brus13 Posted July 1, 2022 Share Posted July 1, 2022 Всем доброго дня. Организован туннель между удаленными сетями по IPsec: инициатор - keenetic (склад), принимающая сторона - kerio (офис) Проблема - каждые 45-60 минут рвется соединение. Логи керио: [01/Jul/2022 09:22:03] VPN tunnel 'remote_srv' disconnected from 37.215.120.102, connection time 01:00:40 [01/Jul/2022 09:22:05] VPN tunnel 'remote_srv' connected to 37.215.120.102 [01/Jul/2022 10:11:05] VPN tunnel 'remote_srv' disconnected from 37.215.120.102, connection time 00:49:00 [01/Jul/2022 10:11:07] VPN tunnel 'remote_srv' connected to 37.215.120.102 Настройки керио: Настройки keenetic Extra 1711 Помогите решить проблему. Quote Link to comment Share on other sites More sharing options...
alekssmak Posted July 21, 2022 Share Posted July 21, 2022 Получил аналогичную проблемы (обрыв IPSec) после обновления 3.7.1 -> 3.8.0 (Giga III) [20/Jul/2022 21:37:35] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:46:44 [20/Jul/2022 21:37:37] VPN tunnel 'RMS-01AD' connected to some_ip [20/Jul/2022 22:21:41] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:44:04 [20/Jul/2022 22:21:43] VPN tunnel 'RMS-01AD' connected to some_ip [20/Jul/2022 23:10:07] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:48:24 [20/Jul/2022 23:10:08] VPN tunnel 'RMS-01AD' connected to some_ip [20/Jul/2022 23:56:53] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:46:45 [20/Jul/2022 23:56:55] VPN tunnel 'RMS-01AD' connected to some_ip [21/Jul/2022 00:42:59] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:46:04 [21/Jul/2022 00:43:01] VPN tunnel 'RMS-01AD' connected to some_ip [21/Jul/2022 01:27:25] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:44:24 [21/Jul/2022 01:27:27] VPN tunnel 'RMS-01AD' connected to some_ip [21/Jul/2022 02:12:51] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:45:24 [21/Jul/2022 02:12:53] VPN tunnel 'RMS-01AD' connected to some_ip [21/Jul/2022 03:03:17] VPN tunnel 'RMS-01AD' disconnected from some_ip, connection time 00:50:24 Был долгое время на удаленке, в июне добрался до модема и обновил (3.8.0), потом 3.8.1 и 3.8.2 На днях обнаружил эти обрывы в логе и по дате сошлось с датой обновления до 3.8.x. Сейчас откатил до бекапа (3.7.1), все нормально, обрывов нет. Затем обновил до 3.7.4 - тоже все ок. До 3.8.x туннель стабильно держался 5 суток (затем провайдер рвет PPPoE сессию). Версия Керио не менялась год точно, провайдеры те-же. Так что где-то что-то в 3.8.x. С ней (3.8.2) также появились множественные записи ошибок в логе при установленных WireGuard подключениях: ndnproxy unable to send request: required key not available. При откате на 3.7.4 - лог чистый. Quote Link to comment Share on other sites More sharing options...
Effgen29 Posted October 23, 2022 Share Posted October 23, 2022 Аналогичная проблема на всех устройствах с прошивкой 3.8.5, господа.. есть новости по теме? Quote Link to comment Share on other sites More sharing options...
Effgen29 Posted October 23, 2022 Share Posted October 23, 2022 Самое гнусное - устройства свежие и приобретены уже с 3.8, т.е. откатиться на 3.7 с включением ipsec vpn я не могу. Что подскажет разработчик? Quote Link to comment Share on other sites More sharing options...
Mamay Posted October 24, 2022 Share Posted October 24, 2022 5 часов назад, Effgen29 сказал: Что подскажет разработчик? Так спросите в тех поддержке. Это неофициальное комьюнити. 1 Quote Link to comment Share on other sites More sharing options...
admin Posted October 24, 2022 Share Posted October 24, 2022 12 hours ago, Effgen29 said: Что подскажет разработчик? Хотелось бы для полноты картины проверить на 3.9 (Preview) есть ли разница с 3.8. Quote Link to comment Share on other sites More sharing options...
