьшите на кинетике ike lifetime, чтобы именно кинетик запускал rekey. Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted August 26, 2021 Author Share Posted August 26, 2021 Спасибо за быстрый ответ. Это параметр ipsec proposal lifetime на уровне интерфейса L2TP? Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 26, 2021 Share Posted August 26, 2021 1 час назад, AlexanderG3 сказал: Спасибо за быстрый ответ. Это параметр ipsec proposal lifetime на уровне интерфейса L2TP? Да, он. Поставьте в районе 20000, и ipsec transform-set в 20000. Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted August 26, 2021 Author Share Posted August 26, 2021 Спасибо, сейчас поставлю - вернусь с результатом. Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted August 26, 2021 Author Share Posted August 26, 2021 Для тестирования, чтобы меньше ждать обновления ключа поставил lifetime 3600, если менять один параметр ipsec proposal lifetime, то ключ по видимому обновляется, а вот если это же значение поставить для ipsec transform-set, то все возвращается к той же ситуации как была, только уже не раз в шесть часов, а раз в час. Поставлю 20000 и подожду, как с этой настройкой дела будут. Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 26, 2021 Share Posted August 26, 2021 1 час назад, AlexanderG3 сказал: Для тестирования, чтобы меньше ждать обновления ключа поставил lifetime 3600, если менять один параметр ipsec proposal lifetime, то ключ по видимому обновляется, а вот если это же значение поставить для ipsec transform-set, то все возвращается к той же ситуации как была, только уже не раз в шесть часов, а раз в час. Поставлю 20000 и подожду, как с этой настройкой дела будут. Да, можно по идее tset не трогать. Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted August 27, 2021 Author Share Posted August 27, 2021 При изменении только ipsec proposal lifetime обновление ISAKMP-SA проходит корректно(видно как на стороне микротика так и на стороне кинетика, служебный тоннель строится). Теперь осталось дождаться чтобы IPSec SA тоже обновились по проcшествию soft lifetime (hard 28800, soft 06:24:00). Напишу результат. Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted August 27, 2021 Author Share Posted August 27, 2021 (edited) К сожалению, IPSec SA без разрыва L2TP не обновился: прошло 8 часов и соединение упало. Скажите, пожалуйста, куда еще можно посмотреть, чтобы решить проблему? 11[IKE] initiator did not reauthenticate as requested Aug 27 16:28:54 ipsec 11[IKE] reauthenticating IKE_SA L2TP0[176] actively Aug 27 16:28:54 ipsec 11[IKE] sending XAuth vendor ID Aug 27 16:28:54 ipsec 11[IKE] sending DPD vendor ID Aug 27 16:28:54 ipsec 11[IKE] sending FRAGMENTATION vendor ID Aug 27 16:28:54 ipsec 11[IKE] sending NAT-T (RFC 3947) vendor ID Aug 27 16:28:54 ipsec 11[IKE] sending draft-ietf-ipsec-nat-t-ike-02\n vendor ID Aug 27 16:28:54 ipsec 11[IKE] initiating Main Mode IKE_SA L2TP0[177] to IP_Mikrotik Aug 27 16:28:54 ipsec 16[IKE] received NAT-T (RFC 3947) vendor ID Aug 27 16:28:54 ipsec 16[IKE] received XAuth vendor ID Aug 27 16:28:54 ipsec 16[IKE] received DPD vendor ID Aug 27 16:28:54 ipsec 16[IKE] received FRAGMENTATION vendor ID Aug 27 16:28:54 ipsec 16[CFG] received proposals: IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024 Aug 27 16:28:54 ipsec 16[CFG] configured proposals: IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/ECP_384, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/ECP_256, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:AES_CBC=256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1024, IKE:AES_CBC=128/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1024, IKE:3DES_CBC/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1024 Aug 27 16:28:54 ipsec 16[CFG] selected proposal: IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024 Aug 27 16:28:55 ipsec 09[IKE] found linked key for crypto map 'L2TP0' Aug 27 16:28:55 ipsec 08[IKE] schedule delete of duplicate IKE_SA for peer 'IP_Mikrotik' due to uniqueness policy and suspected reauthentication Aug 27 16:28:55 ipsec 08[IKE] IKE_SA L2TP0[177] established between IP_Keenetic[IP_Keenetic]...IP_Mikrotik[IP_Mikrotik] Aug 27 16:28:55 ipsec 08[IKE] scheduling reauthentication in 3566s Aug 27 16:28:55 ipsec 08[IKE] maximum IKE_SA lifetime 3586s Aug 27 16:28:55 ndm IpSec::CryptoMapInfo: "L2TP0": crypto map active IKE SA: 2, active CHILD SA: 1. Aug 27 16:29:05 ipsec 09[IKE] deleting IKE_SA L2TP0[176] between IP_Keenetic[IP_Keenetic]...IP_Mikrotik[IP_Mikrotik] Aug 27 16:29:05 ipsec 09[IKE] sending DELETE for IKE_SA L2TP0[176] Aug 27 16:29:05 ndm IpSec::CryptoMapInfo: "L2TP0": crypto map active IKE SA: 1, active CHILD SA: 1. Aug 27 16:30:22 ndhcps Aug 27 16:30:56 pppd_L2TP0 No response to 3 echo-requests Aug 27 16:30:56 pppd_L2TP0 Serial link appears to be disconnected. Edited August 27, 2021 by AlexanderG3 Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 27, 2021 Share Posted August 27, 2021 Очень уж похоже на баг в ROS, если честно. Он умеет реаутентификацию? Потому что пока видно, что оно или выключено или не умеет принципиально. Могу посоветовать только костыль в виде установки в ROS lifetime (оба, ike и sa) на, скажем, неделю-другую, и в keenetic тоже. Тогда разрывы сократятся до раз в неделю, но принципиально они останутся. Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted August 27, 2021 Author Share Posted August 27, 2021 Спасибо большое, буду копать в сторону ROS. Вы мне очень помогли, очень рад, что у Keenetic такая замечательная поддержка. Если что то узнаю про микротик - напишу. Quote Link to comment Share on other sites More sharing options...
krass Posted August 27, 2021 Share Posted August 27, 2021 1 час назад, AlexanderG3 сказал: ROS У вас он на ветке stable or long term? попробуйте long term -- может поможет.... Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted September 2, 2021 Author Share Posted September 2, 2021 On 8/27/2021 at 6:22 PM, krass said: У вас он на ветке stable or long term? попробуйте long term -- может поможет.... Спасибо. Уже на long term. Включил PFS - стало 3 rekey проходить норм, четвертый падает. Quote Link to comment Share on other sites More sharing options...
krass Posted September 2, 2021 Share Posted September 2, 2021 18 минут назад, AlexanderG3 сказал: Спасибо. Уже на long term. Включил PFS - стало 3 rekey проходить норм, четвертый падает. думаю тут придется уже обратиться в тех. поддержку микрота...ну и попробовать написать на форуме микрота -- может быть там смогут подсказать решение... Quote Link to comment Share on other sites More sharing options...
AlexanderG3 Posted September 2, 2021 Author Share Posted September 2, 2021 Да, тоже уже решил, что к ним надо обращаться. Напишу здесь результат в случае решения вопроса. 2 Quote Link to comment Share on other sites More sharing options...
