На версии 3.8.2 эта команда не работает. Поэтому был модифицирован скрипт /opt/etc/ndm/ifstatechanged.d/000-fix-Wireguard2.sh
#!/bin/sh
[ "$1" == "hook" ] || exit 0
[ "$change" == "link" ] || exit 0
[ "$id" == "Wireguard2" ] || exit 0
ip6t() {
if ! ip6tables -C "$@" &>/dev/null; then
ip6tables -A "$@"
fi
case ${id}-${change}-${connected}-${link}-${up} in
${id}-link-yes-up-up)
cat << EOF >/tmp/fix-${id}.conf
[Interface]
PrivateKey = MMVM2wVNQqUyug1cBY=
[Peer]
PublicKey = bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = engage.cloudflareclient.com:2408
EOF
ip -6 addr add fd01:5ca1:ab1e:891f:c4fc:4a2e:e64d:503d/128 dev nwg2
wg setconf nwg2 /tmp/fix-${id}.conf
ip6t POSTROUTING -t nat -o nwg2 -j MASQUERADE
esac
exit 0
Сам тест:
wg show nwg2
ifconfig nwg2
ip -6 rule add from all lookup 123 priority 1123
ip -6 route add table 123 2a03:1b20:1:f410::ff1 dev nwg2
ip -6 rule
ip -6 route show table 123
traceroute6 2a03:1b20:1:f410::ff1
Результат:
~ # uname -a
Linux ZyAvenger 4.9-ndm-5 #0 SMP Tue Jun 21 16:39:31 2022 mips GNU/Linux
~ # wg show nwg2
interface: nwg2
public key: JL+TtFAHd2heTNrACYj8tlkn9f4rrZi7auvuQRBkajY=
private key: (hidden)
listening port: 49203
peer: bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=
endpoint: [2606:4700:d0::a29f:c001]:2408
allowed ips: 0.0.0.0/0, ::/0
latest handshake: 1 minute, 33 seconds ago
transfer: 15.29 KiB received, 6.19 KiB sent
~ # ifconfig nwg2
nwg2 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:172.16.0.2 P-t-P:172.16.0.2 Mask:255.255.255.255
inet6 addr: fd01:5ca1:ab1e:891f:c4fc:4a2e:e64d:503d/128 Scope:Global
UP POINTOPOINT RUNNING NOARP MTU:1280 Metric:1
RX packets:52643 errors:0 dropped:53 overruns:0 frame:0
TX packets:63283 errors:3 dropped:1 overruns:0 carrier:0
collisions:0 txqueuelen:50
RX bytes:14968865 (14.2 MiB) TX bytes:8037372 (7.6 MiB)
~ # ip -6 rule
0: from all lookup local
233: from all fwmark 0x2333 lookup 233
1123: from all lookup 123
1778: from all fwmark 0xd1001 lookup 1001
32766: from all lookup main
~ # ip -6 route show table 123
2a03:1b20:1:f410::ff1 dev nwg2 metric 1024 pref medium
~ # traceroute6 2a03:1b20:1:f410::ff1
traceroute to 2a03:1b20:1:f410::ff1 (2a03:1b20:1:f410::ff1) from fd01:5ca1:ab1e:891f:c4fc:4a2e:e64d:503d, port 33434, from port 45415, 30 hops max, 60 bytes packets
1 fd01:5ca1:ab1e::1 (fd01:5ca1:ab1e::1) 10.845 ms 10.961 ms 10.997 ms
2 2400:cb00:87:1000::1 (2400:cb00:87:1000::1) 11.906 ms 17.869 ms 20.842 ms
3 mow-b4-link.ip.twelve99.net (2001:2000:3080:539::1) 11.994 ms 11.797 ms 11.299 ms
4 mow-b8-v6.ip.twelve99.net (2001:2034:0:220::1) 11.474 ms 11.974 ms 12.476 ms
5 kbn-bb2-v6.ip.twelve99.net (2001:2034:1:78::1) 40.321 ms 41.409 ms 72.470 ms
^C22% completed...
avn
Добрый день!
Может кому-то пригодится выборочная маршрутизация через Wireguard по ipv6.
