1) When the logo is clicked to return to the homepage (/dashboard) from a different page in the mobile view, it redirects to the /dasboard page, but the menu is automatically open. It should be closed. It works properly in the old interface, the new interface has a problem in this way.
2) The "command line" option that appears in the desktop version does not appear in the mobile view.
3) When the "Traffic monitor" page is opened for the first time, the time interval in the graph is nested. It will be fixed if the time interval is changed. This issue is triggered only when the "Traffic monitor" page is opened for the first time.
Spoiler
4) When I want to list the interfaces in the "default route" on the "Routing" page, I get a strange error. The "save" and "cancel" buttons are located above the interface names.
Spoiler
(The z-index value for the row with the buttons is set to 70, so they are always at the top. Changing the value to 1 fixes problem 4 and 5)
5) In the same way, when I want to list the interfaces in a setup with a "default route", the scroll does not work in the interfaces section and there is a huge gap. If you reduce the height of the page and force the menu to open upwards, the "interfaces" are displayed properly.
Spoiler
6) The warning text that appears in Turkish in the "my network and wifi" section on the home page is in English. It should be in Turkish. There is also a difference between the English text that appears when Turkish is selected and the English text that appears when English is selected, even though they mean the same thing.
Spoiler
7) Although Turkish language is selected, the segment names on the "Wireless Access Control" page are in English.
Spoiler
8) The Turkish equivalent of "Import settings from previous router" is a bit long, so it does not fit in the allocated space and overflows.
PriSonerS61
Hello, I would like to report a few bugs I noticed. @eralde @Anna Zhelankina
9 answers to this question
