SMB Disk Reappears Despite Removal
8 answers to this question
Posted (edited)
And even after disconnecting the disk from the interface, it came back again.
https://prnt.sc/qh0pUPhNW7A8
https://prnt.sc/3HVOZz_XzqAA
        "Media0": {
            "usb": {
                "port": 1,
                "version": "3.00"
            "state": "ACTIVE",
            "manufacturer": "Intenso",
            "product": "External USB 3.0",
            "serial": "20201108102D9",
            "size": "5000981078016",
            "partition": [
                    "uuid": "f3cff6b6-fe95-d701-0085-f6b6fe95d701",
                    "label": "STORAGE",
                    "fstype": "ext4",
                    "state": "UNMOUNTED",
                    "total": "263122944",
                    "free": "262684672"
    "prompt": "(config)"
Edited by KYTECHNGAMING
Posted
2 minutes ago, eralde said:
Uncheck the "Auto-mount new USB drives" checkbox to disable this behavior.
But I think there is something wrong here.
I made a disconnect myself. I'm going to remove the disk. Why is disk coming back there? It also comes with permissions. I can access SMB even though it shows Disconnect.
Posted
2 минуты назад, KYTECHNGAMING сказал:
@vst, would you please check this out?
Posted (edited)
Sorry, I may have misremembered the action.
But I don't want to share that folder or disk anymore in smb.
Why is it coming back? This is the main case.
addition:
sorry again.
I also showed unmounted disk in the cli output. while the disk is in a disconneted state.
It was something I noticed late at night. I had trouble remembering because of lack of sleep. 😟
Posted (edited)
11 minutes ago, sergeyk said:
Because the "Auto-mount new USB drives" function enabled.
I understand.
But this is not a new USB. I maybe want to remove that directory from SMB. I'll just source another directory. It comes back automatically after deleting
if i insert a new disk i will understand. it comes back when completely removing the current disk.
So we will delete the source path that cannot be found after unmounting?
Posted
В 24.12.2022 в 16:14, KYTECHNGAMING сказал:
Probably this is a wrong name of a feature.
The function each time creates shares for all partitions of a (re)attached disk, not only for a new one.
  • Thanks 2
