KN-1210 Firewall Problem
stps2
Hi there
I've got the Keenetic 4G with the latest firmware.
I have enabled firewall for Home segment. The default  rule is deny TCP/UDP.
DNS requests (UDP 53) are permitted. However this is not working (timeout on nslookup from clients).
If I disable the Deny UDP rule, DNS requests are working.
What is wrong?
Edited by stps2
  • Need more info 1
9 answers to this question
Also I've figured out that if I create an upper rule like 'Permit / UDP / Source IP: client IP / Source Port: Any / Destination IP: Any / Destination Port: Any", everything works.
So it is a bug that the rule mechanism does not take matter of destination IP address and port + Protocol, only Protocol (in case of UDP)
I've got an old deprecated model ZyXel / Keenetic Lite III with the same rule set, and it does not have this bug.
Can I contact the vendor support to fix this bug?