Effgen29 Posted October 24, 2022 Share Posted October 24, 2022 34 минуты назад, admin сказал: Хотелось бы для полноты картины проверить на 3.9 (Preview) есть ли разница с 3.8. готов протестировать прям сегодня Quote Link to comment Share on other sites More sharing options...
alekssmak Posted October 24, 2022 Share Posted October 24, 2022 3 часа назад, admin сказал: Хотелось бы для полноты картины проверить на 3.9 (Preview) есть ли разница с 3.8. В другой ветке это-же и для 3.9 подтвердили. Не указано только, для какой версии (beta или preview) Quote Link to comment Share on other sites More sharing options...
Effgen29 Posted October 24, 2022 Share Posted October 24, 2022 2 часа назад, alekssmak сказал: В другой ветке это-же и для 3.9 подтвердили. Не указано только, для какой версии (beta или preview) все верно. на 3.9 тоже не работает. в итоге - откатился на 3.7 и работаю Quote Link to comment Share on other sites More sharing options...
Migel Posted October 24, 2022 Share Posted October 24, 2022 (edited) Giga (KN-1010) на 3.9 Beta 1 такие сообщения часто бывают: IpSec::Configurator: (possibly because of wrong pre-shared key) После чего начинается следующее: E] Oct 25 13:20:59 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:20:59 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:20:59 ndm: IpSec::Vici::Command: "Office": system failed [0xcffd0018], unable to subscribe to events: operation timeout. [C] Oct 25 13:20:59 ndm: IpSec::Configurator: system failed [0xcffd064d]. [I] Oct 25 13:21:00 ndm: IpSec::Configurator: crypto map "Office" shutdown started. [E] Oct 25 13:21:06 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:21:06 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:21:06 ndm: IpSec::Vici::Stats: system failed [0xcffd0328], unable to subscribe to events: operation timeout. [E] Oct 25 13:21:07 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:21:07 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:21:07 ndm: IpSec::Vici::Command: "Office": system failed [0xcffd0018], unable to subscribe to events: operation timeout. [C] Oct 25 13:21:07 ndm: IpSec::Configurator: system failed [0xcffd064d]. [I] Oct 25 13:21:07 ndm: IpSec::Configurator: crypto map "Office" shutdown started. [E] Oct 25 13:21:14 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:21:14 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:21:14 ndm: IpSec::Vici::Command: "Office": system failed [0xcffd0018], unable to subscribe to events: operation timeout. [C] Oct 25 13:21:14 ndm: IpSec::Configurator: system failed [0xcffd064d]. [I] Oct 25 13:21:14 ndm: IpSec::Configurator: crypto map "Office" shutdown started. И лечится только перезагрузкой. Edited October 25, 2022 by Migel Quote Link to comment Share on other sites More sharing options...
okarapetyants Posted October 26, 2022 Share Posted October 26, 2022 Доброго дня друзья! Есть новости по проблеме? лежат два Кинетика для удаленных точек - как раз под тунель с Керио вот почитал вас - теперь парюсь 😂 завтра буду смотреть прошивку с завода - надеюсь повезет 😇 Quote Link to comment Share on other sites More sharing options...
