mystique_man Posted July 21, 2023 Share Posted July 21, 2023 Всё круто, только вопрос: где теперь этот конфиг то взять "по умолчанию" ?) Quote Link to comment Share on other sites More sharing options...
TheBB Posted July 22, 2023 Share Posted July 22, 2023 (edited) owrt`шники изменили структуру Makefile`a, ну-у-у, потерялся конфиг, дело-то житейское, за всем не уследить... https://www.nginx.com/resources/wiki/start/topics/examples/full/ или Скрытый текст user nobody; worker_processes 1; #error_log /opt/var/log/nginx/error.log; #error_log /opt/var/log/nginx/error.log notice; #error_log /opt/var/log/nginx/error.log info; #pid /opt/var/run/nginx.pid; events { worker_connections 64; } http { include mime.types; default_type application/octet-stream; #log_format main '$remote_addr - $remote_user [$time_local] "$request" ' # '$status $body_bytes_sent "$http_referer" ' # '"$http_user_agent" "$http_x_forwarded_for"'; #access_log /opt/var/log/nginx/access.log main; sendfile on; #tcp_nopush on; #keepalive_timeout 0; keepalive_timeout 65; #gzip on; server { listen 80; server_name localhost; #charset koi8-r; #access_log /opt/var/log/nginx/host.access.log; location / { root /opt/share/nginx/html; index index.html index.htm; } #error_page 404 /404.html; # redirect server error pages to the static page /50x.html # error_page 500 502 503 504 /50x.html; location = /50x.html { root html; } # proxy the PHP scripts to Apache listening on 127.0.0.1:80 # #location ~ \.php$ { # proxy_pass http://127.0.0.1; #} # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000 # #location ~ \.php$ { # root html; # fastcgi_pass 127.0.0.1:9000; # fastcgi_index index.php; # fastcgi_param SCRIPT_FILENAME /scripts$fastcgi_script_name; # include fastcgi_params; #} # deny access to .htaccess files, if Apache's document root # concurs with nginx's one # #location ~ /\.ht { # deny all; #} } # another virtual host using mix of IP-, name-, and port-based configuration # #server { # listen 8000; # listen somename:8080; # server_name somename alias another.alias; # location / { # root html; # index index.html index.htm; # } #} # HTTPS server # #server { # listen 443 ssl; # server_name localhost; # ssl_certificate cert.pem; # ssl_certificate_key cert.key; # ssl_session_cache shared:SSL:1m; # ssl_session_timeout 5m; # ssl_ciphers HIGH:!aNULL:!MD5; # ssl_prefer_server_ciphers on; # location / { # root html; # index index.html index.htm; # } #} } Edited July 22, 2023 by TheBB add def conf 2 Quote Link to comment Share on other sites More sharing options...
