noua Posted October 13, 2022 Share Posted October 13, 2022 (edited) Доброго времени суток, при перезагрузке роутера или при сохранении изменения конфигурации, происходит отвал зарегистрированных трубок, dect plus вставлен в пассивный хаб, приходится каждый раз регистрировать трубку снова. Кусок лога: [I] Oct 12 22:14:54 ndm: Core::System::StartupConfig: saving (http/rci). [I] Oct 12 22:14:55 nvox: Line 1000: localhost unregistration successful: response 200 OK. [I] Oct 12 22:14:55 nvox: Line SIPNET (TLS): sipnet.ru unregistration successful: response 200 OK. [I] Oct 12 22:14:55 ndm: Nvox::Sip: line "1000": "localhost" unregistered. [I] Oct 12 22:14:58 ndm: Core::System::StartupConfig: configuration saved. [I] Oct 12 22:14:59 kernel: usb 1-2.3: USB disconnect, device number 9 [I] Oct 12 22:14:59 ndm: Nvox::Manager: Keenetic Plus DECT removed. [I] Oct 12 22:15:00 kernel: usb 1-2.3: new full-speed USB device number 10 using xhci-mtk [I] Oct 12 22:15:00 kernel: usb 1-2.3: New USB device found, idVendor=0586, idProduct=3428 [I] Oct 12 22:15:00 kernel: usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [I] Oct 12 22:15:00 kernel: usb 1-2.3: Product: Keenetic Plus DECT [I] Oct 12 22:15:00 kernel: usb 1-2.3: Manufacturer: ZyXEL [I] Oct 12 22:15:00 kernel: usb 1-2.3: SerialNumber: S155729002021 [I] Oct 12 22:15:00 ndm: Nvox::Manager: Keenetic Plus DECT added. [I] Oct 12 22:15:01 ndm: Nvox::Manager: handset id "1" registered. [I] Oct 12 22:15:01 ndm: Nvox::Manager: found new DECT dongle. [I] Oct 12 22:15:01 ndm: Core::System::StartupConfig: saving (event). [I] Oct 12 22:15:01 ndm: Nvox::Manager: handset id "1" removed. [I] Oct 12 22:15:01 cron[10195]: (root) CMD (/opt/bin/run-parts /opt/etc/cron.5mins^I) [I] Oct 12 22:15:01 cron[10196]: (root) CMD (/opt/bin/run-parts /opt/etc/cron.1min^I) [I] Oct 12 22:15:02 nvox: Line 1000: localhost registration successful: response 200 OK. [I] Oct 12 22:15:02 ndm: Nvox::Sip: line "1000": "localhost" registered. [I] Oct 12 22:15:05 ndm: Core::System::StartupConfig: configuration saved. [I] Oct 12 22:16:01 cron[10536]: (root) CMD (/opt/bin/run-parts /opt/etc/cron.1min^I) [I] Oct 12 22:17:01 cron[10971]: (root) CMD (/opt/bin/run-parts /opt/etc/cron.1min^I) [I] Oct 12 22:17:21 ndm: Nvox::Manager: enabled SIP line "1". [I] Oct 12 22:17:21 ndm: Core::System::StartupConfig: saving (http/rci). [I] Oct 12 22:17:23 nvox: Line 1000: localhost unregistration successful: response 200 OK. [I] Oct 12 22:17:25 ndm: Core::System::StartupConfig: configuration saved. [I] Oct 12 22:17:25 kernel: usb 1-2.3: USB disconnect, device number 10 [I] Oct 12 22:17:25 ndm: Nvox::Manager: Keenetic Plus DECT removed. [I] Oct 12 22:17:26 kernel: usb 1-2.3: new full-speed USB device number 11 using xhci-mtk [I] Oct 12 22:17:26 kernel: usb 1-2.3: New USB device found, idVendor=0586, idProduct=3428 [I] Oct 12 22:17:26 kernel: usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [I] Oct 12 22:17:26 kernel: usb 1-2.3: Product: Keenetic Plus DECT [I] Oct 12 22:17:26 kernel: usb 1-2.3: Manufacturer: ZyXEL [I] Oct 12 22:17:26 kernel: usb 1-2.3: SerialNumber: S155729002021 [I] Oct 12 22:17:26 ndm: Nvox::Manager: Keenetic Plus DECT added. [I] Oct 12 22:17:27 ndm: Nvox::Manager: found new DECT dongle. [I] Oct 12 22:17:27 ndm: Core::System::StartupConfig: saving (event). Видно что каждый раз устройству узб присваивается новый номер, думаю связано именно с этим, есть ли вариант запоминания устройства на определённом номере? ЧЯДН? Всем спасибо Ultra (KN-1810) RU 3.9 Beta 1 Edited October 13, 2022 by noua PS Quote Link to comment Share on other sites More sharing options...
ANDYBOND Posted October 13, 2022 Share Posted October 13, 2022 1 час назад, noua сказал: ЧЯДН? 1 час назад, noua сказал: 3.9 Beta 1 На релизной версии (3.8) проблема тоже есть? Quote Link to comment Share on other sites More sharing options...
noua Posted October 13, 2022 Author Share Posted October 13, 2022 попробую вечером, отпишусь Quote Link to comment Share on other sites More sharing options...