brus13 Posted November 3, 2022 Author Share Posted November 3, 2022 В 26.10.2022 в 23:25, okarapetyants сказал: Доброго дня друзья! Есть новости по проблеме? лежат два Кинетика для удаленных точек - как раз под тунель с Керио вот почитал вас - теперь парюсь 😂 завтра буду смотреть прошивку с завода - надеюсь повезет 😇 Я так и не победил. И даунгрейдинг прошивки делал и с бубнами танцевал). Короче поменял кинетик на tp-link, поднял туннели и проблема ушла. В общем, пока не рекомендую связываться Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted November 3, 2022 Share Posted November 3, 2022 В 24.10.2022 в 15:54, Migel сказал: Giga (KN-1010) на 3.9 Beta 1 такие сообщения часто бывают: IpSec::Configurator: (possibly because of wrong pre-shared key) После чего начинается следующее: E] Oct 25 13:20:59 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:20:59 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:20:59 ndm: IpSec::Vici::Command: "Office": system failed [0xcffd0018], unable to subscribe to events: operation timeout. [C] Oct 25 13:20:59 ndm: IpSec::Configurator: system failed [0xcffd064d]. [I] Oct 25 13:21:00 ndm: IpSec::Configurator: crypto map "Office" shutdown started. [E] Oct 25 13:21:06 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:21:06 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:21:06 ndm: IpSec::Vici::Stats: system failed [0xcffd0328], unable to subscribe to events: operation timeout. [E] Oct 25 13:21:07 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:21:07 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:21:07 ndm: IpSec::Vici::Command: "Office": system failed [0xcffd0018], unable to subscribe to events: operation timeout. [C] Oct 25 13:21:07 ndm: IpSec::Configurator: system failed [0xcffd064d]. [I] Oct 25 13:21:07 ndm: IpSec::Configurator: crypto map "Office" shutdown started. [E] Oct 25 13:21:14 ndm: Io::UnixStreamSocket: unable to connect: timed out after 71 retries. [C] Oct 25 13:21:14 ndm: IpSec::Vici::Socket: system failed [0xcffd049a]. [C] Oct 25 13:21:14 ndm: IpSec::Vici::Command: "Office": system failed [0xcffd0018], unable to subscribe to events: operation timeout. [C] Oct 25 13:21:14 ndm: IpSec::Configurator: system failed [0xcffd064d]. [I] Oct 25 13:21:14 ndm: IpSec::Configurator: crypto map "Office" shutdown started. И лечится только перезагрузкой. А можно self-test в эти моменты? Quote Link to comment Share on other sites More sharing options...
Deadlock Posted November 22, 2022 Share Posted November 22, 2022 В 03.11.2022 в 14:04, brus13 сказал: Я так и не победил. И даунгрейдинг прошивки делал и с бубнами танцевал). Короче поменял кинетик на tp-link, поднял туннели и проблема ушла. В общем, пока не рекомендую связываться Я победил! Kerio c Кинетиком дружат уже 8 часов без реконнекта!!! Quote Link to comment Share on other sites More sharing options...
Migel Posted December 10, 2022 Share Posted December 10, 2022 В 03.11.2022 в 15:56, Le ecureuil сказал: А можно self-test в эти моменты? Self-test ниже. Quote Link to comment Share on other sites More sharing options...
0Net Posted January 11, 2023 Share Posted January 11, 2023 (edited) Ребят, взорвав себе мозги, докопался до проблемы. Что надо сделать: 1. Подключиться к kerio по SSH ssh root@ip_address Пароль от admin 2. Открыть редактором файл winroute.cfg (я пользуюсь nano) nano /var/winroute/winroute.cfg 3. Найти раздел <table name="Firewall"> 4. В этом разделе найти <variable name="IKEVersion">ikev1</variable> 5. Заменить ikev1 на ikev2, сохранить (в nano CTRL+O) и выйти 6. Перезагрузить /etc/boxinit.d/60winroute restart Edited January 11, 2023 by 0Net Quote Link to comment Share on other sites More sharing options...
vitalforce Posted February 2, 2023 Share Posted February 2, 2023 (edited) В 11.01.2023 в 20:27, 0Net сказал: Ребят, взорвав себе мозги, докопался до проблемы. Что надо сделать: 1. Подключиться к kerio по SSH ssh root@ip_address Пароль от admin 2. Открыть редактором файл winroute.cfg (я пользуюсь nano) nano /var/winroute/winroute.cfg 3. Найти раздел <table name="Firewall"> 4. В этом разделе найти <variable name="IKEVersion">ikev1</variable> 5. Заменить ikev1 на ikev2, сохранить (в nano CTRL+O) и выйти 6. Перезагрузить /etc/boxinit.d/60winroute restart Для этого нужно поставить Etware из статьи? И для какой прошивки это работает? 3.7.5? На 3.9.2 работает без исправлений/изменений видимо исправили. А вот Omni KN-1410 дальше 3.7.5 не обновляется. Edited February 2, 2023 by vitalforce Quote Link to comment Share on other sites More sharing options...