На версии 3.7.4 ipv6 адрес на интерфейсе nwg можно было задать командой:
interface Wireguard2 ipv6 address fd01:5ca1:ab1e:891f:c4fc:4a2e:e64d:503d
#!/bin/sh [ "$1" == "hook" ] || exit 0 [ "$change" == "link" ] || exit 0 [ "$id" == "Wireguard2" ] || exit 0 ip6t() { if ! ip6tables -C "$@" &>/dev/null; then ip6tables -A "$@" fi } case ${id}-${change}-${connected}-${link}-${up} in ${id}-link-yes-up-up) cat << EOF >/tmp/fix-${id}.conf [Interface] PrivateKey = MMVM2wVNQqUyug1cBY= [Peer] PublicKey = bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo= AllowedIPs = 0.0.0.0/0, ::/0 Endpoint = engage.cloudflareclient.com:2408 EOF ip -6 addr add fd01:5ca1:ab1e:891f:c4fc:4a2e:e64d:503d/128 dev nwg2 wg setconf nwg2 /tmp/fix-${id}.conf ip6t POSTROUTING -t nat -o nwg2 -j MASQUERADE ;; esac exit 0
Сам тест:
wg show nwg2 ifconfig nwg2 ip -6 rule add from all lookup 123 priority 1123 ip -6 route add table 123 2a03:1b20:1:f410::ff1 dev nwg2 ip -6 rule ip -6 route show table 123 traceroute6 2a03:1b20:1:f410::ff1
Результат:
~ # uname -a Linux ZyAvenger 4.9-ndm-5 #0 SMP Tue Jun 21 16:39:31 2022 mips GNU/Linux ~ # wg show nwg2 interface: nwg2 public key: JL+TtFAHd2heTNrACYj8tlkn9f4rrZi7auvuQRBkajY= private key: (hidden) listening port: 49203 peer: bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo= endpoint: [2606:4700:d0::a29f:c001]:2408 allowed ips: 0.0.0.0/0, ::/0 latest handshake: 1 minute, 33 seconds ago transfer: 15.29 KiB received, 6.19 KiB sent ~ # ifconfig nwg2 nwg2 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:172.16.0.2 P-t-P:172.16.0.2 Mask:255.255.255.255 inet6 addr: fd01:5ca1:ab1e:891f:c4fc:4a2e:e64d:503d/128 Scope:Global UP POINTOPOINT RUNNING NOARP MTU:1280 Metric:1 RX packets:52643 errors:0 dropped:53 overruns:0 frame:0 TX packets:63283 errors:3 dropped:1 overruns:0 carrier:0 collisions:0 txqueuelen:50 RX bytes:14968865 (14.2 MiB) TX bytes:8037372 (7.6 MiB) ~ # ip -6 rule 0: from all lookup local 233: from all fwmark 0x2333 lookup 233 1123: from all lookup 123 1778: from all fwmark 0xd1001 lookup 1001 32766: from all lookup main ~ # ip -6 route show table 123 2a03:1b20:1:f410::ff1 dev nwg2 metric 1024 pref medium ~ # traceroute6 2a03:1b20:1:f410::ff1 traceroute to 2a03:1b20:1:f410::ff1 (2a03:1b20:1:f410::ff1) from fd01:5ca1:ab1e:891f:c4fc:4a2e:e64d:503d, port 33434, from port 45415, 30 hops max, 60 bytes packets 1 fd01:5ca1:ab1e::1 (fd01:5ca1:ab1e::1) 10.845 ms 10.961 ms 10.997 ms 2 2400:cb00:87:1000::1 (2400:cb00:87:1000::1) 11.906 ms 17.869 ms 20.842 ms 3 mow-b4-link.ip.twelve99.net (2001:2000:3080:539::1) 11.994 ms 11.797 ms 11.299 ms 4 mow-b8-v6.ip.twelve99.net (2001:2034:0:220::1) 11.474 ms 11.974 ms 12.476 ms 5 kbn-bb2-v6.ip.twelve99.net (2001:2034:1:78::1) 40.321 ms 41.409 ms 72.470 ms ^C22% completed...
40 answers to this question