noua Posted October 14, 2022 Author Share Posted October 14, 2022 16 часов назад, ANDYBOND сказал: На релизной версии (3.8) проблема тоже есть? Да всё таже проблема, обратил внимание что это происходит даже если просто выключить какую-то активную линию, трубка сразу теряется и в логах вновь идёт нумерация устройств: Nvox::Manager: disabled SIP line "1". Окт 14 07:33:07 ndm Core::System::StartupConfig: saving (http/rci). Окт 14 07:33:09 nvox Line 1000: localhost unregistration successful: response 200 OK. Окт 14 07:33:09 nvox Line SIPNET (TLS): sipnet.ru unregistration successful: response 200 OK. Окт 14 07:33:09 ndm Nvox::Sip: line "1000": "localhost" unregistered. Окт 14 07:33:11 ndm Core::System::StartupConfig: configuration saved. Окт 14 07:33:12 kernel usb 1-2.3: USB disconnect, device number 6 Окт 14 07:33:12 ndm Nvox::Manager: Keenetic Plus DECT removed. Окт 14 07:33:14 kernel usb 1-2.3: new full-speed USB device number 7 using xhci-mtk Окт 14 07:33:14 kernel usb 1-2.3: New USB device found, idVendor=0586, idProduct=3428 Окт 14 07:33:14 kernel usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Окт 14 07:33:14 kernel usb 1-2.3: Product: Keenetic Plus DECT Окт 14 07:33:14 kernel usb 1-2.3: Manufacturer: ZyXEL Окт 14 07:33:14 kernel usb 1-2.3: SerialNumber: S155729002021 Окт 14 07:33:14 ndm Nvox::Manager: Keenetic Plus DECT added. Окт 14 07:33:14 ndm Nvox::Manager: handset id "1" registered. Окт 14 07:33:15 ndm Nvox::Manager: found new DECT dongle. Окт 14 07:33:15 ndm Core::System::StartupConfig: saving (event). 1 Quote Link to comment Share on other sites More sharing options...
ANDYBOND Posted October 14, 2022 Share Posted October 14, 2022 29 минут назад, noua сказал: Да всё таже проблема Тогда хорошо, что написали здесь, но по релизной прошивке обязательно напишите в техподдержку, чтобы исправление внесли и в релиз, и в будущие версии. 1 Quote Link to comment Share on other sites More sharing options...
Monstr86 Posted October 14, 2022 Share Posted October 14, 2022 41 минуту назад, noua сказал: Да всё таже проблема, обратил внимание что это происходит даже если просто выключить какую-то активную линию, трубка сразу теряется и в логах вновь идёт нумерация устройств: Только что выключил линию, 1 трубка подключилась сама, 2 остальные нашлись после нажатия поиск трубок. Попробуйте исключить хаб. Версия на моем роутере 3.8.5 Quote Link to comment Share on other sites More sharing options...
Mamay Posted October 14, 2022 Share Posted October 14, 2022 4 часа назад, noua сказал: Да всё таже проблема Не вижу леса рук за вашу тему из чего делаю закономерный вывод. Вы что-то либо локально перемудрили с настройками/железом, либо нашли багу ПО/дефект железа! 1 Quote Link to comment Share on other sites More sharing options...
Mamay Posted October 14, 2022 Share Posted October 14, 2022 В 13.10.2022 в 14:28, noua сказал: пассивный хаб Блин проглядел. Практически убеждён корень зла. 1 Quote Link to comment Share on other sites More sharing options...
noua Posted October 14, 2022 Author Share Posted October 14, 2022 5 часов назад, Mamay сказал: Блин проглядел. Практически убеждён корень зла. Пробовал и с активным, всё тоже перечисление, помоему это баг, просто раньше не так активно пользовался, а ткт астериск все дела.. не долго радовался, перегруз и отвал .. и регистрация по новой, можно ли как то запомнить устройство вот в чем вопрос... 2 Quote Link to comment Share on other sites More sharing options...
noua Posted October 14, 2022 Author Share Posted October 14, 2022 Исключив хаб уверен всё будет гуд, без хаба не вариант 2 Quote Link to comment Share on other sites More sharing options...
Mamay Posted October 15, 2022 Share Posted October 15, 2022 8 часов назад, noua сказал: Исключив хаб уверен всё будет гуд, без хаба не вариант То есть, вы в здравом уме и при светлой памяти, знаете что весь косяк из-за usb hub, но зачем-то спрашиваете чяднт? Однако на этом мысль останавливается. 1 Quote Link to comment Share on other sites More sharing options...
Mamay Posted October 15, 2022 Share Posted October 15, 2022 9 часов назад, noua сказал: помоему это баг А по моему это незнание материальной части. 1 Quote Link to comment Share on other sites More sharing options...
noua Posted October 17, 2022 Author Share Posted October 17, 2022 В 15.10.2022 в 06:17, Mamay сказал: То есть, вы в здравом уме и при светлой памяти, знаете что весь косяк из-за usb hub, но зачем-то спрашиваете чяднт? Однако на этом мысль останавливается. Нигде не написано ограничений на использование USB hub-ов с Keenetic dect plus, мало того хотелось бы к примеру список совместимых хабов, тоже ни где не нашёл, поэтому я и обратился сюда, помимо свиста декта подключен принтер и dvb, второй порт занят HDD. 1 1 Quote Link to comment Share on other sites More sharing options...
Mamay Posted October 17, 2022 Share Posted October 17, 2022 5 минут назад, noua сказал: Нигде не написано ограничений на использование USB hub-ов с Keenetic dect plus, мало того хотелось бы к примеру список совместимых хабов, тоже ни где не нашёл, поэтому я и обратился сюда Такого списка не существует в природе. Только метод научного "тыка" вам в руки или возможный опыт волонтёров. 9 минут назад, noua сказал: помимо свиста декта подключен принтер и dvb, второй порт занят HDD. ИМХО вы слишком многого хотите от роутера на пассивном хабе и совершенно необоснованно пытаетесь найти причину в keenetic! 1 1 1 Quote Link to comment Share on other sites More sharing options...
